[U-Boot] [PATCH 1/4] mips: Add basic MediaTek MT7620/88 support
This patch adds basic support for the MediaTek MT7620/88 SoCs. Parts of the code is copied from the MediaTek GitHub repository:
https://github.com/MediaTek-Labs/linkit-smart-uboot.git
Support for the LinkIt Smart 7688 module and the Gardena Smart Gateway both based on the MT7688 will be added in further patches.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/Kconfig | 15 ++ arch/mips/Makefile | 1 + arch/mips/mach-mt7620/Kconfig | 130 ++++++++++ arch/mips/mach-mt7620/Makefile | 8 + arch/mips/mach-mt7620/cpu.c | 66 +++++ arch/mips/mach-mt7620/ddr_calibrate.c | 331 +++++++++++++++++++++++++ arch/mips/mach-mt7620/lowlevel_init.S | 337 ++++++++++++++++++++++++++ arch/mips/mach-mt7620/mt76xx.h | 39 +++ 8 files changed, 927 insertions(+) create mode 100644 arch/mips/mach-mt7620/Kconfig create mode 100644 arch/mips/mach-mt7620/Makefile create mode 100644 arch/mips/mach-mt7620/cpu.c create mode 100644 arch/mips/mach-mt7620/ddr_calibrate.c create mode 100644 arch/mips/mach-mt7620/lowlevel_init.S create mode 100644 arch/mips/mach-mt7620/mt76xx.h
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 31b622ff51..af791c320d 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -87,6 +87,20 @@ config ARCH_BMIPS select SYSRESET imply CMD_DM
+config ARCH_MT7620 + bool "Support MT7620/7688 SoCs" + select SUPPORTS_LITTLE_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select ROM_EXCEPTION_VECTORS + select MIPS_TUNE_4KC + select OF_CONTROL + select DM + select DM_SERIAL + select DM_SPI + select DM_SPI_FLASH + select DISPLAY_CPUINFO + config MACH_PIC32 bool "Support Microchip PIC32" select DM @@ -141,6 +155,7 @@ source "board/qemu-mips/Kconfig" source "arch/mips/mach-ath79/Kconfig" source "arch/mips/mach-bmips/Kconfig" source "arch/mips/mach-pic32/Kconfig" +source "arch/mips/mach-mt7620/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 5deec9a202..cc8ea5d7d4 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -15,6 +15,7 @@ machine-$(CONFIG_SOC_AU1X00) += au1x00 machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_ARCH_BMIPS) += bmips machine-$(CONFIG_MACH_PIC32) += pic32 +machine-$(CONFIG_ARCH_MT7620) += mt7620
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) libs-y += $(machdirs) diff --git a/arch/mips/mach-mt7620/Kconfig b/arch/mips/mach-mt7620/Kconfig new file mode 100644 index 0000000000..40e15b8a31 --- /dev/null +++ b/arch/mips/mach-mt7620/Kconfig @@ -0,0 +1,130 @@ +menu "MediaTek MIPS platforms" + depends on ARCH_MT7620 + +config SYS_MALLOC_F_LEN + default 0x1000 + +config SYS_SOC + default "mt7620" if SOC_MT7620 + +choice + prompt "MediaTek MIPS SoC select" + +config SOC_MT7620 + bool "MT7620/8" + select MIPS_L1_CACHE_SHIFT_5 + help + This supports MediaTek MIPS MT7620 family. + +endchoice + +choice + prompt "Board select" + +config BOARD_LINKIT_SMART_7688 + bool "LinkIt Smart 7688" + depends on SOC_MT7620 + select SUPPORTS_BOOT_RAM + help + Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM + and 32 MiB of flash (SPI). + Between its different peripherals there's an integrated switch with 4 + ethernet ports, 1 USB port, 1 UART, GPIO buttons and LEDs, and + a MT7688 (PCIe). + +endchoice + +choice + prompt "Boot mode" + +config BOOT_RAM + bool "RAM boot" + depends on SUPPORTS_BOOT_RAM + select SKIP_LOWLEVEL_INIT + help + This builds an image that is linked to a RAM address. It can be used + for booting from CFE via TFTP using an ELF image, but it can also be + booted from RAM by other bootloaders using a BIN image. + +config BOOT_ROM + bool "ROM boot" + depends on SUPPORTS_BOOT_RAM + help + This builds an image that is linked to a ROM address. It can be + used as main bootloader image which is programmed onto the onboard + flash storage (SPI NOR). + +endchoice + +choice + prompt "DDR2 size" + +config ONBOARD_DDR2_SIZE_256MBIT + bool "256MBit (32MByte) total size" + depends on BOOT_ROM + help + Use 256MBit (32MByte) of DDR total size + +config ONBOARD_DDR2_SIZE_512MBIT + bool "512MBit (64MByte) total size" + depends on BOOT_ROM + help + Use 512MBit (64MByte) of DDR total size + +config ONBOARD_DDR2_SIZE_1024MBIT + bool "1024MBit (128MByte) total size" + depends on BOOT_ROM + help + Use 1024MBit (128MByte) of DDR total size + +config ONBOARD_DDR2_SIZE_2048MBIT + bool "2048MBit (256MByte) total size" + depends on BOOT_ROM + help + Use 2048MBit (256MByte) of DDR total size + +endchoice + +choice + prompt "DDR2 chip width" + +config ONBOARD_DDR2_CHIP_WIDTH_8BIT + bool "8bit DDR chip width" + depends on BOOT_ROM + help + Use DDR chips with 8bit width + +config ONBOARD_DDR2_CHIP_WIDTH_16BIT + bool "16bit DDR chip width" + depends on BOOT_ROM + help + Use DDR chips with 16bit width + +endchoice + +choice + prompt "DDR2 bus width" + +config ONBOARD_DDR2_BUS_WIDTH_16BIT + bool "16bit DDR bus width" + depends on BOOT_ROM + help + Use 16bit DDR bus width + +config ONBOARD_DDR2_BUS_WIDTH_32BIT + bool "32bit DDR bus width" + depends on BOOT_ROM + help + Use 32bit DDR bus width + +endchoice + +config SUPPORTS_BOOT_RAM + bool + +config SKIP_LOWLEVEL_INIT + bool + +source "board/seeed/linkit-smart-7688/Kconfig" + +endmenu diff --git a/arch/mips/mach-mt7620/Makefile b/arch/mips/mach-mt7620/Makefile new file mode 100644 index 0000000000..1f3e65e8a5 --- /dev/null +++ b/arch/mips/mach-mt7620/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += cpu.o + +ifndef CONFIG_SKIP_LOWLEVEL_INIT +obj-y += ddr_calibrate.o +obj-y += lowlevel_init.o +endif diff --git a/arch/mips/mach-mt7620/cpu.c b/arch/mips/mach-mt7620/cpu.c new file mode 100644 index 0000000000..0b22956499 --- /dev/null +++ b/arch/mips/mach-mt7620/cpu.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <dm.h> +#include <ram.h> +#include <asm/io.h> +#include <linux/io.h> +#include <linux/sizes.h> +#include "mt76xx.h" + +#define STR_LEN 6 + +#ifdef CONFIG_BOOT_ROM +int mach_cpu_init(void) +{ + void (*ptr)(void); + + /* + * DDR calibration routine needs to be called very early. This + * function also configures the clock to run at full speed. + */ + ptr = (void *)CKSEG0ADDR(ddr_calibrate); + (*ptr)(); + + return 0; +} +#endif + +int print_cpuinfo(void) +{ + static const char * const boot_str[] = { "PLL (3-Byte SPI Addr)", + "PLL (4-Byte SPI Addr)", + "XTAL (3-Byte SPI Addr)", + "XTAL (4-Byte SPI Addr)" }; + char *chr = (char *)MT76XX_CHIPID; + char buf[STR_LEN + 1]; + u32 val; + + snprintf(buf, STR_LEN + 1, "%s", chr); + val = readl((void *)MT76XX_CHIP_REV_ID); + printf("CPU: %-*s Rev %ld.%ld - ", STR_LEN, buf, + (val & GENMASK(11, 8)) >> 8, val & GENMASK(3, 0)); + + val = (readl((void *)MT76XX_SYSCFG0) & GENMASK(3, 1)) >> 1; + printf("Boot from %s\n", boot_str[val]); + + return 0; +} + +void _machine_restart(void) +{ + writel(0x01, (void *)MT76XX_RSTCTL); + + while (1) + ; /* NOP */ +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, SZ_256M); + + return 0; +} diff --git a/arch/mips/mach-mt7620/ddr_calibrate.c b/arch/mips/mach-mt7620/ddr_calibrate.c new file mode 100644 index 0000000000..6fd136674e --- /dev/null +++ b/arch/mips/mach-mt7620/ddr_calibrate.c @@ -0,0 +1,331 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + * + * This code is mostly based on the code extracted from this MediaTek + * github repository: + * + * https://github.com/MediaTek-Labs/linkit-smart-uboot.git + * + * I was not able to find a specific license or other developers + * copyrights here, so I can't add them here. + * + * Most functions in this file are copied from the MediaTek U-Boot + * repository. Without any documentation, it was impossible to really + * implement this differently. So its mostly a cleaned-up version of + * the original code, with only support for the MT7628 / MT7688 SoC. + */ + +#include <common.h> +#include <linux/io.h> +#include <asm/cacheops.h> +#include <asm/io.h> +#include "mt76xx.h" + +#define NUM_OF_CACHELINE 64 +#define MIN_START 6 +#define MIN_FINE_START 0xf +#define MAX_START 7 +#define MAX_FINE_START 0x0 + +#define CPU_FRAC_DIV 1 + +#if defined(CONFIG_ONBOARD_DDR2_SIZE_256MBIT) +#define DRAM_BUTTOM 0x02000000 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_512MBIT) +#define DRAM_BUTTOM 0x04000000 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_1024MBIT) +#define DRAM_BUTTOM 0x08000000 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_2048MBIT) +#define DRAM_BUTTOM 0x10000000 +#endif + +static inline void cal_memcpy(void *src, void *dst, u32 size) +{ + u8 *psrc = (u8 *)src; + u8 *pdst = (u8 *)dst; + int i; + + for (i = 0; i < size; i++, psrc++, pdst++) + *pdst = *psrc; +} + +static inline void cal_memset(void *src, u8 pat, u32 size) +{ + u8 *psrc = (u8 *)src; + int i; + + for (i = 0; i < size; i++, psrc++) + *psrc = pat; +} + +#define pref_op(hint, addr) \ + __asm__ __volatile__( \ + ".set push\n" \ + ".set noreorder\n" \ + "pref %0, %1\n" \ + ".set pop\n" \ + : \ + : "i" (hint), "R" (*(u8 *)(addr))) + +#define cache_op(op, addr) \ + __asm__ __volatile__( \ + ".set push\n" \ + ".set noreorder\n" \ + ".set mips3\n" \ + "cache %0, %1\n" \ + ".set pop\n" \ + : \ + : "i" (op), "R" (*(u8 *)(addr))) + +static inline void cal_invalidate_dcache_range(u32 start_addr, u32 stop) +{ + u32 lsize = CONFIG_SYS_CACHELINE_SIZE; + u32 addr = start_addr & ~(lsize - 1); + u32 aend = (stop - 1) & ~(lsize - 1); + + while (1) { + cache_op(HIT_INVALIDATE_D, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +static inline void cal_patgen(u32 start_addr, u32 size, u32 bias) +{ + u32 *addr = (u32 *)start_addr; + int i; + + for (i = 0; i < size; i++) + addr[i] = start_addr + i + bias; +} + +static inline int test_loop(int k, int dqs, u32 test_dqs, u32 *coarse_dqs, + u32 offs, u32 pat, u32 val) +{ + u32 nc_addr; + u32 *c_addr; + int i; + + for (nc_addr = 0xa0000000; + nc_addr < (0xa0000000 + DRAM_BUTTOM - NUM_OF_CACHELINE * 32); + nc_addr += (DRAM_BUTTOM >> 6) + offs) { + writel(0x00007474, MT76XX_MEMCTRL_BASE + 0x64); + wmb(); /* Make sure store if finished */ + + c_addr = (u32 *)(nc_addr & 0xdfffffff); + cal_memset(((u8 *)c_addr), 0x1F, NUM_OF_CACHELINE * 32); + cal_patgen(nc_addr, NUM_OF_CACHELINE * 8, pat); + + if (dqs > 0) + writel(0x00000074 | + (((k == 1) ? coarse_dqs[dqs] : test_dqs) << 12) | + (((k == 0) ? val : test_dqs) << 8), + MT76XX_MEMCTRL_BASE + 0x64); + else + writel(0x00007400 | + (((k == 1) ? coarse_dqs[dqs] : test_dqs) << 4) | + (((k == 0) ? val : test_dqs) << 0), + MT76XX_MEMCTRL_BASE + 0x64); + wmb(); /* Make sure store if finished */ + + cal_invalidate_dcache_range((u32)c_addr, + (u32)c_addr + + NUM_OF_CACHELINE * 32); + wmb(); /* Make sure store if finished */ + + for (i = 0; i < NUM_OF_CACHELINE * 8; i++) { + if (i % 8 == 0) + pref_op(0, &c_addr[i]); + } + + for (i = 0; i < NUM_OF_CACHELINE * 8; i++) { + if (c_addr[i] != nc_addr + i + pat) + return -1; + } + } + + return 0; +} + +void ddr_calibrate(void) +{ + u32 min_coarse_dqs[2]; + u32 max_coarse_dqs[2]; + u32 min_fine_dqs[2]; + u32 max_fine_dqs[2]; + u32 coarse_dqs[2]; + u32 fine_dqs[2]; + int reg = 0, ddr_cfg2_reg; + int flag; + int i, k; + int dqs = 0; + u32 min_coarse_dqs_bnd, min_fine_dqs_bnd, coarse_dqs_dll, fine_dqs_dll; + u32 val; + u32 fdiv = 0, frac = 0; + + /* Setup clock to run at full speed */ + val = readl(MT76XX_DYN_CFG0_REG); + fdiv = (u32)((val >> 8) & 0x0F); + if (CPU_FRAC_DIV < 1 || CPU_FRAC_DIV > 10) + frac = val & 0x0f; + else + frac = CPU_FRAC_DIV; + + while (frac < fdiv) { + val = readl(MT76XX_DYN_CFG0_REG); + fdiv = (val >> 8) & 0x0f; + fdiv--; + val &= ~(0x0f << 8); + val |= (fdiv << 8); + writel(val, MT76XX_DYN_CFG0_REG); + udelay(500); + val = readl(MT76XX_DYN_CFG0_REG); + fdiv = (val >> 8) & 0x0f; + } + + clrbits_le32(MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); + ddr_cfg2_reg = readl(MT76XX_MEMCTRL_BASE + 0x48); + clrbits_le32(MT76XX_MEMCTRL_BASE + 0x48, (0x3 << 28) | (0x3 << 26)); + + min_coarse_dqs[0] = MIN_START; + min_coarse_dqs[1] = MIN_START; + min_fine_dqs[0] = MIN_FINE_START; + min_fine_dqs[1] = MIN_FINE_START; + max_coarse_dqs[0] = MAX_START; + max_coarse_dqs[1] = MAX_START; + max_fine_dqs[0] = MAX_FINE_START; + max_fine_dqs[1] = MAX_FINE_START; + dqs = 0; + + /* Add by KP, DQS MIN boundary */ + reg = readl(MT76XX_MEMCTRL_BASE + 0x20); + coarse_dqs_dll = (reg & 0xf00) >> 8; + fine_dqs_dll = (reg & 0xf0) >> 4; + if (coarse_dqs_dll <= 8) + min_coarse_dqs_bnd = 8 - coarse_dqs_dll; + else + min_coarse_dqs_bnd = 0; + + if (fine_dqs_dll <= 8) + min_fine_dqs_bnd = 8 - fine_dqs_dll; + else + min_fine_dqs_bnd = 0; + /* DQS MIN boundary */ + +DQS_CAL: + + for (k = 0; k < 2; k++) { + u32 test_dqs; + + if (k == 0) + test_dqs = MAX_START; + else + test_dqs = MAX_FINE_START; + + do { + flag = test_loop(k, dqs, test_dqs, max_coarse_dqs, + 0x400, 0x3, 0xf); + if (flag == -1) + break; + + test_dqs++; + } while (test_dqs <= 0xf); + + if (k == 0) { + max_coarse_dqs[dqs] = test_dqs; + } else { + test_dqs--; + + if (test_dqs == MAX_FINE_START - 1) { + max_coarse_dqs[dqs]--; + max_fine_dqs[dqs] = 0xf; + } else { + max_fine_dqs[dqs] = test_dqs; + } + } + } + + for (k = 0; k < 2; k++) { + u32 test_dqs; + + if (k == 0) + test_dqs = MIN_START; + else + test_dqs = MIN_FINE_START; + + do { + flag = test_loop(k, dqs, test_dqs, min_coarse_dqs, + 0x480, 0x1, 0x0); + if (k == 0) { + if (flag == -1 || + test_dqs == min_coarse_dqs_bnd) + break; + + test_dqs--; + + if (test_dqs < min_coarse_dqs_bnd) + break; + } else { + if (flag == -1) { + test_dqs++; + break; + } else if (test_dqs == min_fine_dqs_bnd) { + break; + } + + test_dqs--; + + if (test_dqs < min_fine_dqs_bnd) + break; + } + } while (test_dqs >= 0); + + if (k == 0) { + min_coarse_dqs[dqs] = test_dqs; + } else { + if (test_dqs == MIN_FINE_START + 1) { + min_coarse_dqs[dqs]++; + min_fine_dqs[dqs] = 0x0; + } else { + min_fine_dqs[dqs] = test_dqs; + } + } + } + + if (dqs == 0) { + dqs = 1; + goto DQS_CAL; + } + + for (i = 0; i < 2; i++) { + u32 temp; + + coarse_dqs[i] = (max_coarse_dqs[i] + min_coarse_dqs[i]) >> 1; + temp = + (((max_coarse_dqs[i] + min_coarse_dqs[i]) % 2) * 4) + + ((max_fine_dqs[i] + min_fine_dqs[i]) >> 1); + if (temp >= 0x10) { + coarse_dqs[i]++; + fine_dqs[i] = (temp - 0x10) + 0x8; + } else { + fine_dqs[i] = temp; + } + } + reg = (coarse_dqs[1] << 12) | (fine_dqs[1] << 8) | + (coarse_dqs[0] << 4) | fine_dqs[0]; + + clrbits_le32(MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); + writel(reg, MT76XX_MEMCTRL_BASE + 0x64); + writel(ddr_cfg2_reg, MT76XX_MEMCTRL_BASE + 0x48); + setbits_le32(MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); + + for (i = 0; i < 2; i++) + debug("[%02X%02X%02X%02X]", min_coarse_dqs[i], + min_fine_dqs[i], max_coarse_dqs[i], max_fine_dqs[i]); + debug("\nDDR Calibration DQS reg = %08X\n", reg); +} diff --git a/arch/mips/mach-mt7620/lowlevel_init.S b/arch/mips/mach-mt7620/lowlevel_init.S new file mode 100644 index 0000000000..92b2fcd2bb --- /dev/null +++ b/arch/mips/mach-mt7620/lowlevel_init.S @@ -0,0 +1,337 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (c) 2018 Stefan Roese sr@denx.de + * + * This code is mostly based on the code extracted from this MediaTek + * github repository: + * + * https://github.com/MediaTek-Labs/linkit-smart-uboot.git + * + * I was not able to find a specific license or other developers + * copyrights here, so I can't add them here. + */ + +#include <config.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/asm.h> +#include "mt76xx.h" + +#ifndef BIT +#define BIT(nr) (1 << (nr)) +#endif + +#define DELAY_USEC(us) ((us) / 100) + +#define DDR_CFG1_CHIP_WIDTH_MASK (0x3 << 16) +#define DDR_CFG1_BUS_WIDTH_MASK (0x3 << 12) + +#if defined(CONFIG_ONBOARD_DDR2_SIZE_256MBIT) +#define DDR_CFG1_SIZE_VAL 0x222e2323 +#define DDR_CFG4_SIZE_VAL 7 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_512MBIT) +#define DDR_CFG1_SIZE_VAL 0x22322323 +#define DDR_CFG4_SIZE_VAL 9 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_1024MBIT) +#define DDR_CFG1_SIZE_VAL 0x22362323 +#define DDR_CFG4_SIZE_VAL 9 +#endif +#if defined(CONFIG_ONBOARD_DDR2_SIZE_2048MBIT) +#define DDR_CFG1_SIZE_VAL 0x223a2323 +#define DDR_CFG4_SIZE_VAL 9 +#endif + +#if defined(CONFIG_ONBOARD_DDR2_CHIP_WIDTH_8BIT) +#define DDR_CFG1_CHIP_WIDTH_VAL (0x1 << 16) +#endif +#if defined(CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT) +#define DDR_CFG1_CHIP_WIDTH_VAL (0x2 << 16) +#endif + +#if defined(CONFIG_ONBOARD_DDR2_BUS_WIDTH_16BIT) +#define DDR_CFG1_BUS_WIDTH_VAL (0x2 << 12) +#endif +#if defined(CONFIG_ONBOARD_DDR2_BUS_WIDTH_32BIT) +#define DDR_CFG1_BUS_WIDTH_VAL (0x3 << 12) +#endif + +LEAF(lowlevel_init) + /* polling CPLL is ready */ + li t1, DELAY_USEC(1000000) + la t5, MT76XX_ROM_STATUS_REG +1: + lw t2, 0(t5) + andi t2, t2, 0x1 + bnez t2, CPLL_READY + subu t1, t1, 1 + bgtz t1, 1b + nop + la t0, MT76XX_CLKCFG0_REG + lw t3, 0(t0) + ori t3, t3, 0x1 + sw t3, 0(t0) + j CPLL_DONE + nop +CPLL_READY: + la t0, MT76XX_CLKCFG0_REG + lw t1, 0(t0) + li t2, ~0x0c + and t1, t1, t2 + ori t1, t1, 0xc + sw t1, 0(t0) + la t0, MT76XX_DYN_CFG0_REG + lw t3, 0(t0) + li t5, ~((0x0f << 8) | (0x0f << 0)) + and t3, t3, t5 + li t5, (10 << 8) | (1 << 0) + or t3, t3, t5 + sw t3, 0(t0) + la t0, MT76XX_CLKCFG0_REG + lw t3, 0(t0) + li t4, ~0x0F + and t3, t3, t4 + ori t3, t3, 0xc + sw t3, 0(t0) + lw t3, 0(t0) + ori t3, t3, 0x08 + sw t3, 0(t0) + +CPLL_DONE: + /* + * SDR and DDR initialization: delay 200us + */ + li t0, DELAY_USEC(200 + 40) + li t1, 0x1 +1: + sub t0, t0, t1 + bnez t0, 1b + nop + + /* set DRAM IO PAD for MT7628IC */ + /* DDR LDO Enable */ + li t1, MT76XX_RGCTRL_BASE+0x100 + lw t4, 0(t1) + li t2, BIT(31) + or t4, t4, t2 + sw t4, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x10c + lw t4, 0(t1) + j LDO_1P8V + nop +LDO_1P8V: + li t2, ~BIT(6) + and t4, t4, t2 + li t1, MT76XX_RGCTRL_BASE+0x10c + sw t4, 0(t1) + j DDRLDO_SOFT_START +LDO_2P5V: + /* suppose external DDR1 LDO 2.5V */ + li t2, BIT(6) + or t4, t4, t2 + li t1, MT76XX_RGCTRL_BASE+0x10c + sw t4, 0(t1) + +DDRLDO_SOFT_START: + li t1, MT76XX_RGCTRL_BASE+0x10c + lw t2, 0(t1) + li t3, BIT(16) + or t2, t2, t3 + sw t2, 0(t1) + li t3, DELAY_USEC(250*50) +LDO_DELAY: + subu t3, t3, 1 + bnez t3, LDO_DELAY + nop + + li t1, MT76XX_RGCTRL_BASE+0x10c + lw t2, 0(t1) + li t3, BIT(18) + or t2, t2, t3 + sw t2, 0(t1) + +SET_RG_BUCK_FPWM: + li t1, MT76XX_RGCTRL_BASE+0x104 + lw t2, 0(t1) + ori t2, t2, BIT(10) + sw t2, 0(t1) + +DDR_PAD_CFG: + /* clean CLK PAD */ + li t1, MT76XX_RGCTRL_BASE+0x704 + lw t2, 0(t1) + li t8, 0xfffff0f0 + and t2, t2, t8 + /* clean CMD PAD */ + li t1, MT76XX_RGCTRL_BASE+0x70c + lw t3, 0(t1) + li t8, 0xfffff0f0 + and t3, t3, t8 + /* clean DQ IPAD */ + li t1, MT76XX_RGCTRL_BASE+0x710 + lw t4, 0(t1) + li t8, 0xfffff8ff + and t4, t4, t8 + /* clean DQ OPAD */ + li t1, MT76XX_RGCTRL_BASE+0x714 + lw t5, 0(t1) + li t8, 0xfffff0f0 + and t5, t5, t8 + /* clean DQS IPAD */ + li t1, MT76XX_RGCTRL_BASE+0x718 + lw t6, 0(t1) + li t8, 0xfffff8ff + and t6, t6, t8 + /* clean DQS OPAD */ + li t1, MT76XX_RGCTRL_BASE+0x71c + lw t7, 0(t1) + li t8, 0xfffff0f0 + and t7, t7, t8 + + li t1, MT76XX_SYSCTL_BASE+0xC + lw t9, 0(t1) + srl t9, t9, 16 + andi t9, t9, 0x1 + bnez t9, MT7628_AN_DDR1_PAD +MT7628_KN_PAD: + li t8, 0x00000303 + or t2, t2, t8 + or t3, t3, t8 + or t5, t5, t8 + or t7, t7, t8 + li t8, 0x00000000 + or t4, t4, t8 + or t6, t6, t8 + j SET_PAD_CFG +MT7628_AN_DDR1_PAD: + li t1, MT76XX_SYSCTL_BASE+0x10 + lw t1, 0(t1) + andi t1, t1, 0x1 + beqz t1, MT7628_AN_DDR2_PAD + li t8, 0x00000c0c + or t2, t2, t8 + li t8, 0x00000202 + or t3, t3, t8 + li t8, 0x00000707 + or t5, t5, t8 + li t8, 0x00000c0c + or t7, t7, t8 + li t8, 0x00000000 + or t4, t4, t8 + or t6, t6, t8 + j SET_PAD_CFG +MT7628_AN_DDR2_PAD: + li t8, 0x00000c0c + or t2, t2, t8 + li t8, 0x00000202 + or t3, t3, t8 + li t8, 0x00000404 + or t5, t5, t8 + li t8, 0x00000c0c + or t7, t7, t8 + li t8, 0x00000000 /* ODT off */ + or t4, t4, t8 + or t6, t6, t8 + +SET_PAD_CFG: + li t1, MT76XX_RGCTRL_BASE+0x704 + sw t2, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x70c + sw t3, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x710 + sw t4, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x714 + sw t5, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x718 + sw t6, 0(t1) + li t1, MT76XX_RGCTRL_BASE+0x71c + sw t7, 0(t1) + + /* + * DDR initialization: reset pin to 0 + */ + li t1, MT76XX_SYSCTL_BASE + 0x34 + lw t2, 0(t1) + and t2, ~BIT(10) + sw t2, 0(t1) + nop + + /* + * DDR initialization: wait til reg DDR_CFG1 bit 21 equal to 1 (ready) + */ +DDR_READY: + li t1, DDR_CFG1_REG + lw t0, 0(t1) + nop + and t2, t0, BIT(21) + beqz t2, DDR_READY + nop + + /* + * DDR initialization + * + * Only DDR2 supported right now. DDR2 support can be added, once + * boards using it will get added to mainline U-Boot. + */ + li t1, DDR_CFG2_REG + lw t0, 0(t1) + nop + and t0, ~BIT(30) + and t0, ~(7 << 4) + or t0, (4 << 4) + or t0, BIT(30) + or t0, BIT(11) + sw t0, 0(t1) + nop + + li t1, DDR_CFG3_REG + lw t2, 0(t1) + /* Disable ODT; reference board ok, ev board fail */ + and t2, ~BIT(6) + or t2, BIT(2) + li t0, DDR_CFG4_REG + lw t1, 0(t0) + li t2, ~(0x01f | 0x0f0) + and t1, t1, t2 + ori t1, t1, DDR_CFG4_SIZE_VAL + sw t1, 0(t0) + nop + + /* + * DDR initialization: config size and width on reg DDR_CFG1 + */ + li t6, DDR_CFG1_SIZE_VAL + + and t6, ~DDR_CFG1_CHIP_WIDTH_MASK + or t6, DDR_CFG1_CHIP_WIDTH_VAL + + /* CONFIG DDR_CFG1[13:12] about TOTAL WIDTH */ + and t6, ~DDR_CFG1_BUS_WIDTH_MASK + or t6, DDR_CFG1_BUS_WIDTH_VAL + + li t5, DDR_CFG1_REG + sw t6, 0(t5) + nop + + /* + * DDR: enable self auto refresh for power saving + * enable it by default for both RAM and ROM version (for CoC) + */ + li t0, MT76XX_MEMCTRL_BASE + 0x14 + lw t1, 0(t0) + nop + and t1, 0xff000000 + or t1, 0x01 + sw t1, 0(t0) + nop + li t0, MT76XX_MEMCTRL_BASE + 0x10 + lw t1, 0(t0) + nop + or t1, 0x10 + sw t1, 0(t0) + nop + + jr ra + nop + END(lowlevel_init) diff --git a/arch/mips/mach-mt7620/mt76xx.h b/arch/mips/mach-mt7620/mt76xx.h new file mode 100644 index 0000000000..712d8aade0 --- /dev/null +++ b/arch/mips/mach-mt7620/mt76xx.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#ifndef __MT76XX_H +#define __MT76XX_H + +#ifdef __ASSEMBLY__ +#define VOID_PTR +#else +#define VOID_PTR (void *) +#endif + +#define MT76XX_SYSCTL_BASE 0xb0000000 + +#define MT76XX_CHIPID (VOID_PTR(MT76XX_SYSCTL_BASE + 0x00)) +#define MT76XX_CHIP_REV_ID (VOID_PTR(MT76XX_SYSCTL_BASE + 0x0c)) +#define MT76XX_SYSCFG0 (VOID_PTR(MT76XX_SYSCTL_BASE + 0x10)) +#define MT76XX_RSTCTL (VOID_PTR(MT76XX_SYSCTL_BASE + 0x34)) + +#define MT76XX_MEMCTRL_BASE (VOID_PTR(MT76XX_SYSCTL_BASE + 0x0300)) +#define MT76XX_RGCTRL_BASE (VOID_PTR(MT76XX_SYSCTL_BASE + 0x1000)) + +#define MT76XX_ROM_STATUS_REG (VOID_PTR(MT76XX_SYSCTL_BASE + 0x0028)) +#define MT76XX_CLKCFG0_REG (VOID_PTR(MT76XX_SYSCTL_BASE + 0x002c)) +#define MT76XX_DYN_CFG0_REG (VOID_PTR(MT76XX_SYSCTL_BASE + 0x0440)) + +#define DDR_CFG1_REG (MT76XX_MEMCTRL_BASE + 0x44) +#define DDR_CFG2_REG (MT76XX_MEMCTRL_BASE + 0x48) +#define DDR_CFG3_REG (MT76XX_MEMCTRL_BASE + 0x4c) +#define DDR_CFG4_REG (MT76XX_MEMCTRL_BASE + 0x50) + +#ifndef __ASSEMBLY__ +/* Prototypes */ +void ddr_calibrate(void); +#endif + +#endif
This is needed for the UBIFS support. The file is a copy of arch/xtensa/include/asm/atomic.h
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/include/asm/atomic.h | 54 ++++++++++++++++++++++++++++++++++ 1 file changed, 54 insertions(+) create mode 100644 arch/mips/include/asm/atomic.h
diff --git a/arch/mips/include/asm/atomic.h b/arch/mips/include/asm/atomic.h new file mode 100644 index 0000000000..7551bf6e6c --- /dev/null +++ b/arch/mips/include/asm/atomic.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Cadence Design Systems Inc. + */ + +#ifndef _MIPS_ATOMIC_H +#define _MIPS_ATOMIC_H + +#include <asm/system.h> + +typedef struct { volatile int counter; } atomic_t; + +#define ATOMIC_INIT(i) { (i) } + +#define atomic_read(v) ((v)->counter) +#define atomic_set(v, i) ((v)->counter = (i)) + +static inline void atomic_add(int i, atomic_t *v) +{ + unsigned long flags; + + local_irq_save(flags); + v->counter += i; + local_irq_restore(flags); +} + +static inline void atomic_sub(int i, atomic_t *v) +{ + unsigned long flags; + + local_irq_save(flags); + v->counter -= i; + local_irq_restore(flags); +} + +static inline void atomic_inc(atomic_t *v) +{ + unsigned long flags; + + local_irq_save(flags); + ++v->counter; + local_irq_restore(flags); +} + +static inline void atomic_dec(atomic_t *v) +{ + unsigned long flags; + + local_irq_save(flags); + --v->counter; + local_irq_restore(flags); +} + +#endif
2018-08-06 17:11 GMT+02:00 Stefan Roese sr@denx.de:
could you try to import this file from Linux MIPS? Then we would have optimized functions.
Other way would be to import include/asm-generic/atomic.h from Linux so that all architectures in U-Boot could at least use a generic version.
- Copyright (C) 2016 Cadence Design Systems Inc.
v->counter += i;
v->counter -= i;
++v->counter;
--v->counter;
2.18.0
Hi Daniel,
Hmmm, looking at this file and the necessary headers that are not present in U-Boot right now, this seems a bit too much in my taste. Especially since U-Boot is not an OS and does not seed to support all kind of protection against other threads / CPUs.
I also took a quick glance at this and moving away from the asm/atomic.h inclusion in U-Boot seems quite intrusive right now. I would prefer to stay with this "simple" implementation for MIPS and perhaps move to using this one (or a similar one) at a later time, not being in the scope of this MIPS SoC addition.
What do you think? Would this be acceptable?
Thanks, Stefan
Stefan Roese sr@denx.de schrieb am Do., 9. Aug. 2018, 11:27:
Hi Daniel,
Thanks, Stefan
Yes okay, I'll put this onto my todo list
The LinkIt Smart 7688 modules have a MT7688 SoC with 128 MiB of RAM and 32 MiB of flash (SPI NOR).
The mt7628a.dtsi file is imported from Linux v4.17.
This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/dts/linkit-smart-7688.dts | 46 ++++++++ arch/mips/dts/mt7628a.dtsi | 135 ++++++++++++++++++++++ board/seeed/linkit-smart-7688/Kconfig | 12 ++ board/seeed/linkit-smart-7688/MAINTAINERS | 8 ++ board/seeed/linkit-smart-7688/Makefile | 3 + board/seeed/linkit-smart-7688/board.c | 22 ++++ configs/linkit-smart-7688-ram_defconfig | 58 ++++++++++ configs/linkit-smart-7688_defconfig | 62 ++++++++++ include/configs/linkit-smart-7688.h | 48 ++++++++ 9 files changed, 394 insertions(+) create mode 100644 arch/mips/dts/linkit-smart-7688.dts create mode 100644 arch/mips/dts/mt7628a.dtsi create mode 100644 board/seeed/linkit-smart-7688/Kconfig create mode 100644 board/seeed/linkit-smart-7688/MAINTAINERS create mode 100644 board/seeed/linkit-smart-7688/Makefile create mode 100644 board/seeed/linkit-smart-7688/board.c create mode 100644 configs/linkit-smart-7688-ram_defconfig create mode 100644 configs/linkit-smart-7688_defconfig create mode 100644 include/configs/linkit-smart-7688.h
diff --git a/arch/mips/dts/linkit-smart-7688.dts b/arch/mips/dts/linkit-smart-7688.dts new file mode 100644 index 0000000000..df4bf907c6 --- /dev/null +++ b/arch/mips/dts/linkit-smart-7688.dts @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +/dts-v1/; + +#include "mt7628a.dtsi" + +/ { + compatible = "seeed,linkit-smart-7688", "ralink,mt7628a-soc"; + model = "LinkIt-Smart-7688"; + + aliases { + serial0 = &uart2; + spi0 = &spi0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x08000000>; + }; + + chosen { + bootargs = "console=ttyS0,57600"; + stdout-path = &uart2; + }; +}; + +&uart2 { + status = "okay"; + clock-frequency = <40000000>; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi new file mode 100644 index 0000000000..d00f528e1f --- /dev/null +++ b/arch/mips/dts/mt7628a.dtsi @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0 + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "ralink,mt7628a-soc"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "mti,mips24KEc"; + device_type = "cpu"; + reg = <0>; + }; + }; + + resetc: reset-controller { + compatible = "ralink,rt2880-reset"; + #reset-cells = <1>; + }; + + cpuintc: interrupt-controller { + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-controller; + compatible = "mti,cpu-interrupt-controller"; + }; + + palmbus@10000000 { + compatible = "palmbus", "simple-bus"; + reg = <0x10000000 0x200000>; + ranges = <0x0 0x10000000 0x1FFFFF>; + + #address-cells = <1>; + #size-cells = <1>; + + sysc: system-controller@0 { + compatible = "ralink,mt7620a-sysc", "syscon"; + reg = <0x0 0x100>; + }; + + intc: interrupt-controller@200 { + compatible = "ralink,rt2880-intc"; + reg = <0x200 0x100>; + + interrupt-controller; + #interrupt-cells = <1>; + + resets = <&resetc 9>; + reset-names = "intc"; + + interrupt-parent = <&cpuintc>; + interrupts = <2>; + + ralink,intc-registers = <0x9c 0xa0 + 0x6c 0xa4 + 0x80 0x78>; + }; + + memory-controller@300 { + compatible = "ralink,mt7620a-memc"; + reg = <0x300 0x100>; + }; + + spi0: spi@b00 { + compatible = "ralink,mt7621-spi"; + reg = <0xb00 0x40>; + #address-cells = <1>; + #size-cells = <0>; + }; + + uart0: uartlite@c00 { + compatible = "ns16550a"; + reg = <0xc00 0x100>; + + resets = <&resetc 12>; + reset-names = "uart0"; + + interrupt-parent = <&intc>; + interrupts = <20>; + + reg-shift = <2>; + }; + + uart1: uart1@d00 { + compatible = "ns16550a"; + reg = <0xd00 0x100>; + + resets = <&resetc 19>; + reset-names = "uart1"; + + interrupt-parent = <&intc>; + interrupts = <21>; + + reg-shift = <2>; + }; + + uart2: uart2@e00 { + compatible = "ns16550a"; + reg = <0xe00 0x100>; + + resets = <&resetc 20>; + reset-names = "uart2"; + + interrupt-parent = <&intc>; + interrupts = <22>; + + reg-shift = <2>; + }; + }; + + usb_phy: usb-phy@10120000 { + compatible = "mediatek,mt7628-usbphy"; + reg = <0x10120000 0x1000>; + + #phy-cells = <0>; + + ralink,sysctl = <&sysc>; + resets = <&resetc 22 &resetc 25>; + reset-names = "host", "device"; + }; + + ehci@101c0000 { + compatible = "generic-ehci"; + reg = <0x101c0000 0x1000>; + + phys = <&usb_phy>; + phy-names = "usb"; + + interrupt-parent = <&intc>; + interrupts = <18>; + }; +}; diff --git a/board/seeed/linkit-smart-7688/Kconfig b/board/seeed/linkit-smart-7688/Kconfig new file mode 100644 index 0000000000..a9d63285c3 --- /dev/null +++ b/board/seeed/linkit-smart-7688/Kconfig @@ -0,0 +1,12 @@ +if BOARD_LINKIT_SMART_7688 + +config SYS_BOARD + default "linkit-smart-7688" + +config SYS_VENDOR + default "seeed" + +config SYS_CONFIG_NAME + default "linkit-smart-7688" + +endif diff --git a/board/seeed/linkit-smart-7688/MAINTAINERS b/board/seeed/linkit-smart-7688/MAINTAINERS new file mode 100644 index 0000000000..c3bbad4231 --- /dev/null +++ b/board/seeed/linkit-smart-7688/MAINTAINERS @@ -0,0 +1,8 @@ +LINKIT_SMART_7688 BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/seeed/linkit-smart-7688 +F: include/configs/linkit-smart-7688.h +F: configs/linkit-smart-7688_defconfig +F: configs/linkit-smart-7688_ram_defconfig +F: arch/mips/dts/linkit-smart-7688.dts diff --git a/board/seeed/linkit-smart-7688/Makefile b/board/seeed/linkit-smart-7688/Makefile new file mode 100644 index 0000000000..70cd7a8e56 --- /dev/null +++ b/board/seeed/linkit-smart-7688/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += board.o diff --git a/board/seeed/linkit-smart-7688/board.c b/board/seeed/linkit-smart-7688/board.c new file mode 100644 index 0000000000..fbe94cc292 --- /dev/null +++ b/board/seeed/linkit-smart-7688/board.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <asm/io.h> + +#define MT76XX_GPIO1_MODE 0xb0000060 + +void board_debug_uart_init(void) +{ + /* Select UART2 mode instead of GPIO mode (default) */ + clrbits_le32((void __iomem *)MT76XX_GPIO1_MODE, GENMASK(27, 26)); +} + +int board_early_init_f(void) +{ + board_debug_uart_init(); + + return 0; +} diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig new file mode 100644 index 0000000000..4b269f459b --- /dev/null +++ b/configs/linkit-smart-7688-ram_defconfig @@ -0,0 +1,58 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x10000e00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MT7620=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" +CONFIG_DEBUG_UART=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +CONFIG_CMD_LICENSE=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_NET is not set +CONFIG_CMD_TIME=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_CLK=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_4BYTE_MODE_ONLY=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY=y +CONFIG_POWER_DOMAIN=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=57600 +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_MT76XX_SPI=y +CONFIG_SYSRESET_SYSCON=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig new file mode 100644 index 0000000000..cdb8c06517 --- /dev/null +++ b/configs/linkit-smart-7688_defconfig @@ -0,0 +1,62 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0xbc000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x10000e00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MT7620=y +CONFIG_BOOT_ROM=y +CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y +CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" +CONFIG_DEBUG_UART=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +CONFIG_CMD_LICENSE=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_NET is not set +CONFIG_CMD_TIME=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_CLK=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_4BYTE_MODE_ONLY=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY=y +CONFIG_POWER_DOMAIN=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=57600 +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_MT76XX_SPI=y +CONFIG_SYSRESET_SYSCON=y diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h new file mode 100644 index 0000000000..def71ad012 --- /dev/null +++ b/include/configs/linkit-smart-7688.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#ifndef __CONFIG_LINKIT_SMART_7688_H +#define __CONFIG_LINKIT_SMART_7688_H + +/* CPU */ +#define CONFIG_SYS_MIPS_TIMER_FREQ 200000000 + +/* RAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x80000000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +/* UART */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 500000, 1500000 } + +/* RAM */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x80400000 + +/* Memory usage */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) +#define CONFIG_SYS_CBSIZE 512 + +/* U-Boot */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +/* Environment settings */ +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SIZE (16 << 10) +#define CONFIG_ENV_SECT_SIZE (64 << 10) + +/* + * Environment is right behind U-Boot in flash. Make sure U-Boot + * doesn't grow into the environment area. + */ +#define CONFIG_BOARD_SIZE_LIMIT CONFIG_ENV_OFFSET + +#endif /* __CONFIG_LINKIT_SMART_7688_H */
The Gardena Smart-Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional 128MiB SPI NAND storage.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- .../mips/dts/gardena-smart-gateway-mt7688.dts | 54 +++++++++++++++ arch/mips/mach-mt7620/Kconfig | 9 +++ board/gardena/smart-gateway-mt7688/Kconfig | 12 ++++ .../gardena/smart-gateway-mt7688/MAINTAINERS | 8 +++ board/gardena/smart-gateway-mt7688/Makefile | 3 + board/gardena/smart-gateway-mt7688/board.c | 18 +++++ ...gardena-smart-gateway-mt7688-ram_defconfig | 65 ++++++++++++++++++ .../gardena-smart-gateway-mt7688_defconfig | 68 +++++++++++++++++++ .../configs/gardena-smart-gateway-mt7688.h | 52 ++++++++++++++ 9 files changed, 289 insertions(+) create mode 100644 arch/mips/dts/gardena-smart-gateway-mt7688.dts create mode 100644 board/gardena/smart-gateway-mt7688/Kconfig create mode 100644 board/gardena/smart-gateway-mt7688/MAINTAINERS create mode 100644 board/gardena/smart-gateway-mt7688/Makefile create mode 100644 board/gardena/smart-gateway-mt7688/board.c create mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig create mode 100644 configs/gardena-smart-gateway-mt7688_defconfig create mode 100644 include/configs/gardena-smart-gateway-mt7688.h
diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts new file mode 100644 index 0000000000..6b2600a446 --- /dev/null +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +/dts-v1/; + +#include "mt7628a.dtsi" + +/ { + compatible = "gardena,smart-gateway-mt7688", "ralink,mt7628a-soc"; + model = "Gardena smart-Gateway-MT7688"; + + aliases { + serial0 = &uart0; + spi0 = &spi0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x08000000>; + }; + + chosen { + bootargs = "console=ttyS0,57600"; + stdout-path = &uart0; + }; +}; + +&uart0 { + status = "okay"; + clock-frequency = <40000000>; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; + + spi-nand@1 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-nand"; + spi-max-frequency = <25000000>; + reg = <1>; + }; +}; diff --git a/arch/mips/mach-mt7620/Kconfig b/arch/mips/mach-mt7620/Kconfig index 40e15b8a31..75e18d4648 100644 --- a/arch/mips/mach-mt7620/Kconfig +++ b/arch/mips/mach-mt7620/Kconfig @@ -21,6 +21,14 @@ endchoice choice prompt "Board select"
+config BOARD_GARDENA_SMART_GATEWAY_MT7688 + bool "Gardena Smart Gateway" + depends on SOC_MT7620 + select SUPPORTS_BOOT_RAM + help + Gardena Smart Gateway boards have a MT7688 SoC with 128 MiB of RAM + and 8 MiB of flash (SPI NOR) and additional SPI NAND storage. + config BOARD_LINKIT_SMART_7688 bool "LinkIt Smart 7688" depends on SOC_MT7620 @@ -125,6 +133,7 @@ config SUPPORTS_BOOT_RAM config SKIP_LOWLEVEL_INIT bool
+source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
endmenu diff --git a/board/gardena/smart-gateway-mt7688/Kconfig b/board/gardena/smart-gateway-mt7688/Kconfig new file mode 100644 index 0000000000..3653f8aadb --- /dev/null +++ b/board/gardena/smart-gateway-mt7688/Kconfig @@ -0,0 +1,12 @@ +if BOARD_GARDENA_SMART_GATEWAY_MT7688 + +config SYS_BOARD + default "smart-gateway-mt7688" + +config SYS_VENDOR + default "gardena" + +config SYS_CONFIG_NAME + default "gardena-smart-gateway-mt7688" + +endif diff --git a/board/gardena/smart-gateway-mt7688/MAINTAINERS b/board/gardena/smart-gateway-mt7688/MAINTAINERS new file mode 100644 index 0000000000..bbb491c1ce --- /dev/null +++ b/board/gardena/smart-gateway-mt7688/MAINTAINERS @@ -0,0 +1,8 @@ +GARDENA_SMART_GATEWAY_MT7688 BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: board/gardena/smart-gateway-mt7688 +F: include/configs/gardena-smart-gateway-mt7688.h +F: configs/gardena-smart-gateway-mt7688_defconfig +F: configs/gardena-smart-gateway-mt7688-ram_defconfig +F: arch/mips/dts/gardena-smart-gateway-mt7688.dts diff --git a/board/gardena/smart-gateway-mt7688/Makefile b/board/gardena/smart-gateway-mt7688/Makefile new file mode 100644 index 0000000000..70cd7a8e56 --- /dev/null +++ b/board/gardena/smart-gateway-mt7688/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += board.o diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c new file mode 100644 index 0000000000..a62dc654f2 --- /dev/null +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <asm/io.h> + +void board_debug_uart_init(void) +{ + /* Nothing to be done here for this board (no UART setup etc) */ +} + +int board_early_init_f(void) +{ + /* Nothing to be done here for this board (no UART setup etc) */ + return 0; +} diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig new file mode 100644 index 0000000000..03c1618b55 --- /dev/null +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -0,0 +1,65 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x80010000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x10000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MT7620=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" +CONFIG_DEBUG_UART=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +CONFIG_CMD_LICENSE=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MTD=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_NET is not set +CONFIG_CMD_TIME=y +CONFIG_MTDIDS_DEFAULT="spi-nand0=spi-nand0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-nand0:-(ubi)" +CONFIG_CMD_UBI=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_CLK=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MTD=y +CONFIG_MTD_SPI_NAND=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY=y +CONFIG_POWER_DOMAIN=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=57600 +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_SPI_MEM_HALF_DUPLEX=y +CONFIG_MT76XX_SPI=y +CONFIG_SYSRESET_SYSCON=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig new file mode 100644 index 0000000000..777c0723eb --- /dev/null +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -0,0 +1,68 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0xbc000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x10000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MT7620=y +CONFIG_BOOT_ROM=y +CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y +CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +# CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set +# CONFIG_MIPS_BOOT_ENV_LEGACY is not set +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" +CONFIG_DEBUG_UART=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_CPU=y +CONFIG_CMD_LICENSE=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MTD=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_NET is not set +CONFIG_CMD_TIME=y +CONFIG_MTDIDS_DEFAULT="spi-nand0=spi-nand0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-nand0:-(ubi)" +CONFIG_CMD_UBI=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_CLK=y +CONFIG_CPU=y +CONFIG_DM_GPIO=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MTD=y +CONFIG_MTD_SPI_NAND=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY=y +CONFIG_POWER_DOMAIN=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=57600 +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_SPI_MEM_HALF_DUPLEX=y +CONFIG_MT76XX_SPI=y +CONFIG_SYSRESET_SYSCON=y diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h new file mode 100644 index 0000000000..1f168076ce --- /dev/null +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#ifndef __CONFIG_GARDENA_SMART_GATEWAY_H +#define __CONFIG_GARDENA_SMART_GATEWAY_H + +/* CPU */ +#define CONFIG_SYS_MIPS_TIMER_FREQ 200000000 + +/* RAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0x80000000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +/* UART */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 500000, 1500000 } + +/* RAM */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x80400000 + +/* Memory usage */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) +#define CONFIG_SYS_CBSIZE 512 + +/* U-Boot */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +/* Environment settings */ +#define CONFIG_ENV_OFFSET 0x80000 +#define CONFIG_ENV_SIZE (64 << 10) +#define CONFIG_ENV_SECT_SIZE (64 << 10) +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +/* + * Environment is right behind U-Boot in flash. Make sure U-Boot + * doesn't grow into the environment area. + */ +#define CONFIG_BOARD_SIZE_LIMIT CONFIG_ENV_OFFSET + +#endif /* __CONFIG_GARDENA_SMART_GATEWAY_H */
+config ARCH_MT7620
MT7620 has a MIPS 24kc core, thus you could optimize for that
select OF_CONTROL
select DM
select DM_SERIAL
select DM_SPI
select DM_SPI_FLASH
could you sort this in alphabetic order? There were some patches recently which did the sorting tree wide. Also drop the SPI options until you add a SPI driver.
if MIPS
default 0x1000
+config SYS_SOC
+choice
+config SOC_MT7620
bool "MT7620/8"
help
+endchoice
+choice
help
a MT7688 (PCIe).
could you add this part with patch 3/4?
+endchoice
+choice
prompt "Boot mode"
+config BOOT_RAM
bool "RAM boot"
help
+config BOOT_ROM
bool "ROM boot"
help
+endchoice
+choice
prompt "DDR2 size"
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
bool
bool
this is a legacy config option, thus you have to define it in your board config header file. MIPS shouldn't add a Kconfig symbol for that. This have to be migrated to Kconfig tree-wide.
+obj-y += cpu.o
- Copyright (C) 2018 Stefan Roese sr@denx.de
+#define STR_LEN 6
void (*ptr)(void);
(*ptr)();
what is the purpose of forcing the function symbol to KSEG0?
+} +#endif
u32 val;
could you try to create a CPU driver like on BMIPS?
while (1)
; /* NOP */
could you try to create a reset controller driver? Then you could also use the generic syscon-reboot driver.
shouldn't you return the real configured DRAM size here?
- This code is mostly based on the code extracted from this MediaTek
- github repository:
- I was not able to find a specific license or other developers
- copyrights here, so I can't add them here.
- Most functions in this file are copied from the MediaTek U-Boot
- repository. Without any documentation, it was impossible to really
- implement this differently. So its mostly a cleaned-up version of
- the original code, with only support for the MT7628 / MT7688 SoC.
int i;
*pdst = *psrc;
int i;
*psrc = pat;
".set push\n" \
"pref %0, %1\n" \
".set pop\n" \
".set push\n" \
".set mips3\n" \
"cache %0, %1\n" \
".set pop\n" \
cache_op() is already available in arch/mips/include/asm/cacheops.h. Maybe you could add pref_op in the same way to that file.
while (1) {
if (addr == aend)
break;
addr += lsize;
you should use the generic MIPS implementation instead
int i;
u32 nc_addr;
u32 *c_addr;
int i;
if (dqs > 0)
writel(0x00000074 |
else
writel(0x00007400 |
(u32)c_addr +
if (i % 8 == 0)
return -1;
u32 coarse_dqs[2];
u32 fine_dqs[2];
int flag;
int i, k;
int dqs = 0;
u32 val;
frac = val & 0x0f;
else
fdiv--;
val |= (fdiv << 8);
udelay(500);
dqs = 0;
else
else
+DQS_CAL:
u32 test_dqs;
if (k == 0)
else
do {
0x400, 0x3, 0xf);
if (flag == -1)
break;
test_dqs++;
if (k == 0) {
} else {
test_dqs--;
} else {
u32 test_dqs;
if (k == 0)
else
do {
0x480, 0x1, 0x0);
if (k == 0) {
if (flag == -1 ||
break;
test_dqs--;
break;
} else {
if (flag == -1) {
test_dqs++;
break;
break;
test_dqs--;
break;
if (k == 0) {
} else {
} else {
if (dqs == 0) {
dqs = 1;
goto DQS_CAL;
u32 temp;
temp =
if (temp >= 0x10) {
coarse_dqs[i]++;
} else {
fine_dqs[i] = temp;
- (c) 2018 Stefan Roese sr@denx.de
+1:
lw t2, 0(t5)
andi t2, t2, 0x1
bnez t2, CPLL_READY
subu t1, t1, 1
bgtz t1, 1b
nop
lw t3, 0(t0)
ori t3, t3, 0x1
sw t3, 0(t0)
j CPLL_DONE
nop
+CPLL_READY:
lw t1, 0(t0)
li t2, ~0x0c
and t1, t1, t2
ori t1, t1, 0xc
sw t1, 0(t0)
lw t3, 0(t0)
and t3, t3, t5
or t3, t3, t5
sw t3, 0(t0)
lw t3, 0(t0)
li t4, ~0x0F
and t3, t3, t4
ori t3, t3, 0xc
sw t3, 0(t0)
lw t3, 0(t0)
ori t3, t3, 0x08
sw t3, 0(t0)
+CPLL_DONE:
li t1, 0x1
+1:
sub t0, t0, t1
bnez t0, 1b
nop
lw t4, 0(t1)
li t2, BIT(31)
or t4, t4, t2
sw t4, 0(t1)
lw t4, 0(t1)
j LDO_1P8V
nop
+LDO_1P8V:
li t2, ~BIT(6)
and t4, t4, t2
sw t4, 0(t1)
j DDRLDO_SOFT_START
+LDO_2P5V:
li t2, BIT(6)
or t4, t4, t2
sw t4, 0(t1)
+DDRLDO_SOFT_START:
lw t2, 0(t1)
li t3, BIT(16)
or t2, t2, t3
sw t2, 0(t1)
+LDO_DELAY:
subu t3, t3, 1
bnez t3, LDO_DELAY
nop
lw t2, 0(t1)
li t3, BIT(18)
or t2, t2, t3
sw t2, 0(t1)
+SET_RG_BUCK_FPWM:
lw t2, 0(t1)
ori t2, t2, BIT(10)
sw t2, 0(t1)
+DDR_PAD_CFG:
/* clean CLK PAD */
lw t2, 0(t1)
li t8, 0xfffff0f0
and t2, t2, t8
/* clean CMD PAD */
lw t3, 0(t1)
li t8, 0xfffff0f0
and t3, t3, t8
/* clean DQ IPAD */
lw t4, 0(t1)
li t8, 0xfffff8ff
and t4, t4, t8
/* clean DQ OPAD */
lw t5, 0(t1)
li t8, 0xfffff0f0
and t5, t5, t8
lw t6, 0(t1)
li t8, 0xfffff8ff
and t6, t6, t8
lw t7, 0(t1)
li t8, 0xfffff0f0
and t7, t7, t8
lw t9, 0(t1)
srl t9, t9, 16
andi t9, t9, 0x1
+MT7628_KN_PAD:
li t8, 0x00000303
or t2, t2, t8
or t3, t3, t8
or t5, t5, t8
or t7, t7, t8
li t8, 0x00000000
or t4, t4, t8
or t6, t6, t8
j SET_PAD_CFG
lw t1, 0(t1)
andi t1, t1, 0x1
li t8, 0x00000c0c
or t2, t2, t8
li t8, 0x00000202
or t3, t3, t8
li t8, 0x00000707
or t5, t5, t8
li t8, 0x00000c0c
or t7, t7, t8
li t8, 0x00000000
or t4, t4, t8
or t6, t6, t8
j SET_PAD_CFG
li t8, 0x00000c0c
or t2, t2, t8
li t8, 0x00000202
or t3, t3, t8
li t8, 0x00000404
or t5, t5, t8
li t8, 0x00000c0c
or t7, t7, t8
or t4, t4, t8
or t6, t6, t8
+SET_PAD_CFG:
sw t2, 0(t1)
sw t3, 0(t1)
sw t4, 0(t1)
sw t5, 0(t1)
sw t6, 0(t1)
sw t7, 0(t1)
lw t2, 0(t1)
and t2, ~BIT(10)
sw t2, 0(t1)
nop
+DDR_READY:
li t1, DDR_CFG1_REG
lw t0, 0(t1)
nop
and t2, t0, BIT(21)
beqz t2, DDR_READY
nop
li t1, DDR_CFG2_REG
lw t0, 0(t1)
nop
and t0, ~BIT(30)
and t0, ~(7 << 4)
or t0, (4 << 4)
or t0, BIT(30)
or t0, BIT(11)
sw t0, 0(t1)
nop
li t1, DDR_CFG3_REG
lw t2, 0(t1)
and t2, ~BIT(6)
or t2, BIT(2)
li t0, DDR_CFG4_REG
lw t1, 0(t0)
and t1, t1, t2
sw t1, 0(t0)
nop
li t5, DDR_CFG1_REG
sw t6, 0(t5)
nop
lw t1, 0(t0)
nop
and t1, 0xff000000
or t1, 0x01
sw t1, 0(t0)
nop
lw t1, 0(t0)
nop
or t1, 0x10
sw t1, 0(t0)
nop
jr ra
nop
END(lowlevel_init)
2.18.0
Hi Daniel,
+config ARCH_MT7620
Okay.
select OF_CONTROL
select DM
select DM_SERIAL
select DM_SPI
select DM_SPI_FLASH
Okay, will do in v2.
The SPI driver is also on the list:
http://patchwork.ozlabs.org/patch/954365/
if MIPS
default 0x1000
+config SYS_SOC
+choice
+config SOC_MT7620
bool "MT7620/8"
help
+endchoice
+choice
help
a MT7688 (PCIe).
Ah, yes. This slipped in too early.
+endchoice
+choice
prompt "Boot mode"
+config BOOT_RAM
bool "RAM boot"
help
+config BOOT_ROM
bool "ROM boot"
help
+endchoice
+choice
prompt "DDR2 size"
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
bool
bool
Will move to config header for now.
Sure.
+obj-y += cpu.o
+#define STR_LEN 6
void (*ptr)(void);
(*ptr)();
Its copied from the original MediaTek code. I just tested it without forcing the execution into KSEG0 and the DDR calibration is extremely slow then, taking a few minutes to complete.
I have to admit that I am not 100% sure, if the caches are configured 100% correctly / optimally for this SoC. Perhaps you (or someone else) has some improvements here.
+} +#endif
u32 val;
Do you really think this is necessary just for printing some SoC information here?
while (1)
; /* NOP */
Yes, I also thought about this. Will do in v2.
I always like using get_ram_size() as it automatically detects the RAM size. This might be different (smaller) than the one configured, if HW problems with the DDR interface exist.
We might think about printing a warning, if the detected size does not match the configured one.
int i;
*pdst = *psrc;
int i;
*psrc = pat;
".set push\n" \
"pref %0, %1\n" \
".set pop\n" \
".set push\n" \
".set mips3\n" \
"cache %0, %1\n" \
".set pop\n" \
Hmm, Where exactly?
Could make sense, but please see above. Again, I'm still pretty new to MIPS and especially the caches.
while (1) {
if (addr == aend)
break;
addr += lsize;
Yes, makes sense.
Thanks, Stefan
Am Do., 9. Aug. 2018 um 12:46 Uhr schrieb Stefan Roese sr@denx.de:
Hi Daniel,
+config ARCH_MT7620
Okay.
select OF_CONTROL
select DM
select DM_SERIAL
select DM_SPI
select DM_SPI_FLASH
ok, I didn't received this one. But since SPI is not strictly required, you should prefer "imply" instead of a hard "select".
if MIPS
default 0x1000
+config SYS_SOC
+choice
+config SOC_MT7620
bool "MT7620/8"
help
+endchoice
+choice
help
a MT7688 (PCIe).
+endchoice
+choice
prompt "Boot mode"
+config BOOT_RAM
bool "RAM boot"
help
+config BOOT_ROM
bool "ROM boot"
help
+endchoice
+choice
prompt "DDR2 size"
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
bool
bool
Sure.
+obj-y += cpu.o
+#define STR_LEN 6
void (*ptr)(void);
(*ptr)();
I guess the BootROM does some XiP magic with the SPI flash controller and runs in the uncached KSEG1 segment. That would explain why the pre-relocation code runs so slowly. But this shift from KSEG1 to KSEG0 could be done generically in start.S after the cache initialization is complete. I will have a look at it.
+} +#endif
u32 val;
according to the datasheet those registers are in the memory space of the system controller block. Thus you should create at least a syscon driver. Also the device tree you're going to add references this syscon device.
while (1)
; /* NOP */
int i;
*pdst = *psrc;
int i;
*psrc = pat;
".set push\n" \
"pref %0, %1\n" \
".set pop\n" \
".set push\n" \
".set mips3\n" \
"cache %0, %1\n" \
".set pop\n" \
Hmm, Where exactly?
sorry, I meant mips_cache()
I noticed prefetch() is already defined in arch/mips/include/asm/processor.h. You could utilize it if you add a boolean Kconfig option CONFIG_CPU_HAS_PREFETCH in arch/mips/Kconfig and select it for MT7620.
while (1) {
if (addr == aend)
break;
addr += lsize;
Yes, makes sense.
Thanks, Stefan
-- - Daniel
Hi Daniel,
Hi Daniel,
+config ARCH_MT7620
Okay.
select OF_CONTROL
select DM
select DM_SERIAL
select DM_SPI
select DM_SPI_FLASH
I've not seen an MT76xx board without SPI NOR flash, but this is okay, I will turn this option into an "imply" instead in v2.
if MIPS
default 0x1000
+config SYS_SOC
+choice
+config SOC_MT7620
bool "MT7620/8"
help
+endchoice
+choice
help
a MT7688 (PCIe).
+endchoice
+choice
prompt "Boot mode"
+config BOOT_RAM
bool "RAM boot"
help
+config BOOT_ROM
bool "ROM boot"
help
+endchoice
+choice
prompt "DDR2 size"
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
+choice
depends on BOOT_ROM
help
depends on BOOT_ROM
help
+endchoice
bool
bool
Sure.
+obj-y += cpu.o
+#define STR_LEN 6
void (*ptr)(void);
(*ptr)();
That would be great. Please let me know if you need some help with testing etc.
+} +#endif
u32 val;
Yes, this would be a plus, to get rid of the base address definition in the header and use the DT here. I'll take a look...
while (1)
; /* NOP */
int i;
*pdst = *psrc;
int i;
*psrc = pat;
".set push\n" \
"pref %0, %1\n" \
".set pop\n" \
".set push\n" \
".set mips3\n" \
"cache %0, %1\n" \
".set pop\n" \
Hmm, Where exactly?
Not needed anymore when moved to using the generic invalidate dcache function.
Yes. But which implementation is the correct one for this SoC?
#define PREF(hint, addr) \ .set push; \ .set arch=r5000; \ pref hint, addr; \ .set pop
#define PREFE(hint, addr) \ .set push; \ .set mips0; \ .set eva; \ prefe hint, addr; \ .set pop
#define PREFX(hint, addr) \ .set push; \ .set arch=r5000; \ prefx hint, addr; \ .set pop
Thanks, Stefan
+#define STR_LEN 6
could you try branch mips_optimize_cache_init from git://git.denx.de/u-boot-mips.git. You have to change your text base from 0xbc000000 to 0x9c000000 to execute all code prior relocation from the cached KSEG0 segment. The code should now run fast without that function pointer magic.
For now the patch series is only tested in Qemu and needs some more cleanup. I'll try to do some testing on real hardware in the next days.
Hi Daniel,
+#define STR_LEN 6
I'm back from a short trip and tested these 2 patches in my current internal branch. It works great, thanks! The speedup is impressive.
How would you like to proceed? Should I re-send my MT7688 SoC port again with the functions pointer magic removed? Or will you pull this version first and your cache improvement later? I can always change this ddr_calibrate() pointer magic at a later time (and change the TEXT_BASE).
Thanks, Stefan
Daniel Schwierzeck
Stefan Roese
