[PATCH] spl: add %z support for tiny-printf
the %zx format are used in spl from files below: lib/lzma/LzmaTools.c common/malloc_simple.c
it results output like "... 0xx", "size=x" output, treat '%z' as '%l' to support `ssize_t' type.
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- lib/tiny-printf.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 8fc7e48..4b65f72 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -228,7 +228,7 @@ static int _vprintf(struct printf_info *info, const char *fmt, va_list va) ch = *fmt++; } } - if (ch == 'l') { + if (ch == 'l' || ch == 'z') { ch = *(fmt++); islong = true; }
if (ch == 'l') {
Generally, we try and change code rather than add more support to tiny-printf as it's supposed to stay as tiny as possible. See eebcdb34d061 ("malloc_simple: Remove usage of unsupported %zx format string") for a recent example.
if (ch == 'l') {
Perhaps we should add a macro like PRIz which expands to "u", "lu", or "llu" as appropriate. This would let us keep code size the same. The problem with this of course is that as far as can tell simple_printf does not support llu...
--Sean
Du Huanpeng
Sean Anderson
