[U-Boot] [PATCH v2] imx8m: clock: Fix oscillator values
OSC_27M_CLK should return 27MHz and OSC_32K_CLK should return 32768Hz to reflect the reality.
This also keeps the values in sync with the Linux clock tree.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v1: - Fixed typo in the Subject line (oscillator)
arch/arm/mach-imx/imx8m/clock.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/clock.c b/arch/arm/mach-imx/imx8m/clock.c index 3766d988ba..289b9417aa 100644 --- a/arch/arm/mach-imx/imx8m/clock.c +++ b/arch/arm/mach-imx/imx8m/clock.c @@ -250,9 +250,9 @@ static u32 get_root_src_clk(enum clk_root_src root_src) case OSC_25M_CLK: return 25000000; case OSC_27M_CLK: - return 25000000; + return 27000000; case OSC_32K_CLK: - return 32000; + return 32768; case ARM_PLL_CLK: return decode_frac_pll(root_src); case SYSTEM_PLL1_800M_CLK:
Fabio Estevam
