[U-Boot] [PATCH] ARM: imx6: DHCOM i.MX6 PDK: enable pad pull ups of SS lines of spi used for boot
It turned out that after a reset the boot process from the spi bootflash is disturbed by other spi slave devices connected to DHCOM SPI1, which uses the same spi interface with a different SS line.
Therefore the pad pull ups are enabled.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index 2939389de3..9494d2d6a3 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -440,8 +440,13 @@ static void setup_iomux_sd(void)
/* SPI */ static iomux_v3_cfg_t const ecspi1_pads[] = { - /* SS0 */ - IOMUX_PADS(PAD_EIM_EB2__GPIO2_IO30 | MUX_PAD_CTRL(SPI_PAD_CTRL)), + /* SS0 - SS of boot flash */ + IOMUX_PADS(PAD_EIM_EB2__GPIO2_IO30 | + MUX_PAD_CTRL(SPI_PAD_CTRL | PAD_CTL_PUS_100K_UP)), + /* SS2 - SS of DHCOM SPI1 */ + IOMUX_PADS(PAD_KEY_ROW2__GPIO4_IO11 | + MUX_PAD_CTRL(SPI_PAD_CTRL | PAD_CTL_PUS_100K_UP)), + IOMUX_PADS(PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL)), IOMUX_PADS(PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL)), IOMUX_PADS(PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL)),
It turned out that after a reset the boot process from the spi bootflash is disturbed by other spi slave devices connected to DHCOM SPI1, which uses the same spi interface with a different SS line. Therefore the pad pull ups are enabled. Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com
Best regards, Stefano Babic
Ludwig Zenz
sbabic@denx.de
