[U-Boot] [PATCH] net: explicitly assign errno to return code in case of network failure
When dealing with two ethernet ports and having "netretry" set to "once", it could occur that the connection (e.g. an ARP request) failed, hence the status of the netloop was "NETLOOP_FAIL". Due to the setting of "netretry", the network logic would then switch to the other network interface, assigning "ret" with the return value of "net_start_again()". If this call succeeded we would return 0 (i.e. success) to the caller when in reality the network action failed.
Change-Id: I58b935b0f6c7a300d1dd0058803f7d3c9455b0dc Signed-off-by: Thomas RIENOESSL thomas.rienoessl@bachmann.info --- net/net.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/net/net.c b/net/net.c index 31cf306ae7..568ba74f78 100644 --- a/net/net.c +++ b/net/net.c @@ -657,6 +657,7 @@ restart: /* Invalidate the last protocol */ eth_set_last_protocol(BOOTP); debug_cond(DEBUG_INT_STATE, "--- net_loop Fail!\n"); + ret = -ENONET; goto done;
case NETLOOP_CONTINUE:
Am Mi., 21. Nov. 2018 um 15:57 Uhr schrieb Thomas RIENOESSL thomas.rienoessl@bachmann.info:
Looks good - Gerrit change id should be removed before pushing this patch.
Reviewed-by: Christian Gmeiner christian.gmeiner@gmail.com
ret = -ENONET; goto done; case NETLOOP_CONTINUE:
-- 2.19.1
Am Di., 27. Nov. 2018 um 21:06 Uhr schrieb Christian Gmeiner christian.gmeiner@gmail.com:
ping
On Wed, Nov 21, 2018 at 8:57 AM Thomas RIENOESSL thomas.rienoessl@bachmann.info wrote:
Apologies for the delay.
Hi Thomas,
https://patchwork.ozlabs.org/patch/1001188/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Christian Gmeiner
Joe Hershberger
Thomas RIENOESSL
