[PATCH v2] imx8mm_beacon: Switch to binman for generating image
To eliminate a warning when using custom imx tools for generating a binary, use binman to generate flash.bin.
Signed-off-by: Adam Ford aford173@gmail.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
--- Note that this re-base is only compile tested.
Changes in v2: - Re-based on top of imx/master.
arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 122 ++++++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 1 + board/beacon/imx8mm/Kconfig | 2 +- board/beacon/imx8mm/README | 6 +- board/beacon/imx8mm/imximage-8mm-lpddr4.cfg | 9 ++ configs/imx8mm_beacon_defconfig | 2 +- 6 files changed, 137 insertions(+), 5 deletions(-) create mode 100644 board/beacon/imx8mm/imximage-8mm-lpddr4.cfg
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index 73ddfdade6a..3c034a85e35 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -6,6 +6,10 @@ #include "imx8mm-u-boot.dtsi"
/ { + binman: binman { + multiple-images; + }; + wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -100,3 +104,121 @@ &wdog1 { u-boot,dm-spl; }; + +&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x920000>; + entry = <0x920000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + fdt { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob: blob-ext { + filename = "u-boot.dtb"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + description = "NAME"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 276b8bd9742..a2822f8c28f 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -117,6 +117,7 @@ config TARGET_VERDIN_IMX8MM
config TARGET_IMX8MM_BEACON bool "imx8mm Beacon Embedded devkit" + select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 diff --git a/board/beacon/imx8mm/Kconfig b/board/beacon/imx8mm/Kconfig index 58799c1a655..63f064e8cb8 100644 --- a/board/beacon/imx8mm/Kconfig +++ b/board/beacon/imx8mm/Kconfig @@ -10,7 +10,7 @@ config SYS_CONFIG_NAME default "imx8mm_beacon"
config IMX_CONFIG - default "arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" + default "board/beacon/imx8mm/imximage-8mm-lpddr4.cfg"
source "board/freescale/common/Kconfig"
diff --git a/board/beacon/imx8mm/README b/board/beacon/imx8mm/README index dce176fa0b2..03d9412f0d6 100644 --- a/board/beacon/imx8mm/README +++ b/board/beacon/imx8mm/README @@ -12,8 +12,8 @@ Get and Build the ARM Trusted firmware Note: $(srctree) is U-Boot source directory
$ git clone https://source.codeaurora.org/external/imx/imx-atf -$ git checkout imx_4.19.35_1.0.0 -$ make PLAT=imx8mm bl31 ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- +$ git checkout imx_5.4.70_2.3.0 +$ make PLAT=imx8mm bl31 CROSS_COMPILE=aarch64-linux-gnu- $ cp build/imx8mm/release/bl31.bin $(srctree)
Get the DDR firmware @@ -26,7 +26,7 @@ $ cp firmware-imx-8.5/firmware/ddr/synopsys/lpddr4*.bin $(srctree) Build U-Boot ============ $ make imx8mm_beacon_defconfig -$ make flash.bin CROSS_COMPILE=aarch64-linux-gnu- ATF_LOAD_ADDR=0x920000 +$ make flash.bin CROSS_COMPILE=aarch64-linux-gnu-
Burn U-Boot to microSD Card =========================== diff --git a/board/beacon/imx8mm/imximage-8mm-lpddr4.cfg b/board/beacon/imx8mm/imximage-8mm-lpddr4.cfg new file mode 100644 index 00000000000..90573be5fd9 --- /dev/null +++ b/board/beacon/imx8mm/imximage-8mm-lpddr4.cfg @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + +#define __ASSEMBLY__ + +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 02cdeda23e5..9d6af69ba15 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -21,7 +21,7 @@ CONFIG_SYS_LOAD_ADDR=0x40480000 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-beacon-kit.dtb" CONFIG_SPL_BOARD_INIT=y
Changes in v2:
Signed-off-by: Adam Ford aford173@gmail.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Simon Glass sjg@chromium.org
Marcel Ziswiler
