[U-Boot] [PATCH v4] misc: fs_loader: Add support for initializing block device
Firmware loader would encounter problem if the block device is accessed before initializing it. This patch would adding the support of probing block device and initializing block before the block device is accessed by firmware loader.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com
changes in v4 - Removed header mmc.h - Dropped extra blank line
changes in v3: - Initializing block device through probing the blk device
changes in v2: - Initializing MMC through probing the blk device --- drivers/misc/fs_loader.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 57a14a3..a2e3763 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -252,6 +252,29 @@ static int fs_loader_ofdata_to_platdata(struct udevice *dev)
static int fs_loader_probe(struct udevice *dev) { +#if CONFIG_IS_ENABLED(DM) && CONFIG_IS_ENABLED(BLK) + int ret; + struct device_platdata *plat = dev->platdata; + + if (plat->phandlepart.phandle) { + ofnode node = ofnode_get_by_phandle(plat->phandlepart.phandle); + struct udevice *parent_dev = NULL; + + ret = device_get_global_by_ofnode(node, &parent_dev); + if (!ret) { + struct udevice *dev; + + ret = blk_get_from_parent(parent_dev, &dev); + if (ret) { + debug("fs_loader: No block device: %d\n", + ret); + + return ret; + } + } + } +#endif + return 0; };
changes in v4
changes in v3:
changes in v2:
(I'm not sure you need to check for DM being enabled, but OK)
On Fri, 2019-02-01 at 23:06 -0700, Simon Glass wrote: On Thu, 31 Jan 2019 at 04:34, <tien.fong.chee@intel.commailto:tien.fong.chee@intel.com> wrote:
From: Tien Fong Chee <tien.fong.chee@intel.commailto:tien.fong.chee@intel.com>
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.commailto:tien.fong.chee@intel.com>
changes in v4
changes in v3:
changes in v2:
Reviewed-by: Simon Glass <sjg@chromium.orgmailto:sjg@chromium.org>
(I'm not sure you need to check for DM being enabled, but OK) Thanks. No strong opinion on this :) .
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass <sjg@chromium.orgmailto:sjg@chromium.org>
Chee, Tien Fong
