[U-Boot] [PATCH 0/2] fs: fat: error handling in get_contents()
If a FAT entry is corrupted, reading a file should always lead to an error.
get_contents() should always return -1 when an error occurs.
Heinrich Schuchardt (2): fs: fat: treat invalid FAT clusters as errors fs: fat: get_contents() always returns -1 for errors
fs/fat/fat.c | 32 +++++++++++++++++++++----------- 1 file changed, 21 insertions(+), 11 deletions(-)
-- 2.23.0
When hitting an invalid FAT cluster while reading a file always print an error message and return an error code.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- fs/fat/fat.c | 30 ++++++++++++++++++++---------- 1 file changed, 20 insertions(+), 10 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 73a89fc9e3..b4e8083734 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -301,10 +301,20 @@ get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size) return 0; }
-/* +/** + * get_contents() - read from file + * * Read at most 'maxsize' bytes from 'pos' in the file associated with 'dentptr' - * into 'buffer'. - * Update the number of bytes read in *gotsize or return -1 on fatal errors. + * into 'buffer'. Update the number of bytes read in *gotsize or return -1 on + * fatal errors. + * + * @mydata: file system description + * @dentprt: directory entry pointer + * @pos: position from where to read + * @buffer: buffer into which to read + * @maxsize: maximum number of bytes to read + * @gotsize: number of bytes actually read + * Return: -1 on error, otherwise 0 */ static int get_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, loff_t maxsize, loff_t *gotsize) @@ -335,8 +345,8 @@ static int get_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, curclust = get_fatent(mydata, curclust); if (CHECK_CLUST(curclust, mydata->fatsize)) { debug("curclust: 0x%x\n", curclust); - debug("Invalid FAT entry\n"); - return 0; + printf("Invalid FAT entry\n"); + return -1; } actsize += bytesperclust; } @@ -374,8 +384,8 @@ static int get_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, curclust = get_fatent(mydata, curclust); if (CHECK_CLUST(curclust, mydata->fatsize)) { debug("curclust: 0x%x\n", curclust); - debug("Invalid FAT entry\n"); - return 0; + printf("Invalid FAT entry\n"); + return -1; } }
@@ -390,8 +400,8 @@ static int get_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, goto getit; if (CHECK_CLUST(newclust, mydata->fatsize)) { debug("curclust: 0x%x\n", newclust); - debug("Invalid FAT entry\n"); - return 0; + printf("Invalid FAT entry\n"); + return -1; } endclust = newclust; actsize += bytesperclust; @@ -418,7 +428,7 @@ getit: if (CHECK_CLUST(curclust, mydata->fatsize)) { debug("curclust: 0x%x\n", curclust); printf("Invalid FAT entry\n"); - return 0; + return -1; } actsize = bytesperclust; endclust = curclust; -- 2.23.0
I don't know what the intention of original author was here.
In general, a cluster's FAT entry points to a next cluster which composes part of a file and hence a chain of clusters. The last cluster's FAT is marked with EOC(End of Cluster), which has a dedicated value, for fat16, one of 0xfff8:0xffff.
As you can see, those values are also detected by CHECK_CLUST() macro. I'm afraid that, at least initially, this macro might have worked for detecting a file end correctly (so returned 0?).
Another issue is that CHECK_CLUST() checks against >0xfff0 for fat16 while 0xfff0:0xfff6 are still valid for cluster numbers. So it will potentially detect a wrong "invalid" FAT entry for a quite large file.
Thanks, -Takahiro Akashi
- get_contents() - read from file
- Read at most 'maxsize' bytes from 'pos' in the file associated with 'dentptr'
- into 'buffer'.
- Update the number of bytes read in *gotsize or return -1 on fatal errors.
- into 'buffer'. Update the number of bytes read in *gotsize or return -1 on
- fatal errors.
- @mydata: file system description
- @dentprt: directory entry pointer
- @pos: position from where to read
- @buffer: buffer into which to read
- @maxsize: maximum number of bytes to read
- @gotsize: number of bytes actually read
- Return: -1 on error, otherwise 0
} actsize += bytesperclust; }return -1;
} }return -1;
} actsize = bytesperclust; endclust = curclust;return -1;
-- 2.23.0
If out of memory, return -1 and not -ENOMEM from get_contents().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- fs/fat/fat.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index b4e8083734..da822f4f38 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -364,7 +364,7 @@ static int get_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, tmp_buffer = malloc_cache_aligned(actsize); if (!tmp_buffer) { debug("Error: allocating buffer\n"); - return -ENOMEM; + return -1; }
if (get_cluster(mydata, curclust, tmp_buffer, actsize) != 0) { -- 2.23.0
AKASHI Takahiro
