[U-Boot-Users] build u-boot error: No rule to make target `.depend', needed by `_depend'.
I 'cd' in eldk-4.1-arm installation directory arm/src/u-boot-1.2.0 and run:
make distclean make sbc2410x_config make all
In the last step, the `make' reported "No rule to make target `.depend', needed by `_depend'. Stop". What's wrong with it? Thanks.
Steven Woody wrote:
This will usually occur when the path for toolchain (for u-boot , I feel it is uclibc ) used is not properly set in PC environment variables.Doing this should solve this issue.
Babu
-- woody
then sun rose thinly from the sea and the old man could see the other boats, low on the water and well in toward the shore, spread out across the current.
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Does anyone know the problem? I need you help.
In message ed4892840805140612i18303b75mb01d943bbeb99713@mail.gmail.com you wrote:
You are aware that U-Boot 1.2.0 is pretty old, aren't you? Is there any pressing reason not to use current code instead?
Except for some warnings, it builds fine here:
-> cd /tmp/u-boot-1.2.0 -> echo $CROSS_COMPILE arm-linux- -> arm-linux-gcc -v Reading specs from /opt/eldk-4.1/usr/bin/../lib/gcc/arm-linux/4.0.0/specs Target: arm-linux Configured with: /opt/eldk/build/arm-2007-01-21/work/usr/src/denx/BUILD/crosstool-0.35/build/gcc-4.0.0-glibc-2.3.5-eldk/arm-linux/gcc-4.0.0/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/var/tmp/eldk.bMi2nK/usr/crosstool/gcc-4.0.0-glibc-2.3.5-eldk/arm-linux --with-headers=/var/tmp/eldk.bMi2nK/usr/crosstool/gcc-4.0.0-glibc-2.3.5-eldk/arm-linux/arm-linux/include --with-local-prefix=/var/tmp/eldk.bMi2nK/usr/crosstool/gcc-4.0.0-glibc-2.3.5-eldk/arm-linux/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long --enable-__cxa_atexit Thread model: posix gcc version 4.0.0 (DENX ELDK 4.1 4.0.0) -> ./MAKEALL sbc2410x Configuring for sbc2410x board... In file included from sbc2410x.c:32: /tmp/u-boot-1.2.0/include/s3c2410.h:73: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:77: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:81: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:85: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:89: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:93: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:97: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:101: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:105: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:109: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:113: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:117: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:121: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:125: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:129: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:133: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:137: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:141: warning: type qualifiers ignored on function return type flash.c:292: warning: type qualifiers ignored on function return type In file included from interrupts.c:39: /tmp/u-boot-1.2.0/include/s3c2410.h:73: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:77: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:81: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:85: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:89: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:93: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:97: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:101: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:105: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:109: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:113: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:117: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:121: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:125: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:129: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:133: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:137: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:141: warning: type qualifiers ignored on function return type In file included from serial.c:27: /tmp/u-boot-1.2.0/include/s3c2410.h:73: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:77: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:81: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:85: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:89: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:93: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:97: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:101: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:105: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:109: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:113: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:117: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:121: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:125: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:129: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:133: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:137: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:141: warning: type qualifiers ignored on function return type In file included from speed.c:38: /tmp/u-boot-1.2.0/include/s3c2410.h:73: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:77: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:81: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:85: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:89: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:93: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:97: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:101: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:105: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:109: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:113: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:117: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:121: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:125: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:129: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:133: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:137: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:141: warning: type qualifiers ignored on function return type In file included from s3c24x0_rtc.c:36: /tmp/u-boot-1.2.0/include/s3c2410.h:73: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:77: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:81: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:85: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:89: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:93: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:97: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:101: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:105: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:109: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:113: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:117: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:121: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:125: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:129: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:133: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:137: warning: type qualifiers ignored on function return type /tmp/u-boot-1.2.0/include/s3c2410.h:141: warning: type qualifiers ignored on function return type text data bss dec hex filename 102787 3904 23844 130535 1fde7 ./u-boot ->
The problem must be on your side, as already suggested.
Dear Denk,
1.2.0 is come frome eldk-4.1 iso file. Downloading independent u-boot seems require `git' tool which I get problem with because my office network gets many limits. Is there a http way to download u-boot?
For 1.2.0 building, I made error because I don't set $CROSS_COMPILE, it's my fault. I will try your method tomorrow. Thank you very much!
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The night sky over the planet Krikkit is the least interesting sight in the entire Universe. - Douglas Adams _Life, the Universe, and Everything_
On Thu, 15 May 2008 01:49:50 +0800 "Steven Woody" narkewoody@gmail.com wrote:
Dear Denk,
git clone http://git.denx.de/u-boot.git
Kim
Steven,
A: Because it messes up the order in which people normally read text.
Q: Why is it such a bad thing?
A: Top-posting.
Q: What is the most annoying thing on usenet and in e-mail?
And you not only top-post, you also full-quote.
You are ignoring Netiquette more or less completely, are you aware of this?
I think you should read http://www.netmeister.org/news/learn2quote.html really carefully.
In message ed4892840805141049v3f7b2828w6d5ee74cf1923e09@mail.gmail.com you wrote:
If you bothered to read the documentation or tyhe U-Boot web pages you should have seen the links to the FTP site, and you should have read about the snapshot feature of git.
Please see http://www.denx.de/wiki/UBoot/SourceCode
On Thu, May 15, 2008 at 2:49 AM, Wolfgang Denk wd@denx.de wrote:
Steven,
A: Top-posting.
I am so sorry, I don't intent to do it. You know email clients ...
I am now downloading the 1.3.3-rc3 in home and will take it to my office. When I in office, I see the ftp link mentioned in the manul, just I cann't touch it because the firewall. Sorry about that. I will go proceed to compile 1.3.3-rc3 anyway. Thanks.
Kim Phillips
Steven Woody
ubootnovice
