[U-Boot] [PATCH v4 0/6] Improve default environment for easy use
This patchset improves the default environment of machines currently supported in OpenEmbedded and Yocto to make it compatible with mainline and Freescale BSP Linux kernel.
A new patch has been add to change the format in mx6qsabrelite in environment setting and already merged patches removed from this new pull request.
Changes in v4: - Use a warning, instead of error when failing to fetch fdt - Drop exit use - Fix netboot - Use fdt instead of ftd
Changes in v3: - Add loadfdt - Use loadfdt - Call exit to abort script
Changes in v2: - New patch - reformat environment change to fit in 80 cols - Allow use of dynamic/static ip - Allow force use, or not, of fdt - Change 'auto' to 'try'
Otavio Salvador (6): mx6qsabrelite: Use tabs to environment setting mx28evk: We shouldn't hardcode a rootfs filesystem type mx28evk: Add support to dynamically choose between ftd use or not mx53loco: Add support to dynamically choose between ftd use or not mx6qsabrelite: Add support to dynamically choose between ftd use or not mx6qsabre{auto,sd}: Add support to dynamically choose between ftd use or not
include/configs/mx28evk.h | 47 ++++++++++++++--- include/configs/mx53loco.h | 40 +++++++++++++- include/configs/mx6qsabre_common.h | 41 +++++++++++++-- include/configs/mx6qsabreauto.h | 1 + include/configs/mx6qsabrelite.h | 101 ++++++++++++++++++++++++------------ include/configs/mx6qsabresd.h | 1 + 6 files changed, 186 insertions(+), 45 deletions(-)
This rework the environment to use tabs for environment setting as done in other boards.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v4: None Changes in v3: None Changes in v2: - New patch
include/configs/mx6qsabrelite.h | 66 +++++++++++++++++++-------------------- 1 file changed, 33 insertions(+), 33 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 0f6bbb4..ee86f9b 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -152,43 +152,43 @@ #define CONFIG_SYS_TEXT_BASE 0x17800000
#define CONFIG_EXTRA_ENV_SETTINGS \ - "script=boot.scr\0" \ - "uimage=uImage\0" \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ "console=ttymxc1\0" \ - "fdt_high=0xffffffff\0" \ + "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "mmcdev=0\0" \ - "mmcpart=2\0" \ - "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ - "loadbootscript=" \ - "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "bootm\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0"
#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev};" \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if run loaduimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "else run netboot; fi" + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi"
#define CONFIG_ARP_TIMEOUT 200UL
For a generic environment, we shouldn't have a fixed rootfs filesystem so we drop it from env.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v4: None Changes in v3: None Changes in v2: - reformat environment change to fit in 80 cols
include/configs/mx28evk.h | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 8b89b25..ac9522f 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -292,11 +292,9 @@ "console_mainline=ttyAMA0\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ - "mmcroot=/dev/mmcblk0p3 rw\0" \ - "mmcrootfstype=ext3 rootwait\0" \ - "mmcargs=setenv bootargs console=${console_mainline},${baudrate} " \ - "root=${mmcroot} " \ - "rootfstype=${mmcrootfstype}\0" \ + "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ + "mmcargs=setenv bootargs console=${console_mainline},${baudrate} " + "root=${mmcroot}\0" \ "loadbootscript=" \ "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v4: - Use a warning, instead of error when failing to fetch fdt - Drop exit use - Fix netboot - Use fdt instead of ftd
Changes in v2: - Allow use of dynamic/static ip - Allow force use, or not, of fdt - Change 'auto' to 'try'
include/configs/mx28evk.h | 39 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 37 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index ac9522f..46442c3 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -290,6 +290,10 @@ "uimage=uImage\0" \ "console_fsl=ttyAM0\0" \ "console_mainline=ttyAMA0\0" \ + "fdt_file=imx28-evk.dtb\0" \ + "fdt_addr=0x41000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ @@ -300,15 +304,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console_mainline},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi;" \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev}; if mmc rescan; then " \
On Wed, Jan 9, 2013 at 8:20 AM, Otavio Salvador otavio@ossystems.com.br wrote:
Changes in v4:
- Drop exit use
- Fix netboot
Subject still uses 'ftd'. It is better to make it consistent.
Changes in v3:
- Add loadfdt
- Use loadfdt
Changes in v2:
"boot_fdt=try\0" \
"bootm\0" \
"else " \
"bootm; " \
"else " \
Actually you are not aborting. It was just mmc load that failed, but tftp will be tried next.
Have all the four combinations below been tested on the hardware?
1. Load a dt kernel from mmc 2. Load a non-dt kernel from mmc 3. Load a dt kernel from tftp 4. Load a non-dt kernel from tftp
Changes in v4:
- Drop exit use
- Fix netboot
Will send v5...
"bootm; " \
"else " \
Yes; I removed the aborting for v5
- Load a dt kernel from mmc
- Load a non-dt kernel from mmc
- Load a dt kernel from tftp
- Load a non-dt kernel from tftp
Stefano has helped testing it :-)
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
include/configs/mx53loco.h | 40 ++++++++++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 996396b..27be023 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -119,6 +119,10 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "uimage=uImage\0" \ + "fdt_file=imx53-qsb.dtb\0" \ + "fdt_addr=0x71000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rw rootwait\0" \ @@ -128,15 +132,47 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo ERROR: Cannot load the DT, aborting...; " \ + "exit; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
include/configs/mx6qsabrelite.h | 39 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 37 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index ee86f9b..fe000d3 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -157,6 +157,10 @@ "console=ttymxc1\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ + "fdt_file=imx6q-sabrelite.dtb\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "mmcdev=0\0" \ "mmcpart=2\0" \ "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ @@ -167,15 +171,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev};" \
include/configs/mx6qsabre_common.h | 41 +++++++++++++++++++++++++++++++++--- include/configs/mx6qsabreauto.h | 1 + include/configs/mx6qsabresd.h | 1 + 3 files changed, 40 insertions(+), 3 deletions(-)
diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6qsabre_common.h index bd2fb10..f0fb0fd 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6qsabre_common.h @@ -83,6 +83,10 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "uimage=uImage\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ "console=" CONFIG_CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ @@ -96,15 +100,46 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ - "mmcboot=echo Booting from mmc ...; " \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ - "bootm\0" \ + "if test ${boot_fdt} = yes; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ "netboot=echo Booting from net ...; " \ "run netargs; " \ - "dhcp ${uimage}; bootm\0" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT, aborting...; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0"
#define CONFIG_BOOTCOMMAND \ "mmc dev ${mmcdev};" \ diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index f1ff201..f4a082a 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -15,6 +15,7 @@ #define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE #define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONFIG_DEFAULT_FDT_FILE "imx6q-sabreauto.dtb" #define CONFIG_MMCROOT "/dev/mmcblk0p2" #define PHYS_SDRAM_SIZE (2u * 1024 * 1024 * 1024)
diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index a1d9285..b64e925 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -21,6 +21,7 @@ #define CONFIG_MXC_UART_BASE UART1_BASE #define CONFIG_CONSOLE_DEV "ttymxc0" #define CONFIG_MMCROOT "/dev/mmcblk1p2" +#define CONFIG_DEFAULT_FDT_FILE "imx6q-sabresd.dtb" #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#include "mx6qsabre_common.h"
Fabio Estevam
Otavio Salvador
