[PATCH 1/1] doc: move README.falcon to HTML
Move the Falcon mode documentation to HTML.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/README.falcon | 232 ------------------------------------ doc/develop/falcon.rst | 258 +++++++++++++++++++++++++++++++++++++++++ doc/develop/index.rst | 1 + 3 files changed, 259 insertions(+), 232 deletions(-) delete mode 100644 doc/README.falcon create mode 100644 doc/develop/falcon.rst
diff --git a/doc/README.falcon b/doc/README.falcon deleted file mode 100644 index 88218d35b9..0000000000 --- a/doc/README.falcon +++ /dev/null @@ -1,232 +0,0 @@ -U-Boot Falcon Mode -==================== - -Introduction ------------- - -This document provides an overview of how to add support for Falcon Mode -to a board. - -Falcon Mode is introduced to speed up the booting process, allowing -to boot a Linux kernel (or whatever image) without a full blown U-Boot. - -Falcon Mode relies on the SPL framework. In fact, to make booting faster, -U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot -image. In most implementations, SPL is used to start U-Boot when booting from -a mass storage, such as NAND or SD-Card. SPL has now support for other media, -and can generally be seen as a way to start an image performing the minimum -required initialization. SPL mainly initializes the RAM controller, and then -copies U-Boot image into the memory. - -The Falcon Mode extends this way allowing to start the Linux kernel directly -from SPL. A new command is added to U-Boot to prepare the parameters that SPL -must pass to the kernel, using ATAGS or Device Tree. - -In normal mode, these parameters are generated each time before -loading the kernel, passing to Linux the address in memory where -the parameters can be read. -With Falcon Mode, this snapshot can be saved into persistent storage and SPL is -informed to load it before running the kernel. - -To boot the kernel, these steps under a Falcon-aware U-Boot are required: - -1. Boot the board into U-Boot. -After loading the desired legacy-format kernel image into memory (and DT as -well, if used), use the "spl export" command to generate the kernel parameters -area or the DT. U-Boot runs as when it boots the kernel, but stops before -passing the control to the kernel. - -2. Save the prepared snapshot into persistent media. -The address where to save it must be configured into board configuration -file (CONFIG_CMD_SPL_NAND_OFS for NAND). - -3. Boot the board into Falcon Mode. SPL will load the kernel and copy -the parameters which are saved in the persistent area to the required address. -If a valid uImage is not found at the defined location, U-Boot will be -booted instead. - -It is required to implement a custom mechanism to select if SPL loads U-Boot -or another image. - -The value of a GPIO is a simple way to operate the selection, as well as -reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. - -Falcon Mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells -SPL that U-Boot is not the only available image that SPL is able to start. - -Configuration ----------------------------- -CONFIG_CMD_SPL Enable the "spl export" command. - The command "spl export" is then available in U-Boot - mode -CONFIG_SYS_SPL_ARGS_ADDR Address in RAM where the parameters must be - copied by SPL. - In most cases, it is <start_of_ram> + 0x100 - -CONFIG_SYS_NAND_SPL_KERNEL_OFFS Offset in NAND where the kernel is stored - -CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved. - -CONFIG_CMD_SPL_NOR_OFS Offset in NOR where the parameters area was saved. - -CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied - -CONFIG_SPL_OS_BOOT Activate Falcon Mode. - -Function that a board must implement ------------------------------------- - -void spl_board_prepare_for_linux(void) : optional - Called from SPL before starting the kernel - -spl_start_uboot() : required - Returns "0" if SPL should start the kernel, "1" if U-Boot - must be started. - -Environment variables ---------------------- - -A board may chose to look at the environment for decisions about falcon -mode. In this case the following variables may be supported: - -boot_os : Set to yes/Yes/true/True/1 to enable booting to OS, - any other value to fall back to U-Boot (including - unset) -falcon_args_file : Filename to load as the 'args' portion of falcon mode - rather than the hard-coded value. -falcon_image_file : Filename to load as the OS image portion of falcon - mode rather than the hard-coded value. - -Using spl command ------------------ - -spl - SPL configuration - -Usage: - -spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ] - -img : "atags" or "fdt" -kernel_addr : kernel is loaded as part of the boot process, but it is not started. - This is the address where a kernel image is stored. -initrd_addr : Address of initial ramdisk - can be set to "-" if fdt_addr without initrd_addr is used -fdt_addr : in case of fdt, the address of the device tree. - -The spl export command does not write to a storage media. The user is -responsible to transfer the gathered information (assembled ATAGS list -or prepared FDT) from temporary storage in RAM into persistant storage -after each run of 'spl export'. Unfortunately the position of temporary -storage can not be predicted nor provided at commandline, it depends -highly on your system setup and your provided data (ATAGS or FDT). -However at the end of an succesful 'spl export' run it will print the -RAM address of temporary storage. The RAM address of FDT will also be -set in the environment variable 'fdtargsaddr', the new length of the -prepared FDT will be set in the environment variable 'fdtargslen'. -These environment variables can be used in scripts for writing updated -FDT to persistent storage. - -Now the user have to save the generated BLOB from that printed address -to the pre-defined address in persistent storage -(CONFIG_CMD_SPL_NAND_OFS in case of NAND). -The following example shows how to prepare the data for Falcon Mode on -twister board with ATAGS BLOB. - -The "spl export" command is prepared to work with ATAGS and FDT. However, -using FDT is at the moment untested. The ppc port (see a3m071 example -later) prepares the fdt blob with the fdt command instead. - - -Usage on the twister board: --------------------------------- - -Using mtd names with the following (default) configuration -for mtdparts: - -device nand0 <omap2-nand.0>, # parts = 9 - #: name size offset mask_flags - 0: MLO 0x00080000 0x00000000 0 - 1: u-boot 0x00100000 0x00080000 0 - 2: env1 0x00040000 0x00180000 0 - 3: env2 0x00040000 0x001c0000 0 - 4: kernel 0x00600000 0x00200000 0 - 5: bootparms 0x00040000 0x00800000 0 - 6: splashimg 0x00200000 0x00840000 0 - 7: mini 0x02800000 0x00a40000 0 - 8: rootfs 0x1cdc0000 0x03240000 0 - - -twister => nand read 82000000 kernel - -NAND read: device 0 offset 0x200000, size 0x600000 - 6291456 bytes read: OK - -Now the kernel is in RAM at address 0x82000000 - -twister => spl export atags 0x82000000 -## Booting kernel from Legacy Image at 82000000 ... - Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 - Image Type: ARM Linux Kernel Image (uncompressed) - Data Size: 3654808 Bytes = 3.5 MiB - Load Address: 80008000 - Entry Point: 80008000 - Verifying Checksum ... OK - Loading Kernel Image ... OK -OK -cmdline subcommand not supported -bdt subcommand not supported -Argument image is now in RAM at: 0x80000100 - -The result can be checked at address 0x80000100: - -twister => md 0x80000100 -80000100: 00000005 54410001 00000000 00000000 ......AT........ -80000110: 00000000 00000067 54410009 746f6f72 ....g.....ATroot -80000120: 65642f3d 666e2f76 77722073 73666e20 =/dev/nfs rw nfs - -The parameters generated with this step can be saved into NAND at the offset -0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS) - -nand erase.part bootparms -nand write 0x80000100 bootparms 0x4000 - -Now the parameters are stored into the NAND flash at the address -CONFIG_CMD_SPL_NAND_OFS (=0x800000). - -Next time, the board can be started into Falcon Mode moving the -setting the gpio (on twister gpio 55 is used) to kernel mode. - -The kernel is loaded directly by the SPL without passing through U-Boot. - -Example with FDT: a3m071 board -------------------------------- - -To boot the Linux kernel from the SPL, the DT blob (fdt) needs to get -prepard/patched first. U-Boot usually inserts some dynamic values into -the DT binary (blob), e.g. autodetected memory size, MAC addresses, -clocks speeds etc. To generate this patched DT blob, you can use -the following command: - -1. Load fdt blob to SDRAM: -=> tftp 1800000 a3m071/a3m071.dtb - -2. Set bootargs as desired for Linux booting (e.g. flash_mtd): -=> run mtdargs addip2 addtty - -3. Use "fdt" commands to patch the DT blob: -=> fdt addr 1800000 -=> fdt boardsetup -=> fdt chosen - -4. Display patched DT blob (optional): -=> fdt print - -5. Save fdt to NOR flash: -=> erase fc060000 fc07ffff -=> cp.b 1800000 fc060000 10000 -... - - -Falcon Mode was presented at the RMLL 2012. Slides are available at: - -http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf diff --git a/doc/develop/falcon.rst b/doc/develop/falcon.rst new file mode 100644 index 0000000000..3e36956fde --- /dev/null +++ b/doc/develop/falcon.rst @@ -0,0 +1,258 @@ +.. SPDX-License-Identifier: GPL-2.0-or-later + +Falcon Mode +=========== + +Introduction +------------ + +This document provides an overview of how to add support for Falcon Mode +to a board. + +Falcon Mode is introduced to speed up the booting process, allowing +to boot a Linux kernel (or whatever image) without a full blown U-Boot. + +Falcon Mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In most implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can generally be seen as a way to start an image performing the minimum +required initialization. SPL mainly initializes the RAM controller, and then +copies U-Boot image into the memory. + +The Falcon Mode extends this way allowing to start the Linux kernel directly +from SPL. A new command is added to U-Boot to prepare the parameters that SPL +must pass to the kernel, using ATAGS or Device Tree. + +In normal mode, these parameters are generated each time before +loading the kernel, passing to Linux the address in memory where +the parameters can be read. +With Falcon Mode, this snapshot can be saved into persistent storage and SPL is +informed to load it before running the kernel. + +To boot the kernel, these steps under a Falcon-aware U-Boot are required: + +1. Boot the board into U-Boot. + After loading the desired legacy-format kernel image into memory (and DT as + well, if used), use the "spl export" command to generate the kernel + parameters area or the DT. U-Boot runs as when it boots the kernel, but + stops before passing the control to the kernel. + +2. Save the prepared snapshot into persistent media. + The address where to save it must be configured into board configuration + file (CONFIG_CMD_SPL_NAND_OFS for NAND). + +3. Boot the board into Falcon Mode. SPL will load the kernel and copy + the parameters which are saved in the persistent area to the required + address. If a valid uImage is not found at the defined location, U-Boot + will be booted instead. + +It is required to implement a custom mechanism to select if SPL loads U-Boot +or another image. + +The value of a GPIO is a simple way to operate the selection, as well as +reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. + +Falcon Mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells +SPL that U-Boot is not the only available image that SPL is able to start. + +Configuration +------------- + +CONFIG_CMD_SPL + Enable the "spl export" command. + The command "spl export" is then available in U-Boot mode. + +CONFIG_SYS_SPL_ARGS_ADDR + Address in RAM where the parameters must be copied by SPL. + In most cases, it is <start_of_ram> + 0x100. + +CONFIG_SYS_NAND_SPL_KERNEL_OFFS + Offset in NAND where the kernel is stored + +CONFIG_CMD_SPL_NAND_OFS + Offset in NAND where the parameters area was saved. + +CONFIG_CMD_SPL_NOR_OFS + Offset in NOR where the parameters area was saved. + +CONFIG_CMD_SPL_WRITE_SIZE + Size of the parameters area to be copied + +CONFIG_SPL_OS_BOOT + Activate Falcon Mode. + +Function that a board must implement +------------------------------------ + +void spl_board_prepare_for_linux(void) + optional, called from SPL before starting the kernel + +spl_start_uboot() + required, returns "0" if SPL should start the kernel, "1" if U-Boot + must be started. + +Environment variables +--------------------- + +A board may chose to look at the environment for decisions about falcon +mode. In this case the following variables may be supported: + +boot_os + Set to yes/Yes/true/True/1 to enable booting to OS, + any other value to fall back to U-Boot (including unset) + +falcon_args_file + Filename to load as the 'args' portion of falcon mode rather than the + hard-coded value. + +falcon_image_file + Filename to load as the OS image portion of falcon mode rather than the + hard-coded value. + +Using spl command +----------------- + +spl - SPL configuration + +Usage:: + + spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ] + +img + "atags" or "fdt" + +kernel_addr + kernel is loaded as part of the boot process, but it is not started. + This is the address where a kernel image is stored. + +initrd_addr + Address of initial ramdisk + can be set to "-" if fdt_addr without initrd_addr is used + +fdt_addr + in case of fdt, the address of the device tree. + +The *spl export* command does not write to a storage media. The user is +responsible to transfer the gathered information (assembled ATAGS list +or prepared FDT) from temporary storage in RAM into persistent storage +after each run of *spl export*. Unfortunately the position of temporary +storage can not be predicted nor provided at command line, it depends +highly on your system setup and your provided data (ATAGS or FDT). +However at the end of an successful *spl export* run it will print the +RAM address of temporary storage. The RAM address of FDT will also be +set in the environment variable *fdtargsaddr*, the new length of the +prepared FDT will be set in the environment variable *fdtargslen*. +These environment variables can be used in scripts for writing updated +FDT to persistent storage. + +Now the user have to save the generated BLOB from that printed address +to the pre-defined address in persistent storage +(CONFIG_CMD_SPL_NAND_OFS in case of NAND). +The following example shows how to prepare the data for Falcon Mode on +twister board with ATAGS BLOB. + +The *spl export* command is prepared to work with ATAGS and FDT. However, +using FDT is at the moment untested. The ppc port (see a3m071 example +later) prepares the fdt blob with the fdt command instead. + + +Usage on the twister board +-------------------------- + +Using mtd names with the following (default) configuration +for mtdparts:: + + device nand0 <omap2-nand.0>, # parts = 9 + #: name size offset mask_flags + 0: MLO 0x00080000 0x00000000 0 + 1: u-boot 0x00100000 0x00080000 0 + 2: env1 0x00040000 0x00180000 0 + 3: env2 0x00040000 0x001c0000 0 + 4: kernel 0x00600000 0x00200000 0 + 5: bootparms 0x00040000 0x00800000 0 + 6: splashimg 0x00200000 0x00840000 0 + 7: mini 0x02800000 0x00a40000 0 + 8: rootfs 0x1cdc0000 0x03240000 0 + +:: + + twister => nand read 82000000 kernel + + NAND read: device 0 offset 0x200000, size 0x600000 + 6291456 bytes read: OK + +Now the kernel is in RAM at address 0x82000000:: + + twister => spl export atags 0x82000000 + ## Booting kernel from Legacy Image at 82000000 ... + Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3654808 Bytes = 3.5 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + Loading Kernel Image ... OK + OK + cmdline subcommand not supported + bdt subcommand not supported + Argument image is now in RAM at: 0x80000100 + +The result can be checked at address 0x80000100:: + + twister => md 0x80000100 + 80000100: 00000005 54410001 00000000 00000000 ......AT........ + 80000110: 00000000 00000067 54410009 746f6f72 ....g.....ATroot + 80000120: 65642f3d 666e2f76 77722073 73666e20 =/dev/nfs rw nfs + +The parameters generated with this step can be saved into NAND at the offset +0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS):: + + nand erase.part bootparms + nand write 0x80000100 bootparms 0x4000 + +Now the parameters are stored into the NAND flash at the address +CONFIG_CMD_SPL_NAND_OFS (=0x800000). + +Next time, the board can be started into Falcon Mode moving the +setting the GPIO (on twister GPIO 55 is used) to kernel mode. + +The kernel is loaded directly by the SPL without passing through U-Boot. + +Example with FDT: a3m071 board +------------------------------- + +To boot the Linux kernel from the SPL, the DT blob (fdt) needs to get +prepared/patched first. U-Boot usually inserts some dynamic values into +the DT binary (blob), e.g. autodetected memory size, MAC addresses, +clocks speeds etc. To generate this patched DT blob, you can use +the following command: + +1. Load fdt blob to SDRAM:: + + => tftp 1800000 a3m071/a3m071.dtb + +2. Set bootargs as desired for Linux booting (e.g. flash_mtd):: + + => run mtdargs addip2 addtty + +3. Use "fdt" commands to patch the DT blob:: + + => fdt addr 1800000 + => fdt boardsetup + => fdt chosen + +4. Display patched DT blob (optional):: + + => fdt print + +5. Save fdt to NOR flash:: + + => erase fc060000 fc07ffff + => cp.b 1800000 fc060000 10000 + ... + + +Falcon Mode was presented at the RMLL 2012. Slides are available at: + +http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf diff --git a/doc/develop/index.rst b/doc/develop/index.rst index ddbf8dad4a..263d404b4c 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -45,6 +45,7 @@ Implementation printf smbios spl + falcon uefi/index vbe version
On Fri, 28 Jul 2023 at 14:49, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
