[U-Boot] gpio: Question about gpio_set_value() implementation in spear_gpio.c
Current code looks strange because no matter the value argument is 0 or 1 it always calls writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]);
And then gpio_get_value() always return 1.
I'm wondering if it needs to be fixed, something like below change:
diff --git a/drivers/gpio/spear_gpio.c b/drivers/gpio/spear_gpio.c index d3c728e..8878608 100644 --- a/drivers/gpio/spear_gpio.c +++ b/drivers/gpio/spear_gpio.c @@ -52,7 +52,10 @@ int gpio_set_value(unsigned gpio, int value) { struct gpio_regs *regs = (struct gpio_regs *)CONFIG_GPIO_BASE;
- writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + if (value) + writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + else + writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]);
return 0; }
if (value)
else
writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]); return 0;
writel(value << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]);
Should do no? This would avoid the if block.
-- Otavio Salvador O.S. Systems http://www.ossystems.com.br http://projetos.ossystems.com.br Mobile: +55 (53) 9981-7854 Mobile: +1 (347) 903-9750
Dear Otavio Salvador,
if (value)
else
No, you need clrbits_le32() to unset the GPIO
Best regards, Marek Vasut
Dear Axel Lin,
- if (value)
- else
You might want to use clrbits_le32() and setbits_le32() here, no?
return 0; }
2013/6/19 Marek Vasut marex@denx.de:
Dear Axel Lin,
if (value)
else
Honestly, I ask this because I cannot find the detail datasheet for the gpio control of this device. ( Just found the code looks strange).
Usually we can use clrbits_le32() and setbits_le32() helpers to set/clear register bits. But if the only meaningful bit is "1 << gpio", simply use "write 1 << gpio" and "write 0" saves a register read operation.
So maybe Stefan or someone from ST can provide the information about gpio control on this hardware.
Regards, Axel
if (value)
else
I honestly have no idea how I tested this GPIO driver. That was too long ago. And I don't have the time to dig out the hardware to do some re-testing. But the code definitely looks wrong, so thanks for catching this. Let's wait what the ST engineers have to comment here.
Thanks, Stefan
On 6/19/2013 7:14 PM, Axel Lin wrote:
Current code looks strange because no matter the value argument is 0 or 1 it always calls writel(1<< gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]);
- writel(1<< gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]);
- if (value)
- else
writel(0,®s->gpiodata[DATA_REG_ADDR(gpio)]);
Yes, this is the right way. It was a blunder. I am wondering no one ever tried to set a ZERO on any GPIO..
Thanks for pointing out
Regards Vipin
return 0; }
participants (5)
Axel Lin
Otavio Salvador
Stefan Roese
Vipin Kumar
