[U-Boot] [PATCH 9/10] board/b4qds:Add support of 2 stage NAND boot-loader
Add support of 2 stage NAND boot loader using SPL framework. here, PBL initialise the internal SRAM and copy SPL(160KB). This further initialise DDR using SPD and environment and copy u-boot(768 KB) from NAND to DDR. Finally SPL transer control to u-boot.
Initialise/create followings required for SPL framework - Add spl.c which defines board_init_f, board_init_r - update tlb and ddr accordingly
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- board/freescale/b4860qds/Makefile | 9 ++- board/freescale/b4860qds/ddr.c | 5 +- board/freescale/b4860qds/spl.c | 115 +++++++++++++++++++++++++++++++++++++ board/freescale/b4860qds/tlb.c | 10 ++++ boards.cfg | 4 +- doc/README.b4860qds | 35 +++++++++++ include/configs/B4860QDS.h | 64 ++++++++++++++++++--- 7 files changed, 230 insertions(+), 12 deletions(-) create mode 100644 board/freescale/b4860qds/spl.c
diff --git a/board/freescale/b4860qds/Makefile b/board/freescale/b4860qds/Makefile index e5cc054..0acd2a9 100644 --- a/board/freescale/b4860qds/Makefile +++ b/board/freescale/b4860qds/Makefile @@ -4,9 +4,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +else obj-y += b4860qds.o -obj-y += ddr.o obj-$(CONFIG_B4860QDS)+= eth_b4860qds.o -obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_PCI) += pci.o +endif + +obj-y += ddr.o obj-y += law.o obj-y += tlb.o diff --git a/board/freescale/b4860qds/ddr.c b/board/freescale/b4860qds/ddr.c index 187c3b3..2c17156 100644 --- a/board/freescale/b4860qds/ddr.c +++ b/board/freescale/b4860qds/ddr.c @@ -179,6 +179,7 @@ phys_size_t initdram(int board_type) { phys_size_t dram_size;
+#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) puts("Initializing....using SPD\n");
dram_size = fsl_ddr_sdram(); @@ -186,7 +187,9 @@ phys_size_t initdram(int board_type) dram_size = setup_ddr_tlbs(dram_size / 0x100000); dram_size *= 0x100000;
- puts(" DDR: "); +#else + dram_size = fsl_ddr_sdram_size(); +#endif return dram_size; }
diff --git a/board/freescale/b4860qds/spl.c b/board/freescale/b4860qds/spl.c new file mode 100644 index 0000000..d56cd30 --- /dev/null +++ b/board/freescale/b4860qds/spl.c @@ -0,0 +1,115 @@ +/* Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/spl.h> +#include <malloc.h> +#include <ns16550.h> +#include <nand.h> +#include <i2c.h> +#include "../common/qixis.h" +#include "b4860qds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +phys_size_t get_effective_memsize(void) +{ + return CONFIG_SYS_L3_SIZE; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch ((sysclk_conf & 0x0C) >> 2) { + case QIXIS_CLK_100: + return 100000000; + case QIXIS_CLK_125: + return 125000000; + case QIXIS_CLK_133: + return 133333333; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + switch (ddrclk_conf & 0x03) { + case QIXIS_CLK_100: + return 100000000; + case QIXIS_CLK_125: + return 125000000; + case QIXIS_CLK_133: + return 133333333; + } + return 66666666; +} + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio, sys_clk, uart_clk; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + /* Memcpy existing GD at CONFIG_SPL_GD_ADDR */ + memcpy((void *)CONFIG_SPL_GD_ADDR, (void *)gd, sizeof(gd_t)); + + /* Update GD pointer */ + gd = (gd_t *)(CONFIG_SPL_GD_ADDR); + __asm__ __volatile__("" : : : "memory"); + + console_init_f(); + + /* initialize selected port with appropriate baud rate */ + sys_clk = get_board_sys_clk(); + plat_ratio = (in_be32(&gur->rcwsr[0]) >> 25) & 0x1f; + uart_clk = sys_clk * plat_ratio / 2; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + uart_clk / 16 / CONFIG_BAUDRATE); + + relocate_code(CONFIG_SPL_RELOC_STACK, (gd_t *)CONFIG_SPL_GD_ADDR, 0x0); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + bd_t *bd; + + bd = (bd_t *)(gd + sizeof(gd_t)); + memset(bd, 0, sizeof(bd_t)); + gd->bd = bd; + bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; + bd->bi_memsize = CONFIG_SYS_L3_SIZE; + + probecpu(); + get_clocks(); + mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, + CONFIG_SPL_RELOC_MALLOC_SIZE); + +#ifndef CONFIG_SPL_NAND_BOOT + env_init(); +#endif + + /* relocate environment function pointers etc. */ +#ifdef CONFIG_SPL_NAND_BOOT + nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_valid = 1; +#else + env_relocate(); +#endif + + i2c_init_all(); + + puts("\n\n"); + + gd->ram_size = initdram(0); + +#ifdef CONFIG_SPL_NAND_BOOT + nand_boot(); +#endif +} diff --git a/board/freescale/b4860qds/tlb.c b/board/freescale/b4860qds/tlb.c index 00798a1..7b55b86 100644 --- a/board/freescale/b4860qds/tlb.c +++ b/board/freescale/b4860qds/tlb.c @@ -62,6 +62,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
+#ifndef CONFIG_SPL_BUILD /* *I*G* - PCI */ SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -96,6 +97,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 9, BOOKE_PAGESZ_16M, 1), #endif +#endif #ifdef CONFIG_SYS_DCSRBAR_PHYS SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -118,6 +120,7 @@ struct fsl_e_tlb_entry tlb_table[] = { * entry 14 and 15 has been used hard coded, they will be disabled * in cpu_init_f, so we use entry 16 for SRIO2. */ +#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_SYS_SRIO1_MEM_PHYS /* *I*G* - SRIO1 */ SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT, CONFIG_SYS_SRIO1_MEM_PHYS, @@ -140,6 +143,13 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 17, BOOKE_PAGESZ_1M, 1), #endif +#endif + +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 17, BOOKE_PAGESZ_2G, 1) +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 5afca26..76f3aae 100644 --- a/boards.cfg +++ b/boards.cfg @@ -740,10 +740,10 @@ Active powerpc mpc85xx - - sbc8548 Active powerpc mpc85xx - - socrates socrates - - Active powerpc mpc85xx - exmeritus hww1u1a HWW1U1A - Kyle Moffett Kyle.D.Moffett@boeing.com Active powerpc mpc85xx - freescale b4860qds B4420QDS B4860QDS:PPC_B4420 - -Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,RAMBOOT_SPLPBL,NAND - Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - -Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,RAMBOOT_SPLPBL,NAND Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND BSC9131RDB:BSC9131RDB,NAND Poonam Aggrwal poonam.aggrwal@freescale.com diff --git a/doc/README.b4860qds b/doc/README.b4860qds index 3da77d9..44b46da 100644 --- a/doc/README.b4860qds +++ b/doc/README.b4860qds @@ -328,3 +328,38 @@ The below commands apply to both B4860QDS and B4420QDS. On Linux the interfaces are renamed as: . eth2 -> fm1-gb2 . eth3 -> fm1-gb3 + +NAND boot with 2 Stage boot loader +---------------------------------- +PBL initialise the internal SRAM and copy SPL(160KB) in SRAM. +SPL further initialise DDR using SPD and environment variables and copy +u-boot(768 KB) from flash to DDR. +Finally SPL transer control to u-boot for futher booting. + +SPL has following features: + - Executes within 256K + - No relocation required + + Run time view of SPL framework :- + ----------------------------------------------- + Area | Address | +----------------------------------------------- + Reserve | 0xFFFC0000 (32KB) | + ----------------------------------------------- + GD, BD | 0xFFFC8000 (4KB) | + ----------------------------------------------- + ENV | 0xFFFC9000 (6KB) | + ----------------------------------------------- + HEAP | 0xFFFCA800 (30KB) | + ----------------------------------------------- + STACK | 0xFFFD8000 (20KB) | + ----------------------------------------------- + U-boot SPL | 0xFFFD8000 (160KB) | + ----------------------------------------------- + +NAND Flash memory Map on B4860 and B4420QDS +------------------------------------------ + Start End Definition Size +0x000000 0x0FFFFF u-boot 1MB +0x140000 0x15FFFF u-boot env 128KB +0x160000 0x17FFFF FMAN Ucode 128KB diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 8fcd1de..4df28a2 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -14,10 +14,43 @@ #define CONFIG_PHYS_64BIT
#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/b4860qds/b4_pbi.cfg +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/b4860qds/b4_rcw.cfg +#ifndef CONFIG_NAND #define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_SYS_FSL_PBL_PBI board/freescale/b4860qds/b4_pbi.cfg -#define CONFIG_SYS_FSL_PBL_RCW board/freescale/b4860qds/b4_rcw.cfg +#else +#define CONFIG_SPL +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x00201000 +#define CONFIG_SPL_TEXT_BASE 0xFFFD8000 +#define CONFIG_SPL_PAD_TO 0x40000 +#define CONFIG_SPL_MAX_SIZE 0x28000 +#define RESET_VECTOR_OFFSET 0x27FFC +#define BOOT_PAGE_OFFSET 0x27000 +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 +#define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (256 << 10) +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot-nand.lds" +#define CONFIG_SPL_NAND_BOOT +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_SKIP_RELOCATE +#define CONFIG_SPL_COMMON_INIT_DDR +#define CONFIG_SYS_CCSR_DO_NOT_RELOCATE +#define CONFIG_SYS_NO_FLASH +#endif +#endif #endif
#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE @@ -113,8 +146,8 @@ #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) #define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 @@ -164,7 +197,16 @@ unsigned long get_board_ddr_clk(void); /* * Config the L3 Cache as L3 SRAM */ -#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE +#define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 +#define CONFIG_SYS_L3_SIZE 256 << 10 +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) +#ifdef CONFIG_NAND +#define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) +#endif +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 10 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (34 << 10) +#define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) +#define CONFIG_SPL_RELOC_STACK_SIZE (20 << 10)
#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_DCSRBAR 0xf0000000 @@ -193,7 +235,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DDR_SPD #define CONFIG_SYS_DDR_RAW_TIMING #define CONFIG_SYS_FSL_DDR3 +#ifndef CONFIG_SPL_BUILD #define CONFIG_FSL_DDR_INTERACTIVE +#endif
#define CONFIG_SYS_SPD_BUS_NUM 0 #define SPD_EEPROM_ADDRESS1 0x51 @@ -381,7 +425,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 #define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE +#else +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif
#if defined(CONFIG_RAMBOOT_PBL) #define CONFIG_SYS_RAMBOOT @@ -435,7 +483,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) #define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ +#endif
/* Use the HUSH parser */ @@ -607,7 +657,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_QE_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing
- u32 plat_ratio, sys_clk, uart_clk;
- ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
- /* Memcpy existing GD at CONFIG_SPL_GD_ADDR */
- memcpy((void *)CONFIG_SPL_GD_ADDR, (void *)gd, sizeof(gd_t));
- /* Update GD pointer */
- gd = (gd_t *)(CONFIG_SPL_GD_ADDR);
- __asm__ __volatile__("" : : : "memory");
Explain why this barrier is needed.
- env_init();
- /* relocate environment function pointers etc. */
- nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE,
- gd->env_addr = (ulong)(CONFIG_ENV_ADDR);
- gd->env_valid = 1;
+#else
- env_relocate();
Move env_init() to be just before env_relocate(), rather than duplicating the ifdef.
- i2c_init_all();
- puts("\n\n");
- gd->ram_size = initdram(0);
What is the 0?
- Run time view of SPL framework :-
- Area | Address |
- Reserve | 0xFFFC0000 (32KB) |
s/Reserve/Reserved/
What is it reserved for/by? Something external? Or does U-Boot just not use that area currently? In that case just say "Unused".
- Start End Definition Size
What goes at 0x100000?
What if 0x140000 or 0x160000 is a bad block?
-Scott
I followed similar to what is present in arch/powerpc/lib/board.c. There is is mentioned like /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("":::"memory");
may i mention this comment here also.
- env_init();
+#else
- env_relocate();
sure, I will do it.
- i2c_init_all();
- puts("\n\n");
What is the 0?
here 0 is board type.
in arch/powerpc/lib/board.c , we pass it as 0 "dummy arg". Same I am following here
- Area | Address |
s/Reserve/Reserved/
Secure boot requires some memory in SRAM in order to put some headers etc. May be I mention in README also
I think, ENV can start from here.
it can be true for any region. I believe it will be taken care by MTD layer to read next good block.
are you suggesting to have a hole of 1 block between every regions.
Regards, Prabhakar
Yes, at least retain the comment when you copy the code.
- i2c_init_all();
- puts("\n\n");
What is the 0?
Right, that comment was more for York -- why do we have this dummy argument?
- Area | Address |
s/Reserve/Reserved/
Secure boot is no longer running at this point, so why does it care?
Or do you mean that code in U-Boot uses this for validating the next image (in which case, it's not reserved, but rather used for that purpose)?
No, it won't. Imagine if it did, and 0x140000 were bad, and it used 0x160000 instead. Then where would FMAN Ucode go?
There are a variety of options for dealing with this for the environment. One of them is leaving a range of blocks (more than two -- consecutive blocks can be bad) within which block skipping can be done. This can be fairly wasteful, especially if you'd extend it to other things like microcode.
Another way is to put the environment in UBI, but that means you can't load the environment during SPL or before relocation.
My suggestion would be to put non-environment things in UBI. For the environment, either use CONFIG_ENV_RANGE, or append the environment (block-aligned) to the U-Boot image so it can participate in its bad block skipping without having to reserve another large chunk.
Also consider having a redundant environment, IIRC this will need additional work to function with any of the bad block handling approaches.
-Scott
Prabhakar Kushwaha
Scott Wood
