[U-Boot] [PATCH-OMAP3 v2] OMAP3: Fix multiline comment style
Fix multiline comment style.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Changes in v2:
- Correct patch header style.
v2 of this patch makes previous version v1 obsolete.
board/omap3/evm/evm.c | 32 ++++++++++++++++++---------- cpu/arm_cortexa8/cpu.c | 12 +++++++--- cpu/arm_cortexa8/omap3/board.c | 41 +++++++++++++++++++++++------------- cpu/arm_cortexa8/omap3/clock.c | 24 ++++++++++++++------- cpu/arm_cortexa8/omap3/interrupts.c | 6 +++-- cpu/arm_cortexa8/omap3/mem.c | 6 +++-- cpu/arm_cortexa8/omap3/sys_info.c | 4 ++- drivers/mtd/nand/omap_gpmc.c | 23 +++++++++++++------- include/asm-arm/arch-omap3/omap3.h | 8 +++---- include/configs/omap3_beagle.h | 3 +- include/configs/omap3_evm.h | 3 +- include/configs/omap3_overo.h | 3 +- 12 files changed, 108 insertions(+), 57 deletions(-)
Index: u-boot-arm/include/asm-arm/arch-omap3/omap3.h =================================================================== --- u-boot-arm.orig/include/asm-arm/arch-omap3/omap3.h +++ u-boot-arm/include/asm-arm/arch-omap3/omap3.h @@ -110,11 +110,11 @@
#define CPU_3430 0x3430
-/* 343x real hardware: +/* + * 343x real hardware: * ES1 = rev 0 - */ - -/* 343x code defines: + * + * 343x code defines: * ES1 = 0+1 = 1 * ES1 = 1+1 = 1 */ Index: u-boot-arm/cpu/arm_cortexa8/cpu.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/cpu.c +++ u-boot-arm/cpu/arm_cortexa8/cpu.c @@ -186,8 +186,10 @@ void l2cache_enable() __asm__ __volatile__("mov %0, r12":"=r"(j)); __asm__ __volatile__("mov %0, r0":"=r"(i));
- /* GP Device ROM code API usage here */ - /* r12 = AUXCR Write function and r0 value */ + /* + * GP Device ROM code API usage here + * r12 = AUXCR Write function and r0 value + */ __asm__ __volatile__("mov r12, #0x3"); __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); __asm__ __volatile__("orr r0, r0, #0x2"); @@ -214,8 +216,10 @@ void l2cache_disable() __asm__ __volatile__("mov %0, r12":"=r"(j)); __asm__ __volatile__("mov %0, r0":"=r"(i));
- /* GP Device ROM code API usage here */ - /* r12 = AUXCR Write function and r0 value */ + /* + * GP Device ROM code API usage here + * r12 = AUXCR Write function and r0 value + */ __asm__ __volatile__("mov r12, #0x3"); __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); __asm__ __volatile__("bic r0, r0, #0x2"); Index: u-boot-arm/cpu/arm_cortexa8/omap3/sys_info.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/sys_info.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/sys_info.c @@ -63,7 +63,9 @@ u32 get_cpu_type(void) u32 get_cpu_rev(void) { u32 cpuid = 0; - /* On ES1.0 the IDCODE register is not exposed on L4 + + /* + * On ES1.0 the IDCODE register is not exposed on L4 * so using CPU ID to differentiate * between ES2.0 and ES1.0. */ Index: u-boot-arm/cpu/arm_cortexa8/omap3/board.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/board.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/board.c @@ -99,8 +99,10 @@ void secureworld_exit() __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i)); /* enabling co-processor CP10 and CP11 accesses in NS world */ __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i)); - /* allow allocation of locked TLBs and L2 lines in NS world */ - /* allow use of PLE registers in NS world also */ + /* + * allow allocation of locked TLBs and L2 lines in NS world + * allow use of PLE registers in NS world also + */ __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i)); __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i));
@@ -128,8 +130,10 @@ void setup_auxcr() __asm__ __volatile__("mov %0, r12":"=r"(j)); __asm__ __volatile__("mov %0, r0":"=r"(i));
- /* GP Device ROM code API usage here */ - /* r12 = AUXCR Write function and r0 value */ + /* + * GP Device ROM code API usage here + * r12 = AUXCR Write function and r0 value + */ __asm__ __volatile__("mov r12, #0x3"); __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); /* Enabling ASA */ @@ -150,17 +154,21 @@ void try_unlock_memory() int mode; int in_sdram = is_running_in_sdram();
- /* if GP device unlock device SRAM for general use */ - /* secure code breaks for Secure/Emulation device - HS/E/T */ + /* + * if GP device unlock device SRAM for general use + * secure code breaks for Secure/Emulation device - HS/E/T + */ mode = get_device_type(); if (mode == GP_DEVICE) secure_unlock_mem();
- /* If device is EMU and boot is XIP external booting + /* + * If device is EMU and boot is XIP external booting * Unlock firewalls and disable L2 and put chip * out of secure world + * + * Assuming memories are unlocked by the demon who put us in SDRAM */ - /* Assuming memories are unlocked by the demon who put us in SDRAM */ if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F) && (!in_sdram)) { secure_unlock_mem(); @@ -183,8 +191,10 @@ void s_init(void)
try_unlock_memory();
- /* Right now flushing at low MPU speed. - Need to move after clock init */ + /* + * Right now flushing at low MPU speed. + * Need to move after clock init + */ v7_flush_dcache_all(get_device_type()); #ifndef CONFIG_ICACHE_OFF icache_enable(); @@ -195,8 +205,9 @@ void s_init(void) #else l2cache_enable(); #endif - /* Writing to AuxCR in U-boot using SMI for GP DEV */ - /* Currently SMI in Kernel on ES2 devices seems to have an isse + /* + * Writing to AuxCR in U-boot using SMI for GP DEV + * Currently SMI in Kernel on ES2 devices seems to have an isse * Once that is resolved, we can postpone this config to kernel */ if (get_device_type() == GP_DEVICE) @@ -231,7 +242,8 @@ void wait_for_command_complete(unsigned *****************************************************************************/ void watchdog_init(void) { - /* There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is + /* + * There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is * either taken care of by ROM (HS/EMU) or not accessible (GP). * We need to take care of WD2-MPU or take a PRCM reset. WD3 * should not be running and does not generate a PRCM reset. @@ -261,7 +273,8 @@ int dram_init(void)
display_board_info(btype);
- /* If a second bank of DDR is attached to CS1 this is + /* + * If a second bank of DDR is attached to CS1 this is * where it can be started. Early init code will init * memory on CS0. */ Index: u-boot-arm/cpu/arm_cortexa8/omap3/clock.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/clock.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/clock.c @@ -131,7 +131,8 @@ void prcm_init(void)
xip_safe = is_running_in_sram();
- /* Gauge the input clock speed and find out the sys_clkin_sel + /* + * Gauge the input clock speed and find out the sys_clkin_sel * value corresponding to the input clock. */ osc_clk = get_osc_clk_speed(); @@ -148,7 +149,8 @@ void prcm_init(void) clk_index = sys_clkin_sel; }
- /* The DPLL tables are defined according to sysclk value and + /* + * The DPLL tables are defined according to sysclk value and * silicon revision. The clk_index value will be used to get * the values for that input sysclk from the DPLL param table * and sil_index will get the values for that SysClk for the @@ -166,12 +168,15 @@ void prcm_init(void) /* Moving it to the right sysclk and ES rev base */ dpll_param_p = dpll_param_p + 3 * clk_index + sil_index; if (xip_safe) { - /* CORE DPLL */ - /* sr32(CM_CLKSEL2_EMU) set override to work when asleep */ + /* + * CORE DPLL + * sr32(CM_CLKSEL2_EMU) set override to work when asleep + */ sr32(CM_CLKEN_PLL, 0, 3, PLL_FAST_RELOCK_BYPASS); wait_on_value(BIT0, 0, CM_IDLEST_CKGEN, LDELAY);
- /* For OMAP3 ES1.0 Errata 1.50, default value directly doesnt + /* + * For OMAP3 ES1.0 Errata 1.50, default value directly doesn't * work. write another value and then default value. */ sr32(CM_CLKSEL1_EMU, 16, 5, CORE_M3X2 + 1); /* m3x2 */ @@ -191,8 +196,10 @@ void prcm_init(void)
wait_on_value(BIT0, 1, CM_IDLEST_CKGEN, LDELAY); } else if (is_running_in_flash()) { - /* if running from flash, jump to small relocated code - area in SRAM. */ + /* + * if running from flash, jump to small relocated code + * area in SRAM. + */ p0 = readl(CM_CLKEN_PLL); sr32((u32) &p0, 0, 3, PLL_FAST_RELOCK_BYPASS); sr32((u32) &p0, 4, 4, dpll_param_p->fsel); /* FREQSEL */ @@ -225,7 +232,8 @@ void prcm_init(void) /* Moving it to the right sysclk base */ dpll_param_p = dpll_param_p + clk_index;
- /* Errata 1.50 Workaround for OMAP3 ES1.0 only + /* + * Errata 1.50 Workaround for OMAP3 ES1.0 only * If using default divisors, write default divisor + 1 * and then the actual divisor value */ Index: u-boot-arm/cpu/arm_cortexa8/omap3/interrupts.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/interrupts.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/interrupts.c @@ -177,8 +177,10 @@ int interrupt_init(void) { int32_t val;
- /* Start the counter ticking up */ - /* reload value on overflow */ + /* + * Start the counter ticking up + * reload value on overflow + */ *((int32_t *) (CONFIG_SYS_TIMERBASE + TLDR)) = TIMER_LOAD_VAL; /* mask to enable timer */ val = (CONFIG_SYS_PVT << 2) | BIT5 | BIT1 | BIT0; Index: u-boot-arm/cpu/arm_cortexa8/omap3/mem.c =================================================================== --- u-boot-arm.orig/cpu/arm_cortexa8/omap3/mem.c +++ u-boot-arm/cpu/arm_cortexa8/omap3/mem.c @@ -32,7 +32,8 @@ #include <asm/arch/sys_proto.h> #include <command.h>
-/* Only One NAND allowed on board at a time. +/* + * Only One NAND allowed on board at a time. * The GPMC CS Base for the same */ unsigned int boot_flash_base; @@ -250,7 +251,8 @@ void gpmc_init(void) config &= (~0xf00); writel(config, gpmc_base + OFFS(GPMC_CONFIG));
- /* Disable the GPMC0 config set by ROM code + /* + * Disable the GPMC0 config set by ROM code * It conflicts with our MPDB (both at 0x08000000) */ writel(0, gpmc_cs_base + OFFS(GPMC_CONFIG7)); Index: u-boot-arm/drivers/mtd/nand/omap_gpmc.c =================================================================== --- u-boot-arm.orig/drivers/mtd/nand/omap_gpmc.c +++ u-boot-arm/drivers/mtd/nand/omap_gpmc.c @@ -43,7 +43,8 @@ static void omap_nand_hwcontrol(struct m { register struct nand_chip *this = mtd->priv;
- /* Point the IO_ADDR to DATA and ADDRESS registers instead + /* + * Point the IO_ADDR to DATA and ADDRESS registers instead * of chip address */ switch (ctrl) { @@ -70,8 +71,10 @@ static void omap_nand_hwcontrol(struct m */ static void omap_hwecc_init(struct nand_chip *chip) { - /* Init ECC Control Register */ - /* Clear all ECC | Enable Reg1 */ + /* + * Init ECC Control Register + * Clear all ECC | Enable Reg1 + */ writel(ECCCLEAR | ECCRESULTREG1, gpmc_base + OFFS(GPMC_ECC_CONTROL)); writel(ECCSIZE1 | ECCSIZE0 | ECCSIZE0SEL, gpmc_base + OFFS(GPMC_ECC_SIZE_CONFIG)); @@ -183,7 +186,8 @@ static int omap_calculate_ecc(struct mtd ecc_code[1] = (val >> 16) & 0xFF; ecc_code[2] = ((val >> 8) & 0x0F) | ((val >> 20) & 0xF0);
- /* Stop reading anymore ECC vals and clear old results + /* + * Stop reading anymore ECC vals and clear old results * enable will be called if more reads are required */ writel(0x000, gpmc_base + OFFS(GPMC_ECC_CONFIG)); @@ -207,7 +211,8 @@ static void omap_enable_hwecc(struct mtd /* Clear the ecc result registers, select ecc reg as 1 */ writel(ECCCLEAR | ECCRESULTREG1, gpmc_base + OFFS(GPMC_ECC_CONTROL)); - /* Size 0 = 0xFF, Size1 is 0xFF - both are 512 bytes + /* + * Size 0 = 0xFF, Size1 is 0xFF - both are 512 bytes * tell all regs to generate size0 sized regs * we just have a single ECC engine for all CS */ @@ -222,7 +227,7 @@ static void omap_enable_hwecc(struct mtd } }
-/** +/* * omap_nand_switch_ecc - switch the ECC operation b/w h/w ecc and s/w ecc. * The default is to come up on s/w ecc * @@ -290,14 +295,16 @@ int board_nand_init(struct nand_chip *na int32_t gpmc_config = 0; cs = 0;
- /* xloader/Uboot's gpmc configuration would have configured GPMC for + /* + * xloader/Uboot's gpmc configuration would have configured GPMC for * nand type of memory. The following logic scans and latches on to the * first CS with NAND type memory. * TBD: need to make this logic generic to handle multiple CS NAND * devices. */ while (cs < GPMC_MAX_CS) { - /* Each GPMC set for a single CS is at offset 0x30 + /* + * Each GPMC set for a single CS is at offset 0x30 * - already remapped for us */ gpmc_cs_base = (void __iomem *)(GPMC_CONFIG_CS0_BASE + Index: u-boot-arm/include/configs/omap3_beagle.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_beagle.h +++ u-boot-arm/include/configs/omap3_beagle.h @@ -179,7 +179,8 @@
#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load address */
-/* 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by +/* + * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ #define V_PVT 7 Index: u-boot-arm/board/omap3/evm/evm.c =================================================================== --- u-boot-arm.orig/board/omap3/evm/evm.c +++ u-boot-arm/board/omap3/evm/evm.c @@ -101,9 +101,11 @@ static int setup_net_chip(void) (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0164)) = 0x00000FCF; (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0168)) = 0x00000f6c;
- /* Configure PIN MUX registers */ - /* Enable GPMC Pin Mux Registers */ - /* Enable GPMC_CLK Pin in CONTROL_PADCONF_gpmc_ncs7 register */ + /* + * Configure PIN MUX registers + * Enable GPMC Pin Mux Registers + * Enable GPMC_CLK Pin in CONTROL_PADCONF_gpmc_ncs7 register + */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xBC)) |= 0x00180000; /* Enable CS5 Pin in CONTROL_PADCONF_gpmc_ncs5 register */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) |= 0x00000018; @@ -115,8 +117,10 @@ static int setup_net_chip(void) /* Enable gpmc_nbe0_cle in CONTROL_PADCONF_GPMC_NWE register */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00180000;
- /* Enable gpmc_nbe1 in CONTROL_PADCONF_GPMC_NBE1 register and - configuring the mux mode to 0 */ + /* + * Enable gpmc_nbe1 in CONTROL_PADCONF_GPMC_NBE1 register and + * configuring the mux mode to 0 + */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) |= 0x00000018; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) &= 0xFFFFFFF8; /* Enable d15 in CONTROL_PADCONF_GPMC_D15 register */ @@ -155,20 +159,26 @@ static int setup_net_chip(void) (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x78)) &= 0xFFFFFFF8;
#if defined(CPU_3430_ES1) || defined(CPU_3430_ES2) - /* GPIO 64 configuration in CONTROL_PADCONF_GPMC_WAIT2 - register mux mode is 4. */ + /* + * GPIO 64 configuration in CONTROL_PADCONF_GPMC_WAIT2 + * register mux mode is 4. + */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) |= 0x00000018; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) &= 0xFFFFFFF8; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) |= 0x00000004;
- /* Configure GPIO 176 in CONTROL_PADCONF_MCSPI1_CS1 - register for ethernet ISR mux mode is 4 */ + /* + * Configure GPIO 176 in CONTROL_PADCONF_MCSPI1_CS1 + * register for ethernet ISR mux mode is 4 + */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) |= 0x00180000; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) &= 0xFFF8FFFF; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) |= 0x00040000;
- /* Enable Clock for GPIO 1-6 module in CM_FCLKEN_PER - and CM_ICLKEN_PER registers */ + /* + * Enable Clock for GPIO 1-6 module in CM_FCLKEN_PER + * and CM_ICLKEN_PER registers + */ (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x5000)) |= 0x0003E800; (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x5010)) |= 0x0003E800;
Index: u-boot-arm/include/configs/omap3_evm.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_evm.h +++ u-boot-arm/include/configs/omap3_evm.h @@ -189,7 +189,8 @@
-/* 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by +/* + * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ #define V_PVT 7 Index: u-boot-arm/include/configs/omap3_overo.h =================================================================== --- u-boot-arm.orig/include/configs/omap3_overo.h +++ u-boot-arm/include/configs/omap3_overo.h @@ -170,7 +170,8 @@
Changes in v2:
apply to u-boot-arm/omap3
dirk.behmeï¼ googlemail.com
Jean-Christophe PLAGNIOL-VILLARD
