[U-Boot] [PULL] Please pull u-boot-nios/master
The following changes since commit 4832e17787acb29734d895751bc7a594908aecc6:
Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze (2015-12-18 07:28:24 -0500)
git://git.denx.de/u-boot-nios.git master
for you to fetch changes up to 1c0e84ca829a09948a61107744402296566aa076:
altera_qspi: initialize instr.mtd in flash_erase (2015-12-19 09:51:19 +0800)
---------------------------------------------------------------- Marek Vasut (5): nios2: Calculate the env position from monitor size nios2: Up the monitor size to 512kiB nios2: Preconfigure $loadaddr variable nios2: Enable support for fitImage nios2: Soup up the shell experience
Thomas Chou (3): nios2: display altera sysid at startup serial-howto: remove altera_jtag_uart and altera_uart from the list altera_qspi: initialize instr.mtd in flash_erase
arch/nios2/cpu/cpu.c | 8 ++++++++ configs/10m50_defconfig | 1 + configs/3c120_defconfig | 1 + doc/driver-model/serial-howto.txt | 2 -- drivers/mtd/altera_qspi.c | 1 + include/configs/10m50_devboard.h | 33 ++++++++++++++++++--------------- include/configs/3c120_devboard.h | 33 ++++++++++++++++++--------------- 7 files changed, 47 insertions(+), 32 deletions(-)
Thomas Chou
