[U-Boot] [PATCH] arm: Tegra: fix undefined instruction hang immediately after reset
commit 0d479b53 (Aneesh V) added code for OMAP4 that doesn't execute on Tegra, due to the AVP (ARM7TDI) not having a CP15. Result was an undefined instruction hang just after reset.
Signed-off-by: Tom Warren twarren@nvidia.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/start.S | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index d23dc9d..ceed11e 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -144,6 +144,7 @@ reset: orr r0, r0, #0xd3 msr cpsr,r0
+#if !defined(CONFIG_TEGRA2) /* * Setup vector: * (OMAP4 spl TEXT_BASE is not 32 byte aligned. @@ -159,6 +160,7 @@ reset: ldr r0, =_start mcr p15, 0, r0, c12, c0, 0 @Set VBAR #endif +#endif /* !Tegra2 */
/* the mask ROM code should have PLL and others stable */ #ifndef CONFIG_SKIP_LOWLEVEL_INIT
- Setup vector:
- (OMAP4 spl TEXT_BASE is not 32 byte aligned.
forgive my ignorance, but would it be better to invert the logic ? have ARM cores that do have a CP15 define CONFIG_ARM_CP15 (or whatever) and then put all this logic behind that rather than grow a list of SoC's that lack it ? -mike
Mike,
- Setup vector:
As far as I understand CP15 is typically available(if not mandatory) on all armv7 processors. Here, IIUC, NVidia has a peculiar architecture that necessitates an armv4 processor supported by armv7 code. IMHO, this is the exceptional case.
br, Aneesh
- Setup vector:
#endif
np then ... thanks -mike
Aneesh & Mike,
-----Original Message----- From: Aneesh V [mailto:aneesh@ti.com] Sent: Wednesday, December 07, 2011 10:51 PM To: Mike Frysinger Cc: u-boot@lists.denx.de; trini@ti.com; Tom Warren; Tom Warren Subject: Re: [U-Boot] [PATCH] arm: Tegra: fix undefined instruction hang immediately after reset
Mike,
- Setup vector:
-mike
Tegra has (at least) 2 ARM processors - the AVP, which is ARM7TDMI-based and hence has no CP15, and the CPU complex, which as 2 or more A9 CPUs. Since the AVP is the boot processor, it runs the initial U-Boot code (start.S) and will eventually setup and kick off the CPU(s) to run the bulk of U-Boot.
Perhaps we should be in our own arch/arm/cpu/arm7tdmi subdir, but that's a major change from the current structure. Is it possible for this code ("Setup vector") to only be defined for OMAP processor builds? The code it replaces was ifdef'd for OMAP3, and had no affect on Tegra builds.
Unless some other SoC decides to use an ARM7TDMI-S boot proc, though, the CONFIG_TEGRA2 fencing should be the only one necessary.
Tom
br, Aneesh
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Tom,
On Thursday 08 December 2011 09:07 PM, Tom Warren wrote:
Aneesh& Mike,
Mike,
-mike
I think setting up vector is useful for all platforms and I think this is the right place to do it. Just that we didn't have it till now ecept for OMAP3 and OMAP3 was doing it in a round-about way.
I agree. I don't think there will be many more exceptions like this. We can live with that #ifdef. Not sure what Albert thinks though.
Tom
br, Aneesh
Hi Tom,
Signed-off-by: Tom Warrentwarren@nvidia.com Cc: Albert Aribaudalbert.u.boot@aribaud.net Cc: Tom Rinitrini@ti.com
- Setup vector:
FWIW,
Acked-by: Aneesh V aneesh@ti.com
Thanks, Aneesh.
On Wed, Dec 21, 2011 at 1:02 AM, Aneesh V aneesh@ti.com wrote:
Hi Tom,
FWIW,
Dear Tom Warren,
Applied, thanks.
Albert: hope this is OK with you.
participants (5)
Aneesh V
Mike Frysinger
Tom Warren
Tom Warren
