[PATCHv2] net: uclass: Save ethernet MAC address when generated
When MAC address is randomly generated it should be also saved to variables. This step is there when MAC address is passed via pdata but not when it is randomly generated.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Ramon Fried rfried.dev@gmail.com [trini: Update Kconfig, handle legacy networking case as well] Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Update Kconfig help text to reflect this change. - Update the legacy path to match. --- net/Kconfig | 6 +++--- net/eth-uclass.c | 2 ++ net/eth_legacy.c | 2 ++ 3 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/net/Kconfig b/net/Kconfig index 7a2d14501881..20a36156a01f 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -28,9 +28,9 @@ config NET_RANDOM_ETHADDR bool "Random ethaddr if unset" help Selecting this will allow the Ethernet interface to function - even when the ethaddr variable for that interface is unset. - A new MAC address will be generated on every boot and it will - not be added to the environment. + even when the ethaddr variable for that interface is unset by + generating a new MAC address in the locally administered address + space and setting the appropriate environment variable.
config NETCONSOLE bool "NetConsole support" diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 0da0e85be031..58c308f33276 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -583,6 +583,8 @@ static int eth_post_probe(struct udevice *dev) net_random_ethaddr(pdata->enetaddr); printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", dev->name, dev_seq(dev), pdata->enetaddr); + eth_env_set_enetaddr_by_index("eth", dev_seq(dev), + pdata->enetaddr); #else printf("\nError: %s address not set.\n", dev->name); diff --git a/net/eth_legacy.c b/net/eth_legacy.c index f383ccce0b92..e7f53b958b2e 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -164,6 +164,8 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, net_random_ethaddr(dev->enetaddr); printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", dev->name, eth_number, dev->enetaddr); + eth_env_set_enetaddr_by_index("eth", dev_seq(dev), + pdata->enetaddr); #else printf("\nError: %s address not set.\n", dev->name);
Dear Tom,
"saved to variables" ? Which variables? In C code? In the environment?
This is not clear here.
Same here: "ethaddr variable" - I guess this refers to the environment variable? Then we should write that.
Hmmm: "when the ethaddr variable ... is unset by generating ... and setting the appropriate environment variable." this is misleading, as the "ethaddr variable" is not unset by setting the env var.
Suggestion:
Selecting this will allow the Ethernet interface to function even when the ethaddr variable for that interface is unset. In this case, a random MAC address in the locally administered address space is generated. It will be saved to the appropriate environment variable, too.
