[PATCH] ns16550: Respect CONFIG_BAUDRATE < 0 in _debug_uart_init
CONFIG_BAUDRATE less than 0 means do not touch baudrate settings.
Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com --- drivers/serial/ns16550.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 702109b23b..286d8aecca 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -333,15 +333,19 @@ static inline void _debug_uart_init(void) * feasible. The better fix is to move all users of this driver to * driver model. */ - baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, - CONFIG_BAUDRATE); serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); serial_dout(&com_port->mcr, UART_MCRVAL); serial_dout(&com_port->fcr, UART_FCR_DEFVAL);
- serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); - serial_dout(&com_port->dll, baud_divisor & 0xff); - serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); + if (CONFIG_BAUDRATE > 0) { + baud_divisor = ns16550_calc_divisor(com_port, + CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE); + + serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); + serial_dout(&com_port->dll, baud_divisor & 0xff); + serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); + } serial_dout(&com_port->lcr, UART_LCRVAL); }
I don't see this in doc/ so please do a follow-up to note it in there as well, thanks!
CONFIG_BAUDRATE);
- if (CONFIG_BAUDRATE > 0) {
The general idea that CONFIG_BAUDRATE == 0 should be ignored is good.
Negative value of CONFIG_BAUDRATE are not consistently treated in the coding. We should not use them.
It may not enough to change _debug_uart_init(). Please, also consider serial_setbrg() in the uclass if you want to avoid that the baudrate is touched.
How about the other debug UART drivers?
Your commit title and the commit message don't match the code which ignores CONFIG_BAUDRATE == 0.
Best regards
Heinrich
CONFIG_BAUDRATE);
- } serial_dout(&com_port->lcr, UART_LCRVAL); }
Joakim Tjernlund
