[U-Boot] [PATCH 4/8] sun8i: Add TZPC setup for A83t
Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- arch/arm/cpu/armv7/sunxi/Makefile | 1 + arch/arm/cpu/armv7/sunxi/tzpc.c | 10 ++++++++++ arch/arm/include/asm/arch-sunxi/tzpc.h | 10 ++++++++++ arch/arm/mach-sunxi/board.c | 2 +- 4 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index 4d2274a..4dd449b 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -11,6 +11,7 @@ obj-y += timer.o
obj-$(CONFIG_MACH_SUN6I) += tzpc.o obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o +obj-$(CONFIG_MACH_SUN8I_A83T) += tzpc.o
ifndef CONFIG_SPL_BUILD ifdef CONFIG_ARMV7_PSCI diff --git a/arch/arm/cpu/armv7/sunxi/tzpc.c b/arch/arm/cpu/armv7/sunxi/tzpc.c index 6c8a0fd..7723853 100644 --- a/arch/arm/cpu/armv7/sunxi/tzpc.c +++ b/arch/arm/cpu/armv7/sunxi/tzpc.c @@ -24,4 +24,14 @@ void tzpc_init(void) writel(SUN8I_H3_TZPC_DECPORT1_ALL, &tzpc->decport1_set); writel(SUN8I_H3_TZPC_DECPORT2_ALL, &tzpc->decport2_set); #endif + +#ifdef SUN8I_A83T_TZPC_DECPORT0_ALL + /* Emable non-secure access to RAM */ + writel(R0SIZE, &tzpc->r0size); + + /* Enable non-secure access to all peripherals */ + writel(SUN8I_A83T_TZPC_DECPORT0_ALL, &tzpc->decport0_set); + writel(SUN8I_A83T_TZPC_DECPORT1_ALL, &tzpc->decport1_set); + writel(SUN8I_A83T_TZPC_DECPORT2_ALL, &tzpc->decport2_set); +#endif } diff --git a/arch/arm/include/asm/arch-sunxi/tzpc.h b/arch/arm/include/asm/arch-sunxi/tzpc.h index 95c55cd..bcf0713 100644 --- a/arch/arm/include/asm/arch-sunxi/tzpc.h +++ b/arch/arm/include/asm/arch-sunxi/tzpc.h @@ -29,6 +29,16 @@ struct sunxi_tzpc { #define SUN8I_H3_TZPC_DECPORT1_ALL 0xff #define SUN8I_H3_TZPC_DECPORT2_ALL 0x7f
+#define SUN8I_A83T_TZPC_DECPORT0_ALL 0xbe +#define SUN8I_A83T_TZPC_DECPORT1_ALL 0x7f +#define SUN8I_A83T_TZPC_DECPORT2_ALL 0x10 + +/* + * TZPC Register Value : + * R0SIZE: 0x10 : Size of secured ram (64Kib) + */ +#define R0SIZE 0x10 + void tzpc_init(void);
#endif /* _SUNXI_TZPC_H */ diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 20149da..4e0f7f9 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -183,7 +183,7 @@ void s_init(void) "orr r0, r0, #1 << 6\n" "mcr p15, 0, r0, c1, c0, 1\n"); #endif -#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 +#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3 || defined CONFIG_MACH_SUN8I_A83T /* Enable non-secure access to some peripherals */ tzpc_init(); #endif
On Tue, May 17, 2016 at 10:39 AM, tpearson@raptorengineering.com wrote:
Description please.
Why would you do that? That defeats the whole purpose of having the secure monitor running in secure SRAM.
And move this block above H3's block.
A83T before H3.
- TZPC Register Value :
- R0SIZE: 0x10 : Size of secured ram (64Kib)
Where did this come from?
A83T comes before H3.
ChenYu
#endif
2.8.0.rc3
Description please.
It still reserves 64k as secure per other sunxi devices. Do we need more secure RAM than the 64k?
A83T before H3.
This is the value for 64k per the datasheet.
ChenYu
#endif
2.8.0.rc3
On Wed, May 18, 2016 at 3:25 AM, Timothy Pearson tpearson@raptorengineering.com wrote:
Description please.
Actually that register is read-only (and just tested it myself). It just indicates how large the secure SRAM is, you can't really change it.
ChenYu
A83T before H3.
ChenYu
#endif
2.8.0.rc3
-- Timothy Pearson Raptor Engineering +1 (415) 727-8645 (direct line) +1 (512) 690-0200 (switchboard) https://www.raptorengineering.com
Chen-Yu Tsai
Timothy Pearson
