[U-Boot] sun8i: h2: Add initial Orange Pi R1 support
Orange Pi R1 is an open-source single-board computer using the Allwinner H2+ SOC.
H2+ Orange Pi R1 has - Quad-core Cortex-A7 - 256MB DDR3 - micrSD slot - 128MBit SPI Nor flash - Debug TTL UART - 100MBit/s Ethernet (H2+) - 100MBit/s Ethernet (RTL8152B) - Wifi (RTL8189ETV) - USB 2.0 OTG + power supply This board is very similar to the Orange Pi Zero.
The device tree file is copied from the Linux kernel 4.17.
Signed-off-by: Hauke Mehrtens hauke@hauke-m.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts | 101 +++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/orangepi_r1_defconfig | 16 +++++ 4 files changed, 123 insertions(+) create mode 100644 arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts create mode 100644 configs/orangepi_r1_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 790571b773..e81a580692 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -355,6 +355,7 @@ dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-tbs-a711.dts dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-libretech-all-h3-cc.dtb \ + sun8i-h2-plus-orangepi-r1.dtb \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ sun8i-h3-libretech-all-h3-cc.dtb \ diff --git a/arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts b/arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts new file mode 100644 index 0000000000..c652ac3b71 --- /dev/null +++ b/arch/arm/dts/sun8i-h2-plus-orangepi-r1.dts @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/* Orange Pi R1 is based on Orange Pi Zero design */ +#include "sun8i-h2-plus-orangepi-zero.dts" + +/ { + model = "Xunlong Orange Pi R1"; + compatible = "xunlong,orangepi-r1", "allwinner,sun8i-h2-plus"; + + /delete-node/ reg_vcc_wifi; + + /* + * Ths pin of this regulator is the same with the Wi-Fi extra + * regulator on the original Zero. However it's used for USB + * Ethernet rather than the Wi-Fi now. + */ + reg_vcc_usb_eth: reg-vcc-usb-ethernet { + compatible = "regulator-fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-usb-ethernet"; + enable-active-high; + gpio = <&pio 0 20 GPIO_ACTIVE_HIGH>; + }; + + aliases { + ethernet1 = &rtl8189etv; + }; +}; + +/* +&spi0 { + status = "okay"; + + flash@0 { + compatible = "mxicy,mx25l12805d", "jedec,spi-nor"; + }; +}; +*/ + +&ohci1 { + /* + * RTL8152B USB-Ethernet adapter is connected to USB1, + * and it's a USB 2.0 device. So the OHCI1 controller + * can be left disabled. + */ + status = "disabled"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + + rtl8189etv: sdio_wifi@1 { + reg = <1>; + }; +}; + +&usbphy { + usb1_vbus-supply = <®_vcc_usb_eth>; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index e90c87b560..6ebf612db3 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -355,6 +355,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/orangepi_prime_defconfig
+ORANGEPI R1 BOARD +M: Hauke Mehrtens hauke@hauke-m.de +S: Maintained +F: configs/orangepi_r1_defconfig + PINE64 BOARDS M: Andre Przywara andre.przywara@arm.com S: Maintained diff --git a/configs/orangepi_r1_defconfig b/configs/orangepi_r1_defconfig new file mode 100644 index 0000000000..8e6ee7b2db --- /dev/null +++ b/configs/orangepi_r1_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=624 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +# CONFIG_VIDEO_DE2 is not set +CONFIG_SPL_SPI_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-r1" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +# CONFIG_CMD_FLASH is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
- 256MB DDR3
- micrSD slot
- Debug TTL UART
- Wifi (RTL8189ETV)
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
On Wed, Jun 13, 2018 at 12:58 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
- 256MB DDR3
- micrSD slot
- Debug TTL UART
- Wifi (RTL8189ETV)
Applied to u-boot-sunxi/master
Hauke Mehrtens
Jagan Teki
Maxime Ripard
