[U-Boot] [PATCH 1/3] ARM: uniphier: fix SSCPLL init code for LD11 SoC
Commit 682e09ff9f35 ("ARM: uniphier: add PLL init code for LD20 SoC") missed to write the computed value to the SSCPLLCTRL2 register.
Fixes: 682e09ff9f35 ("ARM: uniphier: add PLL init code for LD20 SoC") Signed-off-by: Dai Okamura okamura.dai@socionext.com Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/clk/pll-base-ld20.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index 3aa42f8..45fdf0a 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -48,6 +48,7 @@ int uniphier_ld20_sscpll_init(unsigned long reg_base, unsigned int freq, tmp = readl(base + 4); tmp &= ~SC_PLLCTRL2_SSC_JK_MASK; tmp |= (41859 * freq / divn) & SC_PLLCTRL2_SSC_JK_MASK; + writel(tmp, base + 4);
udelay(50); }
Use DIV_ROUND_CLOSEST(). To make the JK value even more precise, I used a bigger coefficient, then divide it by 512.
arch/arm/mach-uniphier/clk/pll-base-ld20.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index 45fdf0a..c9b78b9 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -7,6 +7,7 @@
#include <linux/bitops.h> #include <linux/delay.h> +#include <linux/kernel.h> #include <linux/errno.h> #include <linux/io.h> #include <linux/sizes.h> @@ -41,13 +42,14 @@ int uniphier_ld20_sscpll_init(unsigned long reg_base, unsigned int freq, if (freq != UNIPHIER_PLL_FREQ_DEFAULT) { tmp = readl(base); /* SSCPLLCTRL */ tmp &= ~SC_PLLCTRL_SSC_DK_MASK; - tmp |= (487 * freq * ssc_rate / divn / 512) & + tmp |= DIV_ROUND_CLOSEST(487UL * freq * ssc_rate, divn * 512) & SC_PLLCTRL_SSC_DK_MASK; writel(tmp, base);
tmp = readl(base + 4); tmp &= ~SC_PLLCTRL2_SSC_JK_MASK; - tmp |= (41859 * freq / divn) & SC_PLLCTRL2_SSC_JK_MASK; + tmp |= DIV_ROUND_CLOSEST(21431887UL * freq, divn * 512) & + SC_PLLCTRL2_SSC_JK_MASK; writel(tmp, base + 4);
udelay(50);
It is tedious to define both mask and bit-shift. <linux/bitfield.h> provides a convenient way to get access to register fields with a single shifted mask.
arch/arm/mach-uniphier/clk/pll-base-ld20.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index c9b78b9..385f54d 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -5,6 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <linux/bitfield.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/kernel.h> @@ -19,7 +20,6 @@ #define SC_PLLCTRL_SSC_EN BIT(31) #define SC_PLLCTRL2_NRSTDS BIT(28) #define SC_PLLCTRL2_SSC_JK_MASK GENMASK(26, 0) -#define SC_PLLCTRL3_REGI_SHIFT 16 #define SC_PLLCTRL3_REGI_MASK GENMASK(19, 16)
/* PLL type: VPLL27 */ @@ -42,14 +42,16 @@ int uniphier_ld20_sscpll_init(unsigned long reg_base, unsigned int freq, if (freq != UNIPHIER_PLL_FREQ_DEFAULT) { tmp = readl(base); /* SSCPLLCTRL */ tmp &= ~SC_PLLCTRL_SSC_DK_MASK; - tmp |= DIV_ROUND_CLOSEST(487UL * freq * ssc_rate, divn * 512) & - SC_PLLCTRL_SSC_DK_MASK; + tmp |= FIELD_PREP(SC_PLLCTRL_SSC_DK_MASK, + DIV_ROUND_CLOSEST(487UL * freq * ssc_rate, + divn * 512)); writel(tmp, base);
tmp = readl(base + 4); tmp &= ~SC_PLLCTRL2_SSC_JK_MASK; - tmp |= DIV_ROUND_CLOSEST(21431887UL * freq, divn * 512) & - SC_PLLCTRL2_SSC_JK_MASK; + tmp |= FIELD_PREP(SC_PLLCTRL2_SSC_JK_MASK, + DIV_ROUND_CLOSEST(21431887UL * freq, + divn * 512)); writel(tmp, base + 4);
udelay(50); @@ -93,7 +95,7 @@ int uniphier_ld20_sscpll_set_regi(unsigned long reg_base, unsigned regi)
tmp = readl(base + 8); /* SSCPLLCTRL3 */ tmp &= ~SC_PLLCTRL3_REGI_MASK; - tmp |= regi << SC_PLLCTRL3_REGI_SHIFT; + tmp |= FIELD_PREP(SC_PLLCTRL3_REGI_MASK, regi); writel(tmp, base + 8);
iounmap(base);
Masahiro Yamada
