[U-Boot] [PATCH] Re-enable setexpr on Raspberry Pi
This patch re-enables the setexpr command, I don't really understand why it got excluded in the first place.
setexpr can be used e.g. to implement failed-boot-counters and failovers to rescue firmware.
Signed-off-by: Marco Schuster m.schuster91@googlemail.com --- configs/rpi_2_defconfig | 1 - configs/rpi_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 5c9e69a..bd81ee6 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -6,5 +6,4 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set CONFIG_PHYS_TO_BUS=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index b8b267f..5d27909 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -6,5 +6,4 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set CONFIG_PHYS_TO_BUS=y -- 2.6.2
Marco Schuster
