[U-Boot] [PATCH]powerpc/mpc8xxx: Fix USB device-tree fixup
Fix usb device-tree fixup: - wrong modification of dr_mode and phy_type when "usb1" is not mentioned inside hwconfig string; now allows hwconfig strings like: "usb2:dr_mode=host,phy_type=ulpi" - add warning message for using usb_dr_mode and usb_phy_type env variables (if either is used)
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- Applies on git://git.denx.de/u-boot.git (branch master)
arch/powerpc/cpu/mpc8xxx/fdt.c | 50 +++++++++++++++++++++++++++------------ 1 files changed, 34 insertions(+), 16 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 09810be..26815b8 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -138,6 +138,8 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) const char *phys[] = { "ulpi", "utmi" }; const char *mode = NULL; const char *phy_type = NULL; + char *dr_mode_type = NULL; + char *dr_phy_type = NULL; char usb1_defined = 0; int usb_mode_off = -1; int usb_phy_off = -1; @@ -155,6 +157,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) break; } } + for (j = 0; j < ARRAY_SIZE(phys); j++) { if (hwconfig_subarg_cmp(str, "phy_type", phys[j])) { @@ -162,31 +165,46 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) break; } } - if (mode_idx >= 0) { - usb_mode_off = fdt_fixup_usb_mode_phy_type(blob, - modes[mode_idx], NULL, usb_mode_off); - if (usb_mode_off < 0) - return; - } - if (phy_idx >= 0) { - usb_phy_off = fdt_fixup_usb_mode_phy_type(blob, - NULL, phys[phy_idx], usb_phy_off); - if (usb_phy_off < 0) - return; - } + + dr_mode_type = modes[mode_idx]; + dr_phy_type = phys[phy_idx]; + + /* use usb_dr_mode and usb_phy_type if + usb1_defined = 0; these variables are to + be deprecated */ if (!strcmp(str, "usb1")) usb1_defined = 1; - if (mode_idx < 0 && phy_idx < 0) + + if (mode_idx < 0 && phy_idx < 0) { printf("WARNING: invalid phy or mode\n"); + return; + } } + + usb_mode_off = fdt_fixup_usb_mode_phy_type(blob, + dr_mode_type, NULL, usb_mode_off); + + if (usb_mode_off < 0) + return; + + usb_phy_off = fdt_fixup_usb_mode_phy_type(blob, + NULL, dr_phy_type, usb_phy_off); + + if (usb_phy_off < 0) + return; } + if (!usb1_defined) { int usb_off = -1; mode = getenv("usb_dr_mode"); phy_type = getenv("usb_phy_type"); - if (!mode && !phy_type) - return; - fdt_fixup_usb_mode_phy_type(blob, mode, phy_type, usb_off); + if (mode || phy_type) { + printf("WARNING: usb_dr_mode and usb_phy_type " + "are to be deprecated soon. Use " + "hwconfig to set these values instead!!\n"); + fdt_fixup_usb_mode_phy_type(blob, mode, + phy_type, usb_off); + } } } #endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */
Ramneek Mehresh
