[U-Boot] [PATCH 6/9 v3] 83xx: add missing TIMING_CFG1_CASLAT_* defines
Signed-off-by: Heiko Schocher hs@denx.de --- this patch is in u-boot-mpc83xx.git, but still again posted, because it is not yet gone in mainline, and I need this patch to get the following patch 7/9 compiled
include/mpc83xx.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 3554fdd..fab3751 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -890,6 +890,8 @@ #define TIMING_CFG1_CASLAT_30 0x00050000 /* CAS latency = 3.0 */ #define TIMING_CFG1_CASLAT_35 0x00060000 /* CAS latency = 3.5 */ #define TIMING_CFG1_CASLAT_40 0x00070000 /* CAS latency = 4.0 */ +#define TIMING_CFG1_CASLAT_45 0x00080000 /* CAS latency = 4.5 */ +#define TIMING_CFG1_CASLAT_50 0x00090000 /* CAS latency = 5.0 */
/* TIMING_CFG_2 - DDR SDRAM Timing Configuration 2 */
so rebase the patchseries on the tree you're targeting so you don't have to continue resending the same patch to the list.
Kim
Heiko Schocher
Kim Phillips
