[U-Boot] [PATCH] arm: Tegra: Use arch-specific pmc.h where needed, else use common pmc.h
PMC block for T20/T30 is able to use a common header, but T1x4 has added registers and/or moved registers around, so these SoCs need a arch-specific pmc.h.
Built all Tegra AOK, tested on T114 Dalmore and T124 Venice OK.
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/cpu/arm720t/tegra-common/cpu.c | 2 +- arch/arm/cpu/arm720t/tegra114/cpu.c | 4 ++-- arch/arm/cpu/arm720t/tegra20/cpu.c | 2 +- arch/arm/cpu/arm720t/tegra30/cpu.c | 2 +- arch/arm/cpu/armv7/tegra-common/cmd_enterrcm.c | 2 +- arch/arm/cpu/tegra-common/ap.c | 2 +- arch/arm/cpu/tegra-common/board.c | 2 +- arch/arm/cpu/tegra20-common/warmboot.c | 2 +- arch/arm/cpu/tegra20-common/warmboot_avp.c | 2 +- arch/arm/include/asm/arch-tegra124/pmc.h | 4 ++-- arch/arm/include/asm/arch-tegra20/pmc.h | 14 ++++++++++++++ arch/arm/include/asm/arch-tegra30/pmc.h | 15 +++++++++++++++ board/nvidia/common/board.c | 2 +- 13 files changed, 42 insertions(+), 13 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra20/pmc.h create mode 100644 arch/arm/include/asm/arch-tegra30/pmc.h
diff --git a/arch/arm/cpu/arm720t/tegra-common/cpu.c b/arch/arm/cpu/arm720t/tegra-common/cpu.c index fbe553a..aea5c2b 100644 --- a/arch/arm/cpu/arm720t/tegra-common/cpu.c +++ b/arch/arm/cpu/arm720t/tegra-common/cpu.c @@ -10,9 +10,9 @@ #include <asm/arch/clock.h> #include <asm/arch/gp_padctrl.h> #include <asm/arch/pinmux.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/scu.h> #include "cpu.h"
diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c index 844299b..e55847e 100644 --- a/arch/arm/cpu/arm720t/tegra114/cpu.c +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -19,9 +19,9 @@ #include <asm/arch/clock.h> #include <asm/arch/flow.h> #include <asm/arch/pinmux.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include "../tegra-common/cpu.h"
/* Tegra114-specific CPU init code */ @@ -211,7 +211,7 @@ static int is_clamp_enabled(u32 mask) struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; u32 reg;
- /* Get clamp status. TODO: Add pmc_clamp_status alias to pmc.h */ + /* Get clamp status */ reg = readl(&pmc->pmc_clamp_status); return (reg & mask) == mask; } diff --git a/arch/arm/cpu/arm720t/tegra20/cpu.c b/arch/arm/cpu/arm720t/tegra20/cpu.c index 2533899..ebd6fbe 100644 --- a/arch/arm/cpu/arm720t/tegra20/cpu.c +++ b/arch/arm/cpu/arm720t/tegra20/cpu.c @@ -16,8 +16,8 @@
#include <common.h> #include <asm/io.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> -#include <asm/arch-tegra/pmc.h> #include "../tegra-common/cpu.h"
static void enable_cpu_power_rail(void) diff --git a/arch/arm/cpu/arm720t/tegra30/cpu.c b/arch/arm/cpu/arm720t/tegra30/cpu.c index e162357..2e7423f 100644 --- a/arch/arm/cpu/arm720t/tegra30/cpu.c +++ b/arch/arm/cpu/arm720t/tegra30/cpu.c @@ -18,9 +18,9 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/flow.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/tegra_i2c.h> #include "../tegra-common/cpu.h"
diff --git a/arch/arm/cpu/armv7/tegra-common/cmd_enterrcm.c b/arch/arm/cpu/armv7/tegra-common/cmd_enterrcm.c index a94ec93..45f0f4d 100644 --- a/arch/arm/cpu/armv7/tegra-common/cmd_enterrcm.c +++ b/arch/arm/cpu/armv7/tegra-common/cmd_enterrcm.c @@ -26,8 +26,8 @@ */
#include <common.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> -#include <asm/arch-tegra/pmc.h>
static int do_enterrcm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/arch/arm/cpu/tegra-common/ap.c b/arch/arm/cpu/tegra-common/ap.c index c2c4a0b..6233305 100644 --- a/arch/arm/cpu/tegra-common/ap.c +++ b/arch/arm/cpu/tegra-common/ap.c @@ -10,10 +10,10 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/gp_padctrl.h> +#include <asm/arch/pmc.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/clock.h> #include <asm/arch-tegra/fuse.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/scu.h> #include <asm/arch-tegra/tegra.h> #include <asm/arch-tegra/warmboot.h> diff --git a/arch/arm/cpu/tegra-common/board.c b/arch/arm/cpu/tegra-common/board.c index 2c9613e..b4675c7 100644 --- a/arch/arm/cpu/tegra-common/board.c +++ b/arch/arm/cpu/tegra-common/board.c @@ -9,9 +9,9 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/board.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/sys_proto.h> #include <asm/arch-tegra/warmboot.h>
diff --git a/arch/arm/cpu/tegra20-common/warmboot.c b/arch/arm/cpu/tegra20-common/warmboot.c index 8beba53..0969753 100644 --- a/arch/arm/cpu/tegra20-common/warmboot.c +++ b/arch/arm/cpu/tegra20-common/warmboot.c @@ -11,12 +11,12 @@ #include <asm/arch/clock.h> #include <asm/arch/emc.h> #include <asm/arch/gp_padctrl.h> +#include <asm/arch/pmc.h> #include <asm/arch/pinmux.h> #include <asm/arch/sdram_param.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/fuse.h> #include <asm/arch-tegra/warmboot.h>
diff --git a/arch/arm/cpu/tegra20-common/warmboot_avp.c b/arch/arm/cpu/tegra20-common/warmboot_avp.c index b910f78..224d10d 100644 --- a/arch/arm/cpu/tegra20-common/warmboot_avp.c +++ b/arch/arm/cpu/tegra20-common/warmboot_avp.c @@ -10,10 +10,10 @@ #include <asm/arch/clock.h> #include <asm/arch/flow.h> #include <asm/arch/pinmux.h> +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/ap.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/warmboot.h> #include "warmboot_avp.h"
diff --git a/arch/arm/include/asm/arch-tegra124/pmc.h b/arch/arm/include/asm/arch-tegra124/pmc.h index fa6ef10..08080e2 100644 --- a/arch/arm/include/asm/arch-tegra124/pmc.h +++ b/arch/arm/include/asm/arch-tegra124/pmc.h @@ -1,6 +1,6 @@ /* - * (C) Copyright 2013 - * NVIDIA Corporation <www.nvidia.com> + * (C) Copyright 2013 + * NVIDIA Corporation <www.nvidia.com> * * SPDX-License-Identifier: GPL-2.0+ */ diff --git a/arch/arm/include/asm/arch-tegra20/pmc.h b/arch/arm/include/asm/arch-tegra20/pmc.h new file mode 100644 index 0000000..6a39848 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra20/pmc.h @@ -0,0 +1,14 @@ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _TEGRA20_PMC_H_ +#define _TEGRA20_PMC_H_ + +/* Use common include */ +#include <asm/arch-tegra/pmc.h> + +#endif /* _TEGRA20_PMC_H_ */ diff --git a/arch/arm/include/asm/arch-tegra30/pmc.h b/arch/arm/include/asm/arch-tegra30/pmc.h new file mode 100644 index 0000000..fc155d7 --- /dev/null +++ b/arch/arm/include/asm/arch-tegra30/pmc.h @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2010-2013 + * NVIDIA Corporation <www.nvidia.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _TEGRA30_PMC_H_ +#define _TEGRA30_PMC_H_ + +/* Use common include */ +#include <asm/arch-tegra/pmc.h> + +#endif /* _TEGRA30_PMC_H_ */ + diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 3f78787..007fdec 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -19,10 +19,10 @@ #ifdef CONFIG_PWM_TEGRA #include <asm/arch/pwm.h> #endif +#include <asm/arch/pmc.h> #include <asm/arch/tegra.h> #include <asm/arch-tegra/board.h> #include <asm/arch-tegra/clk_rst.h> -#include <asm/arch-tegra/pmc.h> #include <asm/arch-tegra/sys_proto.h> #include <asm/arch-tegra/uart.h> #include <asm/arch-tegra/warmboot.h>
Tom Warren
