[U-Boot] [PATCH] warp: Add a README file
Provide instructions on how to upgrade U-boot in the eMMC.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/warp/README | 56 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 56 insertions(+) create mode 100644 board/warp/README
diff --git a/board/warp/README b/board/warp/README new file mode 100644 index 0000000..da77542 --- /dev/null +++ b/board/warp/README @@ -0,0 +1,56 @@ +How to Update U-boot on Warp board +---------------------------------- + +Required software on the host PC: + +- imx_loader: https://github.com/warpboard/imx_usb_loader + +- dfu-util: http://dfu-util.sourceforge.net/releases/ + +Build U-boot for Warp: + +$ make mrproper +$ make warp_config +$ make + +This will generate the U-boot binary called u-boot.imx. + +Put warp board in USB download mode + +Connect a USB to serial adapter between the host PC and warp + +Connect a USB cable between the OTG warp port and the host PC + +Open a terminal program such as minicom + +Copy u-boot.imx to the imx_usb folder. + +Load u-boot.imx via USB: + +$ sudo ./imx_usb + +Then U-boot should start and its messages will appear in the console program. + +Use the default environment variables: + +=> env default -f -a +=> save + +Run the DFU command: +=> dfu 0 mmc 0 + +Transfer u-boot.imx that will be flashed into the eMMC: + +$ sudo dfu-util -D u-boot.imx -a boot + +Then on the U-boot prompt the following message should be seen after a succesful +upgrade: + +#DOWNLOAD ... OK +Ctrl+C to exit ... + +Remove power from the warp board. + +Put warp board into normal boot mode + +Power up the board and the new updated U-boot should boot from eMMC
On Mon, Mar 2, 2015 at 10:20 AM, Fabio Estevam fabio.estevam@freescale.com wrote:
I see no reason to link WaRP's fork. The Boundary Devices upstream code offers a more up to date bases and I think we should give them the credit for the tool. Mind to change it?
+$ sudo ./imx_usb
$ sudo ./imx_usb <path to u-boot.imx>
I think this is not needed as the environment will be rewritten when the U-Boot is overridden.
Hi Otavio,
On Mon, Mar 2, 2015 at 11:52 AM, Otavio Salvador otavio@ossystems.com.br wrote:
No problem for me to link Boundary Device's tree, but then we would need to create a mx6sl_usb_work.conf in this tree, so that the LOADADDR could be adapted for mx6sl. Then we also need to pass mx6sl_usb_work.conf in the imx_usb command line.
Eric,
What do you think?
+$ sudo ./imx_usb
It worked for me without the extra arg, but I can pass the arg in this Howto to make it clearer.
I tested it and the env ins not overwritten, so we need to explicitly overwrite the envs in order to have the correct dfu_alt_info variable for DFU to work.
Regards,
Fabio Estevam
Hi Fabio,
On 03/02/2015 08:33 AM, Fabio Estevam wrote:
Hi Otavio,
Eric,
What do you think?
It's probably best to use ours, but we're okay either way.
I wasn't aware that Warp had forked imx_usb_loader, but a quick read shows that it's behind by a couple of (minor) updates.
As for the mx6sl_usb_work.conf file, we'll certainly allow the Warp-specific version to be stored in our repository as long as it's named for the Warp
i.e.: mx6sl_usb_work-warp.conf
If somebody want to push a pull request, we'll be happy to stash it there.
Regards,
Eric
Hi Eric,
On Mon, Mar 2, 2015 at 12:48 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
I have just tested top of tree imx_usb_loader from Boundary Device and it can load U-boot on mx6sl without any change.
Thanks,
Fabio Estevam
On 03/02/2015 08:52 AM, Fabio Estevam wrote:
Hi Eric,
Cool. Glad to hear it.
Eric Nelson
Fabio Estevam
Fabio Estevam
Otavio Salvador
