Binman entry 'u-boot-any' not found in list
Hi!
U-Boot build for J721E with binman enabled on the latest tip of the master branch throws an error when I try to use u-boot-spl-nodtb entry in my dtsi.
What I'm trying to do is, to show I've made a small example (https://github.com/nehamalcom/u-boot/commit/f53dc83944f7774008afbb24fff42904...) that is:
&binman { foo { filename = "foo.bin"; u-boot-spl-nodtb { }; }; };
which throws the error (https://gist.github.com/nehamalcom/4d855db7e4d5bd03aa29099b0e915e53):
binman: Section '/binman/foo': Symbol '_binman_u_boot_any_prop_image_pos' in entry '/binman/foo/u-boot-spl-nodtb': Entry 'u-boot-any' not found in list (u-boot-spl-nodtb,main-section)
This can be traced to the WriteSymbols() in etype/u_boot_spl_nodtb.py. On commenting out this function since it's not necessary in our use-case, the build was successful (https://github.com/nehamalcom/u-boot/commit/5666721860e1d2f759440a00c4aee8b6...)
Why is binman not picking up on the "any" and choosing u-boot-spl-nodtb from the list?
[Adding Alper - binmam maintainer and Oliver, who faced the same issue on imx8]
On Fri, Oct 28, 2022 at 7:56 AM Neha Malcom Francis n-francis@ti.com wrote:
Hi!
-- Thanking You Neha Malcom Francis
Hi Neha,
Hi!
You might need this patch?
https://patchwork.ozlabs.org/project/uboot/patch/20221021002320.1169603-5-sj...
Hi Simon,
On 30/10/22 07:13, Simon Glass wrote:
Hi Neha,
Hi!
Even after applying this patch, the entry is not working for me.
Hi Neha,
On 31/10/2022 05:40, Neha Malcom Francis wrote:
Hi Simon,
Hi Neha,
Hi!
Probably because that patch doesn't deal with CONFIG_SPL case, only CONFIG_TPL and CONFIG_VPL? Can you please try to do the same for CONFIG_SPL?
e.g.
#ifdef CONFIG_SPL binman_sym_declare(ulong, u_boot_spl, image_pos); binman_sym_declare(ulong, u_boot_spl, size); #endif
cheers, -roger
On 31/10/2022 15:56, Roger Quadros wrote:> On 31/10/2022 05:40, Neha Malcom Francis wrote:
(Sorry I've been unavailable here for longer than I hoped for. Still trying to get some other work into Debian before their freeze.)
Hi!
Binman is trying to embed into the SPL the position/size of U-Boot (its next phase), but there's no U-Boot proper entry in the same binman image, so it can't. Try disabling CONFIG_SPL_BINMAN_UBOOT_SYMBOLS to stop writing these symbols since you said you don't need them, see [1][2] merged since v2022.04 or so.
You can try putting everything into a monolithic binman image, but that proved difficult to do for i.MX8M, so I added that config and disabled it there. Maybe it should be disabled by default.
[1] spl: binman: Split binman symbols support from enabling binman https://lore.kernel.org/u-boot/20220618121316.12061-5-alpernebiyasak@gmail.c...
[2] spl: binman: Disable u_boot_any symbols for i.MX8M boards https://lore.kernel.org/u-boot/20220618121316.12061-8-alpernebiyasak@gmail.c...
The "u-boot-any" ones are for SPL, and implicitly #ifdef CONFIG_SPL. Those #ifdefs are a bit underspecified, but 'work' in the sense that for any phase its next phase is declared.
e.g.
cheers, -roger
Hi Roger, Alper,
Thank you for the help!
Hi!
Yes disabling the CONFIG_SPL_BINMAN_UBOOT_SYMBOLS worked, thank you for explaining what it was trying to do. Yes, if the use-case is lower, I think it can be 'n' by default.
Okay, got it.
e.g.
cheers, -roger
participants (5)
Alper Nebi Yasak
Fabio Estevam
Neha Malcom Francis
Roger Quadros
