[PATCH v2] mach-snapdragon: Allow other board vendors apart from Qcom
Qcom SoCs derived boards can come from various OEMs/ODMs and not just Qcom itself. So allow CONFIG_SYS_VENDOR to be set correctly corressponding to the actual board vendor.
Suggested-by: Stephan Gerhold stephan@gerhold.net Reviewed-by: Caleb Connolly caleb.connolly@linaro.org Signed-off-by: Sumit Garg sumit.garg@linaro.org ---
Changes in v2: - Retained default vendor being "qualcomm". - Collected review tag.
arch/arm/mach-snapdragon/Kconfig | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index 96e44e2c549..536960b83c3 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -4,7 +4,12 @@ config SYS_SOC default "snapdragon"
config SYS_VENDOR + string "Snapdragon board vendor" default "qualcomm" + help + Allows to specify vendor for the Snapdragon SoCs based boards. + Based on this option board/<CONFIG_SYS_VENDOR>/<CONFIG_SYS_BOARD> + will be used as the custom board directory.
config SYS_MALLOC_F_LEN default 0x2000 @@ -19,12 +24,11 @@ config LNX_KRNL_IMG_TEXT_OFFSET_BASE default 0x80000000
config SYS_BOARD - string "Qualcomm custom board" + string "Snapdragon SoCs based board" help - The Dragonboard 410c and 820c have additional board init - code that isn't shared with other Qualcomm boards. - Based on this option board/qualcomm/<CONFIG_SYS_BOARD> will - be used. + Allows to specify the Snapdragon SoCs based board name. + Based on this option board/<CONFIG_SYS_VENDOR>/<CONFIG_SYS_BOARD> + will be used as the custom board directory.
config SYS_CONFIG_NAME string "Board configuration name"
Applied, thanks!
[1/1] mach-snapdragon: Allow other board vendors apart from Qcom commit: 68f98096c09734257e5218897500a7279c6c4ca2
Applied, thanks!
[1/1] mach-snapdragon: Allow other board vendors apart from Qcom commit: b01c8a8ea420a422bbb0550f7dff8ec5a2a03979
Caleb Connolly
Sumit Garg
