[U-Boot] [PATCH v2] rockchip: rk3399: Initialize CPU B clock.
This patch sets the PLL of CPU cluster B (BPLL) to 600 MHz. This decreases the boot time of Linux 4.19 by about 8%.
The 600 MHz are inspired by the 600 MHz used for LPLL initialization (came in with commit 9f636a249c1).
Tested on RK3399-Q7 on Haikou base board.
Changes since v1:
* Set clk_core_b parent to BPLL instead of LPLL. Kudos to Mark Kettenis mark.kettenis@xs4all.nl for spotting this.
Signed-off-by: Christoph Muellner christoph.muellner@theobroma-systems.com --- arch/arm/include/asm/arch-rockchip/cru_rk3399.h | 22 +++++-- drivers/clk/rockchip/clk_rk3399.c | 79 ++++++++++++++++++++++--- 2 files changed, 88 insertions(+), 13 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3399.h b/arch/arm/include/asm/arch-rockchip/cru_rk3399.h index b18de9f7c2e..15eeb9c4407 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3399.h @@ -69,16 +69,21 @@ check_member(rk3399_cru, sdio1_con[1], 0x594); #define MHz 1000000 #define KHz 1000 #define OSC_HZ (24*MHz) -#define APLL_HZ (600*MHz) +#define LPLL_HZ (600*MHz) +#define BPLL_HZ (600*MHz) #define GPLL_HZ (594*MHz) #define CPLL_HZ (384*MHz) #define PPLL_HZ (676*MHz)
#define PMU_PCLK_HZ (48*MHz)
-#define ACLKM_CORE_HZ (300*MHz) -#define ATCLK_CORE_HZ (300*MHz) -#define PCLK_DBG_HZ (100*MHz) +#define ACLKM_CORE_L_HZ (300*MHz) +#define ATCLK_CORE_L_HZ (300*MHz) +#define PCLK_DBG_L_HZ (100*MHz) + +#define ACLKM_CORE_B_HZ (300*MHz) +#define ATCLK_CORE_B_HZ (300*MHz) +#define PCLK_DBG_B_HZ (100*MHz)
#define PERIHP_ACLK_HZ (148500*KHz) #define PERIHP_HCLK_HZ (148500*KHz) @@ -98,4 +103,13 @@ enum apll_l_frequencies { APLL_L_600_MHZ, };
+enum apll_b_frequencies { + APLL_B_600_MHZ, +}; + +void rk3399_configure_cpu_l(struct rk3399_cru *cru, + enum apll_l_frequencies apll_l_freq); +void rk3399_configure_cpu_b(struct rk3399_cru *cru, + enum apll_b_frequencies apll_b_freq); + #endif /* __ASM_ARCH_CRU_RK3399_H_ */ diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 26faf88116b..198914b0676 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -61,6 +61,11 @@ static const struct pll_div *apll_l_cfgs[] = { [APLL_L_600_MHZ] = &apll_l_600_cfg, };
+static const struct pll_div apll_b_600_cfg = PLL_DIVISORS(600*MHz, 1, 2, 1); +static const struct pll_div *apll_b_cfgs[] = { + [APLL_B_600_MHZ] = &apll_b_600_cfg, +}; + enum { /* PLL_CON0 */ PLL_FBDIV_MASK = 0xfff, @@ -128,6 +133,24 @@ enum { ATCLK_CORE_L_DIV_SHIFT = 0, ATCLK_CORE_L_DIV_MASK = 0x1f << ATCLK_CORE_L_DIV_SHIFT,
+ /* CLKSEL_CON2 */ + ACLKM_CORE_B_DIV_CON_SHIFT = 8, + ACLKM_CORE_B_DIV_CON_MASK = 0x1f << ACLKM_CORE_B_DIV_CON_SHIFT, + CLK_CORE_B_PLL_SEL_SHIFT = 6, + CLK_CORE_B_PLL_SEL_MASK = 3 << CLK_CORE_B_PLL_SEL_SHIFT, + CLK_CORE_B_PLL_SEL_ALPLL = 0x0, + CLK_CORE_B_PLL_SEL_ABPLL = 0x1, + CLK_CORE_B_PLL_SEL_DPLL = 0x10, + CLK_CORE_B_PLL_SEL_GPLL = 0x11, + CLK_CORE_B_DIV_MASK = 0x1f, + CLK_CORE_B_DIV_SHIFT = 0, + + /* CLKSEL_CON3 */ + PCLK_DBG_B_DIV_SHIFT = 0x8, + PCLK_DBG_B_DIV_MASK = 0x1f << PCLK_DBG_B_DIV_SHIFT, + ATCLK_CORE_B_DIV_SHIFT = 0, + ATCLK_CORE_B_DIV_MASK = 0x1f << ATCLK_CORE_B_DIV_SHIFT, + /* CLKSEL_CON14 */ PCLK_PERIHP_DIV_CON_SHIFT = 12, PCLK_PERIHP_DIV_CON_MASK = 0x7 << PCLK_PERIHP_DIV_CON_SHIFT, @@ -395,25 +418,26 @@ static int pll_para_config(u32 freq_hz, struct pll_div *div) return 0; }
-void rk3399_configure_cpu(struct rk3399_cru *cru, - enum apll_l_frequencies apll_l_freq) +void rk3399_configure_cpu_l(struct rk3399_cru *cru, + enum apll_l_frequencies apll_l_freq) { u32 aclkm_div; u32 pclk_dbg_div; u32 atclk_div;
+ /* Setup cluster L */ rkclk_set_pll(&cru->apll_l_con[0], apll_l_cfgs[apll_l_freq]);
- aclkm_div = APLL_HZ / ACLKM_CORE_HZ - 1; - assert((aclkm_div + 1) * ACLKM_CORE_HZ == APLL_HZ && + aclkm_div = LPLL_HZ / ACLKM_CORE_L_HZ - 1; + assert((aclkm_div + 1) * ACLKM_CORE_L_HZ == LPLL_HZ && aclkm_div < 0x1f);
- pclk_dbg_div = APLL_HZ / PCLK_DBG_HZ - 1; - assert((pclk_dbg_div + 1) * PCLK_DBG_HZ == APLL_HZ && + pclk_dbg_div = LPLL_HZ / PCLK_DBG_L_HZ - 1; + assert((pclk_dbg_div + 1) * PCLK_DBG_L_HZ == LPLL_HZ && pclk_dbg_div < 0x1f);
- atclk_div = APLL_HZ / ATCLK_CORE_HZ - 1; - assert((atclk_div + 1) * ATCLK_CORE_HZ == APLL_HZ && + atclk_div = LPLL_HZ / ATCLK_CORE_L_HZ - 1; + assert((atclk_div + 1) * ATCLK_CORE_L_HZ == LPLL_HZ && atclk_div < 0x1f);
rk_clrsetreg(&cru->clksel_con[0], @@ -428,6 +452,42 @@ void rk3399_configure_cpu(struct rk3399_cru *cru, pclk_dbg_div << PCLK_DBG_L_DIV_SHIFT | atclk_div << ATCLK_CORE_L_DIV_SHIFT); } + +void rk3399_configure_cpu_b(struct rk3399_cru *cru, + enum apll_b_frequencies apll_b_freq) +{ + u32 aclkm_div; + u32 pclk_dbg_div; + u32 atclk_div; + + /* Setup cluster B */ + rkclk_set_pll(&cru->apll_b_con[0], apll_b_cfgs[apll_b_freq]); + + aclkm_div = BPLL_HZ / ACLKM_CORE_B_HZ - 1; + assert((aclkm_div + 1) * ACLKM_CORE_B_HZ == BPLL_HZ && + aclkm_div < 0x1f); + + pclk_dbg_div = BPLL_HZ / PCLK_DBG_B_HZ - 1; + assert((pclk_dbg_div + 1) * PCLK_DBG_B_HZ == BPLL_HZ && + pclk_dbg_div < 0x1f); + + atclk_div = BPLL_HZ / ATCLK_CORE_B_HZ - 1; + assert((atclk_div + 1) * ATCLK_CORE_B_HZ == BPLL_HZ && + atclk_div < 0x1f); + + rk_clrsetreg(&cru->clksel_con[2], + ACLKM_CORE_B_DIV_CON_MASK | CLK_CORE_B_PLL_SEL_MASK | + CLK_CORE_B_DIV_MASK, + aclkm_div << ACLKM_CORE_B_DIV_CON_SHIFT | + CLK_CORE_B_PLL_SEL_ABPLL << CLK_CORE_B_PLL_SEL_SHIFT | + 0 << CLK_CORE_B_DIV_SHIFT); + + rk_clrsetreg(&cru->clksel_con[3], + PCLK_DBG_B_DIV_MASK | ATCLK_CORE_B_DIV_MASK, + pclk_dbg_div << PCLK_DBG_B_DIV_SHIFT | + atclk_div << ATCLK_CORE_B_DIV_SHIFT); +} + #define I2C_CLK_REG_MASK(bus) \ (I2C_DIV_CON_MASK << \ CLK_I2C ##bus## _DIV_CON_SHIFT | \ @@ -1026,7 +1086,8 @@ static void rkclk_init(struct rk3399_cru *cru) u32 hclk_div; u32 pclk_div;
- rk3399_configure_cpu(cru, APLL_L_600_MHZ); + rk3399_configure_cpu_l(cru, APLL_L_600_MHZ); + rk3399_configure_cpu_b(cru, APLL_B_600_MHZ); /* * some cru registers changed by bootrom, we'd better reset them to * reset/default values described in TRM to avoid confusion in kernel.
On 30.11.2018, at 20:32, Christoph Muellner christoph.muellner@theobroma-systems.com wrote:
Changes since v1:
- Set clk_core_b parent to BPLL instead of LPLL.
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Christoph,
Changes since v1:
Please use patman in the future (or format this as a note), so it can automatically get supressed when applying. For this specific instance, I will hand-edit when applying…
Thanks, Philipp.
+ Elaine for this patch review.
Changes since v1:
- Set clk_core_b parent to BPLL instead of LPLL. Kudos to Mark Kettenis mark.kettenis@xs4all.nl for spotting this.
- APLL_B_600_MHZ,
- [APLL_B_600_MHZ] = &apll_b_600_cfg,
- /* CLKSEL_CON2 */
- ACLKM_CORE_B_DIV_CON_SHIFT = 8,
- ACLKM_CORE_B_DIV_CON_MASK = 0x1f << ACLKM_CORE_B_DIV_CON_SHIFT,
- CLK_CORE_B_PLL_SEL_SHIFT = 6,
- CLK_CORE_B_PLL_SEL_MASK = 3 << CLK_CORE_B_PLL_SEL_SHIFT,
- CLK_CORE_B_PLL_SEL_ALPLL = 0x0,
- CLK_CORE_B_PLL_SEL_ABPLL = 0x1,
- CLK_CORE_B_PLL_SEL_DPLL = 0x10,
- CLK_CORE_B_PLL_SEL_GPLL = 0x11,
- CLK_CORE_B_DIV_MASK = 0x1f,
- CLK_CORE_B_DIV_SHIFT = 0,
- /* CLKSEL_CON3 */
- PCLK_DBG_B_DIV_SHIFT = 0x8,
- PCLK_DBG_B_DIV_MASK = 0x1f << PCLK_DBG_B_DIV_SHIFT,
- ATCLK_CORE_B_DIV_SHIFT = 0,
- ATCLK_CORE_B_DIV_MASK = 0x1f << ATCLK_CORE_B_DIV_SHIFT,
- /* CLKSEL_CON14 */ PCLK_PERIHP_DIV_CON_SHIFT = 12, PCLK_PERIHP_DIV_CON_MASK = 0x7 << PCLK_PERIHP_DIV_CON_SHIFT,
- /* Setup cluster L */ rkclk_set_pll(&cru->apll_l_con[0], apll_l_cfgs[apll_l_freq]);
- aclkm_div = LPLL_HZ / ACLKM_CORE_L_HZ - 1;
- assert((aclkm_div + 1) * ACLKM_CORE_L_HZ == LPLL_HZ && aclkm_div < 0x1f);
- pclk_dbg_div = LPLL_HZ / PCLK_DBG_L_HZ - 1;
- assert((pclk_dbg_div + 1) * PCLK_DBG_L_HZ == LPLL_HZ && pclk_dbg_div < 0x1f);
- u32 aclkm_div;
- u32 pclk_dbg_div;
- u32 atclk_div;
- /* Setup cluster B */
- rkclk_set_pll(&cru->apll_b_con[0], apll_b_cfgs[apll_b_freq]);
- aclkm_div = BPLL_HZ / ACLKM_CORE_B_HZ - 1;
- assert((aclkm_div + 1) * ACLKM_CORE_B_HZ == BPLL_HZ &&
aclkm_div < 0x1f);
- pclk_dbg_div = BPLL_HZ / PCLK_DBG_B_HZ - 1;
- assert((pclk_dbg_div + 1) * PCLK_DBG_B_HZ == BPLL_HZ &&
- atclk_div = BPLL_HZ / ATCLK_CORE_B_HZ - 1;
- assert((atclk_div + 1) * ATCLK_CORE_B_HZ == BPLL_HZ &&
atclk_div < 0x1f);
- rk_clrsetreg(&cru->clksel_con[2],
- rk_clrsetreg(&cru->clksel_con[3],
- rk3399_configure_cpu_l(cru, APLL_L_600_MHZ);
- rk3399_configure_cpu_b(cru, APLL_B_600_MHZ); /*
- some cru registers changed by bootrom, we'd better reset them to
- reset/default values described in TRM to avoid confusion in kernel.
Christoph Muellner
Kever Yang
Philipp Tomsich
