[U-Boot] [PATCH 1/2] imx: drop imx-regs.h
imx-regs.h under arch-imx has no user, drop it.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
CI: https://travis-ci.org/MrVan/u-boot/builds/530082356
arch/arm/include/asm/arch-imx/imx-regs.h | 637 ------------------------------- 1 file changed, 637 deletions(-) delete mode 100644 arch/arm/include/asm/arch-imx/imx-regs.h
diff --git a/arch/arm/include/asm/arch-imx/imx-regs.h b/arch/arm/include/asm/arch-imx/imx-regs.h deleted file mode 100644 index 93e336951c..0000000000 --- a/arch/arm/include/asm/arch-imx/imx-regs.h +++ /dev/null @@ -1,637 +0,0 @@ -#ifndef _IMX_REGS_H -#define _IMX_REGS_H - -#define ARCH_MXC - -/* ------------------------------------------------------------------------ - * Motorola IMX system registers - * ------------------------------------------------------------------------ - * - */ - -#define IO_ADDRESS(x) ((x) | IMX_IO_BASE) - -# ifndef __ASSEMBLY__ -# define __REG(x) (*((volatile u32 *)IO_ADDRESS(x))) -# define __REG2(x,y) (*(volatile u32 *)((u32)&__REG(x) + (y))) -# else -# define __REG(x) (x) -# define __REG2(x,y) ((x)+(y)) -#endif - -#define IMX_IO_BASE 0x00200000 - -/* - * Register BASEs, based on OFFSETs - * - */ -#define IMX_AIPI1_BASE (0x00000 + IMX_IO_BASE) -#define IMX_WDT_BASE (0x01000 + IMX_IO_BASE) -#define IMX_TIM1_BASE (0x02000 + IMX_IO_BASE) -#define IMX_TIM2_BASE (0x03000 + IMX_IO_BASE) -#define IMX_RTC_BASE (0x04000 + IMX_IO_BASE) -#define IMX_LCDC_BASE (0x05000 + IMX_IO_BASE) -#define IMX_UART1_BASE (0x06000 + IMX_IO_BASE) -#define IMX_UART2_BASE (0x07000 + IMX_IO_BASE) -#define IMX_PWM_BASE (0x08000 + IMX_IO_BASE) -#define IMX_DMAC_BASE (0x09000 + IMX_IO_BASE) -#define IMX_AIPI2_BASE (0x10000 + IMX_IO_BASE) -#define IMX_SIM_BASE (0x11000 + IMX_IO_BASE) -#define IMX_USBD_BASE (0x12000 + IMX_IO_BASE) -#define IMX_SPI1_BASE (0x13000 + IMX_IO_BASE) -#define IMX_MMC_BASE (0x14000 + IMX_IO_BASE) -#define IMX_ASP_BASE (0x15000 + IMX_IO_BASE) -#define IMX_BTA_BASE (0x16000 + IMX_IO_BASE) -#define I2C1_BASE_ADDR (0x17000 + IMX_IO_BASE) -#define IMX_SSI_BASE (0x18000 + IMX_IO_BASE) -#define IMX_SPI2_BASE (0x19000 + IMX_IO_BASE) -#define IMX_MSHC_BASE (0x1A000 + IMX_IO_BASE) -#define IMX_PLL_BASE (0x1B000 + IMX_IO_BASE) -#define IMX_SYSCTRL_BASE (0x1B800 + IMX_IO_BASE) -#define IMX_GPIO_BASE (0x1C000 + IMX_IO_BASE) -#define IMX_EIM_BASE (0x20000 + IMX_IO_BASE) -#define IMX_SDRAMC_BASE (0x21000 + IMX_IO_BASE) -#define IMX_MMA_BASE (0x22000 + IMX_IO_BASE) -#define IMX_AITC_BASE (0x23000 + IMX_IO_BASE) -#define IMX_CSI_BASE (0x24000 + IMX_IO_BASE) - -/* Watchdog Registers*/ - -#define WCR __REG(IMX_WDT_BASE + 0x00) /* Watchdog Control Register */ -#define WSR __REG(IMX_WDT_BASE + 0x04) /* Watchdog Service Register */ -#define WSTR __REG(IMX_WDT_BASE + 0x08) /* Watchdog Status Register */ - -/* SYSCTRL Registers */ -#define SIDR __REG(IMX_SYSCTRL_BASE + 0x4) /* Silicon ID Register */ -#define FMCR __REG(IMX_SYSCTRL_BASE + 0x8) /* Function Multiplex Control Register */ -#define GPCR __REG(IMX_SYSCTRL_BASE + 0xC) /* Function Multiplex Control Register */ - -/* Chip Select Registers */ -#define CS0U __REG(IMX_EIM_BASE) /* Chip Select 0 Upper Register */ -#define CS0L __REG(IMX_EIM_BASE + 0x4) /* Chip Select 0 Lower Register */ -#define CS1U __REG(IMX_EIM_BASE + 0x8) /* Chip Select 1 Upper Register */ -#define CS1L __REG(IMX_EIM_BASE + 0xc) /* Chip Select 1 Lower Register */ -#define CS2U __REG(IMX_EIM_BASE + 0x10) /* Chip Select 2 Upper Register */ -#define CS2L __REG(IMX_EIM_BASE + 0x14) /* Chip Select 2 Lower Register */ -#define CS3U __REG(IMX_EIM_BASE + 0x18) /* Chip Select 3 Upper Register */ -#define CS3L __REG(IMX_EIM_BASE + 0x1c) /* Chip Select 3 Lower Register */ -#define CS4U __REG(IMX_EIM_BASE + 0x20) /* Chip Select 4 Upper Register */ -#define CS4L __REG(IMX_EIM_BASE + 0x24) /* Chip Select 4 Lower Register */ -#define CS5U __REG(IMX_EIM_BASE + 0x28) /* Chip Select 5 Upper Register */ -#define CS5L __REG(IMX_EIM_BASE + 0x2c) /* Chip Select 5 Lower Register */ -#define EIM __REG(IMX_EIM_BASE + 0x30) /* EIM Configuration Register */ - -/* SDRAM controller registers */ - -#define SDCTL0 __REG(IMX_SDRAMC_BASE) /* SDRAM 0 Control Register */ -#define SDCTL1 __REG(IMX_SDRAMC_BASE + 0x4) /* SDRAM 1 Control Register */ -#define SDMISC __REG(IMX_SDRAMC_BASE + 0x14) /* Miscellaneous Register */ -#define SDRST __REG(IMX_SDRAMC_BASE + 0x18) /* SDRAM Reset Register */ - -/* PLL registers */ -#define CSCR __REG(IMX_PLL_BASE) /* Clock Source Control Register */ -#define CSCR_SPLL_RESTART (1<<22) -#define CSCR_MPLL_RESTART (1<<21) -#define CSCR_SYSTEM_SEL (1<<16) -#define CSCR_BCLK_DIV (0xf<<10) -#define CSCR_MPU_PRESC (1<<15) -#define CSCR_SPEN (1<<1) -#define CSCR_MPEN (1<<0) - -#define MPCTL0 __REG(IMX_PLL_BASE + 0x4) /* MCU PLL Control Register 0 */ -#define MPCTL1 __REG(IMX_PLL_BASE + 0x8) /* MCU PLL and System Clock Register 1 */ -#define SPCTL0 __REG(IMX_PLL_BASE + 0xc) /* System PLL Control Register 0 */ -#define SPCTL1 __REG(IMX_PLL_BASE + 0x10) /* System PLL Control Register 1 */ -#define PCDR __REG(IMX_PLL_BASE + 0x20) /* Peripheral Clock Divider Register */ - -/* - * GPIO Module and I/O Multiplexer - * x = 0..3 for reg_A, reg_B, reg_C, reg_D - */ -#define DDIR(x) __REG2(IMX_GPIO_BASE + 0x00, ((x) & 3) << 8) -#define OCR1(x) __REG2(IMX_GPIO_BASE + 0x04, ((x) & 3) << 8) -#define OCR2(x) __REG2(IMX_GPIO_BASE + 0x08, ((x) & 3) << 8) -#define ICONFA1(x) __REG2(IMX_GPIO_BASE + 0x0c, ((x) & 3) << 8) -#define ICONFA2(x) __REG2(IMX_GPIO_BASE + 0x10, ((x) & 3) << 8) -#define ICONFB1(x) __REG2(IMX_GPIO_BASE + 0x14, ((x) & 3) << 8) -#define ICONFB2(x) __REG2(IMX_GPIO_BASE + 0x18, ((x) & 3) << 8) -#define DR(x) __REG2(IMX_GPIO_BASE + 0x1c, ((x) & 3) << 8) -#define GIUS(x) __REG2(IMX_GPIO_BASE + 0x20, ((x) & 3) << 8) -#define SSR(x) __REG2(IMX_GPIO_BASE + 0x24, ((x) & 3) << 8) -#define ICR1(x) __REG2(IMX_GPIO_BASE + 0x28, ((x) & 3) << 8) -#define ICR2(x) __REG2(IMX_GPIO_BASE + 0x2c, ((x) & 3) << 8) -#define IMR(x) __REG2(IMX_GPIO_BASE + 0x30, ((x) & 3) << 8) -#define ISR(x) __REG2(IMX_GPIO_BASE + 0x34, ((x) & 3) << 8) -#define GPR(x) __REG2(IMX_GPIO_BASE + 0x38, ((x) & 3) << 8) -#define SWR(x) __REG2(IMX_GPIO_BASE + 0x3c, ((x) & 3) << 8) -#define PUEN(x) __REG2(IMX_GPIO_BASE + 0x40, ((x) & 3) << 8) - -#define GPIO_PORT_MAX 3 - -#define GPIO_PIN_MASK 0x1f -#define GPIO_PORT_MASK (0x3 << 5) - -#define GPIO_PORT_SHIFT 5 -#define GPIO_PORTA (0<<5) -#define GPIO_PORTB (1<<5) -#define GPIO_PORTC (2<<5) -#define GPIO_PORTD (3<<5) - -#define GPIO_OUT (1<<7) -#define GPIO_IN (0<<7) -#define GPIO_PUEN (1<<8) - -#define GPIO_PF (0<<9) -#define GPIO_AF (1<<9) - -#define GPIO_OCR_SHIFT 10 -#define GPIO_OCR_MASK (3<<10) -#define GPIO_AIN (0<<10) -#define GPIO_BIN (1<<10) -#define GPIO_CIN (2<<10) -#define GPIO_DR (3<<10) - -#define GPIO_AOUT_SHIFT 12 -#define GPIO_AOUT_MASK (3<<12) -#define GPIO_AOUT (0<<12) -#define GPIO_AOUT_ISR (1<<12) -#define GPIO_AOUT_0 (2<<12) -#define GPIO_AOUT_1 (3<<12) - -#define GPIO_BOUT_SHIFT 14 -#define GPIO_BOUT_MASK (3<<14) -#define GPIO_BOUT (0<<14) -#define GPIO_BOUT_ISR (1<<14) -#define GPIO_BOUT_0 (2<<14) -#define GPIO_BOUT_1 (3<<14) - -#define GPIO_GIUS (1<<16) - -/* assignements for GPIO alternate/primary functions */ - -/* FIXME: This list is not completed. The correct directions are - * missing on some (many) pins - */ -#define PA0_AIN_SPI2_CLK ( GPIO_GIUS | GPIO_PORTA | GPIO_OUT | 0 ) -#define PA0_AF_ETMTRACESYNC ( GPIO_PORTA | GPIO_AF | 0 ) -#define PA1_AOUT_SPI2_RXD ( GPIO_GIUS | GPIO_PORTA | GPIO_IN | 1 ) -#define PA1_PF_TIN ( GPIO_PORTA | GPIO_PF | 1 ) -#define PA2_PF_PWM0 ( GPIO_PORTA | GPIO_OUT | GPIO_PF | 2 ) -#define PA3_PF_CSI_MCLK ( GPIO_PORTA | GPIO_PF | 3 ) -#define PA4_PF_CSI_D0 ( GPIO_PORTA | GPIO_PF | 4 ) -#define PA5_PF_CSI_D1 ( GPIO_PORTA | GPIO_PF | 5 ) -#define PA6_PF_CSI_D2 ( GPIO_PORTA | GPIO_PF | 6 ) -#define PA7_PF_CSI_D3 ( GPIO_PORTA | GPIO_PF | 7 ) -#define PA8_PF_CSI_D4 ( GPIO_PORTA | GPIO_PF | 8 ) -#define PA9_PF_CSI_D5 ( GPIO_PORTA | GPIO_PF | 9 ) -#define PA10_PF_CSI_D6 ( GPIO_PORTA | GPIO_PF | 10 ) -#define PA11_PF_CSI_D7 ( GPIO_PORTA | GPIO_PF | 11 ) -#define PA12_PF_CSI_VSYNC ( GPIO_PORTA | GPIO_PF | 12 ) -#define PA13_PF_CSI_HSYNC ( GPIO_PORTA | GPIO_PF | 13 ) -#define PA14_PF_CSI_PIXCLK ( GPIO_PORTA | GPIO_PF | 14 ) -#define PA15_PF_I2C_SDA ( GPIO_PORTA | GPIO_OUT | GPIO_PF | 15 ) -#define PA16_PF_I2C_SCL ( GPIO_PORTA | GPIO_OUT | GPIO_PF | 16 ) -#define PA17_AF_ETMTRACEPKT4 ( GPIO_PORTA | GPIO_AF | 17 ) -#define PA17_AIN_SPI2_SS ( GPIO_GIUS | GPIO_PORTA | GPIO_OUT | 17 ) -#define PA18_AF_ETMTRACEPKT5 ( GPIO_PORTA | GPIO_AF | 18 ) -#define PA19_AF_ETMTRACEPKT6 ( GPIO_PORTA | GPIO_AF | 19 ) -#define PA20_AF_ETMTRACEPKT7 ( GPIO_PORTA | GPIO_AF | 20 ) -#define PA21_PF_A0 ( GPIO_PORTA | GPIO_PF | 21 ) -#define PA22_PF_CS4 ( GPIO_PORTA | GPIO_PF | 22 ) -#define PA23_PF_CS5 ( GPIO_PORTA | GPIO_PF | 23 ) -#define PA24_PF_A16 ( GPIO_PORTA | GPIO_PF | 24 ) -#define PA24_AF_ETMTRACEPKT0 ( GPIO_PORTA | GPIO_AF | 24 ) -#define PA25_PF_A17 ( GPIO_PORTA | GPIO_PF | 25 ) -#define PA25_AF_ETMTRACEPKT1 ( GPIO_PORTA | GPIO_AF | 25 ) -#define PA26_PF_A18 ( GPIO_PORTA | GPIO_PF | 26 ) -#define PA26_AF_ETMTRACEPKT2 ( GPIO_PORTA | GPIO_AF | 26 ) -#define PA27_PF_A19 ( GPIO_PORTA | GPIO_PF | 27 ) -#define PA27_AF_ETMTRACEPKT3 ( GPIO_PORTA | GPIO_AF | 27 ) -#define PA28_PF_A20 ( GPIO_PORTA | GPIO_PF | 28 ) -#define PA28_AF_ETMPIPESTAT0 ( GPIO_PORTA | GPIO_AF | 28 ) -#define PA29_PF_A21 ( GPIO_PORTA | GPIO_PF | 29 ) -#define PA29_AF_ETMPIPESTAT1 ( GPIO_PORTA | GPIO_AF | 29 ) -#define PA30_PF_A22 ( GPIO_PORTA | GPIO_PF | 30 ) -#define PA30_AF_ETMPIPESTAT2 ( GPIO_PORTA | GPIO_AF | 30 ) -#define PA31_PF_A23 ( GPIO_PORTA | GPIO_PF | 31 ) -#define PA31_AF_ETMTRACECLK ( GPIO_PORTA | GPIO_AF | 31 ) -#define PB8_PF_SD_DAT0 ( GPIO_PORTB | GPIO_PF | GPIO_PUEN | 8 ) -#define PB8_AF_MS_PIO ( GPIO_PORTB | GPIO_AF | 8 ) -#define PB9_PF_SD_DAT1 ( GPIO_PORTB | GPIO_PF | GPIO_PUEN | 9 ) -#define PB9_AF_MS_PI1 ( GPIO_PORTB | GPIO_AF | 9 ) -#define PB10_PF_SD_DAT2 ( GPIO_PORTB | GPIO_PF | GPIO_PUEN | 10 ) -#define PB10_AF_MS_SCLKI ( GPIO_PORTB | GPIO_AF | 10 ) -#define PB11_PF_SD_DAT3 ( GPIO_PORTB | GPIO_PF | 11 ) -#define PB11_AF_MS_SDIO ( GPIO_PORTB | GPIO_AF | 11 ) -#define PB12_PF_SD_CLK ( GPIO_PORTB | GPIO_PF | 12 ) -#define PB12_AF_MS_SCLK0 ( GPIO_PORTB | GPIO_AF | 12 ) -#define PB13_PF_SD_CMD ( GPIO_PORTB | GPIO_PF | GPIO_PUEN | 13 ) -#define PB13_AF_MS_BS ( GPIO_PORTB | GPIO_AF | 13 ) -#define PB14_AF_SSI_RXFS ( GPIO_PORTB | GPIO_AF | 14 ) -#define PB15_AF_SSI_RXCLK ( GPIO_PORTB | GPIO_AF | 15 ) -#define PB16_AF_SSI_RXDAT ( GPIO_PORTB | GPIO_IN | GPIO_AF | 16 ) -#define PB17_AF_SSI_TXDAT ( GPIO_PORTB | GPIO_OUT | GPIO_AF | 17 ) -#define PB18_AF_SSI_TXFS ( GPIO_PORTB | GPIO_AF | 18 ) -#define PB19_AF_SSI_TXCLK ( GPIO_PORTB | GPIO_AF | 19 ) -#define PB20_PF_USBD_AFE ( GPIO_PORTB | GPIO_PF | 20 ) -#define PB21_PF_USBD_OE ( GPIO_PORTB | GPIO_PF | 21 ) -#define PB22_PFUSBD_RCV ( GPIO_PORTB | GPIO_PF | 22 ) -#define PB23_PF_USBD_SUSPND ( GPIO_PORTB | GPIO_PF | 23 ) -#define PB24_PF_USBD_VP ( GPIO_PORTB | GPIO_PF | 24 ) -#define PB25_PF_USBD_VM ( GPIO_PORTB | GPIO_PF | 25 ) -#define PB26_PF_USBD_VPO ( GPIO_PORTB | GPIO_PF | 26 ) -#define PB27_PF_USBD_VMO ( GPIO_PORTB | GPIO_PF | 27 ) -#define PB28_PF_UART2_CTS ( GPIO_PORTB | GPIO_OUT | GPIO_PF | 28 ) -#define PB29_PF_UART2_RTS ( GPIO_PORTB | GPIO_IN | GPIO_PF | 29 ) -#define PB30_PF_UART2_TXD ( GPIO_PORTB | GPIO_OUT | GPIO_PF | 30 ) -#define PB31_PF_UART2_RXD ( GPIO_PORTB | GPIO_IN | GPIO_PF | 31 ) -#define PC3_PF_SSI_RXFS ( GPIO_PORTC | GPIO_PF | 3 ) -#define PC4_PF_SSI_RXCLK ( GPIO_PORTC | GPIO_PF | 4 ) -#define PC5_PF_SSI_RXDAT ( GPIO_PORTC | GPIO_IN | GPIO_PF | 5 ) -#define PC6_PF_SSI_TXDAT ( GPIO_PORTC | GPIO_OUT | GPIO_PF | 6 ) -#define PC7_PF_SSI_TXFS ( GPIO_PORTC | GPIO_PF | 7 ) -#define PC8_PF_SSI_TXCLK ( GPIO_PORTC | GPIO_PF | 8 ) -#define PC9_PF_UART1_CTS ( GPIO_PORTC | GPIO_OUT | GPIO_PF | 9 ) -#define PC10_PF_UART1_RTS ( GPIO_PORTC | GPIO_IN | GPIO_PF | 10 ) -#define PC11_PF_UART1_TXD ( GPIO_PORTC | GPIO_OUT | GPIO_PF | 11 ) -#define PC12_PF_UART1_RXD ( GPIO_PORTC | GPIO_IN | GPIO_PF | 12 ) -#define PC13_PF_SPI1_SPI_RDY ( GPIO_PORTC | GPIO_PF | 13 ) -#define PC14_PF_SPI1_SCLK ( GPIO_PORTC | GPIO_PF | 14 ) -#define PC15_PF_SPI1_SS ( GPIO_PORTC | GPIO_PF | 15 ) -#define PC16_PF_SPI1_MISO ( GPIO_PORTC | GPIO_PF | 16 ) -#define PC17_PF_SPI1_MOSI ( GPIO_PORTC | GPIO_PF | 17 ) -#define PC24_BIN_UART3_RI ( GPIO_GIUS | GPIO_PORTC | GPIO_OUT | GPIO_BIN | 24 ) -#define PC25_BIN_UART3_DSR ( GPIO_GIUS | GPIO_PORTC | GPIO_OUT | GPIO_BIN | 25 ) -#define PC26_AOUT_UART3_DTR ( GPIO_GIUS | GPIO_PORTC | GPIO_IN | 26 ) -#define PC27_BIN_UART3_DCD ( GPIO_GIUS | GPIO_PORTC | GPIO_OUT | GPIO_BIN | 27 ) -#define PC28_BIN_UART3_CTS ( GPIO_GIUS | GPIO_PORTC | GPIO_OUT | GPIO_BIN | 28 ) -#define PC29_AOUT_UART3_RTS ( GPIO_GIUS | GPIO_PORTC | GPIO_IN | 29 ) -#define PC30_BIN_UART3_TX ( GPIO_GIUS | GPIO_PORTC | GPIO_BIN | 30 ) -#define PC31_AOUT_UART3_RX ( GPIO_GIUS | GPIO_PORTC | GPIO_IN | 31) -#define PD6_PF_LSCLK ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 6 ) -#define PD7_PF_REV ( GPIO_PORTD | GPIO_PF | 7 ) -#define PD7_AF_UART2_DTR ( GPIO_GIUS | GPIO_PORTD | GPIO_IN | GPIO_AF | 7 ) -#define PD7_AIN_SPI2_SCLK ( GPIO_GIUS | GPIO_PORTD | GPIO_AIN | 7 ) -#define PD8_PF_CLS ( GPIO_PORTD | GPIO_PF | 8 ) -#define PD8_AF_UART2_DCD ( GPIO_PORTD | GPIO_OUT | GPIO_AF | 8 ) -#define PD8_AIN_SPI2_SS ( GPIO_GIUS | GPIO_PORTD | GPIO_AIN | 8 ) -#define PD9_PF_PS ( GPIO_PORTD | GPIO_PF | 9 ) -#define PD9_AF_UART2_RI ( GPIO_PORTD | GPIO_OUT | GPIO_AF | 9 ) -#define PD9_AOUT_SPI2_RXD ( GPIO_GIUS | GPIO_PORTD | GPIO_IN | 9 ) -#define PD10_PF_SPL_SPR ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 10 ) -#define PD10_AF_UART2_DSR ( GPIO_PORTD | GPIO_OUT | GPIO_AF | 10 ) -#define PD10_AIN_SPI2_TXD ( GPIO_GIUS | GPIO_PORTD | GPIO_OUT | 10 ) -#define PD11_PF_CONTRAST ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 11 ) -#define PD12_PF_ACD_OE ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 12 ) -#define PD13_PF_LP_HSYNC ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 13 ) -#define PD14_PF_FLM_VSYNC ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 14 ) -#define PD15_PF_LD0 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 15 ) -#define PD16_PF_LD1 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 16 ) -#define PD17_PF_LD2 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 17 ) -#define PD18_PF_LD3 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 18 ) -#define PD19_PF_LD4 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 19 ) -#define PD20_PF_LD5 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 20 ) -#define PD21_PF_LD6 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 21 ) -#define PD22_PF_LD7 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 22 ) -#define PD23_PF_LD8 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 23 ) -#define PD24_PF_LD9 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 24 ) -#define PD25_PF_LD10 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 25 ) -#define PD26_PF_LD11 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 26 ) -#define PD27_PF_LD12 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 27 ) -#define PD28_PF_LD13 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 28 ) -#define PD29_PF_LD14 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 29 ) -#define PD30_PF_LD15 ( GPIO_PORTD | GPIO_OUT | GPIO_PF | 30 ) -#define PD31_PF_TMR2OUT ( GPIO_PORTD | GPIO_PF | 31 ) -#define PD31_BIN_SPI2_TXD ( GPIO_GIUS | GPIO_PORTD | GPIO_BIN | 31 ) - -/* - * PWM controller - */ -#define PWMC __REG(IMX_PWM_BASE + 0x00) /* PWM Control Register */ -#define PWMS __REG(IMX_PWM_BASE + 0x04) /* PWM Sample Register */ -#define PWMP __REG(IMX_PWM_BASE + 0x08) /* PWM Period Register */ -#define PWMCNT __REG(IMX_PWM_BASE + 0x0C) /* PWM Counter Register */ - -#define PWMC_HCTR (0x01<<18) /* Halfword FIFO Data Swapping */ -#define PWMC_BCTR (0x01<<17) /* Byte FIFO Data Swapping */ -#define PWMC_SWR (0x01<<16) /* Software Reset */ -#define PWMC_CLKSRC (0x01<<15) /* Clock Source */ -#define PWMC_PRESCALER(x) (((x-1) & 0x7F) << 8) /* PRESCALER */ -#define PWMC_IRQ (0x01<< 7) /* Interrupt Request */ -#define PWMC_IRQEN (0x01<< 6) /* Interrupt Request Enable */ -#define PWMC_FIFOAV (0x01<< 5) /* FIFO Available */ -#define PWMC_EN (0x01<< 4) /* Enables/Disables the PWM */ -#define PWMC_REPEAT(x) (((x) & 0x03) << 2) /* Sample Repeats */ -#define PWMC_CLKSEL(x) (((x) & 0x03) << 0) /* Clock Selection */ - -#define PWMS_SAMPLE(x) ((x) & 0xFFFF) /* Contains a two-sample word */ -#define PWMP_PERIOD(x) ((x) & 0xFFFF) /* Represents the PWM's period */ -#define PWMC_COUNTER(x) ((x) & 0xFFFF) /* Represents the current count value */ - -/* - * DMA Controller - */ -#define DCR __REG(IMX_DMAC_BASE +0x00) /* DMA Control Register */ -#define DISR __REG(IMX_DMAC_BASE +0x04) /* DMA Interrupt status Register */ -#define DIMR __REG(IMX_DMAC_BASE +0x08) /* DMA Interrupt mask Register */ -#define DBTOSR __REG(IMX_DMAC_BASE +0x0c) /* DMA Burst timeout status Register */ -#define DRTOSR __REG(IMX_DMAC_BASE +0x10) /* DMA Request timeout Register */ -#define DSESR __REG(IMX_DMAC_BASE +0x14) /* DMA Transfer Error Status Register */ -#define DBOSR __REG(IMX_DMAC_BASE +0x18) /* DMA Buffer overflow status Register */ -#define DBTOCR __REG(IMX_DMAC_BASE +0x1c) /* DMA Burst timeout control Register */ -#define WSRA __REG(IMX_DMAC_BASE +0x40) /* W-Size Register A */ -#define XSRA __REG(IMX_DMAC_BASE +0x44) /* X-Size Register A */ -#define YSRA __REG(IMX_DMAC_BASE +0x48) /* Y-Size Register A */ -#define WSRB __REG(IMX_DMAC_BASE +0x4c) /* W-Size Register B */ -#define XSRB __REG(IMX_DMAC_BASE +0x50) /* X-Size Register B */ -#define YSRB __REG(IMX_DMAC_BASE +0x54) /* Y-Size Register B */ -#define SAR(x) __REG2( IMX_DMAC_BASE + 0x80, (x) << 6) /* Source Address Registers */ -#define DAR(x) __REG2( IMX_DMAC_BASE + 0x84, (x) << 6) /* Destination Address Registers */ -#define CNTR(x) __REG2( IMX_DMAC_BASE + 0x88, (x) << 6) /* Count Registers */ -#define CCR(x) __REG2( IMX_DMAC_BASE + 0x8c, (x) << 6) /* Control Registers */ -#define RSSR(x) __REG2( IMX_DMAC_BASE + 0x90, (x) << 6) /* Request source select Registers */ -#define BLR(x) __REG2( IMX_DMAC_BASE + 0x94, (x) << 6) /* Burst length Registers */ -#define RTOR(x) __REG2( IMX_DMAC_BASE + 0x98, (x) << 6) /* Request timeout Registers */ -#define BUCR(x) __REG2( IMX_DMAC_BASE + 0x98, (x) << 6) /* Bus Utilization Registers */ - -/* TODO: define DMA_REQ lines */ - -#define DCR_DRST (1<<1) -#define DCR_DEN (1<<0) -#define DBTOCR_EN (1<<15) -#define DBTOCR_CNT(x) ((x) & 0x7fff ) -#define CNTR_CNT(x) ((x) & 0xffffff ) -#define CCR_DMOD_LINEAR ( 0x0 << 12 ) -#define CCR_DMOD_2D ( 0x1 << 12 ) -#define CCR_DMOD_FIFO ( 0x2 << 12 ) -#define CCR_DMOD_EOBFIFO ( 0x3 << 12 ) -#define CCR_SMOD_LINEAR ( 0x0 << 10 ) -#define CCR_SMOD_2D ( 0x1 << 10 ) -#define CCR_SMOD_FIFO ( 0x2 << 10 ) -#define CCR_SMOD_EOBFIFO ( 0x3 << 10 ) -#define CCR_MDIR_DEC (1<<9) -#define CCR_MSEL_B (1<<8) -#define CCR_DSIZ_32 ( 0x0 << 6 ) -#define CCR_DSIZ_8 ( 0x1 << 6 ) -#define CCR_DSIZ_16 ( 0x2 << 6 ) -#define CCR_SSIZ_32 ( 0x0 << 4 ) -#define CCR_SSIZ_8 ( 0x1 << 4 ) -#define CCR_SSIZ_16 ( 0x2 << 4 ) -#define CCR_REN (1<<3) -#define CCR_RPT (1<<2) -#define CCR_FRC (1<<1) -#define CCR_CEN (1<<0) -#define RTOR_EN (1<<15) -#define RTOR_CLK (1<<14) -#define RTOR_PSC (1<<13) - -/* - * LCD Controller - */ - -#define LCDC_SSA __REG(IMX_LCDC_BASE+0x00) - -#define LCDC_SIZE __REG(IMX_LCDC_BASE+0x04) -#define SIZE_XMAX(x) ((((x) >> 4) & 0x3f) << 20) -#define SIZE_YMAX(y) ( (y) & 0x1ff ) - -#define LCDC_VPW __REG(IMX_LCDC_BASE+0x08) -#define VPW_VPW(x) ( (x) & 0x3ff ) - -#define LCDC_CPOS __REG(IMX_LCDC_BASE+0x0C) -#define CPOS_CC1 (1<<31) -#define CPOS_CC0 (1<<30) -#define CPOS_OP (1<<28) -#define CPOS_CXP(x) (((x) & 3ff) << 16) -#define CPOS_CYP(y) ((y) & 0x1ff) - -#define LCDC_LCWHB __REG(IMX_LCDC_BASE+0x10) -#define LCWHB_BK_EN (1<<31) -#define LCWHB_CW(w) (((w) & 0x1f) << 24) -#define LCWHB_CH(h) (((h) & 0x1f) << 16) -#define LCWHB_BD(x) ((x) & 0xff) - -#define LCDC_LCHCC __REG(IMX_LCDC_BASE+0x14) -#define LCHCC_CUR_COL_R(r) (((r) & 0x1f) << 11) -#define LCHCC_CUR_COL_G(g) (((g) & 0x3f) << 5) -#define LCHCC_CUR_COL_B(b) ((b) & 0x1f) - -#define LCDC_PCR __REG(IMX_LCDC_BASE+0x18) -#define PCR_TFT (1<<31) -#define PCR_COLOR (1<<30) -#define PCR_PBSIZ_1 (0<<28) -#define PCR_PBSIZ_2 (1<<28) -#define PCR_PBSIZ_4 (2<<28) -#define PCR_PBSIZ_8 (3<<28) -#define PCR_BPIX_1 (0<<25) -#define PCR_BPIX_2 (1<<25) -#define PCR_BPIX_4 (2<<25) -#define PCR_BPIX_8 (3<<25) -#define PCR_BPIX_12 (4<<25) -#define PCR_BPIX_16 (4<<25) -#define PCR_PIXPOL (1<<24) -#define PCR_FLMPOL (1<<23) -#define PCR_LPPOL (1<<22) -#define PCR_CLKPOL (1<<21) -#define PCR_OEPOL (1<<20) -#define PCR_SCLKIDLE (1<<19) -#define PCR_END_SEL (1<<18) -#define PCR_END_BYTE_SWAP (1<<17) -#define PCR_REV_VS (1<<16) -#define PCR_ACD_SEL (1<<15) -#define PCR_ACD(x) (((x) & 0x7f) << 8) -#define PCR_SCLK_SEL (1<<7) -#define PCR_SHARP (1<<6) -#define PCR_PCD(x) ((x) & 0x3f) - -#define LCDC_HCR __REG(IMX_LCDC_BASE+0x1C) -#define HCR_H_WIDTH(x) (((x) & 0x3f) << 26) -#define HCR_H_WAIT_1(x) (((x) & 0xff) << 8) -#define HCR_H_WAIT_2(x) ((x) & 0xff) - -#define LCDC_VCR __REG(IMX_LCDC_BASE+0x20) -#define VCR_V_WIDTH(x) (((x) & 0x3f) << 26) -#define VCR_V_WAIT_1(x) (((x) & 0xff) << 8) -#define VCR_V_WAIT_2(x) ((x) & 0xff) - -#define LCDC_POS __REG(IMX_LCDC_BASE+0x24) -#define POS_POS(x) ((x) & 1f) - -#define LCDC_LSCR1 __REG(IMX_LCDC_BASE+0x28) -#define LSCR1_PS_RISE_DELAY(x) (((x) & 0x7f) << 26) -#define LSCR1_CLS_RISE_DELAY(x) (((x) & 0x3f) << 16) -#define LSCR1_REV_TOGGLE_DELAY(x) (((x) & 0xf) << 8) -#define LSCR1_GRAY2(x) (((x) & 0xf) << 4) -#define LSCR1_GRAY1(x) (((x) & 0xf)) - -#define LCDC_PWMR __REG(IMX_LCDC_BASE+0x2C) -#define PWMR_CLS(x) (((x) & 0x1ff) << 16) -#define PWMR_LDMSK (1<<15) -#define PWMR_SCR1 (1<<10) -#define PWMR_SCR0 (1<<9) -#define PWMR_CC_EN (1<<8) -#define PWMR_PW(x) ((x) & 0xff) - -#define LCDC_DMACR __REG(IMX_LCDC_BASE+0x30) -#define DMACR_BURST (1<<31) -#define DMACR_HM(x) (((x) & 0xf) << 16) -#define DMACR_TM(x) ((x) &0xf) - -#define LCDC_RMCR __REG(IMX_LCDC_BASE+0x34) -#define RMCR_LCDC_EN (1<<1) -#define RMCR_SELF_REF (1<<0) - -#define LCDC_LCDICR __REG(IMX_LCDC_BASE+0x38) -#define LCDICR_INT_SYN (1<<2) -#define LCDICR_INT_CON (1) - -#define LCDC_LCDISR __REG(IMX_LCDC_BASE+0x40) -#define LCDISR_UDR_ERR (1<<3) -#define LCDISR_ERR_RES (1<<2) -#define LCDISR_EOF (1<<1) -#define LCDISR_BOF (1<<0) -/* - * UART Module - */ -#define URXD0(x) __REG2( IMX_UART1_BASE + 0x0, ((x) & 1) << 12) /* Receiver Register */ -#define URTX0(x) __REG2( IMX_UART1_BASE + 0x40, ((x) & 1) << 12) /* Transmitter Register */ -#define UCR1(x) __REG2( IMX_UART1_BASE + 0x80, ((x) & 1) << 12) /* Control Register 1 */ -#define UCR2(x) __REG2( IMX_UART1_BASE + 0x84, ((x) & 1) << 12) /* Control Register 2 */ -#define UCR3(x) __REG2( IMX_UART1_BASE + 0x88, ((x) & 1) << 12) /* Control Register 3 */ -#define UCR4(x) __REG2( IMX_UART1_BASE + 0x8c, ((x) & 1) << 12) /* Control Register 4 */ -#define UFCR(x) __REG2( IMX_UART1_BASE + 0x90, ((x) & 1) << 12) /* FIFO Control Register */ -#define USR1(x) __REG2( IMX_UART1_BASE + 0x94, ((x) & 1) << 12) /* Status Register 1 */ -#define USR2(x) __REG2( IMX_UART1_BASE + 0x98, ((x) & 1) << 12) /* Status Register 2 */ -#define UESC(x) __REG2( IMX_UART1_BASE + 0x9c, ((x) & 1) << 12) /* Escape Character Register */ -#define UTIM(x) __REG2( IMX_UART1_BASE + 0xa0, ((x) & 1) << 12) /* Escape Timer Register */ -#define UBIR(x) __REG2( IMX_UART1_BASE + 0xa4, ((x) & 1) << 12) /* BRM Incremental Register */ -#define UBMR(x) __REG2( IMX_UART1_BASE + 0xa8, ((x) & 1) << 12) /* BRM Modulator Register */ -#define UBRC(x) __REG2( IMX_UART1_BASE + 0xac, ((x) & 1) << 12) /* Baud Rate Count Register */ -#define BIPR1(x) __REG2( IMX_UART1_BASE + 0xb0, ((x) & 1) << 12) /* Incremental Preset Register 1 */ -#define BIPR2(x) __REG2( IMX_UART1_BASE + 0xb4, ((x) & 1) << 12) /* Incremental Preset Register 2 */ -#define BIPR3(x) __REG2( IMX_UART1_BASE + 0xb8, ((x) & 1) << 12) /* Incremental Preset Register 3 */ -#define BIPR4(x) __REG2( IMX_UART1_BASE + 0xbc, ((x) & 1) << 12) /* Incremental Preset Register 4 */ -#define BMPR1(x) __REG2( IMX_UART1_BASE + 0xc0, ((x) & 1) << 12) /* BRM Modulator Register 1 */ -#define BMPR2(x) __REG2( IMX_UART1_BASE + 0xc4, ((x) & 1) << 12) /* BRM Modulator Register 2 */ -#define BMPR3(x) __REG2( IMX_UART1_BASE + 0xc8, ((x) & 1) << 12) /* BRM Modulator Register 3 */ -#define BMPR4(x) __REG2( IMX_UART1_BASE + 0xcc, ((x) & 1) << 12) /* BRM Modulator Register 4 */ -#define UTS(x) __REG2( IMX_UART1_BASE + 0xd0, ((x) & 1) << 12) /* UART Test Register */ - -/* UART Control Register Bit Fields.*/ -#define URXD_CHARRDY (1<<15) -#define URXD_ERR (1<<14) -#define URXD_OVRRUN (1<<13) -#define URXD_FRMERR (1<<12) -#define URXD_BRK (1<<11) -#define URXD_PRERR (1<<10) -#define UCR1_ADEN (1<<15) /* Auto dectect interrupt */ -#define UCR1_ADBR (1<<14) /* Auto detect baud rate */ -#define UCR1_TRDYEN (1<<13) /* Transmitter ready interrupt enable */ -#define UCR1_IDEN (1<<12) /* Idle condition interrupt */ -#define UCR1_RRDYEN (1<<9) /* Recv ready interrupt enable */ -#define UCR1_RDMAEN (1<<8) /* Recv ready DMA enable */ -#define UCR1_IREN (1<<7) /* Infrared interface enable */ -#define UCR1_TXMPTYEN (1<<6) /* Transimitter empty interrupt enable */ -#define UCR1_RTSDEN (1<<5) /* RTS delta interrupt enable */ -#define UCR1_SNDBRK (1<<4) /* Send break */ -#define UCR1_TDMAEN (1<<3) /* Transmitter ready DMA enable */ -#define UCR1_UARTCLKEN (1<<2) /* UART clock enabled */ -#define UCR1_DOZE (1<<1) /* Doze */ -#define UCR1_UARTEN (1<<0) /* UART enabled */ -#define UCR2_ESCI (1<<15) /* Escape seq interrupt enable */ -#define UCR2_IRTS (1<<14) /* Ignore RTS pin */ -#define UCR2_CTSC (1<<13) /* CTS pin control */ -#define UCR2_CTS (1<<12) /* Clear to send */ -#define UCR2_ESCEN (1<<11) /* Escape enable */ -#define UCR2_PREN (1<<8) /* Parity enable */ -#define UCR2_PROE (1<<7) /* Parity odd/even */ -#define UCR2_STPB (1<<6) /* Stop */ -#define UCR2_WS (1<<5) /* Word size */ -#define UCR2_RTSEN (1<<4) /* Request to send interrupt enable */ -#define UCR2_TXEN (1<<2) /* Transmitter enabled */ -#define UCR2_RXEN (1<<1) /* Receiver enabled */ -#define UCR2_SRST (1<<0) /* SW reset */ -#define UCR3_DTREN (1<<13) /* DTR interrupt enable */ -#define UCR3_PARERREN (1<<12) /* Parity enable */ -#define UCR3_FRAERREN (1<<11) /* Frame error interrupt enable */ -#define UCR3_DSR (1<<10) /* Data set ready */ -#define UCR3_DCD (1<<9) /* Data carrier detect */ -#define UCR3_RI (1<<8) /* Ring indicator */ -#define UCR3_TIMEOUTEN (1<<7) /* Timeout interrupt enable */ -#define UCR3_RXDSEN (1<<6) /* Receive status interrupt enable */ -#define UCR3_AIRINTEN (1<<5) /* Async IR wake interrupt enable */ -#define UCR3_AWAKEN (1<<4) /* Async wake interrupt enable */ -#define UCR3_REF25 (1<<3) /* Ref freq 25 MHz */ -#define UCR3_REF30 (1<<2) /* Ref Freq 30 MHz */ -#define UCR3_INVT (1<<1) /* Inverted Infrared transmission */ -#define UCR3_BPEN (1<<0) /* Preset registers enable */ -#define UCR4_CTSTL_32 (32<<10) /* CTS trigger level (32 chars) */ -#define UCR4_INVR (1<<9) /* Inverted infrared reception */ -#define UCR4_ENIRI (1<<8) /* Serial infrared interrupt enable */ -#define UCR4_WKEN (1<<7) /* Wake interrupt enable */ -#define UCR4_REF16 (1<<6) /* Ref freq 16 MHz */ -#define UCR4_IRSC (1<<5) /* IR special case */ -#define UCR4_TCEN (1<<3) /* Transmit complete interrupt enable */ -#define UCR4_BKEN (1<<2) /* Break condition interrupt enable */ -#define UCR4_OREN (1<<1) /* Receiver overrun interrupt enable */ -#define UCR4_DREN (1<<0) /* Recv data ready interrupt enable */ -#define UFCR_RXTL_SHF 0 /* Receiver trigger level shift */ -#define UFCR_RFDIV (7<<7) /* Reference freq divider mask */ -#define UFCR_TXTL_SHF 10 /* Transmitter trigger level shift */ -#define USR1_PARITYERR (1<<15) /* Parity error interrupt flag */ -#define USR1_RTSS (1<<14) /* RTS pin status */ -#define USR1_TRDY (1<<13) /* Transmitter ready interrupt/dma flag */ -#define USR1_RTSD (1<<12) /* RTS delta */ -#define USR1_ESCF (1<<11) /* Escape seq interrupt flag */ -#define USR1_FRAMERR (1<<10) /* Frame error interrupt flag */ -#define USR1_RRDY (1<<9) /* Receiver ready interrupt/dma flag */ -#define USR1_TIMEOUT (1<<7) /* Receive timeout interrupt status */ -#define USR1_RXDS (1<<6) /* Receiver idle interrupt flag */ -#define USR1_AIRINT (1<<5) /* Async IR wake interrupt flag */ -#define USR1_AWAKE (1<<4) /* Aysnc wake interrupt flag */ -#define USR2_ADET (1<<15) /* Auto baud rate detect complete */ -#define USR2_TXFE (1<<14) /* Transmit buffer FIFO empty */ -#define USR2_DTRF (1<<13) /* DTR edge interrupt flag */ -#define USR2_IDLE (1<<12) /* Idle condition */ -#define USR2_IRINT (1<<8) /* Serial infrared interrupt flag */ -#define USR2_WAKE (1<<7) /* Wake */ -#define USR2_RTSF (1<<4) /* RTS edge interrupt flag */ -#define USR2_TXDC (1<<3) /* Transmitter complete */ -#define USR2_BRCD (1<<2) /* Break condition */ -#define USR2_ORE (1<<1) /* Overrun error */ -#define USR2_RDR (1<<0) /* Recv data ready */ -#define UTS_FRCPERR (1<<13) /* Force parity error */ -#define UTS_LOOP (1<<12) /* Loop tx and rx */ -#define UTS_TXEMPTY (1<<6) /* TxFIFO empty */ -#define UTS_RXEMPTY (1<<5) /* RxFIFO empty */ -#define UTS_TXFULL (1<<4) /* TxFIFO full */ -#define UTS_RXFULL (1<<3) /* RxFIFO full */ -#define UTS_SOFTRST (1<<0) /* Software reset */ - -/* General purpose timers registers */ -#define TCTL1 __REG(IMX_TIM1_BASE) -#define TPRER1 __REG(IMX_TIM1_BASE + 0x4) -#define TCMP1 __REG(IMX_TIM1_BASE + 0x8) -#define TCR1 __REG(IMX_TIM1_BASE + 0xc) -#define TCN1 __REG(IMX_TIM1_BASE + 0x10) -#define TSTAT1 __REG(IMX_TIM1_BASE + 0x14) -#define TCTL2 __REG(IMX_TIM2_BASE) -#define TPRER2 __REG(IMX_TIM2_BASE + 0x4) -#define TCMP2 __REG(IMX_TIM2_BASE + 0x8) -#define TCR2 __REG(IMX_TIM2_BASE + 0xc) -#define TCN2 __REG(IMX_TIM2_BASE + 0x10) -#define TSTAT2 __REG(IMX_TIM2_BASE + 0x14) - -/* General purpose timers bitfields */ -#define TCTL_SWR (1<<15) /* Software reset */ -#define TCTL_FRR (1<<8) /* Freerun / restart */ -#define TCTL_CAP (3<<6) /* Capture Edge */ -#define TCTL_OM (1<<5) /* output mode */ -#define TCTL_IRQEN (1<<4) /* interrupt enable */ -#define TCTL_CLKSOURCE (7<<1) /* Clock source */ -#define TCTL_TEN (1) /* Timer enable */ -#define TPRER_PRES (0xff) /* Prescale */ -#define TSTAT_CAPT (1<<1) /* Capture event */ -#define TSTAT_COMP (1) /* Compare event */ - -#endif /* _IMX_REGS_H */
Without this definition, fsl_esdhc will access reserved registers on i.MX chips, so define ARCH_MXC to fix it.
arch/arm/include/asm/arch-imx8/imx-regs.h | 2 ++ arch/arm/include/asm/arch-imx8m/imx-regs.h | 2 ++ arch/arm/include/asm/arch-mx7ulp/imx-regs.h | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8/imx-regs.h b/arch/arm/include/asm/arch-imx8/imx-regs.h index af0fb5154b..6333ff4686 100644 --- a/arch/arm/include/asm/arch-imx8/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8/imx-regs.h @@ -6,6 +6,8 @@ #ifndef __ASM_ARCH_IMX8_REGS_H__ #define __ASM_ARCH_IMX8_REGS_H__
+#define ARCH_MXC + #define LPUART_BASE 0x5A060000
#define GPT1_BASE_ADDR 0x5D140000 diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index 3facd5450c..68666a535b 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -6,6 +6,8 @@ #ifndef __ASM_ARCH_IMX8M_REGS_H__ #define __ASM_ARCH_IMX8M_REGS_H__
+#define ARCH_MXC + #include <asm/mach-imx/regs-lcdif.h>
#define ROM_VERSION_A0 0x800 diff --git a/arch/arm/include/asm/arch-mx7ulp/imx-regs.h b/arch/arm/include/asm/arch-mx7ulp/imx-regs.h index bf9f39aca2..63b02de087 100644 --- a/arch/arm/include/asm/arch-mx7ulp/imx-regs.h +++ b/arch/arm/include/asm/arch-mx7ulp/imx-regs.h @@ -8,6 +8,8 @@
#include <linux/sizes.h>
+#define ARCH_MXC + #define CAAM_SEC_SRAM_BASE (0x26000000) #define CAAM_SEC_SRAM_SIZE (SZ_32K) #define CAAM_SEC_SRAM_END (CAAM_SEC_SRAM_BASE + CAAM_SEC_SRAM_SIZE - 1)
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Peng Fan
