[U-Boot] [PATCH 0/3 v4] devkit3250: add Timll DevKit3250 board initial support
This patchset adds generic NXP LPC32XX SoC support and basic support for Embest/Timll DevKit3250 board, which powered by this SoC.
The patchset is done on top of u-boot/master branch. The general difference of this resent series from the previous ones is that high speed UART driver was added into support.
Changes from v3 to v4 * rebase on recent arm-next branch * add get_ticks() function * update boards.cfg context
Changes from v2 to v3 * renamed register structures from *_t to *_regs * renamed clkpwr.c file to clk.c * fixed bi_boot_params initialization * applied some cosmetic fixes
Changes from v1 to v2: * setbits_le32() and similar helpers are used * added general arch_cpu_init() routine
Vladimir Zapolskiy (3): arm926ejs: add NXP LPC32x0 cpu series support serial: add LPC32X0 high-speed UART devices support devkit3250: add Timll DevKit3250 board initial support
MAINTAINERS | 4 + arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 45 +++++++ arch/arm/cpu/arm926ejs/lpc32xx/clk.c | 117 +++++++++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 70 ++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 52 ++++++++ arch/arm/cpu/arm926ejs/lpc32xx/timer.c | 95 ++++++++++++++ arch/arm/include/asm/arch-lpc32xx/clk.h | 170 +++++++++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/config.h | 76 +++++++++++ arch/arm/include/asm/arch-lpc32xx/cpu.h | 64 +++++++++ arch/arm/include/asm/arch-lpc32xx/emc.h | 92 +++++++++++++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 25 ++++ arch/arm/include/asm/arch-lpc32xx/timer.h | 74 +++++++++++ arch/arm/include/asm/arch-lpc32xx/uart.h | 114 +++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/wdt.h | 51 ++++++++ board/timll/devkit3250/Makefile | 44 +++++++ board/timll/devkit3250/devkit3250.c | 65 ++++++++++ boards.cfg | 1 + drivers/serial/Makefile | 1 + drivers/serial/lpc32xx_hsuart.c | 112 ++++++++++++++++ include/configs/devkit3250.h | 117 +++++++++++++++++ 20 files changed, 1389 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/clk.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/devices.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/timer.c create mode 100644 arch/arm/include/asm/arch-lpc32xx/clk.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/config.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/cpu.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/emc.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/sys_proto.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/timer.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/uart.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/wdt.h create mode 100644 board/timll/devkit3250/Makefile create mode 100644 board/timll/devkit3250/devkit3250.c create mode 100644 drivers/serial/lpc32xx_hsuart.c create mode 100644 include/configs/devkit3250.h
This change adds initial support for NXP LPC32x0 SoC series.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Acked-by: Marek Vasut marek.vasut@gmail.com --- Changes from v8 to v9: * add get_ticks() function
Changes from v7 to v8: * renamed register structures from *_t to *_regs * renamed clkpwr.c file to clk.c * fixed several macro definitions * various cosmetic fixes
Changes from v6 to v7: * get use of setbits_le32() and friends * add arch_cpu_init() routine
Changes from v5 to v6: * replaced some spaces with tabs in macro declarations * more rules separating 14-clock and ns16650 UARTs in config.h
Changes from v4 to v5: * corrected address in GPLv2+ licence header in files
Changes from v3 to v4: * extended memory controller definitions are introduced * added print_cpuinfo() function
Changes from v2 to v3: * checkpatch.pl reports zero errors and warnings
Changes from v1 to v2: * BIT(n) and SBF(s, v) macro are not used anymore * removed NS16550 and 14-clock UART definitions from uart.h * added devices.c file, which contains standard UART preinitialization routine * added get_serial_clock() function, it returns actual frequency of UART clock * __udelay() realization is simplified, no need of interrupt handling
arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 45 +++++++ arch/arm/cpu/arm926ejs/lpc32xx/clk.c | 117 +++++++++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 70 ++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 52 ++++++++ arch/arm/cpu/arm926ejs/lpc32xx/timer.c | 95 ++++++++++++++ arch/arm/include/asm/arch-lpc32xx/clk.h | 170 +++++++++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/config.h | 76 +++++++++++ arch/arm/include/asm/arch-lpc32xx/cpu.h | 64 +++++++++ arch/arm/include/asm/arch-lpc32xx/emc.h | 92 +++++++++++++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 25 ++++ arch/arm/include/asm/arch-lpc32xx/timer.h | 74 +++++++++++ arch/arm/include/asm/arch-lpc32xx/uart.h | 54 ++++++++ arch/arm/include/asm/arch-lpc32xx/wdt.h | 51 ++++++++ 13 files changed, 985 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/clk.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/devices.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/timer.c create mode 100644 arch/arm/include/asm/arch-lpc32xx/clk.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/config.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/cpu.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/emc.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/sys_proto.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/timer.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/uart.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/wdt.h
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile new file mode 100644 index 0000000..ae1f0a5 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License +# as published by the Free Software Foundation; either version 2 +# of the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS = cpu.o clk.o devices.o timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/clk.c b/arch/arm/cpu/arm926ejs/lpc32xx/clk.c new file mode 100644 index 0000000..6f26d62 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/clk.c @@ -0,0 +1,117 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <div64.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/io.h> + +static struct clk_pm_regs *clk = (struct clk_pm_regs *)CLK_PM_BASE; + +unsigned int get_sys_clk_rate(void) +{ + if (readl(&clk->sysclk_ctrl) & CLK_SYSCLK_PLL397) + return RTC_CLK_FREQUENCY * 397; + else + return OSC_CLK_FREQUENCY; +} + +unsigned int get_hclk_pll_rate(void) +{ + unsigned long long fin, fref, fcco, fout; + u32 val, m_div, n_div, p_div; + + /* + * Valid frequency ranges: + * 1 * 10^6 <= Fin <= 20 * 10^6 + * 1 * 10^6 <= Fref <= 27 * 10^6 + * 156 * 10^6 <= Fcco <= 320 * 10^6 + */ + + fref = fin = get_sys_clk_rate(); + if (fin > 20000000ULL || fin < 1000000ULL) + return 0; + + val = readl(&clk->hclkpll_ctrl); + m_div = ((val & CLK_HCLK_PLL_FEEDBACK_DIV_MASK) >> 1) + 1; + n_div = ((val & CLK_HCLK_PLL_PREDIV_MASK) >> 9) + 1; + if (val & CLK_HCLK_PLL_DIRECT) + p_div = 0; + else + p_div = ((val & CLK_HCLK_PLL_POSTDIV_MASK) >> 11) + 1; + p_div = 1 << p_div; + + if (val & CLK_HCLK_PLL_BYPASS) { + do_div(fin, p_div); + return fin; + } + + do_div(fref, n_div); + if (fref > 27000000ULL || fref < 1000000ULL) + return 0; + + fout = fref * m_div; + if (val & CLK_HCLK_PLL_FEEDBACK) { + fcco = fout; + do_div(fout, p_div); + } else + fcco = fout * p_div; + + if (fcco > 320000000ULL || fcco < 156000000ULL) + return 0; + + return fout; +} + +unsigned int get_hclk_clk_div(void) +{ + u32 val; + + val = readl(&clk->hclkdiv_ctrl) & CLK_HCLK_ARM_PLL_DIV_MASK; + + return 1 << val; +} + +unsigned int get_hclk_clk_rate(void) +{ + return get_hclk_pll_rate() / get_hclk_clk_div(); +} + +unsigned int get_periph_clk_div(void) +{ + u32 val; + + val = readl(&clk->hclkdiv_ctrl) & CLK_HCLK_PERIPH_DIV_MASK; + + return (val >> 2) + 1; +} + +unsigned int get_periph_clk_rate(void) +{ + if (!(readl(&clk->pwr_ctrl) & CLK_PWR_NORMAL_RUN)) + return get_sys_clk_rate(); + + return get_hclk_pll_rate() / get_periph_clk_div(); +} + +int get_serial_clock(void) +{ + return get_periph_clk_rate(); +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c new file mode 100644 index 0000000..e29e130 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c @@ -0,0 +1,70 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/wdt.h> +#include <asm/io.h> + +static struct clk_pm_regs *clk = (struct clk_pm_regs *)CLK_PM_BASE; +static struct wdt_regs *wdt = (struct wdt_regs *)WDT_BASE; + +void reset_cpu(ulong addr) +{ + /* Enable watchdog clock */ + setbits_le32(&clk->timclk_ctrl, CLK_TIMCLK_WATCHDOG); + + /* Reset pulse length is 13005 peripheral clock frames */ + writel(13000, &wdt->pulse); + + /* Force WDOG_RESET2 and RESOUT_N signal active */ + writel(WDTIM_MCTRL_RESFRC2 | WDTIM_MCTRL_RESFRC1 | WDTIM_MCTRL_M_RES2, + &wdt->mctrl); + + while (1) + /* NOP */; +} + +#if defined(CONFIG_ARCH_CPU_INIT) +int arch_cpu_init(void) +{ + /* + * It might be necessary to flush data cache, if U-boot is loaded + * from kickstart bootloader, e.g. from S1L loader + */ + flush_dcache_all(); + + return 0; +} +#else +#error "You have to select CONFIG_ARCH_CPU_INIT" +#endif + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + printf("CPU: NXP LPC32XX\n"); + printf("CPU clock: %uMHz\n", get_hclk_pll_rate() / 1000000); + printf("AHB bus clock: %uMHz\n", get_hclk_clk_rate() / 1000000); + printf("Peripheral clock: %uMHz\n", get_periph_clk_rate() / 1000000); + + return 0; +} +#endif diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c new file mode 100644 index 0000000..9f305b5 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/uart.h> +#include <asm/io.h> + +static struct clk_pm_regs *clk = (struct clk_pm_regs *)CLK_PM_BASE; +static struct uart_ctrl_regs *ctrl = (struct uart_ctrl_regs *)UART_CTRL_BASE; + +void lpc32xx_uart_init(unsigned int uart_id) +{ + if (uart_id < 1 || uart_id > 7) + return; + + /* Disable loopback mode, if it is set by S1L bootloader */ + clrbits_le32(&ctrl->loop, + UART_LOOPBACK(CONFIG_SYS_LPC32XX_UART)); + + if (uart_id < 3 || uart_id > 6) + return; + + /* Enable UART system clock */ + setbits_le32(&clk->uartclk_ctrl, CLK_UART(uart_id)); + + /* Set UART into autoclock mode */ + clrsetbits_le32(&ctrl->clkmode, + UART_CLKMODE_MASK(uart_id), + UART_CLKMODE_AUTO(uart_id)); + + /* Bypass pre-divider of UART clock */ + writel(CLK_UART_X_DIV(1) | CLK_UART_Y_DIV(1), + &clk->u3clk + (uart_id - 3)); +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/timer.c b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c new file mode 100644 index 0000000..1ce2358 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/timer.h> +#include <asm/io.h> + +static struct timer_regs *timer0 = (struct timer_regs *)TIMER0_BASE; +static struct timer_regs *timer1 = (struct timer_regs *)TIMER1_BASE; +static struct clk_pm_regs *clk = (struct clk_pm_regs *)CLK_PM_BASE; + +static void lpc32xx_timer_clock(u32 bit, int enable) +{ + if (enable) + setbits_le32(&clk->timclk_ctrl1, bit); + else + clrbits_le32(&clk->timclk_ctrl1, bit); +} + +static void lpc32xx_timer_reset(struct timer_regs *timer, u32 freq) +{ + writel(TIMER_TCR_COUNTER_RESET, &timer->tcr); + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); + writel(0, &timer->tc); + writel(0, &timer->pr); + + /* Count mode is every rising PCLK edge */ + writel(TIMER_CTCR_MODE_TIMER, &timer->ctcr); + + /* Set prescale counter value */ + writel((get_periph_clk_rate() / freq) - 1, &timer->pr); +} + +static void lpc32xx_timer_count(struct timer_regs *timer, int enable) +{ + if (enable) + writel(TIMER_TCR_COUNTER_ENABLE, &timer->tcr); + else + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); +} + +int timer_init(void) +{ + lpc32xx_timer_clock(CLK_TIMCLK_TIMER0, 1); + lpc32xx_timer_reset(timer0, CONFIG_SYS_HZ); + lpc32xx_timer_count(timer0, 1); + + return 0; +} + +ulong get_timer(ulong base) +{ + return readl(&timer0->tc) - base; +} + +void __udelay(unsigned long usec) +{ + lpc32xx_timer_clock(CLK_TIMCLK_TIMER1, 1); + lpc32xx_timer_reset(timer1, CONFIG_SYS_HZ * 1000); + lpc32xx_timer_count(timer1, 1); + + while (readl(&timer1->tc) < usec) + /* NOP */; + + lpc32xx_timer_count(timer1, 0); + lpc32xx_timer_clock(CLK_TIMCLK_TIMER1, 0); +} + +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/include/asm/arch-lpc32xx/clk.h b/arch/arm/include/asm/arch-lpc32xx/clk.h new file mode 100644 index 0000000..c1dad0a --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/clk.h @@ -0,0 +1,170 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_CLK_H +#define _LPC32XX_CLK_H + +#include <asm/types.h> + +#define OSC_CLK_FREQUENCY 13000000 +#define RTC_CLK_FREQUENCY 32768 + +/* Clocking and Power Control Registers */ +struct clk_pm_regs { + u32 reserved0[5]; + u32 boot_map; /* Boot Map Control Register */ + u32 p0_intr_er; /* Port 0/1 Start and Interrupt Enable */ + u32 usbdiv_ctrl; /* USB Clock Pre-Divide Register */ + /* Internal Start Signal Sources Registers */ + u32 start_er_int; /* Start Enable Register */ + u32 start_rsr_int; /* Start Raw Status Register */ + u32 start_sr_int; /* Start Status Register */ + u32 start_apr_int; /* Start Activation Polarity Register */ + /* Device Pin Start Signal Sources Registers */ + u32 start_er_pin; /* Start Enable Register */ + u32 start_rsr_pin; /* Start Raw Status Register */ + u32 start_sr_pin; /* Start Status Register */ + u32 start_apr_pin; /* Start Activation Polarity Register */ + /* Clock Control Registers */ + u32 hclkdiv_ctrl; /* HCLK Divider Control Register */ + u32 pwr_ctrl; /* Power Control Register */ + u32 pll397_ctrl; /* PLL397 Control Register */ + u32 osc_ctrl; /* Main Oscillator Control Register */ + u32 sysclk_ctrl; /* SYSCLK Control Register */ + u32 lcdclk_ctrl; /* LCD Clock Control Register */ + u32 hclkpll_ctrl; /* HCLK PLL Control Register */ + u32 reserved1; + u32 adclk_ctrl1; /* ADC Clock Control1 Register */ + u32 usb_ctrl; /* USB Control Register */ + u32 sdramclk_ctrl; /* SDRAM Clock Control Register */ + u32 ddr_lap_nom; /* DDR Calibration Nominal Value */ + u32 ddr_lap_count; /* DDR Calibration Measured Value */ + u32 ddr_cal_delay; /* DDR Calibration Delay Value */ + u32 ssp_ctrl; /* SSP Control Register */ + u32 i2s_ctrl; /* I2S Clock Control Register */ + u32 ms_ctrl; /* Memory Card Control Register */ + u32 reserved2[3]; + u32 macclk_ctrl; /* Ethernet MAC Clock Control Register */ + u32 reserved3[4]; + u32 test_clk; /* Test Clock Selection Register */ + u32 sw_int; /* Software Interrupt Register */ + u32 i2cclk_ctrl; /* I2C Clock Control Register */ + u32 keyclk_ctrl; /* Keyboard Scan Clock Control Register */ + u32 adclk_ctrl; /* ADC Clock Control Register */ + u32 pwmclk_ctrl; /* PWM Clock Control Register */ + u32 timclk_ctrl; /* Watchdog and Highspeed Timer Control */ + u32 timclk_ctrl1; /* Motor and Timer Clock Control */ + u32 spi_ctrl; /* SPI Control Register */ + u32 flashclk_ctrl; /* NAND Flash Clock Control Register */ + u32 reserved4; + u32 u3clk; /* UART 3 Clock Control Register */ + u32 u4clk; /* UART 4 Clock Control Register */ + u32 u5clk; /* UART 5 Clock Control Register */ + u32 u6clk; /* UART 6 Clock Control Register */ + u32 irdaclk; /* IrDA Clock Control Register */ + u32 uartclk_ctrl; /* UART Clock Control Register */ + u32 dmaclk_ctrl; /* DMA Clock Control Register */ + u32 autoclk_ctrl; /* Autoclock Control Register */ +}; + +/* HCLK Divider Control Register bits */ +#define CLK_HCLK_DDRAM_HALF (0x2 << 7) +#define CLK_HCLK_DDRAM_NOMINAL (0x1 << 7) +#define CLK_HCLK_DDRAM_STOPPED (0x0 << 7) +#define CLK_HCLK_PERIPH_DIV_MASK (0x1F << 2) +#define CLK_HCLK_PERIPH_DIV(n) ((((n) - 1) & 0x1F) << 2) +#define CLK_HCLK_ARM_PLL_DIV_MASK (0x3 << 0) +#define CLK_HCLK_ARM_PLL_DIV_4 (0x2 << 0) +#define CLK_HCLK_ARM_PLL_DIV_2 (0x1 << 0) +#define CLK_HCLK_ARM_PLL_DIV_1 (0x0 << 0) + +/* Power Control Register bits */ +#define CLK_PWR_HCLK_RUN_PERIPH (1 << 10) +#define CLK_PWR_EMC_SREFREQ (1 << 9) +#define CLK_PWR_EMC_SREFREQ_UPDATE (1 << 8) +#define CLK_PWR_SDRAM_SREFREQ (1 << 7) +#define CLK_PWR_HIGHCORE_LEVEL (1 << 5) +#define CLK_PWR_SYSCLKEN_LEVEL (1 << 4) +#define CLK_PWR_SYSCLKEN_CTRL (1 << 3) +#define CLK_PWR_NORMAL_RUN (1 << 2) +#define CLK_PWR_HIGHCORE_CTRL (1 << 1) +#define CLK_PWR_STOP_MODE (1 << 0) + +/* SYSCLK Control Register bits */ +#define CLK_SYSCLK_PLL397 (1 << 1) +#define CLK_SYSCLK_MUX (1 << 0) + +/* HCLK PLL Control Register bits */ +#define CLK_HCLK_PLL_OPERATING (1 << 16) +#define CLK_HCLK_PLL_BYPASS (1 << 15) +#define CLK_HCLK_PLL_DIRECT (1 << 14) +#define CLK_HCLK_PLL_FEEDBACK (1 << 13) +#define CLK_HCLK_PLL_POSTDIV_MASK (0x3 << 11) +#define CLK_HCLK_PLL_POSTDIV_16 (0x3 << 11) +#define CLK_HCLK_PLL_POSTDIV_8 (0x2 << 11) +#define CLK_HCLK_PLL_POSTDIV_4 (0x1 << 11) +#define CLK_HCLK_PLL_POSTDIV_2 (0x0 << 11) +#define CLK_HCLK_PLL_PREDIV_MASK (0x3 << 9) +#define CLK_HCLK_PLL_PREDIV_4 (0x3 << 9) +#define CLK_HCLK_PLL_PREDIV_3 (0x2 << 9) +#define CLK_HCLK_PLL_PREDIV_2 (0x1 << 9) +#define CLK_HCLK_PLL_PREDIV_1 (0x0 << 9) +#define CLK_HCLK_PLL_FEEDBACK_DIV_MASK (0xFF << 1) +#define CLK_HCLK_PLL_FEEDBACK_DIV(n) ((((n) - 1) & 0xFF) << 1) +#define CLK_HCLK_PLL_LOCKED (1 << 0) + +/* Ethernet MAC Clock Control Register bits */ +#define CLK_MAC_RMII (0x3 << 3) +#define CLK_MAC_MII (0x1 << 3) +#define CLK_MAC_MASTER (1 << 2) +#define CLK_MAC_SLAVE (1 << 1) +#define CLK_MAC_REG (1 << 0) + +/* Timer Clock Control1 Register bits */ +#define CLK_TIMCLK_MOTOR (1 << 6) +#define CLK_TIMCLK_TIMER3 (1 << 5) +#define CLK_TIMCLK_TIMER2 (1 << 4) +#define CLK_TIMCLK_TIMER1 (1 << 3) +#define CLK_TIMCLK_TIMER0 (1 << 2) +#define CLK_TIMCLK_TIMER5 (1 << 1) +#define CLK_TIMCLK_TIMER4 (1 << 0) + +/* Timer Clock Control Register bits */ +#define CLK_TIMCLK_HSTIMER (1 << 1) +#define CLK_TIMCLK_WATCHDOG (1 << 0) + +/* UART Clock Control Register bits */ +#define CLK_UART(n) (1 << ((n) - 3)) + +/* UARTn Clock Select Registers bits */ +#define CLK_UART_HCLK (1 << 16) +#define CLK_UART_X_DIV(n) (((n) & 0xFF) << 8) +#define CLK_UART_Y_DIV(n) (((n) & 0xFF) << 0) + +/* DMA Clock Control Register bits */ +#define CLK_DMA_ENABLE (1 << 0) + +unsigned int get_sys_clk_rate(void); +unsigned int get_hclk_pll_rate(void); +unsigned int get_hclk_clk_div(void); +unsigned int get_hclk_clk_rate(void); +unsigned int get_periph_clk_div(void); +unsigned int get_periph_clk_rate(void); + +#endif /* _LPC32XX_CLK_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h new file mode 100644 index 0000000..41fcd32 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -0,0 +1,76 @@ +/* + * Common definitions for LPC32XX board configurations + * + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_CONFIG_H +#define _LPC32XX_CONFIG_H + +/* Basic CPU architecture */ +#define CONFIG_ARM926EJS +#define CONFIG_ARCH_CPU_INIT + +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +/* 1KHz clock tick */ +#define CONFIG_SYS_HZ 1000 + +/* UART configuration */ +#if (CONFIG_SYS_LPC32XX_UART >= 3) && (CONFIG_SYS_LPC32XX_UART <= 6) +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_CONS_INDEX (CONFIG_SYS_LPC32XX_UART - 2) +#elif (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ + (CONFIG_SYS_LPC32XX_UART == 7) +#define CONFIG_LPC32XX_HSUART +#else +#error "define CONFIG_SYS_LPC32XX_UART in the range from 1 to 7" +#endif + +#if defined(CONFIG_SYS_NS16550_SERIAL) +#define CONFIG_SYS_NS16550 + +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_CLK get_serial_clock() + +#define CONFIG_SYS_NS16550_COM1 UART3_BASE +#define CONFIG_SYS_NS16550_COM2 UART4_BASE +#define CONFIG_SYS_NS16550_COM3 UART5_BASE +#define CONFIG_SYS_NS16550_COM4 UART6_BASE +#endif + +#if defined(CONFIG_LPC32XX_HSUART) +#if CONFIG_SYS_LPC32XX_UART == 1 +#define HS_UART_BASE HS_UART1_BASE +#elif CONFIG_SYS_LPC32XX_UART == 2 +#define HS_UART_BASE HS_UART2_BASE +#else /* CONFIG_SYS_LPC32XX_UART == 7 */ +#define HS_UART_BASE HS_UART7_BASE +#endif +#endif + +#define CONFIG_SYS_BAUDRATE_TABLE \ + { 9600, 19200, 38400, 57600, 115200, 230400, 460800 } + +/* NOR Flash */ +#if defined(CONFIG_SYS_FLASH_CFI) +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_PROTECTION +#endif + +#endif /* _LPC32XX_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/cpu.h b/arch/arm/include/asm/arch-lpc32xx/cpu.h new file mode 100644 index 0000000..c5343c3 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/cpu.h @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_CPU_H +#define _LPC32XX_CPU_H + +/* LPC32XX Memory map */ + +/* AHB physical base addresses */ +#define SLC_NAND_BASE 0x20020000 /* SLC NAND Flash registers base */ +#define SSP0_BASE 0x20084000 /* SSP0 registers base */ +#define SD_CARD_BASE 0x20098000 /* SD card interface registers base */ +#define MLC_NAND_BASE 0x200A8000 /* MLC NAND Flash registers base */ +#define DMA_BASE 0x31000000 /* DMA controller registers base */ +#define USB_BASE 0x31020000 /* USB registers base */ +#define LCD_BASE 0x31040000 /* LCD registers base */ +#define ETHERNET_BASE 0x31060000 /* Ethernet registers base */ +#define EMC_BASE 0x31080000 /* EMC configuration registers base */ + +/* FAB peripherals base addresses */ +#define CLK_PM_BASE 0x40004000 /* System control registers base */ +#define HS_UART1_BASE 0x40014000 /* High speed UART 1 registers base */ +#define HS_UART2_BASE 0x40018000 /* High speed UART 2 registers base */ +#define HS_UART7_BASE 0x4001C000 /* High speed UART 7 registers base */ +#define RTC_BASE 0x40024000 /* RTC registers base */ +#define GPIO_BASE 0x40028000 /* GPIO registers base */ +#define WDT_BASE 0x4003C000 /* Watchdog timer registers base */ +#define TIMER0_BASE 0x40044000 /* Timer0 registers base */ +#define TIMER1_BASE 0x4004C000 /* Timer1 registers base */ +#define UART_CTRL_BASE 0x40054000 /* UART control regsisters base */ + +/* APB peripherals base addresses */ +#define UART3_BASE 0x40080000 /* UART 3 registers base */ +#define UART4_BASE 0x40088000 /* UART 4 registers base */ +#define UART5_BASE 0x40090000 /* UART 5 registers base */ +#define UART6_BASE 0x40098000 /* UART 6 registers base */ + +/* External SDRAM Memory Bank base addresses */ +#define EMC_DYCS0_BASE 0x80000000 /* SDRAM DYCS0 base address */ +#define EMC_DYCS1_BASE 0xA0000000 /* SDRAM DYCS1 base address */ + +/* External Static Memory Bank base addresses */ +#define EMC_CS0_BASE 0xE0000000 +#define EMC_CS1_BASE 0xE1000000 +#define EMC_CS2_BASE 0xE2000000 +#define EMC_CS3_BASE 0xE3000000 + +#endif /* _LPC32XX_CPU_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/emc.h b/arch/arm/include/asm/arch-lpc32xx/emc.h new file mode 100644 index 0000000..feb03bd --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/emc.h @@ -0,0 +1,92 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_EMC_H +#define _LPC32XX_EMC_H + +#include <asm/types.h> + +/* EMC Registers */ +struct emc_regs { + u32 ctrl; /* Controls operation of the EMC */ + u32 status; /* Provides EMC status information */ + u32 config; /* Configures operation of the EMC */ + u32 reserved0[5]; + u32 control; /* Controls dyn memory operation */ + u32 refresh; /* Configures dyn memory refresh operation */ + u32 read_config; /* Configures the dyn memory read strategy */ + u32 reserved1; + u32 t_rp; /* Precharge command period */ + u32 t_ras; /* Active to precharge command period */ + u32 t_srex; /* Self-refresh exit time */ + u32 reserved2[2]; + u32 t_wr; /* Write recovery time */ + u32 t_rc; /* Active to active command period */ + u32 t_rfc; /* Auto-refresh period */ + u32 t_xsr; /* Exit self-refresh to active command time */ + u32 t_rrd; /* Active bank A to active bank B latency */ + u32 t_mrd; /* Load mode register to active command time */ + u32 t_cdlr; /* Last data in to read command time */ + u32 reserved3[8]; + u32 extended_wait; /* time for static memory rd/wr transfers */ + u32 reserved4[31]; + u32 config0; /* Configuration information for the SDRAM */ + u32 rascas0; /* RAS and CAS latencies for the SDRAM */ + u32 reserved5[6]; + u32 config1; /* Configuration information for the SDRAM */ + u32 rascas1; /* RAS and CAS latencies for the SDRAM */ + u32 reserved6[54]; + struct emc_stat_t { + u32 config; /* Static memory configuration */ + u32 waitwen; /* Delay from chip select to write enable */ + u32 waitoen; /* Delay to output enable */ + u32 waitrd; /* Delay to a read access */ + u32 waitpage; /* Delay for async page mode read */ + u32 waitwr; /* Delay to a write access */ + u32 waitturn; /* Number of bus turnaround cycles */ + u32 reserved; + } stat[4]; + u32 reserved7[96]; + struct emc_ahb_t { + u32 control; /* Control register for AHB */ + u32 status; /* Status register for AHB */ + u32 timeout; /* Timeout register for AHB */ + u32 reserved[5]; + } ahb[5]; +}; + +/* Static Memory Configuration Register bits */ +#define EMC_STAT_CONFIG_WP (1 << 20) +#define EMC_STAT_CONFIG_EW (1 << 8) +#define EMC_STAT_CONFIG_PB (1 << 7) +#define EMC_STAT_CONFIG_PC (1 << 6) +#define EMC_STAT_CONFIG_PM (1 << 3) +#define EMC_STAT_CONFIG_32BIT (2 << 0) +#define EMC_STAT_CONFIG_16BIT (1 << 0) +#define EMC_STAT_CONFIG_8BIT (0 << 0) + +/* Static Memory Delay Registers */ +#define EMC_STAT_WAITWEN(n) (((n) - 1) & 0x0F) +#define EMC_STAT_WAITOEN(n) (((n) - 1) & 0x0F) +#define EMC_STAT_WAITRD(n) (((n) - 1) & 0x1F) +#define EMC_STAT_WAITPAGE(n) (((n) - 1) & 0x1F) +#define EMC_STAT_WAITWR(n) (((n) - 2) & 0x1F) +#define EMC_STAT_WAITTURN(n) (((n) - 1) & 0x0F) + +#endif /* _LPC32XX_EMC_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h new file mode 100644 index 0000000..b2cbfcd --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_SYS_PROTO_H +#define _LPC32XX_SYS_PROTO_H + +void lpc32xx_uart_init(unsigned int uart_id); + +#endif /* _LPC32XX_SYS_PROTO_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/timer.h b/arch/arm/include/asm/arch-lpc32xx/timer.h new file mode 100644 index 0000000..7d63763 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/timer.h @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_TIMER_H +#define _LPC32XX_TIMER_H + +#include <asm/types.h> + +/* Timer/Counter Registers */ +struct timer_regs { + u32 ir; /* Interrupt Register */ + u32 tcr; /* Timer Control Register */ + u32 tc; /* Timer Counter */ + u32 pr; /* Prescale Register */ + u32 pc; /* Prescale Counter */ + u32 mcr; /* Match Control Register */ + u32 mr[4]; /* Match Registers */ + u32 ccr; /* Capture Control Register */ + u32 cr[4]; /* Capture Registers */ + u32 emr; /* External Match Register */ + u32 reserved[12]; + u32 ctcr; /* Count Control Register */ +}; + +/* Timer/Counter Interrupt Register bits */ +#define TIMER_IR_CR(n) (1 << ((n) + 4)) +#define TIMER_IR_MR(n) (1 << (n)) + +/* Timer/Counter Timer Control Register bits */ +#define TIMER_TCR_COUNTER_RESET (1 << 1) +#define TIMER_TCR_COUNTER_ENABLE (1 << 0) +#define TIMER_TCR_COUNTER_DISABLE (0 << 0) + +/* Timer/Counter Match Control Register bits */ +#define TIMER_MCR_STOP(n) (1 << (3 * (n) + 2)) +#define TIMER_MCR_RESET(n) (1 << (3 * (n) + 1)) +#define TIMER_MCR_INTERRUPT(n) (1 << (3 * (n))) + +/* Timer/Counter Capture Control Register bits */ +#define TIMER_CCR_INTERRUPT(n) (1 << (3 * (n) + 2)) +#define TIMER_CCR_FALLING_EDGE(n) (1 << (3 * (n) + 1)) +#define TIMER_CCR_RISING_EDGE(n) (1 << (3 * (n))) + +/* Timer/Counter External Match Register bits */ +#define TIMER_EMR_EMC_TOGGLE(n) (0x3 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_SET(n) (0x2 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_CLEAR(n) (0x1 << (2 * (n) + 4)) +#define TIMER_EMR_EMC_NOTHING(n) (0x0 << (2 * (n) + 4)) +#define TIMER_EMR_EM(n) (1 << (n)) + +/* Timer/Counter Count Control Register bits */ +#define TIMER_CTCR_INPUT(n) ((n) << 2) +#define TIMER_CTCR_MODE_COUNTER_BOTH (0x3 << 0) +#define TIMER_CTCR_MODE_COUNTER_FALLING (0x2 << 0) +#define TIMER_CTCR_MODE_COUNTER_RISING (0x1 << 0) +#define TIMER_CTCR_MODE_TIMER (0x0 << 0) + +#endif /* _LPC32XX_TIMER_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/uart.h b/arch/arm/include/asm/arch-lpc32xx/uart.h new file mode 100644 index 0000000..b613df8 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/uart.h @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_UART_H +#define _LPC32XX_UART_H + +#include <asm/types.h> + +/* UART Control Registers */ +struct uart_ctrl_regs { + u32 ctrl; /* Control Register */ + u32 clkmode; /* Clock Mode Register */ + u32 loop; /* Loopback Control Register */ +}; + +/* UART Control Register bits */ +#define UART_CTRL_UART3_MD_CTRL (1 << 11) +#define UART_CTRL_HDPX_INV (1 << 10) +#define UART_CTRL_HDPX_EN (1 << 9) +#define UART_CTRL_UART6_IRDA (1 << 5) +#define UART_CTRL_IR_TX6_INV (1 << 4) +#define UART_CTRL_IR_RX6_INV (1 << 3) +#define UART_CTRL_IR_RX_LENGTH (1 << 2) +#define UART_CTRL_IR_TX_LENGTH (1 << 1) +#define UART_CTRL_UART5_USB_MODE (1 << 0) + +/* UART Clock Mode Register bits */ +#define UART_CLKMODE_STATX(n) (1 << ((n) + 16)) +#define UART_CLKMODE_STAT (1 << 14) +#define UART_CLKMODE_MASK(n) (0x3 << (2 * (n) - 2)) +#define UART_CLKMODE_AUTO(n) (0x2 << (2 * (n) - 2)) +#define UART_CLKMODE_ON(n) (0x1 << (2 * (n) - 2)) +#define UART_CLKMODE_OFF(n) (0x0 << (2 * (n) - 2)) + +/* UART Loopback Control Register bits */ +#define UART_LOOPBACK(n) (1 << ((n) - 1)) + +#endif /* _LPC32XX_UART_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/wdt.h b/arch/arm/include/asm/arch-lpc32xx/wdt.h new file mode 100644 index 0000000..133f29f --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/wdt.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef _LPC32XX_WDT_H +#define _LPC32XX_WDT_H + +#include <asm/types.h> + +/* Watchdog Timer Registers */ +struct wdt_regs { + u32 isr; /* Interrupt Status Register */ + u32 ctrl; /* Control Register */ + u32 counter; /* Counter Value Register */ + u32 mctrl; /* Match Control Register */ + u32 match0; /* Match 0 Register */ + u32 emr; /* External Match Control Register */ + u32 pulse; /* Reset Pulse Length Register */ + u32 res; /* Reset Source Register */ +}; + +/* Watchdog Timer Control Register bits */ +#define WDTIM_CTRL_PAUSE_EN (1 << 2) +#define WDTIM_CTRL_RESET_COUNT (1 << 1) +#define WDTIM_CTRL_COUNT_ENAB (1 << 0) + +/* Watchdog Timer Match Control Register bits */ +#define WDTIM_MCTRL_RESFRC2 (1 << 6) +#define WDTIM_MCTRL_RESFRC1 (1 << 5) +#define WDTIM_MCTRL_M_RES2 (1 << 4) +#define WDTIM_MCTRL_M_RES1 (1 << 3) +#define WDTIM_MCTRL_STOP_COUNT0 (1 << 2) +#define WDTIM_MCTRL_RESET_COUNT0 (1 << 1) +#define WDTIM_MCTRL_MR0_INT (1 << 0) + +#endif /* _LPC32XX_WDT_H */
This change adds an implementation of high-speed UART found on NXP LPC32X0 SoCs. Such UARTs are enumerated as UART1, UART2 and UART7.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Acked-by: Marek Vasut marek.vasut@gmail.com --- Changes from v2 to v3: * renamed struct hsuart_t to hsuart_regs
Changes from v1 to v2: * simplified lpc32xx_hsuart_init() a little * put SoC specific changes into patch 1/3
arch/arm/include/asm/arch-lpc32xx/uart.h | 60 ++++++++++++++++ drivers/serial/Makefile | 1 + drivers/serial/lpc32xx_hsuart.c | 112 ++++++++++++++++++++++++++++++ 3 files changed, 173 insertions(+), 0 deletions(-) create mode 100644 drivers/serial/lpc32xx_hsuart.c
diff --git a/arch/arm/include/asm/arch-lpc32xx/uart.h b/arch/arm/include/asm/arch-lpc32xx/uart.h index b613df8..ec12893 100644 --- a/arch/arm/include/asm/arch-lpc32xx/uart.h +++ b/arch/arm/include/asm/arch-lpc32xx/uart.h @@ -22,6 +22,66 @@
+/* 14-clock UART Registers */ +struct hsuart_regs { + union { + u32 rx; /* Receiver FIFO */ + u32 tx; /* Transmitter FIFO */ + }; + u32 level; /* FIFO Level Register */ + u32 iir; /* Interrupt ID Register */ + u32 ctrl; /* Control Register */ + u32 rate; /* Rate Control Register */ +}; + +/* 14-clock UART Receiver FIFO Register bits */ +#define HSUART_RX_BREAK (1 << 10) +#define HSUART_RX_ERROR (1 << 9) +#define HSUART_RX_EMPTY (1 << 8) +#define HSUART_RX_DATA (0xff << 0) + +/* 14-clock UART Level Register bits */ +#define HSUART_LEVEL_TX (0xff << 8) +#define HSUART_LEVEL_RX (0xff << 0) + +/* 14-clock UART Interrupt Identification Register bits */ +#define HSUART_IIR_TX_INT_SET (1 << 6) +#define HSUART_IIR_RX_OE (1 << 5) +#define HSUART_IIR_BRK (1 << 4) +#define HSUART_IIR_FE (1 << 3) +#define HSUART_IIR_RX_TIMEOUT (1 << 2) +#define HSUART_IIR_RX_TRIG (1 << 1) +#define HSUART_IIR_TX (1 << 0) + +/* 14-clock UART Control Register bits */ +#define HSUART_CTRL_HRTS_INV (1 << 21) +#define HSUART_CTRL_HRTS_TRIG_48 (0x3 << 19) +#define HSUART_CTRL_HRTS_TRIG_32 (0x2 << 19) +#define HSUART_CTRL_HRTS_TRIG_16 (0x1 << 19) +#define HSUART_CTRL_HRTS_TRIG_8 (0x0 << 19) +#define HSUART_CTRL_HRTS_EN (1 << 18) +#define HSUART_CTRL_TMO_16 (0x3 << 16) +#define HSUART_CTRL_TMO_8 (0x2 << 16) +#define HSUART_CTRL_TMO_4 (0x1 << 16) +#define HSUART_CTRL_TMO_DISABLED (0x0 << 16) +#define HSUART_CTRL_HCTS_INV (1 << 15) +#define HSUART_CTRL_HCTS_EN (1 << 14) +#define HSUART_CTRL_HSU_OFFSET(n) ((n) << 9) +#define HSUART_CTRL_HSU_BREAK (1 << 8) +#define HSUART_CTRL_HSU_ERR_INT_EN (1 << 7) +#define HSUART_CTRL_HSU_RX_INT_EN (1 << 6) +#define HSUART_CTRL_HSU_TX_INT_EN (1 << 5) +#define HSUART_CTRL_HSU_RX_TRIG_48 (0x5 << 2) +#define HSUART_CTRL_HSU_RX_TRIG_32 (0x4 << 2) +#define HSUART_CTRL_HSU_RX_TRIG_16 (0x3 << 2) +#define HSUART_CTRL_HSU_RX_TRIG_8 (0x2 << 2) +#define HSUART_CTRL_HSU_RX_TRIG_4 (0x1 << 2) +#define HSUART_CTRL_HSU_RX_TRIG_1 (0x0 << 2) +#define HSUART_CTRL_HSU_TX_TRIG_16 (0x3 << 0) +#define HSUART_CTRL_HSU_TX_TRIG_8 (0x2 << 0) +#define HSUART_CTRL_HSU_TX_TRIG_4 (0x1 << 0) +#define HSUART_CTRL_HSU_TX_TRIG_0 (0x0 << 0) + /* UART Control Registers */ struct uart_ctrl_regs { u32 ctrl; /* Control Register */ diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 616b857..65d0f23 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -29,6 +29,7 @@ COBJS-$(CONFIG_ALTERA_UART) += altera_uart.o COBJS-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o COBJS-$(CONFIG_ARM_DCC) += arm_dcc.o COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o +COBJS-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-$(CONFIG_NS9750_UART) += ns9750_serial.o COBJS-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o diff --git a/drivers/serial/lpc32xx_hsuart.c b/drivers/serial/lpc32xx_hsuart.c new file mode 100644 index 0000000..8ce3382 --- /dev/null +++ b/drivers/serial/lpc32xx_hsuart.c @@ -0,0 +1,112 @@ +/* + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/uart.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct hsuart_regs *hsuart = (struct hsuart_regs *)HS_UART_BASE; + +static void lpc32xx_hsuart_set_baudrate(void) +{ + u32 div; + + /* UART rate = PERIPH_CLK / ((HSU_RATE + 1) x 14) */ + div = (get_serial_clock() / 14 + gd->baudrate / 2) / gd->baudrate - 1; + if (div > 255) + div = 255; + + writel(div, &hsuart->rate); +} + +static int lpc32xx_hsuart_getc(void) +{ + while (!(readl(&hsuart->level) & HSUART_LEVEL_RX)) + /* NOP */; + + return readl(&hsuart->rx) & HSUART_RX_DATA; +} + +static void lpc32xx_hsuart_putc(const char c) +{ + writel(c, &hsuart->tx); + + /* Wait for character to be sent */ + while (readl(&hsuart->level) & HSUART_LEVEL_TX) + /* NOP */; +} + +static int lpc32xx_hsuart_tstc(void) +{ + if (readl(&hsuart->level) & HSUART_LEVEL_RX) + return 1; + + return 0; +} + +static void lpc32xx_hsuart_init(void) +{ + lpc32xx_hsuart_set_baudrate(); + + /* Disable hardware RTS and CTS flow control, set up RX and TX FIFO */ + writel(HSUART_CTRL_TMO_16 | HSUART_CTRL_HSU_OFFSET(20) | + HSUART_CTRL_HSU_RX_TRIG_32 | HSUART_CTRL_HSU_TX_TRIG_0, + &hsuart->ctrl); +} + +void serial_setbrg(void) +{ + return lpc32xx_hsuart_set_baudrate(); +} + +void serial_putc(const char c) +{ + lpc32xx_hsuart_putc(c); + + /* If \n, also do \r */ + if (c == '\n') + lpc32xx_hsuart_putc('\r'); +} + +int serial_getc(void) +{ + return lpc32xx_hsuart_getc(); +} + +void serial_puts(const char *s) +{ + while (*s) + serial_putc(*s++); +} + +int serial_tstc(void) +{ + return lpc32xx_hsuart_tstc(); +} + +int serial_init(void) +{ + lpc32xx_hsuart_init(); + + return 0; +}
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Acked-by: Marek Vasut marek.vasut@gmail.com --- Changes from v5 to v6: * update boards.cfg context
Changes from v4 to v5: * fixed bi_boot_params initialization * cosmetic changes in board configuration
Changes from v3 to v4: * removed dcache flushing from board_init() * tabs instead of spaces in board config file
Changes from v2 to v3: * updated a relocation address * combined a record in maintainers file into the patch * use high speed UART2 by default
Changes from v1 to v2: * corrected address in GPLv2+ licence header in files * removed clean and distclean targets from board makefile * do not set machine id explicitly, if CONFIG_MACH_TYPE is defined * minor indentation cleanups
MAINTAINERS | 4 + board/timll/devkit3250/Makefile | 44 +++++++++++++ board/timll/devkit3250/devkit3250.c | 65 +++++++++++++++++++ boards.cfg | 1 + include/configs/devkit3250.h | 117 +++++++++++++++++++++++++++++++++++ 5 files changed, 231 insertions(+), 0 deletions(-) create mode 100644 board/timll/devkit3250/Makefile create mode 100644 board/timll/devkit3250/devkit3250.c create mode 100644 include/configs/devkit3250.h
diff --git a/MAINTAINERS b/MAINTAINERS index 708ded7..35d0a9a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -932,6 +932,10 @@ Sughosh Ganu urwithsughosh@gmail.com
hawkboard ARM926EJS (OMAP-L138)
+Vladimir Zapolskiy vz@mleia.com + + devkit3250 lpc32xx + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/board/timll/devkit3250/Makefile b/board/timll/devkit3250/Makefile new file mode 100644 index 0000000..ea7827c --- /dev/null +++ b/board/timll/devkit3250/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com +# Copyright (C) 2008, Guennadi Liakhovetski lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := devkit3250.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/timll/devkit3250/devkit3250.c b/board/timll/devkit3250/devkit3250.c new file mode 100644 index 0000000..6b0ec80 --- /dev/null +++ b/board/timll/devkit3250/devkit3250.c @@ -0,0 +1,65 @@ +/* + * Embest/Timll DevKit3250 board support + * + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/cpu.h> +#include <asm/arch/emc.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct emc_regs *emc = (struct emc_regs *)EMC_BASE; + +int board_early_init_f(void) +{ + lpc32xx_uart_init(CONFIG_SYS_LPC32XX_UART); + + return 0; +} + +int board_init(void) +{ + /* adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + +#ifdef CONFIG_SYS_FLASH_CFI + /* Use 16-bit memory interface for NOR Flash */ + emc->stat[0].config = EMC_STAT_CONFIG_PB | EMC_STAT_CONFIG_16BIT; + + /* Change the NOR timings to optimum value to get maximum bandwidth */ + emc->stat[0].waitwen = EMC_STAT_WAITWEN(1); + emc->stat[0].waitoen = EMC_STAT_WAITOEN(1); + emc->stat[0].waitrd = EMC_STAT_WAITRD(12); + emc->stat[0].waitpage = EMC_STAT_WAITPAGE(12); + emc->stat[0].waitwr = EMC_STAT_WAITWR(5); + emc->stat[0].waitturn = EMC_STAT_WAITTURN(2); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 3cf75c3..87a1f0c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -154,6 +154,7 @@ openrd_ultimate arm arm926ejs openrd Marvell rd6281a arm arm926ejs - Marvell kirkwood sheevaplug arm arm926ejs - Marvell kirkwood dockstar arm arm926ejs - Seagate kirkwood +devkit3250 arm arm926ejs devkit3250 timll lpc32xx jadecpu arm arm926ejs jadecpu syteco mb86r0x mx25pdk arm arm926ejs mx25pdk freescale mx25 mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg tx25 arm arm926ejs tx25 karo mx25 diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h new file mode 100644 index 0000000..9f15ffb --- /dev/null +++ b/include/configs/devkit3250.h @@ -0,0 +1,117 @@ +/* + * Embest/Timll DevKit3250 board configuration file + * + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version 2 + * of the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301, USA. + */ + +#ifndef __CONFIG_DEVKIT3250_H__ +#define __CONFIG_DEVKIT3250_H__ + +/* SoC and board defines */ +#include <asm/sizes.h> +#include <asm/arch/cpu.h> + +/* + * Define DevKit3250 machine type by hand until it lands in mach-types + */ +#define MACH_TYPE_DEVKIT3250 3697 +#define CONFIG_MACH_TYPE MACH_TYPE_DEVKIT3250 + +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F + +/* + * Memory configurations + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_STACKSIZE SZ_32K +#define CONFIG_SYS_MALLOC_LEN SZ_1M +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_SDRAM_BASE EMC_DYCS0_BASE +#define CONFIG_SYS_SDRAM_SIZE SZ_64M +#define CONFIG_SYS_TEXT_BASE 0x83FA0000 +#define CONFIG_SYS_MEMTEST_START (CONFIG_SYS_SDRAM_BASE + SZ_32K) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_TEXT_BASE - SZ_1M) + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_32K) + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_4K \ + - GENERATED_GBL_DATA_SIZE) + +/* + * Serial Driver + */ +#define CONFIG_SYS_LPC32XX_UART 2 /* UART2 */ +#define CONFIG_BAUDRATE 115200 + +/* + * NOR Flash + */ +#define CONFIG_CMD_FLASH +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 71 +#define CONFIG_SYS_FLASH_BASE EMC_CS0_BASE +#define CONFIG_SYS_FLASH_SIZE SZ_4M +#define CONFIG_SYS_FLASH_CFI + +/* + * U-Boot General Configurations + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_VERSION_VARIABLE +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION + +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE SZ_128K + +/* + * U-Boot Commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_CACHE + +/* + * Boot Linux + */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyS2,115200n8" +#define CONFIG_LOADADDR 0x80008000 + +/* + * Include SoC specific configuration + */ +#include <asm/arch/config.h> + +#endif /* __CONFIG_DEVKIT3250_H__*/
Hi Vladimir,
Applied to u-boot-arm/next, thanks -- and apologies for delaying so much.
Amicalement,
On 19.04.2012 20:17, Albert ARIBAUD wrote:
Hi Vladimir,
no problem, thank you a lot.
Albert ARIBAUD
Vladimir Zapolskiy
