[U-Boot] [PATCH] ARM: OMAP5: DRA7xx: Enable I2C5 operation
Unlike regular OMAP5, on the DRA7xx SoCs the I2C5 module belongs to the IPU clock domain. This patch takes care of the appropriate clock preparation and makes I2C5 operational - it fixes the 'data abort' exception that otherwise happened upon accessing the I2C5 controller.
Signed-off-by: Lubomir Popov l-popov@ti.com --- arch/arm/cpu/armv7/omap5/hw_data.c | 9 +++++++++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 4 ++++ arch/arm/include/asm/omap_common.h | 4 ++++ 3 files changed, 17 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 0257383..5f7b392 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -515,6 +515,10 @@ void enable_basic_clocks(void) void enable_basic_uboot_clocks(void) { u32 const clk_domains_essential[] = { +#ifdef CONFIG_DRA7XX + /* Needed for I2C5 operation */ + (*prcm)->cm_ipu_clkstctrl, +#endif 0 };
@@ -528,7 +532,12 @@ void enable_basic_uboot_clocks(void) (*prcm)->cm_l4per_i2c2_clkctrl, (*prcm)->cm_l4per_i2c3_clkctrl, (*prcm)->cm_l4per_i2c4_clkctrl, +#ifdef CONFIG_DRA7XX + /* I2C5 is in the IPU clock domain on the DRA7xx */ + (*prcm)->cm_ipu_i2c5_clkctrl, +#else (*prcm)->cm_l4per_i2c5_clkctrl, +#endif (*prcm)->cm_l3init_hsusbhost_clkctrl, (*prcm)->cm_l3init_fsusb_clkctrl, 0 diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index ff08ef4..1337198 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -808,6 +808,10 @@ struct prcm_regs const dra7xx_prcm = { /* cm1.dsp */ .cm_dsp_clkstctrl = 0x4a005400, .cm_dsp_dsp_clkctrl = 0x4a005420, + + /* cm1.ipu */ + .cm_ipu_clkstctrl = 0x4a005540, + .cm_ipu_i2c5_clkctrl = 0x4a005578,
/* prm irqstatus regs */ .prm_irqstatus_mpu_2 = 0x4ae06014, diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 1838234..962c8a5 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -80,6 +80,10 @@ struct prcm_regs { u32 cm_dsp_clkstctrl; u32 cm_dsp_dsp_clkctrl;
+ /* cm1.ipu */ + u32 cm_ipu_clkstctrl; + u32 cm_ipu_i2c5_clkctrl; + /* cm1.abe */ u32 cm1_abe_clkstctrl; u32 cm1_abe_l4abe_clkctrl;
Lubomir Popov
