[U-Boot] Pull request: u-boot-riscv/master
Hi Tom,
Please pull some riscv updates:
- Fix sifive serial y-modem transfer. - Access CSRs using CSR numbers. - Update doc sifive-fu540 - Support big endian hosts and target. - Support SPL and OpenSBI (FW_DYNAMIC firmware) boot.
https://travis-ci.org/rickchen36/u-boot-riscv/builds/570682542
Thanks Rick
The following changes since commit feb5a02f869d5678190dfc915ef6c2781b4f7a6c:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2019-08-10 17:57:58 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 30c150bae4e3a61f87a159579cd3784f4d64e79e:
riscv: qemu: Fix kconfig build warning (2019-08-12 13:30:53 +0800)
---------------------------------------------------------------- Anup Patel (1): doc: sifive-fu540: Update README to explicitly load DTB for Linux
Bin Meng (3): riscv: Sync csr.h with Linux kernel v5.2 riscv: Access CSRs using CSR numbers riscv: qemu: Fix kconfig build warning
Lukas Auer (10): fdtdec: make CONFIG_OF_PRIOR_STAGE available in SPL Makefile: support building SPL FIT images without device trees spl: fit: use U-Boot device tree when FIT image has no device tree riscv: add run mode configuration for SPL riscv: add SPL support riscv: support SPL stack and global data relocation riscv: add a generic FIT generator script riscv: set default FIT generator script and build target for SPL builds riscv: qemu: add SPL configuration doc: update QEMU RISC-V documentation
Marcus Comstedt (2): riscv: tools: Fix prelink-riscv to work on big endian hosts riscv: tools: Add big endian target support to prelink-riscv
Sagar Shrikant Kadam (1): riscv : serial: use rx watermark to indicate rx data is present
Kconfig | 4 +- Makefile | 8 ++- arch/Kconfig | 6 ++ arch/riscv/Kconfig | 36 ++++++++-- arch/riscv/cpu/ax25/Kconfig | 6 +- arch/riscv/cpu/cpu.c | 15 ++--- arch/riscv/cpu/generic/Kconfig | 5 +- arch/riscv/cpu/start.S | 65 ++++++++++++++++-- arch/riscv/cpu/u-boot-spl.lds | 82 +++++++++++++++++++++++ arch/riscv/include/asm/asm.h | 68 +++++++++++++++++++ arch/riscv/include/asm/csr.h | 74 ++++++++++++++++----- arch/riscv/include/asm/encoding.h | 240 +----------------------------------------------------------------- arch/riscv/include/asm/spl.h | 31 +++++++++ arch/riscv/lib/Makefile | 8 ++- arch/riscv/lib/mkimage_fit_opensbi.sh | 100 ++++++++++++++++++++++++++++ arch/riscv/lib/spl.c | 48 ++++++++++++++ board/emulation/qemu-riscv/Kconfig | 11 ++++ board/emulation/qemu-riscv/MAINTAINERS | 2 + board/emulation/qemu-riscv/qemu-riscv.c | 17 +++++ common/spl/spl.c | 2 +- common/spl/spl_fit.c | 37 +++++++---- configs/qemu-riscv32_spl_defconfig | 11 ++++ configs/qemu-riscv64_spl_defconfig | 12 ++++ doc/board/emulation/qemu-riscv.rst | 60 ++++++++++++++++- doc/board/sifive/fu540.rst | 396 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------------ drivers/serial/serial_sifive.c | 23 ++----- include/configs/qemu-riscv.h | 14 ++++ include/fdtdec.h | 2 +- lib/fdtdec.c | 6 +- tools/prelink-riscv.c | 39 ++++++++--- tools/prelink-riscv.inc | 60 +++++++++-------- 31 files changed, 962 insertions(+), 526 deletions(-) create mode 100644 arch/riscv/cpu/u-boot-spl.lds create mode 100644 arch/riscv/include/asm/asm.h create mode 100644 arch/riscv/include/asm/spl.h create mode 100755 arch/riscv/lib/mkimage_fit_opensbi.sh create mode 100644 arch/riscv/lib/spl.c create mode 100644 configs/qemu-riscv32_spl_defconfig create mode 100644 configs/qemu-riscv64_spl_defconfig
On Mon, Aug 12, 2019 at 06:23:02PM +0800, uboot@andestech.com wrote:
Hi Tom,
Thanks Rick
There is some change in here that is reliably causing this job to fail, please investigate: https://gitlab.denx.de/u-boot/u-boot/-/jobs/5493
uboot@andestech.com
