[PATCH v2 1/2] rockchip: rk3328: Add support for Orange Pi R1 Plus
Orange Pi R1 Plus is a Rockchip RK3328 based SBC by Xunlong.
This device is similar to the NanoPi R2S, and has a 16MB SPI NOR (mx25l12805d). The reset button is changed to directly reset the power supply, another detail is that both network ports have independent MAC addresses.
The device tree and description are taken from kernel v6.3-rc1.
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Tianling Shen cnsztl@gmail.com ---
Changes in v2: * Rebased upon the latest git HEAD * Collected R-b tag. * Removed kernel link from commit message.
--- arch/arm/dts/Makefile | 1 + .../dts/rk3328-orangepi-r1-plus-u-boot.dtsi | 46 +++ arch/arm/dts/rk3328-orangepi-r1-plus.dts | 373 ++++++++++++++++++ board/rockchip/evb_rk3328/MAINTAINERS | 6 + configs/orangepi-r1-plus-rk3328_defconfig | 114 ++++++ 5 files changed, 540 insertions(+) create mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus.dts create mode 100644 configs/orangepi-r1-plus-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60..9d189788aa 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -125,6 +125,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ rk3328-nanopi-r2c.dtb \ rk3328-nanopi-r2s.dtb \ + rk3328-orangepi-r1-plus.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi new file mode 100644 index 0000000000..637c70adf1 --- /dev/null +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2020 David Bauer + */ + +#include "rk3328-u-boot.dtsi" +#include "rk3328-sdram-ddr4-666.dtsi" +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; + +&gpio0 { + bootph-pre-ram; +}; + +&pinctrl { + bootph-pre-ram; +}; + +&sdmmc0m1_pin { + bootph-pre-ram; +}; + +&pcfg_pull_up_4ma { + bootph-pre-ram; +}; + +/* Need this and all the pinctrl/gpio stuff above to set pinmux */ +&vcc_sd { + bootph-pre-ram; +}; + +&gmac2io { + snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; +}; + +&spi0 { + spi_flash: spiflash@0 { + bootph-all; + }; +}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus.dts b/arch/arm/dts/rk3328-orangepi-r1-plus.dts new file mode 100644 index 0000000000..dc83d74045 --- /dev/null +++ b/arch/arm/dts/rk3328-orangepi-r1-plus.dts @@ -0,0 +1,373 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Based on rk3328-nanopi-r2s.dts, which is: + * Copyright (c) 2020 David Bauer mail@david-bauer.net + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include "rk3328.dtsi" + +/ { + model = "Xunlong Orange Pi R1 Plus"; + compatible = "xunlong,orangepi-r1-plus", "rockchip,rk3328"; + + aliases { + ethernet1 = &rtl8153; + mmc0 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + gmac_clk: gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac_clkin"; + #clock-cells = <0>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>; + pinctrl-names = "default"; + + led-0 { + function = LED_FUNCTION_LAN; + color = <LED_COLOR_ID_GREEN>; + gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; + }; + + led-1 { + function = LED_FUNCTION_STATUS; + color = <LED_COLOR_ID_RED>; + gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + led-2 { + function = LED_FUNCTION_WAN; + color = <LED_COLOR_ID_GREEN>; + gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; + }; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; + pinctrl-0 = <&sdmmc0m1_pin>; + pinctrl-names = "default"; + regulator-name = "vcc_sd"; + regulator-boot-on; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vdd_5v_lan: vdd-5v-lan-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&lan_vdd_pin>; + pinctrl-names = "default"; + regulator-name = "vdd_5v_lan"; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&display_subsystem { + status = "disabled"; +}; + +&gmac2io { + assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; + assigned-clock-parents = <&gmac_clk>, <&gmac_clk>; + clock_in_out = "input"; + phy-handle = <&rtl8211e>; + phy-mode = "rgmii"; + phy-supply = <&vcc_io>; + pinctrl-0 = <&rgmiim1_pins>; + pinctrl-names = "default"; + snps,aal; + rx_delay = <0x18>; + tx_delay = <0x24>; + status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + rtl8211e: ethernet-phy@1 { + reg = <1>; + pinctrl-0 = <ð_phy_reset_pin>; + pinctrl-names = "default"; + reset-assert-us = <10000>; + reset-deassert-us = <50000>; + reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&i2c1 { + status = "okay"; + + rk805: pmic@18 { + compatible = "rockchip,rk805"; + reg = <0x18>; + interrupt-parent = <&gpio1>; + interrupts = <24 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + gpio-controller; + #gpio-cells = <2>; + pinctrl-0 = <&pmic_int_l>; + pinctrl-names = "default"; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc5-supply = <&vcc_io>; + vcc6-supply = <&vcc_sys>; + + regulators { + vdd_log: DCDC_REG1 { + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <950000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_18: LDO_REG1 { + regulator-name = "vcc_18"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc18_emmc: LDO_REG2 { + regulator-name = "vcc18_emmc"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&io_domains { + pmuio-supply = <&vcc_io>; + vccio1-supply = <&vcc_io>; + vccio2-supply = <&vcc18_emmc>; + vccio3-supply = <&vcc_io>; + vccio4-supply = <&vcc_io>; + vccio5-supply = <&vcc_io>; + vccio6-supply = <&vcc_io>; + status = "okay"; +}; + +&pinctrl { + gmac2io { + eth_phy_reset_pin: eth-phy-reset-pin { + rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + leds { + lan_led_pin: lan-led-pin { + rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + sys_led_pin: sys-led-pin { + rockchip,pins = <3 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wan_led_pin: wan-led-pin { + rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + lan { + lan_vdd_pin: lan-vdd-pin { + rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm2 { + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + disable-wp; + pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; + pinctrl-names = "default"; + vmmc-supply = <&vcc_sd>; + status = "okay"; +}; + +&spi0 { + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <50000000>; + }; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&u2phy { + status = "okay"; +}; + +&u2phy_host { + status = "okay"; +}; + +&u2phy_otg { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb20_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbdrd3 { + dr_mode = "host"; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + /* Second port is for USB 3.0 */ + rtl8153: device@2 { + compatible = "usbbda,8153"; + reg = <2>; + }; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index 3c46613ab5..91dc6b58cf 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -18,6 +18,12 @@ F: configs/nanopi-r2s-rk3328_defconfig F: arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi F: arch/arm/dts/rk3328-nanopi-r2s.dts
+ORANGEPI-R1-PLUS-RK3328 +M: Tianling Shen cnsztl@gmail.com +S: Maintained +F: configs/orangepi-r1-plus-rk3328_defconfig +F: arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi + ROC-RK3328-CC M: Loic Devulder ldevulder@suse.com M: Chen-Yu Tsai wens@csie.org diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig new file mode 100644 index 0000000000..3f62f0588d --- /dev/null +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -0,0 +1,114 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3328-orangepi-r1-plus" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_STACK=0x400000 +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2000000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSINFO=y +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
The OrangePi R1 Plus LTS is a minor variant of OrangePi R1 Plus with the on-board NIC chip changed from rtl8211e to yt8531c, and RAM type changed from DDR4 to LPDDR3.
The device tree is taken from kernel v6.4-rc1.
Changes in v2: * Rebased upon the latest git HEAD * Fixed memory profile (rk3328-sdram-lpddr3-1600.dtsi -> rk3328-sdram-lpddr3-666.dtsi) * Removed kernel link from commit message
--- arch/arm/dts/Makefile | 1 + .../rk3328-orangepi-r1-plus-lts-u-boot.dtsi | 46 +++++++ arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts | 40 ++++++ board/rockchip/evb_rk3328/MAINTAINERS | 6 + configs/orangepi-r1-plus-lts-rk3328_defconfig | 114 ++++++++++++++++++ 5 files changed, 207 insertions(+) create mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts create mode 100644 configs/orangepi-r1-plus-lts-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9d189788aa..425bf4e7a9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -126,6 +126,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-nanopi-r2c.dtb \ rk3328-nanopi-r2s.dtb \ rk3328-orangepi-r1-plus.dtb \ + rk3328-orangepi-r1-plus-lts.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi new file mode 100644 index 0000000000..ebe33e48cb --- /dev/null +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2020 David Bauer + */ + +#include "rk3328-u-boot.dtsi" +#include "rk3328-sdram-lpddr3-666.dtsi" +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; + +&gpio0 { + bootph-pre-ram; +}; + +&pinctrl { + bootph-pre-ram; +}; + +&sdmmc0m1_pin { + bootph-pre-ram; +}; + +&pcfg_pull_up_4ma { + bootph-pre-ram; +}; + +/* Need this and all the pinctrl/gpio stuff above to set pinmux */ +&vcc_sd { + bootph-pre-ram; +}; + +&gmac2io { + snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; +}; + +&spi0 { + spi_flash: spiflash@0 { + bootph-all; + }; +}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts b/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts new file mode 100644 index 0000000000..5d7d567283 --- /dev/null +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2016 Xunlong Software. Co., Ltd. + * (http://www.orangepi.org) + * + * Copyright (c) 2021-2023 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include "rk3328-orangepi-r1-plus.dts" + +/ { + model = "Xunlong Orange Pi R1 Plus LTS"; + compatible = "xunlong,orangepi-r1-plus-lts", "rockchip,rk3328"; +}; + +&gmac2io { + phy-handle = <&yt8531c>; + tx_delay = <0x19>; + rx_delay = <0x05>; + + mdio { + /delete-node/ ethernet-phy@1; + + yt8531c: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + + motorcomm,clk-out-frequency-hz = <125000000>; + motorcomm,keep-pll-enabled; + motorcomm,auto-sleep-disabled; + + pinctrl-0 = <ð_phy_reset_pin>; + pinctrl-names = "default"; + reset-assert-us = <15000>; + reset-deassert-us = <50000>; + reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + }; + }; +}; diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index 91dc6b58cf..8a19eb373d 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -24,6 +24,12 @@ S: Maintained F: configs/orangepi-r1-plus-rk3328_defconfig F: arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi
+ORANGEPI-R1-PLUS-LTS-RK3328 +M: Tianling Shen cnsztl@gmail.com +S: Maintained +F: configs/orangepi-r1-plus-lts-rk3328_defconfig +F: arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi + ROC-RK3328-CC M: Loic Devulder ldevulder@suse.com M: Chen-Yu Tsai wens@csie.org diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig new file mode 100644 index 0000000000..59a28e5209 --- /dev/null +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -0,0 +1,114 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3328-orangepi-r1-plus-lts" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_SPL_STACK=0x400000 +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus-lts.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2000000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSINFO=y +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
Thanks, - Kever
Changes in v2:
- Rebased upon the latest git HEAD
- Fixed memory profile (rk3328-sdram-lpddr3-1600.dtsi -> rk3328-sdram-lpddr3-666.dtsi)
- Removed kernel link from commit message
- rk3328-orangepi-r1-plus-lts.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb
- (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd
- (C) Copyright 2020 David Bauer
- chosen {
+&gpio0 {
- bootph-pre-ram;
+&pinctrl {
- bootph-pre-ram;
+&sdmmc0m1_pin {
- bootph-pre-ram;
- bootph-pre-ram;
- bootph-pre-ram;
+&gmac2io {
- snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
+&spi0 {
- spi_flash: spiflash@0 {
bootph-all;
- Copyright (c) 2016 Xunlong Software. Co., Ltd.
- Copyright (c) 2021-2023 Tianling Shen cnsztl@gmail.com
- model = "Xunlong Orange Pi R1 Plus LTS";
- compatible = "xunlong,orangepi-r1-plus-lts", "rockchip,rk3328";
+&gmac2io {
- phy-handle = <&yt8531c>;
- tx_delay = <0x19>;
- rx_delay = <0x05>;
- mdio {
reg = <0>;
- ROC-RK3328-CC M: Loic Devulder ldevulder@suse.com M: Chen-Yu Tsai wens@csie.org
Kever Yang
Tianling Shen
