[U-Boot] [PATCH v3 0/16] tegra: Add fdt definitions and USB driver
This series brings in the kernel fdt file and provides a working USB driver for Tegra2 Seaboard.
(I have done this in one series since otherwise most of the fdt additions will just look like dead code.)
The driver requires CONFIG_OF_CONTROL and a device tree to operate.
Some enhancements to fdtdec are required to make this easier, and these are included in the series also. I have had to bring in basic GPIO support due to the request to put the USB VBUS into the fdt.
Since the kernel recently got a very minimal USB binding, I have started with that and extended it where appropriate.
Tegra likes to have cache-aligned buffers. I have dropped the patch which implements this since we will solve this problem by making callers align their buffers (as we did with MMC).
Changes in v2: - Use "okay" instead of "ok" for fdt node status - Remove 0x from fdt aliases - Rename params to timing - Store entire fdt config in port list, not just register pointer - Remove non-fdt operation of USB, since it is not needed - Decode USB VBUS GPIO from the fdt - Decode phy type differently (to match new kernel fdt) - Rename tegra20-usb to tegra20-ehcui (to match new kernel fdt) - Improve debug() printouts in case of failure to init USB - Add setting of pinmux for USB VBUS GPIO - Remove unneeded CONFIG_TEGRA_USBx defines
Changes in v3: - Remove "okay" from nodes since this is the default anyway - Fix device tree indenting with tabs instead of spaces - Disable USB2 which is not used on Seaboard - Remove usbparams properties from fdt and moved them to C code - Drop Tegra USB alignment patch as we will deal with this another way
Simon Glass (16): fdt: Tidy up a few fdtdec problems fdt: Add functions to access phandles, arrays and bools Add gpio_request() to asm-generic header fdt: Add basic support for decoding GPIO definitions arm: fdt: Ensure that an embedded fdt is word-aligned arm: fdt: Add skeleton device tree file from kernel tegra: fdt: Add Tegra2x device tree file from kernel tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard usb: Add support for txfifo threshold tegra: usb: Add support for Tegra USB peripheral tegra: usb: Add USB support to nvidia boards tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Enable USB on Seaboard tegra: fdt: Enable FDT support for Seaboard
README | 3 + arch/arm/cpu/armv7/tegra2/Makefile | 4 +- arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/cpu/armv7/tegra2/usb.c | 430 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/u-boot.lds | 5 + arch/arm/dts/skeleton.dtsi | 13 + arch/arm/dts/tegra20.dtsi | 172 ++++++++++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 2 + arch/arm/include/asm/arch-tegra2/usb.h | 255 +++++++++++++++++ board/nvidia/common/board.c | 8 + board/nvidia/dts/tegra2-seaboard.dts | 47 ++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-hcd.c | 7 + drivers/usb/host/ehci-tegra.c | 63 +++++ drivers/usb/host/ehci.h | 6 +- dts/Makefile | 2 +- include/asm-generic/gpio.h | 10 + include/configs/seaboard.h | 12 + include/configs/tegra2-common.h | 14 + include/fdtdec.h | 109 +++++++- lib/fdtdec.c | 168 +++++++++++- 21 files changed, 1320 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/usb.c create mode 100644 arch/arm/dts/skeleton.dtsi create mode 100644 arch/arm/dts/tegra20.dtsi create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 board/nvidia/dts/tegra2-seaboard.dts create mode 100644 drivers/usb/host/ehci-tegra.c
This fixes five trivial issues in fdtdec.c: 1. fdtdec_get_is_enabled() doesn't really need a default value 2. The fdt must be word-aligned, since otherwise it will fail on ARM 3. The compat_names[] array is missing its first element. This is needed only because the first fdt_compat_id is defined to be invalid. 4. Added a header prototype for fdtdec_next_compatible() 5. Change fdtdec_next_alias() to only increment its 'upto' parameter on success, to make the display error messages in the caller easier.
include/fdtdec.h | 23 +++++++++++++++++++---- lib/fdtdec.c | 22 ++++++++++++++++------ 2 files changed, 35 insertions(+), 10 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index d871cdd..49dbac4 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -82,6 +82,21 @@ int fdtdec_next_alias(const void *blob, const char *name, enum fdt_compat_id id, int *upto);
/** + * Find the next compatible node for a peripheral. + * + * Do the first call with node = 0. This function will return a pointer to + * the next compatible node. Next time you call this function, pass the + * value returned, and the next node will be provided. + * + * @param blob FDT blob to use + * @param node Start node for search + * @param id Compatible ID to look for (enum fdt_compat_id) + * @return offset of next compatible node, or -FDT_ERR_NOTFOUND if no more + */ +int fdtdec_next_compatible(const void *blob, int node, + enum fdt_compat_id id); + +/** * Look up an address property in a node and return it as an address. * The property must hold either one address with no trailing data or * one address with a length. This is only tested on 32-bit machines. @@ -112,14 +127,14 @@ s32 fdtdec_get_int(const void *blob, int node, const char *prop_name, * Checks whether a node is enabled. * This looks for a 'status' property. If this exists, then returns 1 if * the status is 'ok' and 0 otherwise. If there is no status property, - * it returns the default value. + * it returns 1 on the assumption that anything mentioned should be enabled + * by default. * * @param blob FDT blob * @param node node to examine - * @param default_val default value to return if no 'status' property exists - * @return integer value 0/1, if found, or default_val if not + * @return integer value 0 (not enabled) or 1 (enabled) */ -int fdtdec_get_is_enabled(const void *blob, int node, int default_val); +int fdtdec_get_is_enabled(const void *blob, int node);
/** * Checks whether we have a valid fdt available to control U-Boot, and panic diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 0f87163..55bbfc8 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -33,6 +33,7 @@ DECLARE_GLOBAL_DATA_PTR; */ #define COMPAT(id, name) name static const char * const compat_names[COMPAT_COUNT] = { + COMPAT(UNKNOWN, "<none>"), };
/** @@ -84,14 +85,21 @@ s32 fdtdec_get_int(const void *blob, int node, const char *prop_name, return default_val; }
-int fdtdec_get_is_enabled(const void *blob, int node, int default_val) +int fdtdec_get_is_enabled(const void *blob, int node) { const char *cell;
+ /* + * It should say "okay", so only allow that. Some fdts use "ok" but + * this is a bug. Please fix your device tree source file. See here + * for discussion: + * + * http://www.mail-archive.com/u-boot@lists.denx.de/msg71598.html + */ cell = fdt_getprop(blob, node, "status", NULL); if (cell) - return 0 == strcmp(cell, "ok"); - return default_val; + return 0 == strcmp(cell, "okay"); + return 1; }
enum fdt_compat_id fd_dec_lookup(const void *blob, int node) @@ -122,14 +130,16 @@ int fdtdec_next_alias(const void *blob, const char *name, /* snprintf() is not available */ assert(strlen(name) < MAX_STR_LEN); sprintf(str, "%.*s%d", MAX_STR_LEN, name, *upto); - (*upto)++; node = find_alias_node(blob, str); if (node < 0) return node; err = fdt_node_check_compatible(blob, node, compat_names[id]); if (err < 0) return err; - return err ? -FDT_ERR_NOTFOUND : node; + if (err) + return -FDT_ERR_NOTFOUND; + (*upto)++; + return node; }
/* @@ -140,7 +150,7 @@ int fdtdec_next_alias(const void *blob, const char *name, int fdtdec_check_fdt(void) { /* We must have an fdt */ - if (fdt_check_header(gd->fdt_blob)) + if (((uintptr_t)gd->fdt_blob & 3) || fdt_check_header(gd->fdt_blob)) panic("No valid fdt found - please append one to U-Boot\n" "binary or define CONFIG_OF_EMBED\n"); return 0;
Add a function to look up a property which is a phandle in a node, and another to read a fixed-length integer array from an fdt property. Also add a function to read boolean properties, although there is no actual boolean type in U-Boot.
include/fdtdec.h | 40 ++++++++++++++++++++++++++++++++ lib/fdtdec.c | 67 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 107 insertions(+), 0 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 49dbac4..c414131 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -141,3 +141,43 @@ int fdtdec_get_is_enabled(const void *blob, int node); * if not. */ int fdtdec_check_fdt(void); + +/** + * Look up a phandle and follow it to its node. Then return the offset + * of that node. + * + * @param blob FDT blob + * @param node node to examine + * @param prop_name name of property to find + * @return node offset if found, -ve error code on error + */ +int fdtdec_lookup_phandle(const void *blob, int node, const char *prop_name); + +/** + * Look up a property in a node and return its contents in an integer + * array of given length. The property must have at least enough data for + * the array (4*count bytes). It may have more, but this will be ignored. + * + * @param blob FDT blob + * @param node node to examine + * @param prop_name name of property to find + * @param array array to fill with data + * @param count number of array elements + * @return 0 if ok, or -FDT_ERR_NOTFOUND if the property is not found, + * or -FDT_ERR_BADLAYOUT if not enough data + */ +int fdtdec_get_int_array(const void *blob, int node, const char *prop_name, + u32 *array, int count); + +/** + * Look up a boolean property in a node and return it. + * + * A boolean properly is true if present in the device tree and false if not + * present, regardless of its value. + * + * @param blob FDT blob + * @param node node to examine + * @param prop_name name of property to find + * @return 1 if the properly is present; 0 if it isn't present + */ +int fdtdec_get_bool(const void *blob, int node, const char *prop_name); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 55bbfc8..ca6a698 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -155,3 +155,70 @@ int fdtdec_check_fdt(void) "binary or define CONFIG_OF_EMBED\n"); return 0; } + +int fdtdec_lookup_phandle(const void *blob, int node, const char *prop_name) +{ + const u32 *phandle; + int lookup; + + phandle = fdt_getprop(blob, node, prop_name, NULL); + if (!phandle) + return -FDT_ERR_NOTFOUND; + + lookup = fdt_node_offset_by_phandle(blob, fdt32_to_cpu(*phandle)); + return lookup; +} + +/** + * Look up a property in a node and check that it has a minimum length. + * + * @param blob FDT blob + * @param node node to examine + * @param prop_name name of property to find + * @param min_len minimum property length in bytes + * @param err 0 if ok, or -FDT_ERR_NOTFOUND if the property is not + found, or -FDT_ERR_BADLAYOUT if not enough data + * @return pointer to cell, which is only valid if err == 0 + */ +static const void *get_prop_check_min_len(const void *blob, int node, + const char *prop_name, int min_len, int *err) +{ + const void *cell; + int len; + + debug("%s: %s\n", __func__, prop_name); + cell = fdt_getprop(blob, node, prop_name, &len); + if (!cell) + *err = -FDT_ERR_NOTFOUND; + else if (len < min_len) + *err = -FDT_ERR_BADLAYOUT; + else + *err = 0; + return cell; +} + +int fdtdec_get_int_array(const void *blob, int node, const char *prop_name, + u32 *array, int count) +{ + const u32 *cell; + int i, err = 0; + + debug("%s: %s\n", __func__, prop_name); + cell = get_prop_check_min_len(blob, node, prop_name, + sizeof(u32) * count, &err); + if (!err) { + for (i = 0; i < count; i++) + array[i] = fdt32_to_cpu(cell[i]); + } + return err; +} + +int fdtdec_get_bool(const void *blob, int node, const char *prop_name) +{ + const s32 *cell; + int len; + + debug("%s: %s\n", __func__, prop_name); + cell = fdt_getprop(blob, node, prop_name, &len); + return cell != NULL; +}
This function should also be part of the GPIO API, so add it.
include/asm-generic/gpio.h | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/include/asm-generic/gpio.h b/include/asm-generic/gpio.h index a1ebb28..c1d697f 100644 --- a/include/asm-generic/gpio.h +++ b/include/asm-generic/gpio.h @@ -72,3 +72,13 @@ int gpio_get_value(int gp); * @return 0 if ok, -1 on error */ int gpio_set_value(int gp, int value); + +/** + * Request a gpio. This should be called before any of the other functions + * are used on this gpio. + * + * @param gp GPIO number + * @param label User label for this GPIO + * @return 0 if ok, -1 on error + */ +int gpio_request(unsigned gpio, const char *label);
On Sun, 8 Jan 2012 03:44:19 -0500 Mike Frysinger vapier@gentoo.org wrote:
should add gpio_free too
fyi, I just sent Wolfgang a pull request for this:
commit 3608b70fec881ccd4e41180c22662293a7e37b66 Author: Joe Hershberger joe.hershberger@ni.com Date: Fri Nov 11 15:55:35 2011 -0600
gpio: Modify common gpio.h to more closely match Linux
Change "int gp" to "unsigned gpio" Add request and free entry-points
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Signed-off-by: Kim Phillips kim.phillips@freescale.com
Kim
This adds some support into fdtdec for reading GPIO definitions from the fdt. We permit up to FDT_GPIO_MAX GPIOs in the system. Each GPIO is of the form:
gpio-function-name = <phandle gpio_num flags>;
where:
phandle is a pointer to the GPIO node gpio_num is the number of the GPIO (0 to 223) flags is a flag, as follows:
bit meaning 0 0=polarity normal, 1=active low (inverted)
An example is:
gpio-enable-propounder = <&gpio 43 0>;
which means that GPIO 43 is used to enable the propounder (setting the GPIO high), or that you can detect that the propounder is enabled by checking if the GPIO is high (the fdt does not indicate input/output).
Two main functions are provided:
fdtdec_decode_gpio() reads a GPIO property from an fdt node and decodes it into a structure.
fdtdec_setup_gpio() sets up the GPIO by calling gpio_request for you.
Both functions can cope with the property being missing, which is taken to mean that that GPIO function is not available or is not needed.
include/fdtdec.h | 45 +++++++++++++++++++++++++++++++ lib/fdtdec.c | 78 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 123 insertions(+), 0 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index c414131..a640db1 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -61,6 +61,23 @@ enum fdt_compat_id { COMPAT_COUNT, };
+/* GPIOs are numbered from 0 */ +enum { + FDT_GPIO_NONE = -1U, /* an invalid GPIO used to end our list */ + + FDT_GPIO_ACTIVE_LOW = 1 << 0, /* input is active low (else high) */ +}; + +/* This is the state of a GPIO pin as defined by the fdt */ +struct fdt_gpio_state { + const char *name; /* name of the fdt property defining this */ + uint gpio; /* GPIO number, or FDT_GPIO_NONE if none */ + u8 flags; /* FDT_GPIO_... flags */ +}; + +/* This tells us whether a fdt_gpio_state record is valid or not */ +#define fdt_gpio_isvalid(x) ((x)->gpio != FDT_GPIO_NONE) + /** * Find the next numbered alias for a peripheral. This is used to enumerate * all the peripherals of a certain type. @@ -181,3 +198,31 @@ int fdtdec_get_int_array(const void *blob, int node, const char *prop_name, * @return 1 if the properly is present; 0 if it isn't present */ int fdtdec_get_bool(const void *blob, int node, const char *prop_name); + +/** + * Decode a single GPIOs from an FDT. + * + * If the property is not found, then the GPIO structure will still be + * initialised, with gpio set to FDT_GPIO_NONE. This makes it easy to + * provide optional GPIOs. + * + * @param blob FDT blob to use + * @param node Node to look at + * @param prop_name Node property name + * @param gpio gpio elements to fill from FDT + * @return 0 if ok, -FDT_ERR_NOTFOUND if the property is missing. + */ +int fdtdec_decode_gpio(const void *blob, int node, const char *prop_name, + struct fdt_gpio_state *gpio); + +/** + * Set up a GPIO pin according to the provided gpio information. At present this + * just requests the GPIO. + * + * If the gpio is FDT_GPIO_NONE, no action is taken. This makes it easy to + * deal with optional GPIOs. + * + * @param gpio GPIO info to use for set up + * @return 0 if all ok or gpio was FDT_GPIO_NONE; -1 on error + */ +int fdtdec_setup_gpio(struct fdt_gpio_state *gpio); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index ca6a698..69f8b66 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -24,6 +24,9 @@ #include <libfdt.h> #include <fdtdec.h>
+/* we need the generic GPIO interface here */ +#include <asm-generic/gpio.h> + DECLARE_GLOBAL_DATA_PTR;
/* @@ -222,3 +225,78 @@ int fdtdec_get_bool(const void *blob, int node, const char *prop_name) cell = fdt_getprop(blob, node, prop_name, &len); return cell != NULL; } + +/** + * Decode a list of GPIOs from an FDT. This creates a list of GPIOs with no + * terminating item. + * + * @param blob FDT blob to use + * @param node Node to look at + * @param prop_name Node property name + * @param gpio Array of gpio elements to fill from FDT. This will be + * untouched if either 0 or an error is returned + * @param max_count Maximum number of elements allowed + * @return number of GPIOs read if ok, -FDT_ERR_BADLAYOUT if max_count would + * be exceeded, or -FDT_ERR_NOTFOUND if the property is missing. + */ +static int fdtdec_decode_gpios(const void *blob, int node, + const char *prop_name, struct fdt_gpio_state *gpio, + int max_count) +{ + const struct fdt_property *prop; + const u32 *cell; + const char *name; + int len, i; + + debug("%s: %s\n", __func__, prop_name); + assert(max_count > 0); + prop = fdt_get_property(blob, node, prop_name, &len); + if (!prop) { + debug("FDT: %s: property '%s' missing\n", __func__, prop_name); + return -FDT_ERR_NOTFOUND; + } + + /* We will use the name to tag the GPIO */ + name = fdt_string(blob, prop->nameoff); + cell = (u32 *)prop->data; + len /= sizeof(u32) * 3; /* 3 cells per GPIO record */ + if (len > max_count) { + debug("FDT: %s: too many GPIOs / cells for " + "property '%s'\n", __func__, prop_name); + return -FDT_ERR_BADLAYOUT; + } + + /* Read out the GPIO data from the cells */ + for (i = 0; i < len; i++, cell += 3) { + gpio[i].gpio = fdt32_to_cpu(cell[1]); + gpio[i].flags = fdt32_to_cpu(cell[2]); + gpio[i].name = name; + } + + return len; +} + +int fdtdec_decode_gpio(const void *blob, int node, const char *prop_name, + struct fdt_gpio_state *gpio) +{ + int err; + + debug("%s: %s\n", __func__, prop_name); + gpio->gpio = FDT_GPIO_NONE; + err = fdtdec_decode_gpios(blob, node, prop_name, gpio, 1); + return err == 1 ? 0 : err; +} + +int fdtdec_setup_gpio(struct fdt_gpio_state *gpio) +{ + /* + * Return success if there is no GPIO defined. This is used for + * optional GPIOs) + */ + if (!fdt_gpio_isvalid(gpio)) + return 0; + + if (gpio_request(gpio->gpio, gpio->name)) + return -1; + return 0; +}
By putting the fdt blob into a distinctive area we can ensure that it appears at the start of the data section and is word-aligned.
Note: It does not seem to be possible to get objcopy to honour its --section-alignment flag, which would otherwise provide an easier fix for this problem.
arch/arm/cpu/armv7/u-boot.lds | 5 +++++ dts/Makefile | 2 +- 2 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index 40ecf78..793e51b 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -43,6 +43,11 @@ SECTIONS
. = ALIGN(4); .data : { + /* + * Sadly objcopy seems to ignore --section-alignment. + * Put any embedded device tree first so it is aligned. + */ + *(.dts.data) *(.data) }
diff --git a/dts/Makefile b/dts/Makefile index 5792afd..83547d4 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -79,7 +79,7 @@ $(obj)dt.o: $(DT_BIN) \ cd $(dir ${DT_BIN}) && \ $(OBJCOPY) -I binary -O $${oformat} -B $${oarch} \ - $(notdir ${DT_BIN}) $@ + --prefix-sections=.dts $(notdir ${DT_BIN}) $@ rm $(DT_BIN)
OBJS-$(CONFIG_OF_EMBED) := dt.o
This was taken from commit b48c54e2 at: git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra.git
arch/arm/dts/skeleton.dtsi | 13 +++++++++++++ 1 files changed, 13 insertions(+), 0 deletions(-) create mode 100644 arch/arm/dts/skeleton.dtsi
diff --git a/arch/arm/dts/skeleton.dtsi b/arch/arm/dts/skeleton.dtsi new file mode 100644 index 0000000..b41d241 --- /dev/null +++ b/arch/arm/dts/skeleton.dtsi @@ -0,0 +1,13 @@ +/* + * Skeleton device tree; the bare minimum needed to boot; just include and + * add a compatible value. The bootloader will typically populate the memory + * node. + */ + +/ { + #address-cells = <1>; + #size-cells = <1>; + chosen { }; + aliases { }; + memory { device_type = "memory"; reg = <0 0>; }; +};
config.mk is updated to provide this file to boards through the built-in mechanism:
/include/ ARCH_CPU_DTS
arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/dts/tegra20.dtsi | 169 +++++++++++++++++++++++++++++++++++ 2 files changed, 171 insertions(+), 0 deletions(-) create mode 100644 arch/arm/dts/tegra20.dtsi
diff --git a/arch/arm/cpu/armv7/tegra2/config.mk b/arch/arm/cpu/armv7/tegra2/config.mk index 2303dba..fe9ef5b 100644 --- a/arch/arm/cpu/armv7/tegra2/config.mk +++ b/arch/arm/cpu/armv7/tegra2/config.mk @@ -31,3 +31,5 @@ CFLAGS_arch/arm/lib/board.o += -march=armv4t endif
USE_PRIVATE_LIBGCC = yes + +CONFIG_ARCH_DEVICE_TREE := tegra20 diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi new file mode 100644 index 0000000..6146d24 --- /dev/null +++ b/arch/arm/dts/tegra20.dtsi @@ -0,0 +1,169 @@ +/include/ "skeleton.dtsi" + +/ { + compatible = "nvidia,tegra20"; + interrupt-parent = <&intc>; + + intc: interrupt-controller@50041000 { + compatible = "nvidia,tegra20-gic"; + interrupt-controller; + #interrupt-cells = <1>; + reg = < 0x50041000 0x1000 >, + < 0x50040100 0x0100 >; + }; + + i2c@7000c000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C000 0x100>; + interrupts = < 70 >; + }; + + i2c@7000c400 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C400 0x100>; + interrupts = < 116 >; + }; + + i2c@7000c500 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000C500 0x100>; + interrupts = < 124 >; + }; + + i2c@7000d000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2c"; + reg = <0x7000D000 0x200>; + interrupts = < 85 >; + }; + + i2s@70002800 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2s"; + reg = <0x70002800 0x200>; + interrupts = < 45 >; + dma-channel = < 2 >; + }; + + i2s@70002a00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-i2s"; + reg = <0x70002a00 0x200>; + interrupts = < 35 >; + dma-channel = < 1 >; + }; + + das@70000c00 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nvidia,tegra20-das"; + reg = <0x70000c00 0x80>; + }; + + gpio: gpio@6000d000 { + compatible = "nvidia,tegra20-gpio"; + reg = < 0x6000d000 0x1000 >; + interrupts = < 64 65 66 67 87 119 121 >; + #gpio-cells = <2>; + gpio-controller; + }; + + pinmux: pinmux@70000000 { + compatible = "nvidia,tegra20-pinmux"; + reg = < 0x70000014 0x10 /* Tri-state registers */ + 0x70000080 0x20 /* Mux registers */ + 0x700000a0 0x14 /* Pull-up/down registers */ + 0x70000868 0xa8 >; /* Pad control registers */ + }; + + serial@70006000 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006000 0x40>; + reg-shift = <2>; + interrupts = < 68 >; + }; + + serial@70006040 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006040 0x40>; + reg-shift = <2>; + interrupts = < 69 >; + }; + + serial@70006200 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006200 0x100>; + reg-shift = <2>; + interrupts = < 78 >; + }; + + serial@70006300 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006300 0x100>; + reg-shift = <2>; + interrupts = < 122 >; + }; + + serial@70006400 { + compatible = "nvidia,tegra20-uart"; + reg = <0x70006400 0x100>; + reg-shift = <2>; + interrupts = < 123 >; + }; + + sdhci@c8000000 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000000 0x200>; + interrupts = < 46 >; + }; + + sdhci@c8000200 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000200 0x200>; + interrupts = < 47 >; + }; + + sdhci@c8000400 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000400 0x200>; + interrupts = < 51 >; + }; + + sdhci@c8000600 { + compatible = "nvidia,tegra20-sdhci"; + reg = <0xc8000600 0x200>; + interrupts = < 63 >; + }; + + usb@c5000000 { + compatible = "nvidia,tegra20-ehci", "usb-ehci"; + reg = <0xc5000000 0x4000>; + interrupts = < 52 >; + phy_type = "utmi"; + }; + + usb@c5004000 { + compatible = "nvidia,tegra20-ehci", "usb-ehci"; + reg = <0xc5004000 0x4000>; + interrupts = < 53 >; + phy_type = "ulpi"; + }; + + usb@c5008000 { + compatible = "nvidia,tegra20-ehci", "usb-ehci"; + reg = <0xc5008000 0x4000>; + interrupts = < 129 >; + phy_type = "utmi"; + }; + +}; +
board/nvidia/dts/tegra2-seaboard.dts | 36 ++++++++++++++++++++++++++++++++++ 1 files changed, 36 insertions(+), 0 deletions(-) create mode 100644 board/nvidia/dts/tegra2-seaboard.dts
diff --git a/board/nvidia/dts/tegra2-seaboard.dts b/board/nvidia/dts/tegra2-seaboard.dts new file mode 100644 index 0000000..dde5d03 --- /dev/null +++ b/board/nvidia/dts/tegra2-seaboard.dts @@ -0,0 +1,36 @@ +/dts-v1/; + +/memreserve/ 0x1c000000 0x04000000; +/include/ ARCH_CPU_DTS + +/ { + model = "NVIDIA Seaboard"; + compatible = "nvidia,seaboard", "nvidia,tegra20"; + + chosen { + bootargs = "vmalloc=192M video=tegrafb console=ttyS0,115200n8 root=/dev/mmcblk1p3 rw rootwait"; + }; + + memory { + device_type = "memory"; + reg = < 0x00000000 0x40000000 >; + }; + + serial@70006300 { + clock-frequency = < 216000000 >; + }; + + sdhci@c8000400 { + cd-gpios = <&gpio 69 0>; /* gpio PI5 */ + wp-gpios = <&gpio 57 0>; /* gpio PH1 */ + power-gpios = <&gpio 70 0>; /* gpio PI6 */ + }; + + sdhci@c8000600 { + support-8bit; + }; + + usb@c5000000 { + nvidia,vbus-gpio = <&gpio 24 0>; /* PD0 */ + }; +};
This adds peripheral IDs to the USB part of the device tree for U-Boot.
The peripheral IDs provide easy access to clock registers. We will likely remove this in favor of a full clock tree when it is available in the kernel (but probably still retain the peripheral ID, just move it into a clock node).
The USB timing information may vary between boards sometimes, but for now we hard-code it in C. This is because all current T2x boards use the same values, we will deal with T3x later and we first need to agree on the format for this timing information in the fdt and may in fact decide that it has no place there.
arch/arm/dts/tegra20.dtsi | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 6146d24..27e3127 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -149,6 +149,7 @@ reg = <0xc5000000 0x4000>; interrupts = < 52 >; phy_type = "utmi"; + u-boot,periph-id = <22>; // PERIPH_ID_USBD };
usb@c5004000 { @@ -156,6 +157,7 @@ reg = <0xc5004000 0x4000>; interrupts = < 53 >; phy_type = "ulpi"; + u-boot,periph-id = <58>; // PERIPH_ID_USB2 };
usb@c5008000 { @@ -163,6 +165,7 @@ reg = <0xc5008000 0x4000>; interrupts = < 129 >; phy_type = "utmi"; + u-boot,periph-id = <59>; // PERIPH_ID_USB3 };
We set up two USB ports, one of which can be host or device. For some reason the kernel version does enable both ports.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Use "okay" instead of "ok" for fdt node status - Remove 0x from fdt aliases
board/nvidia/dts/tegra2-seaboard.dts | 13 ++++++++++++- 1 files changed, 12 insertions(+), 1 deletions(-)
diff --git a/board/nvidia/dts/tegra2-seaboard.dts b/board/nvidia/dts/tegra2-seaboard.dts index dde5d03..839e761 100644 --- a/board/nvidia/dts/tegra2-seaboard.dts +++ b/board/nvidia/dts/tegra2-seaboard.dts @@ -11,6 +11,12 @@ bootargs = "vmalloc=192M video=tegrafb console=ttyS0,115200n8 root=/dev/mmcblk1p3 rw rootwait"; };
+ aliases { + /* This defines the order of our USB ports */ + usb0 = "/usb@c5008000"; + usb1 = "/usb@c5000000"; + }; + memory { device_type = "memory"; reg = < 0x00000000 0x40000000 >; @@ -31,6 +37,11 @@ };
usb@c5000000 { - nvidia,vbus-gpio = <&gpio 24 0>; /* PD0 */ + nvidia,vbus-gpio = <&gpio 24 0>; /* PD0 high to enable vbus */ + support-host-mode; + }; + + usb@c5004000 { + status = "disabled"; }; };
CONFIG_USB_EHCI_TXFIFO_THRESH enables setting of the txfilltuning field in the EHCI controller on reset.
README | 3 +++ drivers/usb/host/ehci-hcd.c | 7 +++++++ drivers/usb/host/ehci.h | 6 +++++- 3 files changed, 15 insertions(+), 1 deletions(-)
diff --git a/README b/README index fda0190..4dbb70c 100644 --- a/README +++ b/README @@ -1096,6 +1096,9 @@ The following options need to be configured: May be defined to allow interrupt polling instead of using asynchronous interrupts
+ CONFIG_USB_EHCI_TXFIFO_THRESH enables setting of the + txfilltuning field in the EHCI controller on reset. + - USB Device: Define the below if you wish to use the USB console. Once firmware is rebuilt from a serial console issue the diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 2197119..16deebc 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -247,6 +247,13 @@ static int ehci_reset(void) #endif ehci_writel(reg_ptr, tmp); } + +#ifdef CONFIG_USB_EHCI_TXFIFO_THRESH + cmd = ehci_readl(&hcor->or_txfilltuning); + cmd &= ~TXFIFO_THRESH(0x3f); + cmd |= TXFIFO_THRESH(CONFIG_USB_EHCI_TXFIFO_THRESH); + ehci_writel(&hcor->or_txfilltuning, cmd); +#endif out: return ret; } diff --git a/drivers/usb/host/ehci.h b/drivers/usb/host/ehci.h index 3d0ad0c..cc00ce4 100644 --- a/drivers/usb/host/ehci.h +++ b/drivers/usb/host/ehci.h @@ -80,7 +80,11 @@ struct ehci_hcor { uint32_t or_ctrldssegment; uint32_t or_periodiclistbase; uint32_t or_asynclistaddr; - uint32_t _reserved_[9]; + uint32_t _reserved_0_; + uint32_t or_burstsize; + uint32_t or_txfilltuning; +#define TXFIFO_THRESH(p) ((p & 0x3f) << 16) + uint32_t _reserved_1_[6]; uint32_t or_configflag; #define FLAG_CF (1 << 0) /* true: we'll support "high speed" */ uint32_t or_portsc[CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS];
2011/12/7 Simon Glass sjg@chromium.org:
Since it is part of a bigger series: Acked-by: Remy Bohmer linux@bohmer.net
Kind regards,
Remy
This adds basic support for the Tegra2 USB controller. Board files should call board_usb_init() to set things up.
Configuration is performed through the FDT, with aliases used to set the order of the ports, like this fragment:
aliases { /* This defines the order of our USB ports */ usb0 = "/usb@0xc5008000"; usb1 = "/usb@0xc5000000"; };
drivers/usb/host files ONLY: Acked-by: Remy Bohmer linux@bohmer.net Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Rename params to timing - Store entire fdt config in port list, not just register pointer - Remove non-fdt operation of USB, since it is not needed - Decode USB VBUS GPIO from the fdt - Decode phy type differently (to match new kernel fdt) - Rename tegra20-usb to tegra20-ehcui (to match new kernel fdt) - Improve debug() printouts in case of failure to init USB
Changes in v3: - Remove usbparams properties from fdt and moved them to C code
arch/arm/cpu/armv7/tegra2/Makefile | 4 +- arch/arm/cpu/armv7/tegra2/usb.c | 430 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 2 + arch/arm/include/asm/arch-tegra2/usb.h | 255 +++++++++++++++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-tegra.c | 63 +++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 8 files changed, 756 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/usb.c create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 drivers/usb/host/ehci-tegra.c
diff --git a/arch/arm/cpu/armv7/tegra2/Makefile b/arch/arm/cpu/armv7/tegra2/Makefile index 955c3b6..70e7abd 100644 --- a/arch/arm/cpu/armv7/tegra2/Makefile +++ b/arch/arm/cpu/armv7/tegra2/Makefile @@ -33,8 +33,10 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o -COBJS := ap20.o board.o clock.o pinmux.o sys_info.o timer.o +COBJS-y := ap20.o board.o clock.o pinmux.o sys_info.o timer.o +COBJS-$(CONFIG_USB_EHCI_TEGRA) += usb.o
+COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/arch/arm/cpu/armv7/tegra2/usb.c b/arch/arm/cpu/armv7/tegra2/usb.c new file mode 100644 index 0000000..215d0d3 --- /dev/null +++ b/arch/arm/cpu/armv7/tegra2/usb.c @@ -0,0 +1,430 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * (C) Copyright 2010,2011 NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <asm/arch/tegra2.h> +#include <asm/arch/clk_rst.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/uart.h> +#include <asm/arch/usb.h> +#include <libfdt.h> +#include <fdtdec.h> + +enum { + USB_PORTS_MAX = 4, /* Maximum ports we allow */ +}; + +/* Parameters we need for USB */ +enum { + PARAM_DIVN, /* PLL FEEDBACK DIVIDer */ + PARAM_DIVM, /* PLL INPUT DIVIDER */ + PARAM_DIVP, /* POST DIVIDER (2^N) */ + PARAM_CPCON, /* BASE PLLC CHARGE Pump setup ctrl */ + PARAM_LFCON, /* BASE PLLC LOOP FILter setup ctrl */ + PARAM_ENABLE_DELAY_COUNT, /* PLL-U Enable Delay Count */ + PARAM_STABLE_COUNT, /* PLL-U STABLE count */ + PARAM_ACTIVE_DELAY_COUNT, /* PLL-U Active delay count */ + PARAM_XTAL_FREQ_COUNT, /* PLL-U XTAL frequency count */ + PARAM_DEBOUNCE_A_TIME, /* 10MS DELAY for BIAS_DEBOUNCE_A */ + PARAM_BIAS_TIME, /* 20US DELAY AFter bias cell op */ + + PARAM_COUNT +}; + +/* Information about a USB port */ +struct fdt_usb { + struct usb_ctlr *reg; /* address of registers in physical memory */ + int host_mode; /* 1 if port has host mode, else 0 */ + int utmi; /* 1 if port has external tranceiver, else 0 */ + int enabled; /* 1 to enable, 0 to disable */ + enum periph_id periph_id;/* peripheral id */ + struct fdt_gpio_state vbus_gpio; /* GPIO for vbus enable */ +}; + +static struct fdt_usb port[USB_PORTS_MAX]; /* List of valid USB ports */ +static unsigned port_count; /* Number of available ports */ +static int port_current; /* Current port (-1 = none) */ + +/* Record which controller can switch from host to device mode */ +static struct fdt_usb *host_dev_ctlr; + +/* + * This table has USB timing parameters for each Oscillator frequency we + * support. There are four sets of values: + * + * 1. PLLU configuration information (reference clock is osc/clk_m and + * PLLU-FOs are fixed at 12MHz/60MHz/480MHz). + * + * Reference frequency 13.0MHz 19.2MHz 12.0MHz 26.0MHz + * ---------------------------------------------------------------------- + * DIVN 960 (0x3c0) 200 (0c8) 960 (3c0h) 960 (3c0) + * DIVM 13 (0d) 4 (04) 12 (0c) 26 (1a) + * Filter frequency (MHz) 1 4.8 6 2 + * CPCON 1100b 0011b 1100b 1100b + * LFCON0 0 0 0 0 + * + * 2. PLL CONFIGURATION & PARAMETERS for different clock generators: + * + * Reference frequency 13.0MHz 19.2MHz 12.0MHz 26.0MHz + * --------------------------------------------------------------------------- + * PLLU_ENABLE_DLY_COUNT 02 (0x02) 03 (03) 02 (02) 04 (04) + * PLLU_STABLE_COUNT 51 (33) 75 (4B) 47 (2F) 102 (66) + * PLL_ACTIVE_DLY_COUNT 05 (05) 06 (06) 04 (04) 09 (09) + * XTAL_FREQ_COUNT 127 (7F) 187 (BB) 118 (76) 254 (FE) + * + * 3. Debounce values IdDig, Avalid, Bvalid, VbusValid, VbusWakeUp, and + * SessEnd. Each of these signals have their own debouncer and for each of + * those one out of two debouncing times can be chosen (BIAS_DEBOUNCE_A or + * BIAS_DEBOUNCE_B). + * + * The values of DEBOUNCE_A and DEBOUNCE_B are calculated as follows: + * 0xffff -> No debouncing at all + * <n> ms = <n> *1000 / (1/19.2MHz) / 4 + * + * So to program a 1 ms debounce for BIAS_DEBOUNCE_A, we have: + * BIAS_DEBOUNCE_A[15:0] = 1000 * 19.2 / 4 = 4800 = 0x12c0 + * + * We need to use only DebounceA for BOOTROM. We don't need the DebounceB + * values, so we can keep those to default. + * + * 4. The 20 microsecond delay after bias cell operation. + */ +static const unsigned usb_pll[CLOCK_OSC_FREQ_COUNT][PARAM_COUNT] = { + /* DivN, DivM, DivP, CPCON, LFCON, Delays Debounce, Bias */ + { 0x3C0, 0x0D, 0x00, 0xC, 0, 0x02, 0x33, 0x05, 0x7F, 0x7EF4, 5 }, + { 0x0C8, 0x04, 0x00, 0x3, 0, 0x03, 0x4B, 0x06, 0xBB, 0xBB80, 7 }, + { 0x3C0, 0x0C, 0x00, 0xC, 0, 0x02, 0x2F, 0x04, 0x76, 0x7530, 5 }, + { 0x3C0, 0x1A, 0x00, 0xC, 0, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 9 } +}; + +/* UTMIP Idle Wait Delay */ +static const u8 utmip_idle_wait_delay = 17; + +/* UTMIP Elastic limit */ +static const u8 utmip_elastic_limit = 16; + +/* UTMIP High Speed Sync Start Delay */ +static const u8 utmip_hs_sync_start_delay = 9; + +/* Put the port into host mode (this only works for USB1) */ +static void set_host_mode(struct fdt_usb *config) +{ + /* Check whether remote host from USB1 is driving VBus */ + if (readl(&config->reg->phy_vbus_sensors) & VBUS_VLD_STS) + return; + + /* + * If not driving, we set GPIO USB1_VBus_En. We assume that the + * pinmux is set up correctly for this. + */ + if (fdt_gpio_isvalid(&config->vbus_gpio)) { + fdtdec_setup_gpio(&config->vbus_gpio); + gpio_direction_output(config->vbus_gpio.gpio, 1); + } +} + +/* Put our ports into host mode */ +void usb_set_host_mode(void) +{ + if (host_dev_ctlr) + set_host_mode(host_dev_ctlr); +} + +void usbf_reset_controller(enum periph_id id, struct usb_ctlr *usbctlr) +{ + /* Reset the USB controller with 2us delay */ + reset_periph(id, 2); + + /* + * Set USB1_NO_LEGACY_MODE to 1, Registers are accessible under + * base address + */ + if (id == PERIPH_ID_USBD) + setbits_le32(&usbctlr->usb1_legacy_ctrl, USB1_NO_LEGACY_MODE); + + /* Put UTMIP1/3 in reset */ + setbits_le32(&usbctlr->susp_ctrl, UTMIP_RESET); + + /* Set USB3 to use UTMIP PHY */ + if (id == PERIPH_ID_USB3) + setbits_le32(&usbctlr->susp_ctrl, UTMIP_PHY_ENB); + + /* + * TODO: where do we take the USB1 out of reset? The old code would + * take USB3 out of reset, but not USB1. This code doesn't do either. + */ +} + +/* set up the USB controller with the parameters provided */ +static void init_usb_controller(enum periph_id id, struct usb_ctlr *usbctlr, + const u32 timing[]) +{ + u32 val; + int loop_count; + + clock_enable(id); + + /* Reset the usb controller */ + usbf_reset_controller(id, usbctlr); + + /* Stop crystal clock by setting UTMIP_PHY_XTAL_CLOCKEN low */ + clrbits_le32(&usbctlr->utmip_misc_cfg1, UTMIP_PHY_XTAL_CLOCKEN); + + /* Follow the crystal clock disable by >100ns delay */ + udelay(1); + + /* + * To Use the A Session Valid for cable detection logic, VBUS_WAKEUP + * mux must be switched to actually use a_sess_vld threshold. + */ + if (id == PERIPH_ID_USBD) { + clrsetbits_le32(&usbctlr->usb1_legacy_ctrl, + VBUS_SENSE_CTL_MASK, VBUS_SENSE_CTL_A_SESS_VLD); + } + + /* + * PLL Delay CONFIGURATION settings. The following parameters control + * the bring up of the plls. + */ + val = readl(&usbctlr->utmip_misc_cfg1); + clrsetbits_le32(&val, UTMIP_PLLU_STABLE_COUNT_MASK, + timing[PARAM_STABLE_COUNT] << UTMIP_PLLU_STABLE_COUNT_SHIFT); + clrsetbits_le32(&val, UTMIP_PLL_ACTIVE_DLY_COUNT_MASK, + timing[PARAM_ACTIVE_DELAY_COUNT] << + UTMIP_PLL_ACTIVE_DLY_COUNT_SHIFT); + writel(val, &usbctlr->utmip_misc_cfg1); + + /* Set PLL enable delay count and crystal frequency count */ + val = readl(&usbctlr->utmip_pll_cfg1); + clrsetbits_le32(&val, UTMIP_PLLU_ENABLE_DLY_COUNT_MASK, + timing[PARAM_ENABLE_DELAY_COUNT] << + UTMIP_PLLU_ENABLE_DLY_COUNT_SHIFT); + clrsetbits_le32(&val, UTMIP_XTAL_FREQ_COUNT_MASK, + timing[PARAM_XTAL_FREQ_COUNT] << + UTMIP_XTAL_FREQ_COUNT_SHIFT); + writel(val, &usbctlr->utmip_pll_cfg1); + + /* Setting the tracking length time */ + clrsetbits_le32(&usbctlr->utmip_bias_cfg1, + UTMIP_BIAS_PDTRK_COUNT_MASK, + timing[PARAM_BIAS_TIME] << UTMIP_BIAS_PDTRK_COUNT_SHIFT); + + /* Program debounce time for VBUS to become valid */ + clrsetbits_le32(&usbctlr->utmip_debounce_cfg0, + UTMIP_DEBOUNCE_CFG0_MASK, + timing[PARAM_DEBOUNCE_A_TIME] << UTMIP_DEBOUNCE_CFG0_SHIFT); + + setbits_le32(&usbctlr->utmip_tx_cfg0, UTMIP_FS_PREAMBLE_J); + + /* Disable battery charge enabling bit */ + setbits_le32(&usbctlr->utmip_bat_chrg_cfg0, UTMIP_PD_CHRG); + + clrbits_le32(&usbctlr->utmip_xcvr_cfg0, UTMIP_XCVR_LSBIAS_SE); + setbits_le32(&usbctlr->utmip_spare_cfg0, FUSE_SETUP_SEL); + + /* + * Configure the UTMIP_IDLE_WAIT and UTMIP_ELASTIC_LIMIT + * Setting these fields, together with default values of the + * other fields, results in programming the registers below as + * follows: + * UTMIP_HSRX_CFG0 = 0x9168c000 + * UTMIP_HSRX_CFG1 = 0x13 + */ + + /* Set PLL enable delay count and Crystal frequency count */ + val = readl(&usbctlr->utmip_hsrx_cfg0); + clrsetbits_le32(&val, UTMIP_IDLE_WAIT_MASK, + utmip_idle_wait_delay << UTMIP_IDLE_WAIT_SHIFT); + clrsetbits_le32(&val, UTMIP_ELASTIC_LIMIT_MASK, + utmip_elastic_limit << UTMIP_ELASTIC_LIMIT_SHIFT); + writel(val, &usbctlr->utmip_hsrx_cfg0); + + /* Configure the UTMIP_HS_SYNC_START_DLY */ + clrsetbits_le32(&usbctlr->utmip_hsrx_cfg1, + UTMIP_HS_SYNC_START_DLY_MASK, + utmip_hs_sync_start_delay << UTMIP_HS_SYNC_START_DLY_SHIFT); + + /* Preceed the crystal clock disable by >100ns delay. */ + udelay(1); + + /* Resuscitate crystal clock by setting UTMIP_PHY_XTAL_CLOCKEN */ + setbits_le32(&usbctlr->utmip_misc_cfg1, UTMIP_PHY_XTAL_CLOCKEN); + + /* Finished the per-controller init. */ + + /* De-assert UTMIP_RESET to bring out of reset. */ + clrbits_le32(&usbctlr->susp_ctrl, UTMIP_RESET); + + /* Wait for the phy clock to become valid in 100 ms */ + for (loop_count = 100000; loop_count != 0; loop_count--) { + if (readl(&usbctlr->susp_ctrl) & USB_PHY_CLK_VALID) + break; + udelay(1); + } +} + +static void power_up_port(struct usb_ctlr *usbctlr) +{ + /* Deassert power down state */ + clrbits_le32(&usbctlr->utmip_xcvr_cfg0, UTMIP_FORCE_PD_POWERDOWN | + UTMIP_FORCE_PD2_POWERDOWN | UTMIP_FORCE_PDZI_POWERDOWN); + clrbits_le32(&usbctlr->utmip_xcvr_cfg1, UTMIP_FORCE_PDDISC_POWERDOWN | + UTMIP_FORCE_PDCHRP_POWERDOWN | UTMIP_FORCE_PDDR_POWERDOWN); +} + +static void config_clock(const u32 timing[]) +{ + clock_start_pll(CLOCK_ID_USB, + timing[PARAM_DIVM], timing[PARAM_DIVN], timing[PARAM_DIVP], + timing[PARAM_CPCON], timing[PARAM_LFCON]); +} + +/** + * Add a new USB port to the list of available ports. + * + * @param config USB port configuration + * @return 0 if ok, -1 if error (too many ports) + */ +static int add_port(struct fdt_usb *config, const u32 timing[]) +{ + struct usb_ctlr *usbctlr = config->reg; + + if (port_count == USB_PORTS_MAX) { + debug("tegrausb: Cannot register more than %d ports\n", + USB_PORTS_MAX); + return -1; + } + init_usb_controller(config->periph_id, usbctlr, timing); + if (config->utmi) { + /* Disable ICUSB FS/LS transceiver */ + clrbits_le32(&usbctlr->icusb_ctrl, IC_ENB1); + + /* Select UTMI parallel interface */ + clrsetbits_le32(&usbctlr->port_sc1, PTS_MASK, + PTS_UTMI << PTS_SHIFT); + clrbits_le32(&usbctlr->port_sc1, STS); + power_up_port(usbctlr); + } + if (config->host_mode) { + /* Only one host-dev port is supported */ + if (host_dev_ctlr) + return -1; + host_dev_ctlr = &port[port_count]; + } + port[port_count++] = *config; + return 0; +} + +int tegrausb_start_port(unsigned portnum, u32 *hccr, u32 *hcor) +{ + struct usb_ctlr *usbctlr; + + if (portnum >= port_count) + return -1; + tegrausb_stop_port(); + + usbctlr = port[portnum].reg; + *hccr = (u32)&usbctlr->cap_length; + *hcor = (u32)&usbctlr->usb_cmd; + port_current = portnum; + return 0; +} + +int tegrausb_stop_port(void) +{ + struct usb_ctlr *usbctlr; + + if (port_current == -1) + return -1; + + usbctlr = port[port_current].reg; + + /* Stop controller */ + writel(0, &usbctlr->usb_cmd); + udelay(1000); + + /* Initiate controller reset */ + writel(2, &usbctlr->usb_cmd); + udelay(1000); + port_current = -1; + return 0; +} + +int fdt_decode_usb(const void *blob, int node, unsigned osc_frequency_mhz, + struct fdt_usb *config) +{ + const char *phy; + + config->reg = (struct usb_ctlr *)fdtdec_get_addr(blob, node, "reg"); + config->host_mode = fdtdec_get_bool(blob, node, "support-host-mode"); + phy = fdt_getprop(blob, node, "phy_type", NULL); + config->utmi = phy && 0 == strcmp("utmi", phy); + config->enabled = fdtdec_get_is_enabled(blob, node); + config->periph_id = fdtdec_get_int(blob, node, "u-boot,periph-id", -1); + if (config->periph_id == -1) + return -FDT_ERR_NOTFOUND; + fdtdec_decode_gpio(blob, node, "nvidia,vbus-gpio", &config->vbus_gpio); + return 0; +} + +int board_usb_init(const void *blob) +{ + struct fdt_usb config; + int node, upto = 0; + unsigned osc_freq = clock_get_rate(CLOCK_ID_OSC); + enum clock_osc_freq freq; + + /* Set up the USB clocks correctly based on our oscillator frequency */ + freq = clock_get_osc_freq(); + config_clock(usb_pll[freq]); + + do { + node = fdtdec_next_alias(blob, "usb", + COMPAT_NVIDIA_TEGRA20_USB, &upto); + if (node < 0) { + debug("Cannot find usb%d alias in fdt\n", upto); + break; + } + if (fdt_decode_usb(blob, node, osc_freq, &config)) { + debug("Cannot decode USB node %s\n", + fdt_get_name(blob, node, NULL)); + return -1; + } + if (!config.enabled) { + debug("Skipping USB node %s since it is disabled\n", + fdt_get_name(blob, node, NULL)); + continue; + } + + if (add_port(&config, usb_pll[freq])) + return -1; + } while (node); + usb_set_host_mode(); + port_current = -1; + return 0; +} diff --git a/arch/arm/include/asm/arch-tegra2/tegra2.h b/arch/arm/include/asm/arch-tegra2/tegra2.h index 8941443..baae2eb 100644 --- a/arch/arm/include/asm/arch-tegra2/tegra2.h +++ b/arch/arm/include/asm/arch-tegra2/tegra2.h @@ -41,6 +41,8 @@ #define TEGRA2_SPI_BASE (NV_PA_APB_MISC_BASE + 0xC380) #define NV_PA_PMC_BASE 0x7000E400 #define NV_PA_CSITE_BASE 0x70040000 +#define TEGRA_USB1_BASE 0xC5000000 +#define TEGRA_USB3_BASE 0xC5008000
#define TEGRA2_SDRC_CS0 NV_PA_SDRAM_BASE #define LOW_LEVEL_SRAM_STACK 0x4000FFFC diff --git a/arch/arm/include/asm/arch-tegra2/usb.h b/arch/arm/include/asm/arch-tegra2/usb.h new file mode 100644 index 0000000..0a3056d --- /dev/null +++ b/arch/arm/include/asm/arch-tegra2/usb.h @@ -0,0 +1,255 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _TEGRA_USB_H_ +#define _TEGRA_USB_H_ + + +/* USB Controller (USBx_CONTROLLER_) regs */ +struct usb_ctlr { + /* 0x000 */ + uint id; + uint reserved0; + uint host; + uint device; + + /* 0x010 */ + uint txbuf; + uint rxbuf; + uint reserved1[2]; + + /* 0x020 */ + uint reserved2[56]; + + /* 0x100 */ + u16 cap_length; + u16 hci_version; + uint hcs_params; + uint hcc_params; + uint reserved3[5]; + + /* 0x120 */ + uint dci_version; + uint dcc_params; + uint reserved4[6]; + + /* 0x140 */ + uint usb_cmd; + uint usb_sts; + uint usb_intr; + uint frindex; + + /* 0x150 */ + uint reserved5; + uint periodic_list_base; + uint async_list_addr; + uint async_tt_sts; + + /* 0x160 */ + uint burst_size; + uint tx_fill_tuning; + uint reserved6; /* is this port_sc1 on some controllers? */ + uint icusb_ctrl; + + /* 0x170 */ + uint ulpi_viewport; + uint reserved7; + uint endpt_nak; + uint endpt_nak_enable; + + /* 0x180 */ + uint reserved; + uint port_sc1; + uint reserved8[6]; + + /* 0x1a0 */ + uint reserved9; + uint otgsc; + uint usb_mode; + uint endpt_setup_stat; + + /* 0x1b0 */ + uint reserved10[20]; + + /* 0x200 */ + uint reserved11[0x80]; + + /* 0x400 */ + uint susp_ctrl; + uint phy_vbus_sensors; + uint phy_vbus_wakeup_id; + uint phy_alt_vbus_sys; + + /* 0x410 */ + uint usb1_legacy_ctrl; + uint reserved12[3]; + + /* 0x420 */ + uint reserved13[56]; + + /* 0x500 */ + uint reserved14[64 * 3]; + + /* 0x800 */ + uint utmip_pll_cfg0; + uint utmip_pll_cfg1; + uint utmip_xcvr_cfg0; + uint utmip_bias_cfg0; + + /* 0x810 */ + uint utmip_hsrx_cfg0; + uint utmip_hsrx_cfg1; + uint utmip_fslsrx_cfg0; + uint utmip_fslsrx_cfg1; + + /* 0x820 */ + uint utmip_tx_cfg0; + uint utmip_misc_cfg0; + uint utmip_misc_cfg1; + uint utmip_debounce_cfg0; + + /* 0x830 */ + uint utmip_bat_chrg_cfg0; + uint utmip_spare_cfg0; + uint utmip_xcvr_cfg1; + uint utmip_bias_cfg1; +}; + + +/* USB1_LEGACY_CTRL */ +#define USB1_NO_LEGACY_MODE 1 + +#define VBUS_SENSE_CTL_SHIFT 1 +#define VBUS_SENSE_CTL_MASK (3 << VBUS_SENSE_CTL_SHIFT) +#define VBUS_SENSE_CTL_VBUS_WAKEUP 0 +#define VBUS_SENSE_CTL_AB_SESS_VLD_OR_VBUS_WAKEUP 1 +#define VBUS_SENSE_CTL_AB_SESS_VLD 2 +#define VBUS_SENSE_CTL_A_SESS_VLD 3 + +/* USBx_IF_USB_SUSP_CTRL_0 */ +#define UTMIP_PHY_ENB (1 << 12) +#define UTMIP_RESET (1 << 11) +#define USB_PHY_CLK_VALID (1 << 7) + +/* USBx_UTMIP_MISC_CFG1 */ +#define UTMIP_PLLU_STABLE_COUNT_SHIFT 6 +#define UTMIP_PLLU_STABLE_COUNT_MASK \ + (0xfff << UTMIP_PLLU_STABLE_COUNT_SHIFT) +#define UTMIP_PLL_ACTIVE_DLY_COUNT_SHIFT 18 +#define UTMIP_PLL_ACTIVE_DLY_COUNT_MASK \ + (0x1f << UTMIP_PLL_ACTIVE_DLY_COUNT_SHIFT) +#define UTMIP_PHY_XTAL_CLOCKEN (1 << 30) + +/* USBx_UTMIP_PLL_CFG1_0 */ +#define UTMIP_PLLU_ENABLE_DLY_COUNT_SHIFT 27 +#define UTMIP_PLLU_ENABLE_DLY_COUNT_MASK \ + (0xf << UTMIP_PLLU_ENABLE_DLY_COUNT_SHIFT) +#define UTMIP_XTAL_FREQ_COUNT_SHIFT 0 +#define UTMIP_XTAL_FREQ_COUNT_MASK 0xfff + +/* USBx_UTMIP_BIAS_CFG1_0 */ +#define UTMIP_BIAS_PDTRK_COUNT_SHIFT 3 +#define UTMIP_BIAS_PDTRK_COUNT_MASK \ + (0x1f << UTMIP_BIAS_PDTRK_COUNT_SHIFT) +#define UTMIP_BIAS_PDTRK_COUNT_SHIFT 3 +#define UTMIP_BIAS_PDTRK_COUNT_MASK \ + (0x1f << UTMIP_BIAS_PDTRK_COUNT_SHIFT) + +#define UTMIP_DEBOUNCE_CFG0_SHIFT 0 +#define UTMIP_DEBOUNCE_CFG0_MASK 0xffff + +/* USBx_UTMIP_TX_CFG0_0 */ +#define UTMIP_FS_PREAMBLE_J (1 << 19) + +/* USBx_UTMIP_BAT_CHRG_CFG0_0 */ +#define UTMIP_PD_CHRG 1 + +/* USBx_UTMIP_XCVR_CFG0_0 */ +#define UTMIP_XCVR_LSBIAS_SE (1 << 21) + +/* USBx_UTMIP_SPARE_CFG0_0 */ +#define FUSE_SETUP_SEL (1 << 3) + +/* USBx_UTMIP_HSRX_CFG0_0 */ +#define UTMIP_IDLE_WAIT_SHIFT 15 +#define UTMIP_IDLE_WAIT_MASK (0x1f << UTMIP_IDLE_WAIT_SHIFT) +#define UTMIP_ELASTIC_LIMIT_SHIFT 10 +#define UTMIP_ELASTIC_LIMIT_MASK \ + (0x1f << UTMIP_ELASTIC_LIMIT_SHIFT) + +/* USBx_UTMIP_HSRX_CFG0_1 */ +#define UTMIP_HS_SYNC_START_DLY_SHIFT 1 +#define UTMIP_HS_SYNC_START_DLY_MASK \ + (0xf << UTMIP_HS_SYNC_START_DLY_SHIFT) + +/* USBx_CONTROLLER_2_USB2D_ICUSB_CTRL_0 */ +#define IC_ENB1 (1 << 3) + +/* SB2_CONTROLLER_2_USB2D_PORTSC1_0 */ +#define PTS_SHIFT 30 +#define PTS_MASK (3 << PTS_SHIFT) +#define PTS_UTMI 0 +#define PTS_RESERVED 1 +#define PTS_ULP 2 +#define PTS_ICUSB_SER 3 + +#define STS (1 << 29) + +/* USBx_UTMIP_XCVR_CFG0_0 */ +#define UTMIP_FORCE_PD_POWERDOWN (1 << 14) +#define UTMIP_FORCE_PD2_POWERDOWN (1 << 16) +#define UTMIP_FORCE_PDZI_POWERDOWN (1 << 18) + +/* USBx_UTMIP_XCVR_CFG1_0 */ +#define UTMIP_FORCE_PDDISC_POWERDOWN (1 << 0) +#define UTMIP_FORCE_PDCHRP_POWERDOWN (1 << 2) +#define UTMIP_FORCE_PDDR_POWERDOWN (1 << 4) + +/* USB3_IF_USB_PHY_VBUS_SENSORS_0 */ +#define VBUS_VLD_STS (1 << 26) + + +/* Change the USB host port into host mode */ +void usb_set_host_mode(void); + +/* Setup USB on the board */ +int board_usb_init(const void *blob); + +/** + * Start up the given port number (ports are numbered from 0 on each board). + * This returns values for the appropriate hccr and hcor addresses to use for + * USB EHCI operations. + * + * @param portnum port number to start + * @param hccr returns start address of EHCI HCCR registers + * @param hcor returns start address of EHCI HCOR registers + * @return 0 if ok, -1 on error (generally invalid port number) + */ +int tegrausb_start_port(unsigned portnum, u32 *hccr, u32 *hcor); + +/** + * Stop the current port + * + * @return 0 if ok, -1 if no port was active + */ +int tegrausb_stop_port(void); + +#endif /* _TEGRA_USB_H_ */ diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 09abb75..39134ff 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -46,6 +46,7 @@ COBJS-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o COBJS-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o COBJS-$(CONFIG_USB_EHCI_KIRKWOOD) += ehci-kirkwood.o COBJS-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o +COBJS-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o COBJS-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o
COBJS := $(COBJS-y) diff --git a/drivers/usb/host/ehci-tegra.c b/drivers/usb/host/ehci-tegra.c new file mode 100644 index 0000000..3a48c26 --- /dev/null +++ b/drivers/usb/host/ehci-tegra.c @@ -0,0 +1,63 @@ +/* + * Copyright (c) 2009 NVIDIA Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <usb.h> + +#include "ehci.h" +#include "ehci-core.h" + +#include <asm/errno.h> +#include <asm/arch/usb.h> + + +/* + * Create the appropriate control structures to manage + * a new EHCI host controller. + */ +int ehci_hcd_init(void) +{ + u32 our_hccr, our_hcor; + + /* + * Select the first port, as we don't have a way of selecting others + * yet + */ + if (tegrausb_start_port(0, &our_hccr, &our_hcor)) + return -1; + + hccr = (struct ehci_hccr *)our_hccr; + hcor = (struct ehci_hcor *)our_hcor; + + return 0; +} + +/* + * Destroy the appropriate control structures corresponding + * the the EHCI host controller. + */ +int ehci_hcd_stop(void) +{ + usb_set_host_mode(); + tegrausb_stop_port(); + return 0; +} diff --git a/include/fdtdec.h b/include/fdtdec.h index a640db1..a8911b5 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -57,6 +57,7 @@ struct fdt_memory { */ enum fdt_compat_id { COMPAT_UNKNOWN, + COMPAT_NVIDIA_TEGRA20_USB, /* Tegra2 USB port */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 69f8b66..931b4ce 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -37,6 +37,7 @@ DECLARE_GLOBAL_DATA_PTR; #define COMPAT(id, name) name static const char * const compat_names[COMPAT_COUNT] = { COMPAT(UNKNOWN, "<none>"), + COMPAT(NVIDIA_TEGRA20_USB, "nvidia,tegra20-ehci"), };
This adds basic USB support for port 0. The other port is not supported yet.
Tegra2 (SeaBoard) # usb start (Re)start USB... USB: Register 10011 NbrPorts 1 USB EHCI 1.00 scanning bus for devices... 5 USB Device(s) found scanning bus for storage devices... 1 Storage Device(s) found Tegra2 (SeaBoard) # ext2load usb 0:3 10000000 /boot/vmlinuz Loading file "/boot/vmlinuz" from usb device 0:3 (ROOT-A) 2932976 bytes read
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add setting of pinmux for USB VBUS GPIO
board/nvidia/common/board.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index f39fb24..c7a33c3 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -32,6 +32,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch/uart.h> #include <spi.h> +#include <asm/arch/usb.h> #include "board.h"
DECLARE_GLOBAL_DATA_PTR; @@ -125,6 +126,13 @@ int board_init(void) /* boot param addr */ gd->bd->bi_boot_params = (NV_PA_SDRAM_BASE + 0x100);
+#ifdef CONFIG_USB_EHCI_TEGRA + /* For USB GPIO PD0. for now, since we have no pinmux in fdt */ + pinmux_tristate_disable(PINGRP_SLXK); + + board_usb_init(gd->fdt_blob); +#endif + return 0; }
All Tegra2 boards should include tegra2-common. This adds the required USB config to that file.
include/configs/tegra2-common.h | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/include/configs/tegra2-common.h b/include/configs/tegra2-common.h index e6f385f..6549d00 100644 --- a/include/configs/tegra2-common.h +++ b/include/configs/tegra2-common.h @@ -84,6 +84,20 @@ #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ 115200}
+/* + * USB Host. Tegra2 requires USB buffers to be aligned to a word boundary + */ +#define CONFIG_USB_EHCI_DATA_ALIGN 4 + +/* + * This parameter affects a TXFILLTUNING field that controls how much data is + * sent to the latency fifo before it is sent to the wire. Without this + * parameter, the default (2) causes occasional Data Buffer Errors in OUT + * packets depending on the buffer address and size. + */ +#define CONFIG_USB_EHCI_TXFIFO_THRESH 10 + +#define CONFIG_EHCI_IS_TDI /* include default commands */ #include <config_cmd_default.h>
Seaboard has a top port which is USB host or device, and a side port which is host only.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Remove unneeded CONFIG_TEGRA_USBx defines
include/configs/seaboard.h | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 261f952..b6d9f7a 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -72,4 +72,11 @@
#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET (CONFIG_SPI_FLASH_SIZE - CONFIG_ENV_SECT_SIZE) + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + #endif /* __CONFIG_H */
This switches Seaboard over to use FDT for run-time config instead of CONFIG options. USB is the only user at present.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Drop Tegra USB alignment patch as we will deal with this another way
include/configs/seaboard.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index b6d9f7a..1dc775a 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -27,6 +27,11 @@ #include <asm/sizes.h> #include "tegra2-common.h"
+/* Enable fdt support for Seaboard. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-seaboard +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + /* High-level configuration options */ #define TEGRA2_SYSMEM "mem=384M@0M nvmem=128M@384M mem=512M@512M" #define V_PROMPT "Tegra2 (SeaBoard) # "
This series brings in the kernel fdt file and provides a working USB driver for Tegra2 Seaboard.
(I have done this in one series since otherwise most of the fdt additions will just look like dead code.)
The driver requires CONFIG_OF_CONTROL and a device tree to operate.
Some enhancements to fdtdec are required to make this easier, and these are included in the series also. I have had to bring in basic GPIO support due to the request to put the USB VBUS into the fdt.
Since the kernel recently got a very minimal USB binding, I have started with that and extended it where appropriate.
Tegra likes to have cache-aligned buffers. I have dropped the patch which implements this since we will solve this problem by making callers align their buffers (as we did with MMC).
Changes in v2:
Changes in v3:
what's the status of this patch/patchset?
Thanks M
Hi Marek,
Changes in v2:
Changes in v3:
It needs a small update to the Tegra device tree files (2 of the patches) and another change to deal with peripheral IDs (another 2 of the patches). I expect to get this done in the next few days. After that I am hoping we are done, but let's see.
Thanks M
Hi Marek,
Changes in v2:
Changes in v3:
- Remove "okay" from nodes since this is the default anyway
- Fix device tree indenting with tabs instead of spaces
- Disable USB2 which is not used on Seaboard
Simon Glass (16): fdt: Tidy up a few fdtdec problems fdt: Add functions to access phandles, arrays and bools Add gpio_request() to asm-generic header fdt: Add basic support for decoding GPIO definitions arm: fdt: Ensure that an embedded fdt is word-aligned arm: fdt: Add skeleton device tree file from kernel tegra: fdt: Add Tegra2x device tree file from kernel tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard usb: Add support for txfifo threshold tegra: usb: Add support for Tegra USB peripheral tegra: usb: Add USB support to nvidia boards tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Enable USB on Seaboard tegra: fdt: Enable FDT support for Seaboard
README | 3 + arch/arm/cpu/armv7/tegra2/Makefile | 4 +- arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/cpu/armv7/tegra2/usb.c | 430 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/u-boot.lds | 5 + arch/arm/dts/skeleton.dtsi | 13 + arch/arm/dts/tegra20.dtsi | 172 ++++++++++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 2 + arch/arm/include/asm/arch-tegra2/usb.h | 255 +++++++++++++++++ board/nvidia/common/board.c | 8 + board/nvidia/dts/tegra2-seaboard.dts | 47 ++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-hcd.c | 7 + drivers/usb/host/ehci-tegra.c | 63 +++++ drivers/usb/host/ehci.h | 6 +- dts/Makefile | 2 +- include/asm-generic/gpio.h | 10 + include/configs/seaboard.h | 12 + include/configs/tegra2-common.h | 14 + include/fdtdec.h | 109 +++++++- lib/fdtdec.c | 168 +++++++++++- 21 files changed, 1320 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/usb.c create mode 100644 arch/arm/dts/skeleton.dtsi create mode 100644 arch/arm/dts/tegra20.dtsi create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 board/nvidia/dts/tegra2-seaboard.dts create mode 100644 drivers/usb/host/ehci-tegra.c
Ok, please CC me when you resubmit so I can check and apply the USB stuff. Thanks!
M
participants (6)
Kim Phillips
Mike Frysinger
Remy Bohmer
