[U-Boot] Pull request: u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into u-boot/master. ./MAKEALL -s tegra is clean. Thanks.
The following changes since commit b939689c7b87773c44275a578ffc8674a867e39d:
Merge branch 'u-boot/master' into 'u-boot-arm/master' (2015-05-05 10:09:06 +0200)
git://git.denx.de/u-boot-tegra.git master
for you to fetch changes up to 5168604f3b7e5b8ea077a69fe9acb7c14a36adf7:
jetson-tk1: Add PSCI configuration options and reserve secure code (2015-05-11 08:35:13 -0700)
---------------------------------------------------------------- Ian Campbell (3): tegra124: Add more registers to struct mc_ctlr tegra124: Reserve secure RAM using MC_SECURITY_CFG{0, 1}_0 jetson-tk1: Add PSCI configuration options and reserve secure code
Jan Kiszka (13): ARM: Clean up CONFIG_ARMV7_NONSEC/VIRT/PSCI conditions sun7i: Remove duplicate call to psci_arch_init ARM: Factor out common psci_get_cpu_id ARM: Factor out reusable psci_cpu_off_common ARM: Factor out reusable psci_cpu_entry ARM: Factor out reusable psci_get_cpu_stack_top ARM: Put target PC for PSCI CPU_ON on per-CPU stack virt-dt: Allow reservation of secure region when in a RAM carveout tegra: Make tegra_powergate_power_on public ARM: Add board-specific initialization hook for PSCI tegra124: Add PSCI support for Tegra124 tegra: Set CNTFRQ for secondary CPUs tegra: Boot in non-secure mode by default
Simon Glass (26): dm: core: Sort the uclasses dm: gpio: Add error handling and a function to claim vector GPIOs fdt: Add binding decode function for display-timings tegra: Move the pwm into tegra-common tegra: pwm: Allow the clock rate to be left as is tegra: Move checkboard() into the board code tegra: Add a board ID function power: Export register access functions from as3722 tegra: Provide a function to allow LCD PMIC setup tegra: Add support for setting up a as3722 PMIC tegra: nyan-big: Add LCD PMIC init and board ID tegra124: dts: Add host1x node to provide display information tegra: config: Use CONFIG_LCD to detect LCD presence tegra: clock: Add checking for invalid clock IDs tegra: clock: Split the clock source code into a separate function tegra124: clock: Add display clocks and functions tegra: Move display controller header into common video: Add drm_dp_helper.h edid: Add a function to read detailed monitor timings dm: video: Add a uclass for display port tegra: dts: nyan-big: Add definitions for eDP display tegra: video: Support serial output resource (SOR) on tegra124 tegra: video: Add Embedded DisplayPort driver tegra: video: support eDP displays on Tegra124 devices tegra: config: nyan-big: Enable LCD tegra124: video: Add full link training for eDP
Stephen Warren (2): ARM: tegra: CONFIG_{SYS_, }LOAD{_, }ADDR rationalization ARM: tegra: enable STDIO deregistration
Thierry Reding (1): ARM: tegra: Enable SMMU when going non-secure
arch/arm/cpu/armv7/Kconfig | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/ls102xa/cpu.c | 2 +- arch/arm/cpu/armv7/psci.S | 121 ++ arch/arm/cpu/armv7/sunxi/psci.S | 112 +- arch/arm/cpu/armv7/virt-dt.c | 31 +- arch/arm/cpu/armv7/virt-v7.c | 11 + arch/arm/cpu/u-boot.lds | 2 +- arch/arm/dts/tegra124-nyan-big.dts | 47 + arch/arm/dts/tegra124.dtsi | 84 + arch/arm/include/asm/arch-tegra/clk_rst.h | 15 +- arch/arm/include/asm/arch-tegra/clock.h | 14 + .../include/asm/{arch-tegra20 => arch-tegra}/dc.h | 67 +- arch/arm/include/asm/arch-tegra/powergate.h | 1 + arch/arm/include/asm/arch-tegra/pwm.h | 60 + arch/arm/include/asm/arch-tegra/sys_proto.h | 19 +- arch/arm/include/asm/arch-tegra124/clock-tables.h | 3 +- arch/arm/include/asm/arch-tegra124/clock.h | 21 + arch/arm/include/asm/arch-tegra124/display.h | 58 + arch/arm/include/asm/arch-tegra124/flow.h | 6 + arch/arm/include/asm/arch-tegra124/mc.h | 37 +- arch/arm/include/asm/arch-tegra124/pwm.h | 14 + arch/arm/include/asm/arch-tegra20/display.h | 2 +- arch/arm/include/asm/arch-tegra20/pwm.h | 54 +- arch/arm/include/asm/armv7.h | 5 +- arch/arm/include/asm/psci.h | 1 + arch/arm/include/asm/system.h | 1 + arch/arm/lib/bootm-fdt.c | 8 +- arch/arm/lib/bootm.c | 6 +- arch/arm/mach-tegra/Makefile | 5 + arch/arm/mach-tegra/ap.c | 55 + arch/arm/mach-tegra/board.c | 8 - arch/arm/mach-tegra/clock.c | 83 +- arch/arm/mach-tegra/powergate.c | 2 +- arch/arm/mach-tegra/psci.S | 114 ++ arch/arm/mach-tegra/{tegra20 => }/pwm.c | 7 +- arch/arm/mach-tegra/tegra124/Kconfig | 2 + arch/arm/mach-tegra/tegra124/Makefile | 4 + arch/arm/mach-tegra/tegra124/clock.c | 141 +- arch/arm/mach-tegra/tegra124/psci.c | 59 + arch/arm/mach-tegra/tegra20/Makefile | 1 - arch/arm/mach-tegra/tegra20/display.c | 2 +- board/armltd/vexpress/vexpress_common.c | 2 +- board/broadcom/bcm_ep/board.c | 2 +- board/freescale/common/arm_sleep.c | 2 +- board/nvidia/common/board.c | 40 +- board/nvidia/nyan-big/nyan-big.c | 34 +- common/edid.c | 105 ++ configs/nyan-big_defconfig | 2 + .../gpu/nvidia,tegra20-host1x.txt | 372 +++++ doc/device-tree-bindings/video/display-timing.txt | 110 ++ drivers/gpio/gpio-uclass.c | 38 +- drivers/power/as3722.c | 16 +- drivers/video/Kconfig | 15 + drivers/video/Makefile | 6 + drivers/video/dp-uclass.c | 34 + drivers/video/tegra124/Makefile | 10 + drivers/video/tegra124/display.c | 472 ++++++ drivers/video/tegra124/displayport.h | 412 +++++ drivers/video/tegra124/dp.c | 1607 ++++++++++++++++++++ drivers/video/tegra124/sor.c | 1024 +++++++++++++ drivers/video/tegra124/sor.h | 922 +++++++++++ drivers/video/tegra124/tegra124-lcd.c | 97 ++ include/asm-generic/gpio.h | 15 +- include/configs/jetson-tk1.h | 5 + include/configs/nyan-big.h | 14 + include/configs/tegra-common-post.h | 4 +- include/configs/tegra-common.h | 3 + include/configs/tegra114-common.h | 7 +- include/configs/tegra124-common.h | 7 +- include/configs/tegra20-common.h | 7 +- include/configs/tegra30-common.h | 7 +- include/displayport.h | 60 + include/dm/uclass-id.h | 29 +- include/edid.h | 19 + include/fdtdec.h | 80 + include/linux/drm_dp_helper.h | 406 +++++ include/power/as3722.h | 3 + lib/fdtdec.c | 95 ++ 79 files changed, 7098 insertions(+), 274 deletions(-) rename arch/arm/include/asm/{arch-tegra20 => arch-tegra}/dc.h (89%) create mode 100644 arch/arm/include/asm/arch-tegra/pwm.h create mode 100644 arch/arm/include/asm/arch-tegra124/display.h create mode 100644 arch/arm/include/asm/arch-tegra124/pwm.h create mode 100644 arch/arm/mach-tegra/psci.S rename arch/arm/mach-tegra/{tegra20 => }/pwm.c (93%) create mode 100644 arch/arm/mach-tegra/tegra124/psci.c create mode 100644 doc/device-tree-bindings/gpu/nvidia,tegra20-host1x.txt create mode 100644 doc/device-tree-bindings/video/display-timing.txt create mode 100644 drivers/video/dp-uclass.c create mode 100644 drivers/video/tegra124/Makefile create mode 100644 drivers/video/tegra124/display.c create mode 100644 drivers/video/tegra124/displayport.h create mode 100644 drivers/video/tegra124/dp.c create mode 100644 drivers/video/tegra124/sor.c create mode 100644 drivers/video/tegra124/sor.h create mode 100644 drivers/video/tegra124/tegra124-lcd.c create mode 100644 include/displayport.h create mode 100644 include/linux/drm_dp_helper.h
Hi Tom Warren,
2015-05-13 6:49 GMT+09:00 Tom Warren tcwarren3959@gmail.com:
Tom,
What about my patch (http://patchwork.ozlabs.org/patch/460596/)? Has it been rejected or deferred?
Sorry, Masahiro. Missed that one. I'll apply it and send a new PR if everything builds OK.
Tom - note that I screwed up and didn't push my rebase of u-boot-tegra/master against u-boot/master (it's still rebased against ARM/master). I'll fix that before the next PR later today, so you can ignore the above PR.
Tom
On Tue, May 12, 2015 at 6:45 PM, Masahiro Yamada < yamada.masahiro@socionext.com> wrote:
Hi Tom Warren,
Tom,
-- Best Regards Masahiro Yamada
OK, Tom. Ready to be pulled into U-Boot/master. Thanks!
./MAKEALL -s tegra is OK, nyan-big boots to console OK.
The following changes since commit bd328eb38274ffaf04caaa8a6ecc09b7e19a650e:
Clean all defconfigs with savedefconfig (2015-05-12 18:10:26 -0400)
for you to fetch changes up to 237c36379c76f7f6647bb11c03aa9c5cb9a4972f:
ARM: tegra: move NVIDIA common files to arch/arm/mach-tegra (2015-05-13 09:46:19 -0700)
Jan Kiszka (12): ARM: Clean up CONFIG_ARMV7_NONSEC/VIRT/PSCI conditions ARM: Factor out common psci_get_cpu_id ARM: Factor out reusable psci_cpu_off_common ARM: Factor out reusable psci_cpu_entry ARM: Factor out reusable psci_get_cpu_stack_top ARM: Put target PC for PSCI CPU_ON on per-CPU stack virt-dt: Allow reservation of secure region when in a RAM carveout tegra: Make tegra_powergate_power_on public ARM: Add board-specific initialization hook for PSCI tegra124: Add PSCI support for Tegra124 tegra: Set CNTFRQ for secondary CPUs tegra: Boot in non-secure mode by default
Masahiro Yamada (1): ARM: tegra: move NVIDIA common files to arch/arm/mach-tegra
arch/arm/cpu/armv7/Kconfig | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/ls102xa/cpu.c | 2 +- arch/arm/cpu/armv7/psci.S | 121 ++ arch/arm/cpu/armv7/sunxi/psci.S | 111 +- arch/arm/cpu/armv7/virt-dt.c | 31 +- arch/arm/cpu/armv7/virt-v7.c | 11 + arch/arm/cpu/u-boot.lds | 2 +- arch/arm/dts/tegra124-nyan-big.dts | 47 + arch/arm/dts/tegra124.dtsi | 84 + arch/arm/include/asm/arch-tegra/clk_rst.h | 15 +- arch/arm/include/asm/arch-tegra/clock.h | 14 + .../include/asm/{arch-tegra20 => arch-tegra}/dc.h | 67 +- arch/arm/include/asm/arch-tegra/powergate.h | 1 + arch/arm/include/asm/arch-tegra/pwm.h | 60 + arch/arm/include/asm/arch-tegra/sys_proto.h | 19 +- arch/arm/include/asm/arch-tegra124/clock-tables.h | 3 +- arch/arm/include/asm/arch-tegra124/clock.h | 21 + arch/arm/include/asm/arch-tegra124/display.h | 58 + arch/arm/include/asm/arch-tegra124/flow.h | 6 + arch/arm/include/asm/arch-tegra124/mc.h | 37 +- arch/arm/include/asm/arch-tegra124/pwm.h | 14 + arch/arm/include/asm/arch-tegra20/display.h | 2 +- arch/arm/include/asm/arch-tegra20/pwm.h | 54 +- arch/arm/include/asm/armv7.h | 5 +- arch/arm/include/asm/psci.h | 1 + arch/arm/include/asm/system.h | 1 + arch/arm/lib/bootm-fdt.c | 8 +- arch/arm/lib/bootm.c | 6 +- arch/arm/mach-tegra/Makefile | 8 +- arch/arm/mach-tegra/ap.c | 55 + arch/arm/mach-tegra/board.c | 8 - .../common/board.c => arch/arm/mach-tegra/board2.c | 40 +- arch/arm/mach-tegra/clock.c | 83 +- {board/nvidia/common => arch/arm/mach-tegra}/emc.c | 0 {board/nvidia/common => arch/arm/mach-tegra}/emc.h | 0 arch/arm/mach-tegra/powergate.c | 2 +- arch/arm/mach-tegra/psci.S | 114 ++ arch/arm/mach-tegra/{tegra20 => }/pwm.c | 7 +- arch/arm/mach-tegra/tegra124/Kconfig | 2 + arch/arm/mach-tegra/tegra124/Makefile | 4 + arch/arm/mach-tegra/tegra124/clock.c | 141 +- arch/arm/mach-tegra/tegra124/psci.c | 59 + arch/arm/mach-tegra/tegra20/Makefile | 1 - arch/arm/mach-tegra/tegra20/display.c | 2 +- board/armltd/vexpress/vexpress_common.c | 2 +- board/avionic-design/medcom-wide/Makefile | 2 - board/avionic-design/plutux/Makefile | 2 - board/avionic-design/tec-ng/Makefile | 2 - board/avionic-design/tec/Makefile | 2 - board/broadcom/bcm_ep/board.c | 2 +- board/compal/paz00/Makefile | 2 - board/compulab/trimslice/Makefile | 2 - board/freescale/common/arm_sleep.c | 2 +- board/nvidia/common/Makefile | 4 - board/nvidia/common/common.mk | 3 - board/nvidia/nyan-big/nyan-big.c | 34 +- board/toradex/apalis_t30/Makefile | 2 - board/toradex/colibri_t20/Makefile | 2 - board/toradex/colibri_t30/Makefile | 2 - common/edid.c | 105 ++ configs/nyan-big_defconfig | 2 + .../gpu/nvidia,tegra20-host1x.txt | 372 +++++ doc/device-tree-bindings/video/display-timing.txt | 110 ++ drivers/gpio/gpio-uclass.c | 38 +- drivers/power/as3722.c | 16 +- drivers/video/Kconfig | 15 + drivers/video/Makefile | 6 + drivers/video/dp-uclass.c | 34 + drivers/video/tegra124/Makefile | 10 + drivers/video/tegra124/display.c | 472 ++++++ drivers/video/tegra124/displayport.h | 412 +++++ drivers/video/tegra124/dp.c | 1607 ++++++++++++++++++++ drivers/video/tegra124/sor.c | 1024 +++++++++++++ drivers/video/tegra124/sor.h | 922 +++++++++++ drivers/video/tegra124/tegra124-lcd.c | 97 ++ include/asm-generic/gpio.h | 15 +- include/configs/jetson-tk1.h | 5 + include/configs/nyan-big.h | 14 + include/configs/tegra-common-post.h | 4 +- include/configs/tegra-common.h | 3 + include/configs/tegra114-common.h | 7 +- include/configs/tegra124-common.h | 7 +- include/configs/tegra20-common.h | 7 +- include/configs/tegra30-common.h | 7 +- include/displayport.h | 60 + include/dm/uclass-id.h | 33 +- include/edid.h | 19 + include/fdtdec.h | 80 + include/linux/drm_dp_helper.h | 406 +++++ include/power/as3722.h | 3 + lib/fdtdec.c | 95 ++ 92 files changed, 7102 insertions(+), 301 deletions(-) rename arch/arm/include/asm/{arch-tegra20 => arch-tegra}/dc.h (89%) create mode 100644 arch/arm/include/asm/arch-tegra/pwm.h create mode 100644 arch/arm/include/asm/arch-tegra124/display.h create mode 100644 arch/arm/include/asm/arch-tegra124/pwm.h rename board/nvidia/common/board.c => arch/arm/mach-tegra/board2.c (88%) rename {board/nvidia/common => arch/arm/mach-tegra}/emc.c (100%) rename {board/nvidia/common => arch/arm/mach-tegra}/emc.h (100%) create mode 100644 arch/arm/mach-tegra/psci.S rename arch/arm/mach-tegra/{tegra20 => }/pwm.c (93%) create mode 100644 arch/arm/mach-tegra/tegra124/psci.c delete mode 100644 board/nvidia/common/Makefile delete mode 100644 board/nvidia/common/common.mk create mode 100644 doc/device-tree-bindings/gpu/nvidia,tegra20-host1x.txt create mode 100644 doc/device-tree-bindings/video/display-timing.txt create mode 100644 drivers/video/dp-uclass.c create mode 100644 drivers/video/tegra124/Makefile create mode 100644 drivers/video/tegra124/display.c create mode 100644 drivers/video/tegra124/displayport.h create mode 100644 drivers/video/tegra124/dp.c create mode 100644 drivers/video/tegra124/sor.c create mode 100644 drivers/video/tegra124/sor.h create mode 100644 drivers/video/tegra124/tegra124-lcd.c create mode 100644 include/displayport.h create mode 100644 include/linux/drm_dp_helper.h
Tom
Hi Tom Warren,
Tom,
is
clean. Thanks.
Masahiro Yamada
Tom Warren
