[PATCH] env: ti: boot: Fix Android boot on AM57x EVM
When applying DTBO on top of DTB (with "fdt apply" command) on AM57x EVM board, there is not enough memory reserved in RAM for DTB blob. Hence, DTBO can't be merged in DTB. It leads to inability to boot Android with next error message:
failed on fdt_overlay_apply(): FDT_ERR_NOSPACE
To overcome that issue let's provide 1 MiB of space to keep DTB and all merged DTBO blobs. To do so, "length" parameter should be specified for "fdt addr" command:
=> fdt addr $fdtaddr 0x100000
Also add size variables to 'adtimg' command invocations, to avoid cluttering the console with DTBO blob sizes.
Signed-off-by: Sam Protsenko joe.skb7@gmail.com --- include/environment/ti/boot.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h index 523c8fc4fe..298c972cd0 100644 --- a/include/environment/ti/boot.h +++ b/include/environment/ti/boot.h @@ -103,18 +103,18 @@ "echo " Reading DTB for AM57x EVM RevA3..."; " \ "abootimg get dtb --index=0 dtb_start dtb_size; " \ "cp.b $dtb_start $fdtaddr $dtb_size; " \ - "fdt addr $fdtaddr; " \ + "fdt addr $fdtaddr 0x100000; " \ "echo " Applying DTBOs for AM57x EVM RevA3..."; " \ "adtimg addr $dtboaddr; " \ - "adtimg get dt --index=0 dtbo0_addr; " \ + "adtimg get dt --index=0 dtbo0_addr dtbo0_size; " \ "fdt apply $dtbo0_addr; " \ - "adtimg get dt --index=1 dtbo1_addr; " \ + "adtimg get dt --index=1 dtbo1_addr dtbo1_size; " \ "fdt apply $dtbo1_addr; " \ "elif test $board_name = beagle_x15_revc; then " \ "echo " Reading DTB for Beagle X15 RevC..."; " \ "abootimg get dtb --index=0 dtb_start dtb_size; " \ "cp.b $dtb_start $fdtaddr $dtb_size; " \ - "fdt addr $fdtaddr; " \ + "fdt addr $fdtaddr 0x100000; " \ "else " \ "echo Error: Android boot is not supported for $board_name; " \ "exit; " \
Hi Sam,
I am not an everyday user of this platform, hence curious what are the usual sizes of DTB and DTBO files employed in Android booting?
For comparison, below are the sizes of R-Car3 DTB (Linux v5.6-rc2):
$ du -sh arch/arm64/boot/dts/renesas/r8a779*dtb | sort -n 32K arch/arm64/boot/dts/renesas/r8a77961-salvator-xs.dtb 32K arch/arm64/boot/dts/renesas/r8a77980-v3hsk.dtb 44K arch/arm64/boot/dts/renesas/r8a77990-ebisu.dtb 52K arch/arm64/boot/dts/renesas/r8a77965-ulcb.dtb 60K arch/arm64/boot/dts/renesas/r8a77960-ulcb.dtb 60K arch/arm64/boot/dts/renesas/r8a77965-salvator-x.dtb 60K arch/arm64/boot/dts/renesas/r8a77965-salvator-xs.dtb 60K arch/arm64/boot/dts/renesas/r8a77965-ulcb-kf.dtb 64K arch/arm64/boot/dts/renesas/r8a77960-salvator-x.dtb 64K arch/arm64/boot/dts/renesas/r8a77960-salvator-xs.dtb 64K arch/arm64/boot/dts/renesas/r8a77960-ulcb-kf.dtb 68K arch/arm64/boot/dts/renesas/r8a77950-ulcb.dtb 68K arch/arm64/boot/dts/renesas/r8a77951-ulcb.dtb 72K arch/arm64/boot/dts/renesas/r8a77950-salvator-x.dtb 72K arch/arm64/boot/dts/renesas/r8a77950-ulcb-kf.dtb 72K arch/arm64/boot/dts/renesas/r8a77951-salvator-x.dtb 72K arch/arm64/boot/dts/renesas/r8a77951-salvator-xs.dtb 72K arch/arm64/boot/dts/renesas/r8a77951-ulcb-kf.dtb
FWIW based on the above values, Renesas scripts reserve 512K for DTB.
Looks good to me.
Reviewed-by: Eugeniu Rosca rosca.eugeniu@gmail.com
Hi Eugeniu,
On Thu, Feb 20, 2020 at 4:33 PM Eugeniu Rosca erosca@de.adit-jv.com wrote:
Hi Sam,
DTB/DTBO files are not big for AM57x EVM, the same order of magnitude as yours. Actually it makes sense to reduce 1 MiB I used to 512 KiB, because:
fdtaddr=0x88000000
and next used address after this:
rdaddr=0x88080000
so if I make the fdt size = 512 KiB, it gives us exactly the gap between $fdtaddr and $rdaddr, which is 0x80000.
Thanks for the review! I will send v2 soon.
Looks good to me.
-- Best Regards Eugeniu Rosca
Eugeniu Rosca
Sam Protsenko
