[U-Boot] [PATCH 1/3] cmd_mem: replace custom PRINTF() with debug()
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_mem.c | 12 +++--------- 1 files changed, 3 insertions(+), 9 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 9ad932c..5121b22 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -35,12 +35,6 @@ #include <watchdog.h> #include <asm/io.h>
-#ifdef CMD_MEM_DEBUG -#define PRINTF(fmt,args...) printf (fmt ,##args) -#else -#define PRINTF(fmt,args...) -#endif - static int mod_mem(cmd_tbl_t *, int, int, int, char * const []);
/* Display values from last command. @@ -681,7 +675,7 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_SYS_ALT_MEMTEST) printf ("Testing %08x ... %08x:\n", (uint)start, (uint)end); - PRINTF("%s:%d: start 0x%p end 0x%p\n", + debug("%s:%d: start 0x%p end 0x%p\n", __FUNCTION__, __LINE__, start, end);
for (;;) { @@ -698,7 +692,7 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
printf("Iteration: %6d\r", iterations); - PRINTF("\n"); + debug("\n"); iterations++;
/* @@ -789,7 +783,7 @@ int do_mem_mtest (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) pattern = (vu_long) 0xaaaaaaaa; anti_pattern = (vu_long) 0x55555555;
- PRINTF("%s:%d: length = 0x%.8lx\n", + debug("%s:%d: length = 0x%.8lx\n", __FUNCTION__, __LINE__, len); /*
Not only does the source code get simpler, but it also shrinks the compiled object code too.
While we're here, tweak the summary message to avoid the plural issue. It isn't that big of a deal, and it's currently wrong anyways in the single (1 byte) case: Total of 1 byte were the same Grammar wise, that should be "was" rather than "were". The new output people should be able to easily figure out: Total of 1 byte(s) were the same Total of 10 byte(s) were the same
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_mem.c | 52 +++++++++++++++++++--------------------------------- 1 files changed, 19 insertions(+), 33 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 5121b22..03e7f87 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -263,6 +263,7 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ulong addr1, addr2, count, ngood; int size; int rcode = 0; + const char *type;
if (argc != 4) return cmd_usage(cmdtp); @@ -271,6 +272,7 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ if ((size = cmd_get_data_size(argv[0], 4)) < 0) return 1; + type = size == 4 ? "word" : size == 2 ? "halfword" : "byte";
addr1 = simple_strtoul(argv[1], NULL, 16); addr1 += base_address; @@ -297,39 +299,25 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ngood = 0;
while (count-- > 0) { + ulong word1, word2; if (size == 4) { - ulong word1 = *(ulong *)addr1; - ulong word2 = *(ulong *)addr2; - if (word1 != word2) { - printf("word at 0x%08lx (0x%08lx) " - "!= word at 0x%08lx (0x%08lx)\n", - addr1, word1, addr2, word2); - rcode = 1; - break; - } - } - else if (size == 2) { - ushort hword1 = *(ushort *)addr1; - ushort hword2 = *(ushort *)addr2; - if (hword1 != hword2) { - printf("halfword at 0x%08lx (0x%04x) " - "!= halfword at 0x%08lx (0x%04x)\n", - addr1, hword1, addr2, hword2); - rcode = 1; - break; - } + word1 = *(ulong *)addr1; + word2 = *(ulong *)addr2; + } else if (size == 2) { + word1 = *(ushort *)addr1; + word2 = *(ushort *)addr2; + } else { + word1 = *(u_char *)addr1; + word2 = *(u_char *)addr2; } - else { - u_char byte1 = *(u_char *)addr1; - u_char byte2 = *(u_char *)addr2; - if (byte1 != byte2) { - printf("byte at 0x%08lx (0x%02x) " - "!= byte at 0x%08lx (0x%02x)\n", - addr1, byte1, addr2, byte2); - rcode = 1; - break; - } + if (word1 != word2) { + printf("%s at 0x%08lx (%#0*lx) != %s at 0x%08lx (%#0*lx)\n", + type, addr1, size, word1, + type, addr2, size, word2); + rcode = 1; + break; } + ngood++; addr1 += size; addr2 += size; @@ -339,9 +327,7 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) WATCHDOG_RESET(); }
- printf("Total of %ld %s%s were the same\n", - ngood, size == 4 ? "word" : size == 2 ? "halfword" : "byte", - ngood == 1 ? "" : "s"); + printf("Total of %ld %s(s) were the same\n", ngood, type); return rcode; }
Dear Mike Frysinger,
Applied, thanks.
Simplify the code slightly by using a for() loop since this is basically what we're already doing -- incrementing "ngood" to the value in "count".
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_mem.c | 7 ++----- 1 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 03e7f87..7a5addc 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -296,9 +296,7 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif
- ngood = 0; - - while (count-- > 0) { + for (ngood = 0; ngood < count; ++ngood) { ulong word1, word2; if (size == 4) { word1 = *(ulong *)addr1; @@ -318,12 +316,11 @@ int do_mem_cmp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) break; }
- ngood++; addr1 += size; addr2 += size;
/* reset watchdog from time to time */ - if ((count % (64 << 10)) == 0) + if ((ngood % (64 << 10)) == 0) WATCHDOG_RESET(); }
Applied, thanks.
Applied, thanks.
Mike Frysinger
