[U-Boot] [PATCH 1/2] sandbox: Fix warnings due to 64-bit printf() strings
Now that we have inttypes.h, use it in a few more places to avoid compiler warnings on sandbox when building on 64-bit machines.
common/cmd_mem.c | 6 ++++-- common/fdt_support.c | 15 +++++++-------- disk/part_efi.c | 21 +++++++++++---------- 3 files changed, 22 insertions(+), 20 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 0d50dcf..bcb3ee3 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -19,6 +19,7 @@ #include <dataflash.h> #endif #include <hash.h> +#include <inttypes.h> #include <watchdog.h> #include <asm/io.h> #include <linux/compiler.h> @@ -338,7 +339,8 @@ static int do_mem_cmp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (word1 != word2) { ulong offset = buf1 - base; #ifdef CONFIG_SYS_SUPPORT_64BIT_DATA - printf("%s at 0x%p (%#0*llx) != %s at 0x%p (%#0*llx)\n", + printf("%s at 0x%p (%#0*"PRIx64") != %s at 0x%p (%#0*" + PRIx64 ")\n", type, (void *)(addr1 + offset), size, word1, type, (void *)(addr2 + offset), size, word2); #else @@ -1146,7 +1148,7 @@ mod_mem(cmd_tbl_t *cmdtp, int incrflag, int flag, int argc, char * const argv[]) printf(" %08x", *((u32 *)ptr)); #ifdef CONFIG_SYS_SUPPORT_64BIT_DATA else if (size == 8) - printf(" %016llx", *((u64 *)ptr)); + printf(" %016" PRIx64, *((u64 *)ptr)); #endif else if (size == 2) printf(" %04x", *((u16 *)ptr)); diff --git a/common/fdt_support.c b/common/fdt_support.c index 3f64156..9fe7383 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <inttypes.h> #include <stdio_dev.h> #include <linux/ctype.h> #include <linux/types.h> @@ -930,8 +931,6 @@ void fdt_del_node_and_alias(void *blob, const char *alias) fdt_delprop(blob, off, alias); }
-#define PRu64 "%llx" - /* Max address size we deal with */ #define OF_MAX_ADDR_CELLS 4 #define OF_BAD_ADDR ((u64)-1) @@ -994,8 +993,8 @@ static u64 of_bus_default_map(fdt32_t *addr, const fdt32_t *range, s = of_read_number(range + na + pna, ns); da = of_read_number(addr, na);
- debug("OF: default map, cp="PRu64", s="PRu64", da="PRu64"\n", - cp, s, da); + debug("OF: default map, cp=%" PRIu64 ", s=%" PRIu64 + ", da=%" PRIu64 "\n", cp, s, da);
if (da < cp || da >= (cp + s)) return OF_BAD_ADDR; @@ -1073,7 +1072,7 @@ static int of_translate_one(void * blob, int parent, struct of_bus *bus,
finish: of_dump_addr("OF: parent translation for:", addr, pna); - debug("OF: with offset: "PRu64"\n", offset); + debug("OF: with offset: %" PRIu64 "\n", offset);
/* Translate it into parent bus space */ return pbus->translate(addr, offset, pna); @@ -1401,9 +1400,9 @@ int fdt_verify_alias_address(void *fdt, int anode, const char *alias, u64 addr)
dt_addr = fdt_translate_address(fdt, node, reg); if (addr != dt_addr) { - printf("Warning: U-Boot configured device %s at address %llx,\n" - " but the device tree has it address %llx.\n", - alias, addr, dt_addr); + printf("Warning: U-Boot configured device %s at address %" + PRIx64 ",\n but the device tree has it address %" + PRIx64 ".\n", alias, addr, dt_addr); return 0; }
diff --git a/disk/part_efi.c b/disk/part_efi.c index 612f092..efed58f 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -14,6 +14,7 @@ #include <common.h> #include <command.h> #include <ide.h> +#include <inttypes.h> #include <malloc.h> #include <part_efi.h> #include <linux/ctype.h> @@ -553,28 +554,28 @@ static int is_gpt_valid(block_dev_desc_t *dev_desc, u64 lba,
/* Check that the my_lba entry points to the LBA that contains the GPT */ if (le64_to_cpu(pgpt_head->my_lba) != lba) { - printf("GPT: my_lba incorrect: %llX != %llX\n", - le64_to_cpu(pgpt_head->my_lba), - lba); + printf("GPT: my_lba incorrect: %llX != %" PRIX64 "\n", + le64_to_cpu(pgpt_head->my_lba), + lba); return 0; }
/* Check the first_usable_lba and last_usable_lba are within the disk. */ lastlba = (u64)dev_desc->lba; if (le64_to_cpu(pgpt_head->first_usable_lba) > lastlba) { - printf("GPT: first_usable_lba incorrect: %llX > %llX\n", - le64_to_cpu(pgpt_head->first_usable_lba), lastlba); + printf("GPT: first_usable_lba incorrect: %llX > %" PRIX64 "\n", + le64_to_cpu(pgpt_head->first_usable_lba), lastlba); return 0; } if (le64_to_cpu(pgpt_head->last_usable_lba) > lastlba) { - printf("GPT: last_usable_lba incorrect: %llX > %llX\n", - le64_to_cpu(pgpt_head->last_usable_lba), lastlba); + printf("GPT: last_usable_lba incorrect: %llX > %" PRIX64 "\n", + le64_to_cpu(pgpt_head->last_usable_lba), lastlba); return 0; }
- debug("GPT: first_usable_lba: %llX last_usable_lba %llX last lba %llX\n", - le64_to_cpu(pgpt_head->first_usable_lba), - le64_to_cpu(pgpt_head->last_usable_lba), lastlba); + debug("GPT: first_usable_lba: %llX last_usable_lba %llX last lba %" + PRIX64 "\n", le64_to_cpu(pgpt_head->first_usable_lba), + le64_to_cpu(pgpt_head->last_usable_lba), lastlba);
/* Read and allocate Partition Table Entries */ *pgpt_pte = alloc_read_gpt_entries(dev_desc, pgpt_head);
This fixes the following two problems:
cppcheck reports: [arch/sandbox/cpu/start.c:132]: (error) Uninitialized variable: err [arch/sandbox/cpu/os.c:371]: (error) Memory leak: fname
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Wolfgang Denk wd@denx.de ---
arch/sandbox/cpu/os.c | 1 + arch/sandbox/cpu/start.c | 3 ++- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 1c4aa3f..f572cae 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -367,6 +367,7 @@ int os_dirent_ls(const char *dirname, struct os_dirent_node **headp)
done: closedir(dir); + free(fname); return ret; }
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 53a99ae..656bd75 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -130,7 +130,8 @@ static int sandbox_cmdline_cb_memory(struct sandbox_state *state, state->write_ram_buf = true; state->ram_buf_fname = arg;
- if (os_read_ram_buf(arg)) { + err = os_read_ram_buf(arg); + if (err) { printf("Failed to read RAM buffer\n"); return err; }
