[U-Boot] [PATCH] riscv: fu540: enable SMP
Hart 0 on the SiFive FU540 is meant for monitoring tasks. It is a E51 core, whereas all other cores are U54 cores. Select hart 1 as the main hart to run U-Boot.
Signed-off-by: Lukas Auer lukas.auer@aisec.fraunhofer.de --- This patch depends on the SMP support [1] and the SiFive FU540 support patch series [2]. I have submitted it independently from the SMP support patch series to allow the series to be merged independently from the SiFive FU540 support patch series.
[1]: https://patchwork.ozlabs.org/project/uboot/list/?series=91320 [2]: https://patchwork.ozlabs.org/project/uboot/list/?series=91125
board/sifive/fu540/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 6be3d88144..d8a6020cf8 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -16,6 +16,9 @@ config SYS_TEXT_BASE default 0x80000000 if !RISCV_SMODE default 0x80200000 if RISCV_SMODE
+config MAIN_HART + default 1 + config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select GENERIC_RISCV @@ -38,5 +41,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply PHY_LIB imply PHY_MSCC imply SIFIVE_SERIAL + imply SMP
endif
-----Original Message----- From: Lukas Auer [mailto:lukas.auer@aisec.fraunhofer.de] Sent: Tuesday, February 12, 2019 4:12 AM To: u-boot@lists.denx.de Cc: Atish Patra Atish.Patra@wdc.com; Anup Patel Anup.Patel@wdc.com; Bin Meng bmeng.cn@gmail.com; Andreas Schwab schwab@suse.de; Palmer Dabbelt palmer@sifive.com; Alexander Graf agraf@suse.de; Lukas Auer lukas.auer@aisec.fraunhofer.de; Anup Patel Anup.Patel@wdc.com; Atish Patra Atish.Patra@wdc.com; Paul Walmsley paul.walmsley@sifive.com Subject: [PATCH] riscv: fu540: enable SMP
Hart 0 on the SiFive FU540 is meant for monitoring tasks. It is a E51 core, whereas all other cores are U54 cores. Select hart 1 as the main hart to run U- Boot.
+config MAIN_HART
- default 1
- imply SMP
endif
2.20.1
It will be better if we can get rid off MAIN_HART config option. Otherwise, looks good to me.
Reviewed-by: Anup Patel anup.patel@wdc.com
Regards, Anup
+config MAIN_HART
- default 1
- imply SMP
endif
2.20.1
Thanks for your review, Anup!
I will update the patch to remove MAIN_HART together with the next version of the SMP series.
Thanks, Lukas
Anup Patel
Auer, Lukas
Lukas Auer
