[U-Boot] [PATCH 1/2] ARM: zynq: Define default SYS_PROMPT
All boards are using the same prompt that's why add it as default value to Kconfig to simplify defconfigs.
cmd/Kconfig | 1 + configs/syzygy_hub_defconfig | 1 - configs/zynq_cc108_defconfig | 1 - configs/zynq_cse_nand_defconfig | 1 - configs/zynq_cse_nor_defconfig | 1 - configs/zynq_cse_qspi_defconfig | 1 - configs/zynq_dlc20_rev1_0_defconfig | 1 - configs/zynq_microzed_defconfig | 1 - configs/zynq_minized_defconfig | 1 - configs/zynq_picozed_defconfig | 1 - configs/zynq_z_turn_defconfig | 1 - configs/zynq_zc702_defconfig | 1 - configs/zynq_zc706_defconfig | 1 - configs/zynq_zc770_xm010_defconfig | 1 - configs/zynq_zc770_xm011_defconfig | 1 - configs/zynq_zc770_xm011_x16_defconfig | 1 - configs/zynq_zc770_xm012_defconfig | 1 - configs/zynq_zc770_xm013_defconfig | 1 - configs/zynq_zed_defconfig | 1 - configs/zynq_zybo_defconfig | 1 - configs/zynq_zybo_z7_defconfig | 1 - 21 files changed, 1 insertion(+), 20 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 98647f58b7ac..ab65f87999dc 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -48,6 +48,7 @@ config SYS_LONGHELP
config SYS_PROMPT string "Shell prompt" + default "Zynq> " if ARCH_ZYNQ default "=> " help This string is displayed in the command line to the left of the diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 8b72983b2376..6f89372ccfd6 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -19,7 +19,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig index 9bfe5ce99631..495c5df60828 100644 --- a/configs/zynq_cc108_defconfig +++ b/configs/zynq_cc108_defconfig @@ -18,7 +18,6 @@ CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 0910d3bf9d93..8740997a825c 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_STACK_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 0a6b172b7e46..a786fa2e23d0 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_STACK_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 4972d7080595..0cc6976c76b6 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index b6751ad35b49..00d1a598dde0 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index d30581b2418a..751d3735bada 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_minized_defconfig b/configs/zynq_minized_defconfig index 3c95f0acebee..d9657f962197 100644 --- a/configs/zynq_minized_defconfig +++ b/configs/zynq_minized_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 6457876ce455..c72307a89d1b 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -10,7 +10,6 @@ CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index d133fea395ec..799277c58e9a 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 6b670aefc989..74e8b3e32ee9 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_DFU=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 3d0cd314c626..f83103915845 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FPGA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 53108ff03c8f..301bc2dffd66 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index feedb327bd42..8bc49ea06687 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -19,7 +19,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 28d63c9ec53d..70429a2f2545 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -19,7 +19,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 01e3d5fb843e..78cdd9c9c745 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -16,7 +16,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_IMLS=y CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 30bb0ef3f209..c6678784afc1 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 9b6d75487208..38bf3e45e650 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 2abc6db0d0cc..71d1638d451a 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index eda1416a9b7e..0cc525c63788 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 -CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set
cmd/Kconfig | 1 + configs/avnet_ultra96_rev1_defconfig | 1 - configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 - configs/xilinx_zynqmp_a2197_g_revA_defconfig | 1 - configs/xilinx_zynqmp_a2197_m_revA_defconfig | 1 - configs/xilinx_zynqmp_a2197_p_revA_defconfig | 1 - configs/xilinx_zynqmp_a2197_revA_defconfig | 1 - configs/xilinx_zynqmp_mini_defconfig | 1 - configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 - configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 - configs/xilinx_zynqmp_mini_nand_defconfig | 1 - configs/xilinx_zynqmp_mini_qspi_defconfig | 1 - configs/xilinx_zynqmp_zc1232_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1254_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 - configs/xilinx_zynqmp_zcu100_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu1275_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu1275_revB_defconfig | 1 - 29 files changed, 1 insertion(+), 28 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index ab65f87999dc..65360a69beb6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -49,6 +49,7 @@ config SYS_LONGHELP config SYS_PROMPT string "Shell prompt" default "Zynq> " if ARCH_ZYNQ + default "ZynqMP> " if ARCH_ZYNQMP default "=> " help This string is displayed in the command line to the left of the diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index 924153081149..b5e61e621acd 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_BIND=y diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index f463318565ff..b9bb0c9b1112 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_OS_BOOT=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADP=y diff --git a/configs/xilinx_zynqmp_a2197_g_revA_defconfig b/configs/xilinx_zynqmp_a2197_g_revA_defconfig index 2f6dc7641a80..47a98c6d4d8b 100644 --- a/configs/xilinx_zynqmp_a2197_g_revA_defconfig +++ b/configs/xilinx_zynqmp_a2197_g_revA_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_a2197_m_revA_defconfig b/configs/xilinx_zynqmp_a2197_m_revA_defconfig index d9107d6bb867..fb4020b2dfed 100644 --- a/configs/xilinx_zynqmp_a2197_m_revA_defconfig +++ b/configs/xilinx_zynqmp_a2197_m_revA_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_a2197_p_revA_defconfig b/configs/xilinx_zynqmp_a2197_p_revA_defconfig index 4ce634cdaacf..d19c6b34cac6 100644 --- a/configs/xilinx_zynqmp_a2197_p_revA_defconfig +++ b/configs/xilinx_zynqmp_a2197_p_revA_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_a2197_revA_defconfig b/configs/xilinx_zynqmp_a2197_revA_defconfig index ace011423249..3498483f4b78 100644 --- a/configs/xilinx_zynqmp_a2197_revA_defconfig +++ b/configs/xilinx_zynqmp_a2197_revA_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 93fa7d8f6bdc..4b7fe5dd40e8 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -13,7 +13,6 @@ CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index b4162abdd715..282e93f03ca1 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -14,7 +14,6 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 76d5aa6c713b..be709886987b 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -14,7 +14,6 @@ CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 2b896f79a72e..35776ab20816 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -14,7 +14,6 @@ CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index a20534a488ca..383f868625bf 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -17,7 +17,6 @@ CONFIG_ZYNQMP_NO_DDR=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 80a310fb1cee..255217df4bd8 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index 75ec572827bf..e058195842f5 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index ce1ea089ce8d..bbf387a6b072 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 01c29c0e70a3..d5434eee85a2 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index 877f5b230da3..4ff52292fb68 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 6f14234a590e..a5a7fc2aeb0b 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_CLK=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index f1970aadf417..5b8cf77085d9 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_CLK=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index cd7d2f5376d2..fc917f0b5d2d 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_BIND=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 52ee2f2a0b04..b64956d5f6a3 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 2b7cab8add62..8b1a1ce0a2cf 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index ce271b5a31ca..2aab26dd3fb0 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index eacf75d9f8e2..07e58b192ab0 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 2f269009dfe9..4829df62b410 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 1b685ca04925..72b3ce16a884 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index 74106d7ea8fa..de739ed3b5f1 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y diff --git a/configs/xilinx_zynqmp_zcu1275_revA_defconfig b/configs/xilinx_zynqmp_zcu1275_revA_defconfig index b9110ca3b936..d86c5d1a76a6 100644 --- a/configs/xilinx_zynqmp_zcu1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revA_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx_zynqmp_zcu1275_revB_defconfig b/configs/xilinx_zynqmp_zcu1275_revB_defconfig index 03372c77e637..957b883abde2 100644 --- a/configs/xilinx_zynqmp_zcu1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revB_defconfig @@ -17,7 +17,6 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_ATF=y -CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set
Hi Michal,
- default "ZynqMP> " if ARCH_ZYNQMP default "=> "
Generally speaking, why do we need a per-machine prompt at all? "=> " ought be enough for everybody, nope?
However to maintain backward compatibility with whatever expects those prompts this patch is a good cleanup anyway:
Reviewed-by: Luca Ceresoli luca@lucaceresoli.net
On 25. 09. 19 13:03, Luca Ceresoli wrote:
Hi Michal,
Lava for example is looking for certain string in prompt that's why we should keep backward compatibility as you mentioned.
M
st 25. 9. 2019 v 12:38 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
2.17.1
Applied both. M
Luca Ceresoli
Michal Simek
Michal Simek
