[U-Boot] [PATCH v2] kconfig: add sanity checks for SPL configuration
For the SPL configuration, "make <dir>/<target>" is used. Here, <dir> is either "spl" or "tpl" <target> is one of "config", "menuconfig", "xconfig", etc.
This commit adds two checks:
[1] If <dir> is given an unsupported subimage, the configuration should error out like this:
$ make qpl/menuconfig *** *** "make qpl/menuconfig" is not supported. ***
[2] Make sure that "CONFIG_SPL" is enabled in the ".config" before running "make spl/menuconfig. Otherwise, the SPL image is not built at all. Having "spl/.config" makes no sense. In such a case, the configuration should exit with a message:
$ make spl/menuconfig *** *** Create ".config" with "CONFIG_SPL" enabled *** before "make spl/menuconfig". ***
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Suggested-by: Simon Glass sjg@chromium.org ---
This check was proposed by Simon in his review before getting the Kconfig series in.
Changes in v2: - Replace "$objdir" with "$2" in check_enabled_subimage()
scripts/multiconfig.sh | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/scripts/multiconfig.sh b/scripts/multiconfig.sh index 49fcfad..4a8737f 100644 --- a/scripts/multiconfig.sh +++ b/scripts/multiconfig.sh @@ -252,6 +252,35 @@ do_savedefconfig () { IFS=$save_IFS }
+# Some sanity checks before running "make <objdir>/<target>", +# where <objdir> should be either "spl" or "tpl". +# Doing "make spl/menuconfig" etc. on a non-SPL board makes no sense. +# It should be allowed only when ".config" exists and "CONFIG_SPL" is enabled. +# +# Usage: +# check_enabled_sumbimage <objdir>/<target> <objdir> +check_enabled_subimage () { + + case $2 in + spl|tpl) ;; + *) + echo >&2 "***" + echo >&2 "*** "make $1" is not supported." + echo >&2 "***" + exit 1 + ;; + esac + test -r "$KCONFIG_CONFIG" && get_enabled_subimages | grep -q $2 || { + config=CONFIG_$(echo $2 | tr '[a-z]' '[A-Z]') + + echo >&2 "***" + echo >&2 "*** Create "$KCONFIG_CONFIG" with "$config" enabled" + echo >&2 "*** before "make $1"." + echo >&2 "***" + exit 1 + } +} + # Usage: # do_others <objdir>/<target> # The field "<objdir>/" is typically empy, "spl/", "tpl/" for Normal, SPL, TPL, @@ -265,6 +294,7 @@ do_others () { objdir= else objdir=${1%/*} + check_enabled_subimage $1 $objdir fi
run_make_config $target $objdir
Masahiro Yamada
