[U-Boot] Please pull u-boot-mpc85xx.git
The following changes since commit c6b734f5aea2ba75caaa1929f7e649ecda8d2f31:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2011-01-12 23:59:53 +0100)
git://git.denx.de/u-boot-mpc85xx master
Becky Bruce (9): socrates: rename sdram_setup fixed_sdram() mpc8569mds: Remove unnecessary CONFIG_SYS_LBC_SDRAM_BASE definition MPC8568/MPC8569: Remove CONFIG_DDR_DLL define tqm85xx: create fixed_sdram() to do sdram setup mpc85xx/tlb.c: Allow platforms to specify wimge bits mpc85xx boards: initdram() cleanup/bugfix mpc85xx: rename sdram_init() lbc_sdram_init() 85xx boards: Rename CONFIG_DDR_DLL to CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_IN MPC8xxx DDR: align informational prints
Chenhui Zhao (1): fsl_esdhc: Fix esdhc disabled problem on some platforms
Jerry Huang (1): fsl_esdhc: Add the workaround for erratum ESDHC111 (enable on P4080)
Kumar Gala (46): powerpc/85xx: Removed support for ATUM8548 board powerpc/85xx: Removed support for MPC8540EVAL board powerpc/85xx: Remove support for PM854/PM856 boards powerpc/85xx: Add support for booting from NAND on MPC8572DS powerpc/85xx: Replace CONFIG_SYS_HAS_SERDES with a weak function powerpc/85xx: Create a SERDES section in Makefile powerpc/86xx: Add SERDES support on MPC8641 & MPC8610 powerpc/85xx: Add is_serdes_configured() support for P2020 SERDES powerpc/85xx: Add is_serdes_configured() support for MPC8572 SERDES powerpc/85xx: Add is_serdes_configured() support for MPC8548 SERDES powerpc/85xx: Add is_serdes_configured() support for MPC8568 SERDES powerpc/85xx: Add is_serdes_configured() support for MPC8569 SERDES powerpc/85xx: Add is_serdes_configured() support for MPC8544 SERDES powerpc/85xx: Add is_serdes_configured() support for P1021 SERDES powerpc/8xxx: Replace is_fsl_pci_cfg with is_serdes_configured powerpc/85xx: Cleanup SGMII detection and reporting powerpc/85xx: Fix bug in dcache_disable powerpc/fsl-pci: Determine pci_controller based on cfg addr for dts fixup powerpc/fsl-pci: Add generic code to setup PCIe controllers powerpc/85xx: Rework MPC8572DS pci_init_board to use common FSL PCIe code powerpc/85xx: Rework P2020DS pci_init_board to use common FSL PCIe code powerpc/85xx: Rework MPC8544DS pci_init_board to use common FSL PCIe code powerpc/85xx: Rework MPC8536DS pci_init_board to use common FSL PCIe code powerpc/86xx: Rework MPC8641HPCN pci_init_board to use common FSL PCIe code powerpc/85xx: Rework MPC8548CDS pci_init_board to use common FSL PCIe code powerpc/8xxx: Rework XES boards pci_init_board to use common FSL PCIe code powerpc/85xx: Rework TQM boards pci_init_board to use common FSL PCIe code powerpc/85xx: Rework MPC8568MDS pci_init_board to use common FSL PCIe code powerpc/85xx: Rework MPC8569MDS pci_init_board to use common FSL PCIe code powerpc/85xx: Rework P1_P2_RDB pci_init_board to use common FSL PCIe code powerpc/86xx: Rework MPC8610HPCD pci_init_board to use common FSL PCIe code powerpc/86xx: Rework SBC8641 pci_init_board to use common FSL PCIe code powerpc/85xx: Rework SBC8548 pci_init_board to use common FSL PCIe code powerpc/85xx: Rework corenet_ds pci_init_board to use common FSL PCIe code powerpc/8xxx: Refactor SRIO initialization into common code powerpc/85xx: Convert MPC8548CDS to use common SRIO init code powerpc/85xx: Convert MPC8568MDS to use common SRIO init code powerpc/85xx: Convert MPC8569MDS to use common SRIO init code powerpc/86xx: Enable common SRIO init code powerpc/86xx: Convert MPC8641HPCN to use common SRIO init code powerpc/86xx: Convert SBC8641 to use common SRIO init code powerpc/8xxx: Move fsl_is_spd() into generic 8xxx ddr code powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boards powerpc/85xx: Add the workaround for erratum CPC-A002 (enable on P4080) powerpc/85xx: Add the workaround for erratum CPC-A003 (enable on P4080) powerpc/85xx: Add the workaround for erratum ELBC-A001 (enable on P4080)
Li Yang (1): powerpc/85xx: Add SRIO support to P2020DS
Paul Gortmaker (1): MPC8xxx: Update maintainer entry for Wind River sbc8xxx boards
Peter Tyser (1): fsl_pci: Update PCIe boot ouput
Piergiorgio Beruto (1): powerpc/85xx: Fix wrong SVR value for MPC8567 and MPC8567E processors
Roy Zang (2): fsl_esdhc: Add the workaround for erratum ESDHC135 (enable on P4080) fsl_esdhc: Add the workaround for erratum ESDHC136 (enable on P4080)
MAINTAINERS | 17 +- README | 18 + arch/powerpc/cpu/mpc85xx/Makefile | 18 +- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 24 +- arch/powerpc/cpu/mpc85xx/cpu.c | 52 ++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 29 +- arch/powerpc/cpu/mpc85xx/fdt.c | 7 +- arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c | 95 +++ arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c | 65 ++ arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c | 65 ++ arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c | 74 ++ arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c | 81 +++ arch/powerpc/cpu/mpc85xx/p1021_serdes.c | 64 ++ arch/powerpc/cpu/mpc85xx/p2020_serdes.c | 73 ++ arch/powerpc/cpu/mpc85xx/start.S | 4 +- arch/powerpc/cpu/mpc85xx/tlb.c | 6 +- arch/powerpc/cpu/mpc86xx/Makefile | 2 + arch/powerpc/cpu/mpc86xx/cpu_init.c | 11 +- arch/powerpc/cpu/mpc86xx/fdt.c | 7 +- arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c | 85 +++ arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c | 94 +++ arch/powerpc/cpu/mpc8xxx/Makefile | 2 +- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 5 +- arch/powerpc/cpu/mpc8xxx/ddr/options.c | 22 +- arch/powerpc/cpu/mpc8xxx/fdt.c | 23 +- arch/powerpc/cpu/mpc8xxx/fsl_lbc.c | 17 +- arch/powerpc/cpu/mpc8xxx/pci_cfg.c | 204 ------ arch/powerpc/cpu/mpc8xxx/srio.c | 86 +++ arch/powerpc/include/asm/fsl_ddr_sdram.h | 16 +- arch/powerpc/include/asm/fsl_law.h | 1 + arch/powerpc/include/asm/fsl_lbc.h | 8 +- arch/powerpc/include/asm/fsl_pci.h | 57 +-- arch/powerpc/include/asm/immap_85xx.h | 4 +- arch/powerpc/include/asm/immap_86xx.h | 4 +- arch/powerpc/include/asm/processor.h | 4 +- board/atum8548/Makefile | 57 -- board/atum8548/atum8548.c | 297 -------- board/atum8548/ddr.c | 83 --- board/atum8548/law.c | 61 -- board/atum8548/tlb.c | 90 --- board/freescale/corenet_ds/corenet_ds.c | 44 -- board/freescale/corenet_ds/ddr.c | 18 +- board/freescale/corenet_ds/pci.c | 118 +--- board/freescale/mpc8536ds/mpc8536ds.c | 160 +---- board/freescale/mpc8540ads/mpc8540ads.c | 61 +-- board/freescale/mpc8540ads/tlb.c | 19 - board/freescale/mpc8541cds/mpc8541cds.c | 52 +-- board/freescale/mpc8544ds/law.c | 10 +- board/freescale/mpc8544ds/mpc8544ds.c | 139 +--- board/freescale/mpc8548cds/law.c | 13 +- board/freescale/mpc8548cds/mpc8548cds.c | 91 +-- board/freescale/mpc8548cds/tlb.c | 9 +- board/freescale/mpc8555cds/mpc8555cds.c | 54 +-- board/freescale/mpc8560ads/mpc8560ads.c | 61 +-- board/freescale/mpc8560ads/tlb.c | 19 - board/freescale/mpc8568mds/law.c | 7 +- board/freescale/mpc8568mds/mpc8568mds.c | 95 +-- board/freescale/mpc8569mds/law.c | 5 +- board/freescale/mpc8569mds/mpc8569mds.c | 76 +-- board/freescale/mpc8572ds/config.mk | 8 +- board/freescale/mpc8572ds/law.c | 8 +- board/freescale/mpc8572ds/mpc8572ds.c | 143 +---- board/freescale/mpc8572ds/tlb.c | 14 +- board/freescale/mpc8610hpcd/law.c | 8 +- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 79 +-- board/freescale/mpc8641hpcn/law.c | 10 +- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 51 +-- board/freescale/p1022ds/p1022ds.c | 80 +-- board/freescale/p1_p2_rdb/ddr.c | 15 +- board/freescale/p1_p2_rdb/law.c | 6 +- board/freescale/p1_p2_rdb/p1_p2_rdb.c | 8 +- board/freescale/p1_p2_rdb/pci.c | 65 +-- board/freescale/p2020ds/law.c | 8 +- board/freescale/p2020ds/p2020ds.c | 154 +---- board/mpc8540eval/Makefile | 54 -- board/mpc8540eval/ddr.c | 73 -- board/mpc8540eval/flash.c | 894 ------------------------ board/mpc8540eval/law.c | 54 -- board/mpc8540eval/mpc8540eval.c | 230 ------ board/mpc8540eval/tlb.c | 78 -- board/pm854/Makefile | 53 -- board/pm854/ddr.c | 73 -- board/pm854/law.c | 58 -- board/pm854/pm854.c | 298 -------- board/pm854/tlb.c | 117 --- board/pm856/Makefile | 53 -- board/pm856/ddr.c | 73 -- board/pm856/law.c | 58 -- board/pm856/pm856.c | 453 ------------ board/pm856/tlb.c | 117 --- board/sbc8548/law.c | 8 - board/sbc8548/sbc8548.c | 99 +--- board/sbc8548/tlb.c | 34 +- board/sbc8560/sbc8560.c | 93 +--- board/sbc8641d/law.c | 5 - board/sbc8641d/sbc8641d.c | 66 +-- board/socrates/sdram.c | 15 +- board/stx/stxgp3/stxgp3.c | 32 - board/stx/stxssa/stxssa.c | 33 - board/tqc/tqm85xx/law.c | 9 +- board/tqc/tqm85xx/sdram.c | 70 +-- board/tqc/tqm85xx/tlb.c | 47 -- board/tqc/tqm85xx/tqm85xx.c | 44 +- board/xes/common/Makefile | 2 - board/xes/common/fsl_8xxx_ddr.c | 46 -- board/xes/common/fsl_8xxx_pci.c | 113 +--- board/xes/xpedite517x/law.c | 8 - board/xes/xpedite517x/xpedite517x.c | 13 + board/xes/xpedite520x/law.c | 8 - board/xes/xpedite537x/law.c | 12 - board/xes/xpedite550x/law.c | 12 - boards.cfg | 9 +- doc/README.atum8548 | 29 - doc/README.mpc85xxads | 4 +- drivers/mmc/fsl_esdhc.c | 29 +- drivers/pci/fsl_pci_init.c | 183 +++++- drivers/pci/pci.c | 12 + include/configs/ATUM8548.h | 443 ------------ include/configs/MPC837XEMDS.h | 1 + include/configs/MPC837XERDB.h | 1 + include/configs/MPC8536DS.h | 8 +- include/configs/MPC8540ADS.h | 3 +- include/configs/MPC8540EVAL.h | 362 ---------- include/configs/MPC8541CDS.h | 3 +- include/configs/MPC8544DS.h | 6 +- include/configs/MPC8548CDS.h | 19 +- include/configs/MPC8555CDS.h | 3 +- include/configs/MPC8560ADS.h | 3 +- include/configs/MPC8568MDS.h | 15 +- include/configs/MPC8569MDS.h | 25 +- include/configs/MPC8572DS.h | 122 +++- include/configs/MPC8610HPCD.h | 4 +- include/configs/MPC8641HPCN.h | 31 +- include/configs/P1022DS.h | 4 +- include/configs/P1_P2_RDB.h | 6 +- include/configs/P2020DS.h | 28 +- include/configs/P4080DS.h | 9 +- include/configs/PM854.h | 426 ----------- include/configs/PM856.h | 429 ------------ include/configs/SBC8540.h | 2 +- include/configs/TQM85xx.h | 6 +- include/configs/corenet_ds.h | 21 +- include/configs/sbc8560.h | 2 +- include/configs/sbc8641d.h | 15 +- include/configs/stxgp3.h | 2 +- include/configs/stxssa.h | 1 - include/pci.h | 1 + nand_spl/board/freescale/mpc8572ds/Makefile | 133 ++++ nand_spl/board/freescale/mpc8572ds/nand_boot.c | 82 +++ 149 files changed, 2041 insertions(+), 7586 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8544_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8548_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8568_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8569_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/mpc8572_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/p1021_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/p2020_serdes.c create mode 100644 arch/powerpc/cpu/mpc86xx/mpc8610_serdes.c create mode 100644 arch/powerpc/cpu/mpc86xx/mpc8641_serdes.c delete mode 100644 arch/powerpc/cpu/mpc8xxx/pci_cfg.c create mode 100644 arch/powerpc/cpu/mpc8xxx/srio.c delete mode 100644 board/atum8548/Makefile delete mode 100644 board/atum8548/atum8548.c delete mode 100644 board/atum8548/ddr.c delete mode 100644 board/atum8548/law.c delete mode 100644 board/atum8548/tlb.c delete mode 100644 board/mpc8540eval/Makefile delete mode 100644 board/mpc8540eval/ddr.c delete mode 100644 board/mpc8540eval/flash.c delete mode 100644 board/mpc8540eval/law.c delete mode 100644 board/mpc8540eval/mpc8540eval.c delete mode 100644 board/mpc8540eval/tlb.c delete mode 100644 board/pm854/Makefile delete mode 100644 board/pm854/ddr.c delete mode 100644 board/pm854/law.c delete mode 100644 board/pm854/pm854.c delete mode 100644 board/pm854/tlb.c delete mode 100644 board/pm856/Makefile delete mode 100644 board/pm856/ddr.c delete mode 100644 board/pm856/law.c delete mode 100644 board/pm856/pm856.c delete mode 100644 board/pm856/tlb.c delete mode 100644 board/xes/common/fsl_8xxx_ddr.c delete mode 100644 doc/README.atum8548 delete mode 100644 include/configs/ATUM8548.h delete mode 100644 include/configs/MPC8540EVAL.h delete mode 100644 include/configs/PM854.h delete mode 100644 include/configs/PM856.h create mode 100644 nand_spl/board/freescale/mpc8572ds/Makefile create mode 100644 nand_spl/board/freescale/mpc8572ds/nand_boot.c
Dear Kumar Gala,
Applied, thanks.
Kumar Gala
