[PATCH 0/8] imx: drivers: ddr: ddr driver update
This is to upstream NXP vendor tree ddr driver related fix and update
Jacky Bai (2): driver: ddr: imx: skip ddr_ss_gpr config on imx8mn driver: ddr: imx: correct the pwrctl setting of selfref_en on imx8m
Jian Li (3): imx8mp: enable rd_port_urgent imx8mp: DDR performance tunning imx8mp: Disables use of MR4 TUF flag (MR4[7]) bit
Oliver Chen (1): drivers: ddr: imx Workaround for i.MX8M DDRPHY rank to rank issue
Sherry Sun (1): imx8mp: ddr: Add inline ECC feature support
Ye Li (1): drivers: ddr: imx8m: add print for DRAM rate
arch/arm/include/asm/arch-imx8m/ddr.h | 10 ++ board/freescale/imx8mp_evk/lpddr4_timing.c | 32 +++++- drivers/ddr/imx/imx8m/Kconfig | 7 ++ drivers/ddr/imx/imx8m/ddr_init.c | 86 ++++++++++++++- drivers/ddr/imx/imx8m/ddrphy_train.c | 7 ++ drivers/ddr/imx/imx8m/ddrphy_utils.c | 166 ++++++++++++++++++++++++++++- 6 files changed, 300 insertions(+), 8 deletions(-)
There is no DDR_SS_GPR0 exits on i.MX8MN, so skip setting this register on i.MX8MN.
Signed-off-by: Jacky Bai ping.bai@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddr_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index af8c1427d2..ba5ae05035 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -73,7 +73,7 @@ int ddr_init(struct dram_timing_info *dram_timing)
/* if ddr type is LPDDR4, do it */ tmp = reg32_read(DDRC_MSTR(0)); - if (tmp & (0x1 << 5)) + if (tmp & (0x1 << 5) && !is_imx8mn()) reg32_write(DDRC_DDR_SS_GPR0, 0x01); /* LPDDR4 mode */
/* determine the initial boot frequency */
The 'selfref_en' should be bit'0', so correct the setting to enable the auto self-refresh.
Reviewed-by: Jian Li jian.li@nxp.com Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Jacky Bai ping.bai@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddr_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index ba5ae05035..06b4341b11 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -162,7 +162,7 @@ int ddr_init(struct dram_timing_info *dram_timing) /* Step26: Set back register in Step4 to the original values if desired */ reg32_write(DDRC_RFSHCTL3(0), 0x0000000); /* enable selfref_en by default */ - setbits_le32(DDRC_PWRCTL(0), 0x1 << 3); + setbits_le32(DDRC_PWRCTL(0), 0x1);
/* enable port 0 */ reg32_write(DDRC_PCTRL_0(0), 0x00000001);
Add inline ECC support for lpddr4 on imx8mp-evk. And add a config which can enable/disable inline ECC feature for lpddr4 on imx8mp-evk board.
Signed-off-by: Sherry Sun sherry.sun@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/ddr.h | 7 +++ board/freescale/imx8mp_evk/lpddr4_timing.c | 27 +++++++++++ drivers/ddr/imx/imx8m/Kconfig | 7 +++ drivers/ddr/imx/imx8m/ddr_init.c | 72 ++++++++++++++++++++++++++++++ 4 files changed, 113 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8m/ddr.h b/arch/arm/include/asm/arch-imx8m/ddr.h index 7a2a2d8edc..04c9c962cf 100644 --- a/arch/arm/include/asm/arch-imx8m/ddr.h +++ b/arch/arm/include/asm/arch-imx8m/ddr.h @@ -529,6 +529,8 @@ enum msg_response { #define DDRC_SBRWDATA0(X) (DDRC_IPS_BASE_ADDR(X) + 0xf2c) #define DDRC_SBRWDATA1(X) (DDRC_IPS_BASE_ADDR(X) + 0xf30) #define DDRC_PDCH(X) (DDRC_IPS_BASE_ADDR(X) + 0xf34) +#define DDRC_SBRSTART0(X) (DDRC_IPS_BASE_ADDR(X) + 0xf38) +#define DDRC_SBRRANGE0(X) (DDRC_IPS_BASE_ADDR(X) + 0xf40)
#define DDRC_FREQ1_DERATEEN(X) (DDRC_IPS_BASE_ADDR(X) + 0x2020) #define DDRC_FREQ1_DERATEINT(X) (DDRC_IPS_BASE_ADDR(X) + 0x2024) @@ -708,6 +710,11 @@ int ddr_cfg_phy(struct dram_timing_info *timing_info); void load_lpddr4_phy_pie(void); void ddrphy_trained_csr_save(struct dram_cfg_param *param, unsigned int num); void dram_config_save(struct dram_timing_info *info, unsigned long base); +void board_dram_ecc_scrub(void); +void ddrc_inline_ecc_scrub(unsigned int start_address, + unsigned int range_address); +void ddrc_inline_ecc_scrub_end(unsigned int start_address, + unsigned int range_address);
/* utils function for ddr phy training */ int wait_ddrphy_training_complete(void); diff --git a/board/freescale/imx8mp_evk/lpddr4_timing.c b/board/freescale/imx8mp_evk/lpddr4_timing.c index 14542490bc..4e5ebf9424 100644 --- a/board/freescale/imx8mp_evk/lpddr4_timing.c +++ b/board/freescale/imx8mp_evk/lpddr4_timing.c @@ -14,6 +14,9 @@ struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d400020, 0x323 }, { 0x3d400024, 0x1e84800 }, { 0x3d400064, 0x7a0118 }, +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC + { 0x3d400070, 0x01027f44 }, +#endif { 0x3d4000d0, 0xc00307a3 }, { 0x3d4000d4, 0xc50000 }, { 0x3d4000dc, 0xf4003f }, @@ -45,12 +48,21 @@ struct dram_cfg_param ddr_ddrc_cfg[] = { { 0x3d4001c4, 0x1 }, { 0x3d4000f4, 0xc99 }, { 0x3d400108, 0x9121c1c }, +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC + { 0x3d400200, 0x13 }, + { 0x3d40020c, 0x13131300 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x50505 }, + { 0x3d400214, 0x4040404 }, + { 0x3d400218, 0x68040404 }, +#else { 0x3d400200, 0x16 }, { 0x3d40020c, 0x0 }, { 0x3d400210, 0x1f1f }, { 0x3d400204, 0x80808 }, { 0x3d400214, 0x7070707 }, { 0x3d400218, 0x68070707 }, +#endif { 0x3d40021c, 0xf08 }, { 0x3d400250, 0x29001701 }, { 0x3d400254, 0x2c }, @@ -1845,3 +1857,18 @@ struct dram_timing_info dram_timing = { .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), .fsp_table = { 4000, 400, 100, }, }; + +#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC +void board_dram_ecc_scrub(void) +{ + /* add inline scrb function MPlus spcific */ + /* scrub 0-1.75G */ + ddrc_inline_ecc_scrub(0x0, 0x1bffffff); + /* scrub 2-3.75G */ + ddrc_inline_ecc_scrub(0x20000000, 0x3bffffff); + /* scrub 4-5.75G */ + ddrc_inline_ecc_scrub(0x40000000, 0x5bffffff); + /* set scruber read range 0-6G */ + ddrc_inline_ecc_scrub_end(0x0, 0x5fffffff); +} +#endif diff --git a/drivers/ddr/imx/imx8m/Kconfig b/drivers/ddr/imx/imx8m/Kconfig index 5bf61eb258..a5f5524fbe 100644 --- a/drivers/ddr/imx/imx8m/Kconfig +++ b/drivers/ddr/imx/imx8m/Kconfig @@ -29,4 +29,11 @@ config SAVED_DRAM_TIMING_BASE info into memory for low power use. OCRAM_S is used for this purpose on i.MX8MM. default 0x180000 + +config IMX8M_DRAM_INLINE_ECC + bool "imx8mp inline ECC" + depends on IMX8MP && IMX8M_LPDDR4 + help + Select this config if you want to use inline ecc feature for + imx8mp-evk board. endmenu diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index 06b4341b11..f573a778d9 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -20,6 +20,76 @@ void ddr_cfg_umctl2(struct dram_cfg_param *ddrc_cfg, int num) } }
+#ifdef CONFIG_IMX8M_DRAM_INLINE_ECC +void ddrc_inline_ecc_scrub(unsigned int start_address, + unsigned int range_address) +{ + unsigned int tmp; + + /* Step1: Enable quasi-dynamic programming */ + reg32_write(DDRC_SWCTL(0), 0x00000000); + /* Step2: Set ECCCFG1.ecc_parity_region_lock to 1 */ + reg32setbit(DDRC_ECCCFG1(0), 0x4); + /* Step3: Block the AXI ports from taking the transaction */ + reg32_write(DDRC_PCTRL_0(0), 0x0); + /* Step4: Set scrub start address */ + reg32_write(DDRC_SBRSTART0(0), start_address); + /* Step5: Set scrub range address */ + reg32_write(DDRC_SBRRANGE0(0), range_address); + /* Step6: Set scrub_mode to write */ + reg32_write(DDRC_SBRCTL(0), 0x00000014); + /* Step7: Set the desired pattern through SBRWDATA0 registers */ + reg32_write(DDRC_SBRWDATA0(0), 0x55aa55aa); + /* Step8: Enable the SBR by programming SBRCTL.scrub_en=1 */ + reg32setbit(DDRC_SBRCTL(0), 0x0); + /* Step9: Poll SBRSTAT.scrub_done=1 */ + tmp = reg32_read(DDRC_SBRSTAT(0)); + while (tmp != 0x00000002) + tmp = reg32_read(DDRC_SBRSTAT(0)) & 0x2; + /* Step10: Poll SBRSTAT.scrub_busy=0 */ + tmp = reg32_read(DDRC_SBRSTAT(0)); + while (tmp != 0x0) + tmp = reg32_read(DDRC_SBRSTAT(0)) & 0x1; + /* Step11: Disable SBR by programming SBRCTL.scrub_en=0 */ + clrbits_le32(DDRC_SBRCTL(0), 0x1); + /* Step12: Prepare for normal scrub operation(Read) and set scrub_interval*/ + reg32_write(DDRC_SBRCTL(0), 0x100); + /* Step13: Enable the SBR by programming SBRCTL.scrub_en=1 */ + reg32_write(DDRC_SBRCTL(0), 0x101); + /* Step14: Enable AXI ports by programming */ + reg32_write(DDRC_PCTRL_0(0), 0x1); + /* Step15: Disable quasi-dynamic programming */ + reg32_write(DDRC_SWCTL(0), 0x00000001); +} + +void ddrc_inline_ecc_scrub_end(unsigned int start_address, + unsigned int range_address) +{ + /* Step1: Enable quasi-dynamic programming */ + reg32_write(DDRC_SWCTL(0), 0x00000000); + /* Step2: Block the AXI ports from taking the transaction */ + reg32_write(DDRC_PCTRL_0(0), 0x0); + /* Step3: Set scrub start address */ + reg32_write(DDRC_SBRSTART0(0), start_address); + /* Step4: Set scrub range address */ + reg32_write(DDRC_SBRRANGE0(0), range_address); + /* Step5: Disable SBR by programming SBRCTL.scrub_en=0 */ + clrbits_le32(DDRC_SBRCTL(0), 0x1); + /* Step6: Prepare for normal scrub operation(Read) and set scrub_interval */ + reg32_write(DDRC_SBRCTL(0), 0x100); + /* Step7: Enable the SBR by programming SBRCTL.scrub_en=1 */ + reg32_write(DDRC_SBRCTL(0), 0x101); + /* Step8: Enable AXI ports by programming */ + reg32_write(DDRC_PCTRL_0(0), 0x1); + /* Step9: Disable quasi-dynamic programming */ + reg32_write(DDRC_SWCTL(0), 0x00000001); +} +#endif + +void __weak board_dram_ecc_scrub(void) +{ +} + int ddr_init(struct dram_timing_info *dram_timing) { unsigned int tmp, initial_drate, target_freq; @@ -168,6 +238,8 @@ int ddr_init(struct dram_timing_info *dram_timing) reg32_write(DDRC_PCTRL_0(0), 0x00000001); debug("DDRINFO: ddrmix config done\n");
+ board_dram_ecc_scrub(); + /* save the dram timing config into memory */ dram_config_save(dram_timing, CONFIG_SAVED_DRAM_TIMING_BASE);
Hi Peng,
Please elaborate more on this inline ECC feature: when and why does it need to be selected, for example.
I see no user for this symbol at the moment.
It is usually better to introduce the symbol when there is a real user for it.
Subject: Re: [PATCH 3/8] imx8mp: ddr: Add inline ECC feature support
Hi Peng,
board.
ok.
This is the the just the driver part. To enable this feature, we need a dedicated defconfig. The defconfig part will be posted in other patches.
Thanks, Peng.
Enable print to show the DRAM rate of current setting and training result.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddr_init.c | 7 ++++--- drivers/ddr/imx/imx8m/ddrphy_utils.c | 2 +- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/ddr_init.c b/drivers/ddr/imx/imx8m/ddr_init.c index f573a778d9..a1d2d21692 100644 --- a/drivers/ddr/imx/imx8m/ddr_init.c +++ b/drivers/ddr/imx/imx8m/ddr_init.c @@ -95,7 +95,7 @@ int ddr_init(struct dram_timing_info *dram_timing) unsigned int tmp, initial_drate, target_freq; int ret;
- debug("DDRINFO: start DRAM init\n"); + printf("DDRINFO: start DRAM init\n");
/* Step1: Follow the power up procedure */ if (is_imx8mq()) { @@ -118,6 +118,7 @@ int ddr_init(struct dram_timing_info *dram_timing)
initial_drate = dram_timing->fsp_msg[0].drate; /* default to the frequency point 0 clock */ + printf("DDRINFO: DRAM rate %dMTS\n", initial_drate); ddrphy_init_set_dfi_clk(initial_drate);
/* D-aasert the presetn */ @@ -184,7 +185,7 @@ int ddr_init(struct dram_timing_info *dram_timing) tmp = reg32_read(DDRPHY_CalBusy(0)); } while ((tmp & 0x1));
- debug("DDRINFO:ddrphy calibration done\n"); + printf("DDRINFO:ddrphy calibration done\n");
/* Step15: Set SWCTL.sw_done to 0 */ reg32_write(DDRC_SWCTL(0), 0x00000000); @@ -236,7 +237,7 @@ int ddr_init(struct dram_timing_info *dram_timing)
/* enable port 0 */ reg32_write(DDRC_PCTRL_0(0), 0x00000001); - debug("DDRINFO: ddrmix config done\n"); + printf("DDRINFO: ddrmix config done\n");
diff --git a/drivers/ddr/imx/imx8m/ddrphy_utils.c b/drivers/ddr/imx/imx8m/ddrphy_utils.c index 9ac7ca923c..9d2378d7dd 100644 --- a/drivers/ddr/imx/imx8m/ddrphy_utils.c +++ b/drivers/ddr/imx/imx8m/ddrphy_utils.c @@ -97,7 +97,7 @@ int wait_ddrphy_training_complete(void) debug("Training PASS\n"); return 0; } else if (mail == 0xff) { - debug("Training FAILED\n"); + printf("Training FAILED\n"); return -1; } }
Hi Peng,
This is basically a revert from:
commit 0d3bc81391ac031758affdb0811bc9c8b905978c Author: Fabio Estevam festevam@gmail.com Date: Wed Dec 11 17:37:09 2019 -0300
imx8m: ddr_init: Move ddr_init() messages to debug level
Currently inside ddr_init() there is a mix of printf() and debug() level messages.
Since this type of information is useful for debug purposes, convert all of them to debug level for consistency.
Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
In the normal boot cases I don't think these messages are helpful.
This one is an error message, so I agree that it is useful to have it printed.
On Mon, May 11, 2020 at 9:13 AM Fabio Estevam festevam@gmail.com wrote:
Hi Peng,
I am not a fan of this.
imx8m: ddr_init: Move ddr_init() messages to debug level Currently inside ddr_init() there is a mix of printf() and debug() level messages. Since this type of information is useful for debug purposes, convert all of them to debug level for consistency. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
I would agree. As a user, I don't think most people will want to know this, and it creates a bunch of chatter. For people who want it, enable the debug.
I would agree here.
adam
This changes the boottime, too. The printf() are really useful only for debugging, IMHO it is better to let it as it is. If something is going wrong, one set DEBUG to get the output.
Regards, Stefano
- printf("DDRINFO: DRAM rate %dMTS\n", initial_drate);
} }printf("Training FAILED\n"); return -1;
Subject: Re: [PATCH 4/8] drivers: ddr: imx8m: add print for DRAM rate
ok. I'll drop this patch from the patchset.
Thanks, Peng.
Regards, Stefano
======= DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ============================================================== =======
Adam Ford
Fabio Estevam
Peng Fan
Stefano Babic
