[U-Boot] [PATCHv2 1/2] configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMAT
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set.
Signed-off-by: Tom Rini trini@konsulko.com --- Kconfig | 4 ++-- arch/arm/mach-imx/hab.c | 2 +- cmd/bootm.c | 6 +++--- cmd/disk.c | 4 ++-- cmd/fdc.c | 4 ++-- cmd/fpga.c | 2 +- cmd/nand.c | 4 ++-- cmd/source.c | 4 ++-- cmd/ximg.c | 6 +++--- common/bootm.c | 8 ++++---- common/image-fdt.c | 6 +++--- common/image.c | 10 +++++----- configs/bcm963158_ram_defconfig | 2 +- configs/bcm968580xref_ram_defconfig | 2 +- configs/gardena-smart-gateway-mt7688-ram_defconfig | 2 +- configs/gardena-smart-gateway-mt7688_defconfig | 2 +- configs/ids8313_defconfig | 2 +- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_mipi_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 2 +- configs/imx6ul_geam_mmc_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_emmc_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/linkit-smart-7688-ram_defconfig | 2 +- configs/linkit-smart-7688_defconfig | 2 +- configs/syzygy_hub_defconfig | 2 +- configs/xilinx_versal_mini_defconfig | 2 +- configs/xilinx_zynqmp_mini_defconfig | 2 +- configs/xilinx_zynqmp_mini_qspi_defconfig | 2 +- configs/zynq_cc108_defconfig | 2 +- configs/zynq_dlc20_rev1_0_defconfig | 2 +- configs/zynq_microzed_defconfig | 2 +- configs/zynq_z_turn_defconfig | 2 +- configs/zynq_zc702_defconfig | 2 +- configs/zynq_zc706_defconfig | 2 +- configs/zynq_zc770_xm010_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm011_x16_defconfig | 2 +- configs/zynq_zc770_xm012_defconfig | 2 +- configs/zynq_zc770_xm013_defconfig | 2 +- configs/zynq_zed_defconfig | 2 +- configs/zynq_zybo_defconfig | 2 +- configs/zynq_zybo_z7_defconfig | 2 +- doc/uImage.FIT/signature.txt | 2 +- include/image.h | 2 +- 49 files changed, 67 insertions(+), 67 deletions(-)
diff --git a/Kconfig b/Kconfig index 5f5c5ccfd6b6..cb67d183e339 100644 --- a/Kconfig +++ b/Kconfig @@ -317,7 +317,7 @@ config FIT_SIGNATURE check the legacy image format is disabled by default, so that unsigned images cannot be loaded. If a board needs the legacy image format support in this case, enable it using - CONFIG_IMAGE_FORMAT_LEGACY. + CONFIG_LEGACY_IMAGE_FORMAT.
config FIT_SIGNATURE_MAX_SIZE hex "Max size of signed FIT structures" @@ -446,7 +446,7 @@ endif # SPL
endif # FIT
-config IMAGE_FORMAT_LEGACY +config LEGACY_IMAGE_FORMAT bool "Enable support for the legacy image format" default y if !FIT_SIGNATURE help diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index d42a15e8772a..632237ee2a8c 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -310,7 +310,7 @@ static ulong get_image_ivt_offset(ulong img_addr)
buf = map_sysmem(img_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: return (image_get_image_size((image_header_t *)img_addr) + 0x1000 - 1) & ~(0x1000 - 1); diff --git a/cmd/bootm.c b/cmd/bootm.c index c3a063474ac6..41b341e2e538 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -249,7 +249,7 @@ static int image_info(ulong addr) printf("\n## Checking Image at %08lx ...\n", addr);
switch (genimg_get_format(hdr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: puts(" Legacy image found\n"); if (!image_check_magic(hdr)) { @@ -337,7 +337,7 @@ static int do_imls_nor(void) goto next_sector;
switch (genimg_get_format(hdr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: if (!image_check_hcrc(hdr)) goto next_sector; @@ -485,7 +485,7 @@ static int do_imls_nand(void) }
switch (genimg_get_format(buffer)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: header = (const image_header_t *)buffer;
diff --git a/cmd/disk.c b/cmd/disk.c index dcc36a6c2cb7..9e635c1172de 100644 --- a/cmd/disk.c +++ b/cmd/disk.c @@ -15,7 +15,7 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, ulong addr = CONFIG_SYS_LOAD_ADDR; ulong cnt; disk_partition_t info; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) image_header_t *hdr; #endif struct blk_desc *dev_desc; @@ -62,7 +62,7 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, bootstage_mark(BOOTSTAGE_ID_IDE_PART_READ);
switch (genimg_get_format((void *) addr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *) addr;
diff --git a/cmd/fdc.c b/cmd/fdc.c index 906845d4049b..7bfaae0e381a 100644 --- a/cmd/fdc.c +++ b/cmd/fdc.c @@ -634,7 +634,7 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) FD_GEO_STRUCT *pFG = (FD_GEO_STRUCT *)floppy_type; FDC_COMMAND_STRUCT *pCMD = &cmd; unsigned long addr,imsize; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) image_header_t *hdr; /* used for fdc boot */ #endif unsigned char boot_drive; @@ -690,7 +690,7 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
switch (genimg_get_format ((void *)addr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *)addr; image_print_contents (hdr); diff --git a/cmd/fpga.c b/cmd/fpga.c index b1f224bc6ad2..bc48abdd6d89 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -280,7 +280,7 @@ static int do_fpga_loadmk(cmd_tbl_t *cmdtp, int flag, int argc, }
switch (genimg_get_format(fpga_data)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: { image_header_t *hdr = (image_header_t *)fpga_data; diff --git a/cmd/nand.c b/cmd/nand.c index a22945d144b3..899d50453375 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -846,7 +846,7 @@ static int nand_load_image(cmd_tbl_t *cmdtp, struct mtd_info *mtd, int r; char *s; size_t cnt; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) image_header_t *hdr; #endif #if defined(CONFIG_FIT) @@ -874,7 +874,7 @@ static int nand_load_image(cmd_tbl_t *cmdtp, struct mtd_info *mtd, bootstage_mark(BOOTSTAGE_ID_NAND_HDR_READ);
diff --git a/cmd/source.c b/cmd/source.c index 6d98a1cfd32b..1a9a71aa3748 100644 --- a/cmd/source.c +++ b/cmd/source.c @@ -44,7 +44,7 @@ int source (ulong addr, const char *fit_uname) { ulong len; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) const image_header_t *hdr; #endif u32 *data; @@ -61,7 +61,7 @@ source (ulong addr, const char *fit_uname)
buf = map_sysmem(addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: hdr = buf;
diff --git a/cmd/ximg.c b/cmd/ximg.c index 32bfae8b22be..9e53cc45572f 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -35,7 +35,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) ulong data, len; int verify; int part = 0; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) ulong count; image_header_t *hdr = NULL; #endif @@ -67,7 +67,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) }
switch (genimg_get_format((void *)addr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY:
printf("## Copying part %d from legacy image " @@ -217,7 +217,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) } break; #endif -#if defined(CONFIG_BZIP2) && defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_BZIP2) && defined(CONFIG_LEGACY_IMAGE_FORMAT) case IH_COMP_BZIP2: { int i; diff --git a/common/bootm.c b/common/bootm.c index d19375164784..bea516025fde 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -98,7 +98,7 @@ static int bootm_find_os(cmd_tbl_t *cmdtp, int flag, int argc,
/* get image parameters */ switch (genimg_get_format(os_hdr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: images.os.type = image_get_type(os_hdr); images.os.comp = image_get_comp(os_hdr); @@ -738,7 +738,7 @@ err: return ret; }
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) /** * image_get_kernel - verify legacy format kernel image * @img_addr: in RAM address of the legacy format image to be verified @@ -807,7 +807,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) image_header_t *hdr; #endif ulong img_addr; @@ -828,7 +828,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, *os_data = *os_len = 0; buf = map_sysmem(img_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: printf("## Booting kernel from Legacy Image at %08lx ...\n", img_addr); diff --git a/common/image-fdt.c b/common/image-fdt.c index eb552ca207ca..e70da3dcb33a 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -33,7 +33,7 @@ static void fdt_error(const char *msg) puts(" - must RESET the board to recover.\n"); }
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) static const image_header_t *image_get_fdt(ulong fdt_addr) { const image_header_t *fdt_hdr = map_sysmem(fdt_addr, 0); @@ -263,7 +263,7 @@ error: int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, bootm_headers_t *images, char **of_flat_tree, ulong *of_size) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) const image_header_t *fdt_hdr; ulong load, load_end; ulong image_start, image_data, image_end; @@ -344,7 +344,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, */ buf = map_sysmem(fdt_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: /* verify fdt_addr points to a valid image header */ printf("## Flattened Device Tree from Legacy Image at %08lx\n", diff --git a/common/image.c b/common/image.c index 75b84d50091d..9f9538fac2fa 100644 --- a/common/image.c +++ b/common/image.c @@ -38,7 +38,7 @@ extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, int verify); #endif @@ -377,7 +377,7 @@ void image_print_contents(const void *ptr)
#ifndef USE_HOSTCC -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) /** * image_get_ramdisk - get and verify ramdisk image * @rd_addr: ramdisk image start address @@ -867,7 +867,7 @@ ulong genimg_get_kernel_addr(char * const img_addr) */ int genimg_get_format(const void *img_addr) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) const image_header_t *hdr;
hdr = (const image_header_t *)img_addr; @@ -933,7 +933,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, { ulong rd_addr, rd_load; ulong rd_data, rd_len; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) const image_header_t *rd_hdr; #endif void *buf; @@ -1025,7 +1025,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, */ buf = map_sysmem(rd_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) case IMAGE_FORMAT_LEGACY: printf("## Loading init Ramdisk from Legacy " "Image at %08lx ...\n", rd_addr); diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index dfd69069c7c5..5eafbaaa5a66 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -12,7 +12,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index d331e4e807f9..49731ee230f1 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -10,7 +10,7 @@ CONFIG_TPL_SYS_MALLOC_F_LEN=0x400 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index e09950637ff9..538498103f98 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -8,7 +8,7 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="cp.b 83000000 84000000 10000 && dhcp uEnv.txt && env import -t ${fileaddr} ${filesize} && run do_u_boot_init; reset" diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index ad0db2e7235d..d654f7fb5165 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -11,7 +11,7 @@ CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="cp.b 83000000 84000000 10000 && dhcp uEnv.txt && env import -t ${fileaddr} ${filesize} && run do_u_boot_init; reset" diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index d9b1642671a8..40ad4b74327d 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -78,7 +78,7 @@ CONFIG_ACR_PIPE_DEP_4=y CONFIG_ACR_RPTCNT_4=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=1 diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index f282064fc7fa..7b09d92638c0 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index d39fd957a383..4ae74a6bf5bb 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -13,7 +13,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 8704006ae710..983910f3f57e 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -18,7 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index e92f1be484fe..5a96f46cc563 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -18,7 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index ad4b930a3902..6614221e2f14 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -12,7 +12,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 83b926b699c6..59b67aa5ee79 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -15,7 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 318628b1a071..9507a1159386 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -14,7 +14,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index ea4d7ad72447..f4c8066b47dc 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -12,7 +12,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 00c9bbd85939..b6194eb7c5ef 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -14,7 +14,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index c60bde7cb7ab..7efa72eefdc2 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -12,7 +12,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index c2502b27139d..844a31fef7f1 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -8,7 +8,7 @@ CONFIG_MIPS_BOOT_FDT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index fba1bfd653cb..b4ef818ae868 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -11,7 +11,7 @@ CONFIG_MIPS_BOOT_FDT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 5616b3e23ac7..b05c8d930d92 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -13,7 +13,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Zynq> " diff --git a/configs/xilinx_versal_mini_defconfig b/configs/xilinx_versal_mini_defconfig index 19fac9012219..012ba3ebbebf 100644 --- a/configs/xilinx_versal_mini_defconfig +++ b/configs/xilinx_versal_mini_defconfig @@ -8,7 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_MALLOC_LEN=0x2000 CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_COUNTER_FREQUENCY=2720000 -# CONFIG_IMAGE_FORMAT_LEGACY is not set +# CONFIG_LEGACY_IMAGE_FORMAT is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index aa9dd230b5f0..93fa7d8f6bdc 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -7,7 +7,7 @@ CONFIG_ENV_SIZE=0x80 CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set -# CONFIG_IMAGE_FORMAT_LEGACY is not set +# CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_CMDLINE_EDITING is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index d3cc85117627..b0bc84d55eca 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -11,7 +11,7 @@ CONFIG_ZYNQMP_NO_DDR=y # CONFIG_PSCI_RESET is not set # CONFIG_CMD_ZYNQMP is not set # CONFIG_EXPERT is not set -# CONFIG_IMAGE_FORMAT_LEGACY is not set +# CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_TEXT_BASE=0xfffc0000 diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig index 966bb150d16f..e8116065767a 100644 --- a/configs/zynq_cc108_defconfig +++ b/configs/zynq_cc108_defconfig @@ -11,7 +11,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_PROMPT="Zynq> " diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index f9d2b31aacfa..15c6ebb666a5 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -12,7 +12,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 5e7ff1666e23..fe0f496e8073 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -8,7 +8,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index 4839ee238fc1..19d27da17b74 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -11,7 +11,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 71559b09b075..bd16925c42f3 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -12,7 +12,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 132ef6c0d75b..de1c41ff52ac 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -14,7 +14,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_FPGA_SUPPORT=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 8ba35cb98309..57203c1d2bd5 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -12,7 +12,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 84f46a79244c..1f2ce0c61a53 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -13,7 +13,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Zynq> " diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 43ff1f4d16c1..559e2f4c51a1 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -13,7 +13,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Zynq> " diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 2adf6868814c..2d93b64f80bb 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -10,7 +10,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="Zynq> " diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index ed6506d1ca5e..e4c724e5f4a0 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -10,7 +10,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 2da6d40b49fc..dd0328124a2f 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -11,7 +11,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index b51272b354b1..13e6146fca0a 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -11,7 +11,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index 4deb14eefa27..1bf069c540e2 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -11,7 +11,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index bfff6fdc7334..78b59e7203fb 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -335,7 +335,7 @@ CONFIG_RSA - enable RSA algorithm for signing
WARNING: When relying on signed FIT images with required signature check the legacy image format is default disabled by not defining -CONFIG_IMAGE_FORMAT_LEGACY +CONFIG_LEGACY_IMAGE_FORMAT
Testing ------- diff --git a/include/image.h b/include/image.h index bb7089ef5d16..5f8219495131 100644 --- a/include/image.h +++ b/include/image.h @@ -561,7 +561,7 @@ int boot_get_setup(bootm_headers_t *images, uint8_t arch, ulong *setup_start, #ifndef USE_HOSTCC /* Image format types, returned by _get_format() routine */ #define IMAGE_FORMAT_INVALID 0x00 -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if defined(CONFIG_LEGACY_IMAGE_FORMAT) #define IMAGE_FORMAT_LEGACY 0x01 /* legacy image_header based format */ #endif #define IMAGE_FORMAT_FIT 0x02 /* new, libfdt based format */
When we have a FIT image being used by SPL by default that means the most common case is that we'll never run into a legacy image. Disable legacy image support by default in that case to reclaim space.
Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index c7cd34449a52..55dba0d42069 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -101,7 +101,7 @@ config SPL_RAW_IMAGE_SUPPORT
config SPL_LEGACY_IMAGE_SUPPORT bool "Support SPL loading and booting of Legacy images" - default y if !TI_SECURE_DEVICE + default y if !TI_SECURE_DEVICE && !SPL_LOAD_FIT help SPL will support loading and booting Legacy images when this option is y. If this is not set, SPL will move on to other available
- default y if !TI_SECURE_DEVICE && !SPL_LOAD_FIT help SPL will support loading and booting Legacy images when this option is y. If this is not set, SPL will move on to other available
reviewed-by and tested-by : Jean-Jacques Hiblot jjhiblot@ti.com
Building for arm, the reduction in size is around 50 bytes
JJ
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index c7cd34449a52..55dba0d42069 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -101,7 +101,7 @@ config SPL_RAW_IMAGE_SUPPORT config SPL_LEGACY_IMAGE_SUPPORT bool "Support SPL loading and booting of Legacy images"
Thanks!
Yup, with gcc-7.3, on the platforms that set SPL_LOAD_FIT it's generally an 84 bytes savings on aarch64 and 40 bytes on arm32.
Jean-Jacques Hiblot
