[U-Boot] [PATCH v1 0/4] ddr: vybrid: various fixes
Some random fixes in vf610 DDR controller initialization. Especially the first patch fixes boot on some Toradex Colibri VFxx modules.
-- Stefan
Stefan Agner (4): toradex: colibri_vf: fix memory initialization ARM: vf610: ddrmc: fix CR138 preprocessor define ARM: vf610: ddrmc: fix initialization completion detection ARM: vf610: ddrmc: do not write CR79 by default
arch/arm/include/asm/arch-vf610/imx-regs.h | 5 +++-- arch/arm/mach-imx/ddrmc-vf610.c | 4 ++-- board/toradex/colibri_vf/colibri_vf.c | 10 +--------- 3 files changed, 6 insertions(+), 13 deletions(-)
Commit 3f353ceccbbb ("vf610: refactor DDRMC code") changed on-die termination (ODT) values from 120 Ohm to 60 Ohm and enabled a static read/write leveling which has not been tested with this board. This commit reverts both changes and makes sure that memory gets initialized as it has been done before the mentioned commit.
Fixes: 3f353ceccbbb ("vf610: refactor DDRMC code") Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com ---
board/toradex/colibri_vf/colibri_vf.c | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 4db1757469..19cf748c5d 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -42,14 +42,6 @@ DECLARE_GLOBAL_DATA_PTR; #define USB_CDET_GPIO 102
static struct ddrmc_cr_setting colibri_vf_cr_settings[] = { - /* levelling */ - { DDRMC_CR97_WRLVL_EN, 97 }, - { DDRMC_CR98_WRLVL_DL_0(0), 98 }, - { DDRMC_CR99_WRLVL_DL_1(0), 99 }, - { DDRMC_CR102_RDLVL_REG_EN | DDRMC_CR102_RDLVL_GT_REGEN, 102 }, - { DDRMC_CR105_RDLVL_DL_0(0), 105 }, - { DDRMC_CR106_RDLVL_GTDL_0(4), 106 }, - { DDRMC_CR110_RDLVL_DL_1(0) | DDRMC_CR110_RDLVL_GTDL_1(4), 110 }, /* AXI */ { DDRMC_CR117_AXI0_W_PRI(0) | DDRMC_CR117_AXI0_R_PRI(0), 117 }, { DDRMC_CR118_AXI1_W_PRI(1) | DDRMC_CR118_AXI1_R_PRI(1), 118 }, @@ -88,7 +80,7 @@ static struct ddrmc_cr_setting colibri_vf_cr_settings[] = { DDRMC_CR154_PAD_ZQ_MODE(1) | DDRMC_CR154_DDR_SEL_PAD_CONTR(3) | DDRMC_CR154_PAD_ZQ_HW_FOR(1), 154 }, - { DDRMC_CR155_PAD_ODT_BYTE1(1) | DDRMC_CR155_PAD_ODT_BYTE0(1), 155 }, + { DDRMC_CR155_PAD_ODT_BYTE1(2) | DDRMC_CR155_PAD_ODT_BYTE0(2), 155 }, { DDRMC_CR158_TWR(6), 158 }, { DDRMC_CR161_ODT_EN(1) | DDRMC_CR161_TODTH_RD(2) | DDRMC_CR161_TODTH_WR(2), 161 },
Hi Stefan,
This is of course colibri_vf specific code, but I had some issue with it on my board.
- /* levelling */
If you have single DDR3 x16, then this is NOT needed (according to NXP).
102 },
The recommended value for RDLVL_DL_x is 0x20.
For the GTDL the recommended value is 0x4.
It is interesting why the board is not working with recommended values. Probably some other values are wrong - as described in:
https://community.nxp.com/thread/490391
- { DDRMC_CR155_PAD_ODT_BYTE1(2) |
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 04.12.2018 12:05, Lukasz Majewski wrote:
Hi Stefan,
Note that this patch *drops* the static leveling.
This values have been introduced in the commit mentioned below, but were never properly evaluated for this board.
We are in the process of evaluating new values using the DDRv tool, but I prefer to first drop them until we are ready to upstream the new values.
-- Stefan
- /* levelling */
102 },
Lukasz Majewski
According to the data sheet bits 10-8 are PHYDRAM_CK_EN. Fix mask to allow setting PHYDRAM_CK_EN correctly.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
arch/arm/include/asm/arch-vf610/imx-regs.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index 08ba8e94f8..b7374bfb8f 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -239,7 +239,7 @@ #define DDRMC_CR132_RDLAT_ADJ(v) ((v) & 0x3f) #define DDRMC_CR137_PHYCTL_DL(v) (((v) & 0xf) << 16) #define DDRMC_CR138_PHY_WRLV_MXDL(v) (((v) & 0xffff) << 16) -#define DDRMC_CR138_PHYDRAM_CK_EN(v) (((v) & 0x8) << 8) +#define DDRMC_CR138_PHYDRAM_CK_EN(v) (((v) & 0x7) << 8) #define DDRMC_CR139_PHY_WRLV_RESPLAT(v) (((v) & 0xff) << 24) #define DDRMC_CR139_PHY_WRLV_LOAD(v) (((v) & 0xff) << 16) #define DDRMC_CR139_PHY_WRLV_DLL(v) (((v) & 0xff) << 8)
Hi Stefan,
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
The CR80 register has multiple interrupt bits, the code is supposed to check bit 8 but instead uses a logical and. In most cases this probably did not affect real operations since at that stage typically none of the other bits are set.
arch/arm/include/asm/arch-vf610/imx-regs.h | 3 ++- arch/arm/mach-imx/ddrmc-vf610.c | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index b7374bfb8f..f71fbf4e73 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -200,7 +200,8 @@ #define DDRMC_CR78_Q_FULLNESS(v) (((v) & 0x7) << 24) #define DDRMC_CR78_BUR_ON_FLY_BIT(v) ((v) & 0xf) #define DDRMC_CR79_CTLUPD_AREF(v) (((v) & 0x1) << 24) -#define DDRMC_CR82_INT_MASK 0x10000000 +#define DDRMC_CR80_MC_INIT_COMPLETE (1 << 8) +#define DDRMC_CR82_INT_MASK (1 << 28) #define DDRMC_CR87_ODT_WR_MAPCS0(v) ((v) << 24) #define DDRMC_CR87_ODT_RD_MAPCS0(v) ((v) << 16) #define DDRMC_CR88_TODTL_CMD(v) (((v) & 0x1f) << 16) diff --git a/arch/arm/mach-imx/ddrmc-vf610.c b/arch/arm/mach-imx/ddrmc-vf610.c index 3d7da1c25e..d121a53898 100644 --- a/arch/arm/mach-imx/ddrmc-vf610.c +++ b/arch/arm/mach-imx/ddrmc-vf610.c @@ -231,6 +231,7 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, /* all inits done, start the DDR controller */ writel(DDRMC_CR00_DRAM_CLASS_DDR3 | DDRMC_CR00_START, &ddrmr->cr[0]);
- while (!(readl(&ddrmr->cr[80]) && 0x100)) + while (!(readl(&ddrmr->cr[80]) & DDRMC_CR80_MC_INIT_COMPLETE)) udelay(10); + writel(DDRMC_CR80_MC_INIT_COMPLETE, &ddrmr->cr[81]); }
Hi Stefan,
It can exit the loop when any error bit is set (but anyway with broken DDR initialization we hang latter anyway).
When I was working on my code - the checkpatch.pl was complaining about (1 << x) code. It was recommended to use BIT(x) instead.
- writel(DDRMC_CR80_MC_INIT_COMPLETE, &ddrmr->cr[81]);
Lukasz Majewski
On 04.12.2018 11:59, Lukasz Majewski wrote:
Hi Stefan,
Yeah I noticed that too, but arch/arm/include/asm/arch-vf610/imx-regs.h does use bit shifting so far. I rated consistency higher than the new recommendation :-)
-- Stefan
Lukasz Majewski
Lukasz, Stefano,
Hi Stefan,
Do you want me to change the whole file to BIT here? I'd rather prefer to keep it for now.
But I think we otherwise are ok with this patch set right? I guess technically patch 4 would not be your realm Stefano, but maybe you can also take it through your tree?
-- Stefan
-- Stefan
Lukasz Majewski
The current value CTLUPD_AREF(0) is the reset value of the register, so there is no need to write a value. If needed, the register can be written using board specific CR settings.
arch/arm/mach-imx/ddrmc-vf610.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/mach-imx/ddrmc-vf610.c b/arch/arm/mach-imx/ddrmc-vf610.c index d121a53898..d4926b5cee 100644 --- a/arch/arm/mach-imx/ddrmc-vf610.c +++ b/arch/arm/mach-imx/ddrmc-vf610.c @@ -188,7 +188,6 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings, DDRMC_CR77_SWAP_EN, &ddrmr->cr[77]); writel(DDRMC_CR78_Q_FULLNESS(timings->q_fullness) | DDRMC_CR78_BUR_ON_FLY_BIT(12), &ddrmr->cr[78]); - writel(DDRMC_CR79_CTLUPD_AREF(0), &ddrmr->cr[79]);
writel(DDRMC_CR82_INT_MASK, &ddrmr->cr[82]);
Hi Stefan,
Lukasz Majewski
Lukasz Majewski
Stefan Agner
