[PATCH] arm: rockchip: Fix binman_init failure on RK3568
For some newer SoCs like RK3568, the Rockchip has not released any DDR drivers yet so idbloader needs to create manually using DDR binaries offered by rkbin. This indeed no requirement to enable TPL in the U-Boot source code.
If we mark TPL disabled and mark BINMAN enabled by default then there would be an issue of binman_init failure during board relocation. This is true as binman failed to find the top-level node like u-boot-tpl here.
Here is the boot issue observed in RK3566 board,
U-Boot 2023.01-rc4-00057-gac2505d463-dirty (Jan 04 2023 - 23:44:18 +0530)
Model: Radxa Compute Module 3(CM3) IO Board DRAM: 2 GiB binman_init failed:-2 initcall sequence 000000007ffd2008 failed at call 0000000000a18cac (err=-2) ### ERROR ### Please RESET the board ###
This might be fixed via binman node in rockchip-u-boot.dtsi however disable binman for rk3568 for now as we are at the end of the release cycle.
Fixes: 05713d570762 ("rockchip: generate u-boot-rockchip.bin with binman for ARM64 boards") Cc: Quentin Schulz quentin.schulz@theobroma-systems.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index cac4fa09fd..0e7a511c79 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1934,7 +1934,7 @@ config ARCH_STM32MP config ARCH_ROCKCHIP bool "Support Rockchip SoCs" select BLK - select BINMAN if SPL_OPTEE || SPL + select BINMAN if SPL_OPTEE || (SPL && !ROCKCHIP_RK3568) select DM select DM_GPIO select DM_I2C
Hi Jagan,
This function seems to not be called if you do NOT define BINMAN_FDT Kconfig option. Is this something you could check? I see that STM32 boards and some Mediatek ones have this disabled. The benefit would be to still have binman build the images like all other rockchip platforms but let your RK336x board boot properly.
I'm wondering what this binman_init is needed for? It seems to me that the functions defined in lib/binman.c are actually used only in x86 platforms?
Cheers, Quentin
Hi Quentin,
On Thu, Jan 5, 2023 at 2:58 PM Quentin Schulz quentin.schulz@theobroma-systems.com wrote:
Hi Jagan,
I did check by disabling BINMAN_FDT before sending this patch, looks like I have tested with the existing build. Now yes, BINMAN_FDT disabled seems to boot fine.
I think it makes sense to disable BINMAN_FDT on respective defconfig as we might move binman in the future.
Any comments Kever?
Jagan.
- select BINMAN if SPL_OPTEE || (SPL && !ROCKCHIP_RK3568)
BINMAN should be available only when both TPL and SPL are available.
if no TPL, means there is no DDR binary available, so not able to use binman to generate
the image.
Thanks, - Kever
Hi Kever,
the image.
Binman can still generate u-boot.itb, u-boot-spl.bin and co. The final u-boot-rockchip.bin won't work indeed, until we fix this in another ifdef madness for cases where TPL/SPL is an external blob and not created by U-Boot.
In next release (not 2023.01) I have high hopes we can have fully migrated to binman, which makes me a bit sad we go a step back by disabling it for RK356x :/
But since the release is a question of days now, maybe that's fine, I don't know. You're the maintainer :)
Cheers, Quentin
Jagan Teki
Kever Yang
Quentin Schulz
