[PATCH 1/2] arm: dts: k3-am64: Sync with kernel v6.7-rc1
Sync with kernel v6.7-rc1 and sync up the u-boot dts files accordingly.
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am64-main.dtsi | 37 ++++++--- arch/arm/dts/k3-am64-mcu.dtsi | 2 + arch/arm/dts/k3-am64.dtsi | 2 + arch/arm/dts/k3-am642-evm-u-boot.dtsi | 110 -------------------------- arch/arm/dts/k3-am642-evm.dts | 37 +++++++++ arch/arm/dts/k3-am642-r5-evm.dts | 24 ------ arch/arm/dts/k3-am642-r5-sk.dts | 12 --- arch/arm/dts/k3-am642-sk-u-boot.dtsi | 98 ----------------------- arch/arm/dts/k3-am642-sk.dts | 29 +++++++ 9 files changed, 94 insertions(+), 257 deletions(-)
diff --git a/arch/arm/dts/k3-am64-main.dtsi b/arch/arm/dts/k3-am64-main.dtsi index 0df54a74182..0be642bc1b8 100644 --- a/arch/arm/dts/k3-am64-main.dtsi +++ b/arch/arm/dts/k3-am64-main.dtsi @@ -38,6 +38,7 @@ };
main_conf: syscon@43000000 { + bootph-all; compatible = "ti,j721e-system-controller", "syscon", "simple-mfd"; reg = <0x0 0x43000000 0x0 0x20000>; #address-cells = <1>; @@ -45,6 +46,7 @@ ranges = <0x0 0x0 0x43000000 0x20000>;
chipid@14 { + bootph-all; compatible = "ti,am654-chipid"; reg = <0x00000014 0x4>; }; @@ -96,7 +98,8 @@ };
dmss: bus@48000000 { - compatible = "simple-mfd"; + bootph-all; + compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; dma-ranges; @@ -105,6 +108,7 @@ ti,sci-dev-id = <25>;
secure_proxy_main: mailbox@4d000000 { + bootph-all; compatible = "ti,am654-secure-proxy"; #mbox-cells = <1>; reg-names = "target_data", "rt", "scfg"; @@ -188,6 +192,7 @@ };
dmsc: system-controller@44043000 { + bootph-all; compatible = "ti,k2g-sci"; ti,host-id = <12>; mbox-names = "rx", "tx"; @@ -197,22 +202,26 @@ reg = <0x00 0x44043000 0x00 0xfe0>;
k3_pds: power-controller { + bootph-all; compatible = "ti,sci-pm-domain"; #power-domain-cells = <2>; };
k3_clks: clock-controller { + bootph-all; compatible = "ti,k2g-sci-clk"; #clock-cells = <2>; };
k3_reset: reset-controller { + bootph-all; compatible = "ti,sci-reset"; #reset-cells = <2>; }; };
main_pmx0: pinctrl@f4000 { + bootph-all; compatible = "pinctrl-single"; reg = <0x00 0xf4000 0x00 0x2d0>; #pinctrl-cells = <1>; @@ -221,6 +230,7 @@ };
main_timer0: timer@2400000 { + bootph-all; compatible = "ti,am654-timer"; reg = <0x00 0x2400000 0x00 0x400>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; @@ -365,6 +375,7 @@ };
main_esm: esm@420000 { + bootph-pre-ram; compatible = "ti,j721e-esm"; reg = <0x00 0x420000 0x00 0x1000>; ti,esm-pins = <160>, <161>; @@ -1158,21 +1169,21 @@ };
main_rti0: watchdog@e000000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0xe000000 0x00 0x100>; - clocks = <&k3_clks 125 0>; - power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 125 0>; - assigned-clock-parents = <&k3_clks 125 2>; + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0xe000000 0x00 0x100>; + clocks = <&k3_clks 125 0>; + power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 125 0>; + assigned-clock-parents = <&k3_clks 125 2>; };
main_rti1: watchdog@e010000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0xe010000 0x00 0x100>; - clocks = <&k3_clks 126 0>; - power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 126 0>; - assigned-clock-parents = <&k3_clks 126 2>; + compatible = "ti,j7-rti-wdt"; + reg = <0x00 0xe010000 0x00 0x100>; + clocks = <&k3_clks 126 0>; + power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 126 0>; + assigned-clock-parents = <&k3_clks 126 2>; };
icssg0: icssg@30000000 { diff --git a/arch/arm/dts/k3-am64-mcu.dtsi b/arch/arm/dts/k3-am64-mcu.dtsi index 686d4979072..b9508072beb 100644 --- a/arch/arm/dts/k3-am64-mcu.dtsi +++ b/arch/arm/dts/k3-am64-mcu.dtsi @@ -146,6 +146,7 @@ };
mcu_pmx0: pinctrl@4084000 { + bootph-all; compatible = "pinctrl-single"; reg = <0x00 0x4084000 0x00 0x84>; #pinctrl-cells = <1>; @@ -154,6 +155,7 @@ };
mcu_esm: esm@4100000 { + bootph-pre-ram; compatible = "ti,j721e-esm"; reg = <0x00 0x4100000 0x00 0x1000>; ti,esm-pins = <0>, <1>; diff --git a/arch/arm/dts/k3-am64.dtsi b/arch/arm/dts/k3-am64.dtsi index 8e9c2bc70f4..0187c42aed4 100644 --- a/arch/arm/dts/k3-am64.dtsi +++ b/arch/arm/dts/k3-am64.dtsi @@ -47,6 +47,7 @@ };
cbass_main: bus@f4000 { + bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; @@ -85,6 +86,7 @@ <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>;
cbass_mcu: bus@4000000 { + bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index b8430782436..a052941e235 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -9,97 +9,27 @@ chosen { tick-timer = &main_timer0; }; - - memory@80000000 { - bootph-all; - }; -}; - -&cbass_main { - bootph-all; };
&main_timer0 { - bootph-all; clock-frequency = <200000000>; };
-&main_conf { - bootph-all; - chipid@14 { - bootph-all; - }; -}; - -&main_pmx0 { - bootph-all; -}; - -&main_i2c0_pins_default { - bootph-all; -}; - -&main_i2c0 { - bootph-all; -}; - -&main_uart0_pins_default { - bootph-all; -}; - -&main_uart0 { - bootph-all; -}; - -&main_usb0_pins_default { - bootph-all; -}; - &usb0 { dr_mode="peripheral"; - bootph-all; -}; - -&usbss0 { - bootph-all; };
&main_mmc1_pins_default { bootph-all; };
-&main_usb0_pins_default { - bootph-all; -}; - -&dmss { - bootph-all; -}; - -&secure_proxy_main { - bootph-all; -}; - &dmsc { - bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; bootph-all; }; };
-&k3_pds { - bootph-all; -}; - -&k3_clks { - bootph-all; -}; - -&k3_reset { - bootph-all; -}; - &sdhci0 { bootph-all; }; @@ -108,10 +38,6 @@ bootph-all; };
-&sdhci1 { - bootph-all; -}; - &inta_main_dmss { bootph-all; }; @@ -143,42 +69,6 @@ bootph-all; };
-&mdio1_pins_default { - bootph-all; -}; - -&cpsw3g_mdio { - bootph-all; -}; - -&cpsw3g_phy0 { - bootph-all; -}; - -&rgmii1_pins_default { - bootph-all; -}; - -&rgmii2_pins_default { - bootph-all; -}; - -&cpsw3g { - bootph-all; - - ethernet-ports { - bootph-all; - }; -}; - -&phy_gmii_sel { - bootph-all; -}; - -&cpsw_port1 { - bootph-all; -}; - &cpsw_port2 { status = "disabled"; }; diff --git a/arch/arm/dts/k3-am642-evm.dts b/arch/arm/dts/k3-am642-evm.dts index b4a1f73d4fb..4dba1894101 100644 --- a/arch/arm/dts/k3-am642-evm.dts +++ b/arch/arm/dts/k3-am642-evm.dts @@ -35,6 +35,7 @@ };
memory@80000000 { + bootph-all; device_type = "memory"; /* 2G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>; @@ -108,6 +109,7 @@
evm_12v0: regulator-0 { /* main DC jack */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "evm_12v0"; regulator-min-microvolt = <12000000>; @@ -129,6 +131,7 @@
vsys_3v3: regulator-2 { /* output of LM5140 */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vsys_3v3"; regulator-min-microvolt = <3300000>; @@ -140,6 +143,7 @@
vdd_mmc1: regulator-3 { /* TPS2051BD */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vdd_mmc1"; regulator-min-microvolt = <3300000>; @@ -161,6 +165,7 @@ };
vtt_supply: regulator-5 { + bootph-all; compatible = "regulator-fixed"; regulator-name = "vtt"; pinctrl-names = "default"; @@ -251,6 +256,7 @@ };
main_uart0_pins_default: main-uart0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0238, PIN_INPUT, 0) /* (B16) UART0_CTSn */ AM64X_IOPAD(0x023c, PIN_OUTPUT, 0) /* (A16) UART0_RTSn */ @@ -269,6 +275,7 @@ };
main_i2c0_pins_default: main-i2c0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0260, PIN_INPUT_PULLUP, 0) /* (A18) I2C0_SCL */ AM64X_IOPAD(0x0264, PIN_INPUT_PULLUP, 0) /* (B18) I2C0_SDA */ @@ -276,6 +283,7 @@ };
main_i2c1_pins_default: main-i2c1-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0268, PIN_INPUT_PULLUP, 0) /* (C18) I2C1_SCL */ AM64X_IOPAD(0x026c, PIN_INPUT_PULLUP, 0) /* (B19) I2C1_SDA */ @@ -283,6 +291,7 @@ };
mdio1_pins_default: mdio1-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x01fc, PIN_OUTPUT, 4) /* (R2) PRG0_PRU1_GPO19.MDIO0_MDC */ AM64X_IOPAD(0x01f8, PIN_INPUT, 4) /* (P5) PRG0_PRU1_GPO18.MDIO0_MDIO */ @@ -290,6 +299,7 @@ };
rgmii1_pins_default: rgmii1-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x01cc, PIN_INPUT, 4) /* (W5) PRG0_PRU1_GPO7.RGMII1_RD0 */ AM64X_IOPAD(0x01d4, PIN_INPUT, 4) /* (Y5) PRG0_PRU1_GPO9.RGMII1_RD1 */ @@ -307,6 +317,7 @@ };
rgmii2_pins_default: rgmii2-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0108, PIN_INPUT, 4) /* (W11) PRG1_PRU1_GPO0.RGMII2_RD0 */ AM64X_IOPAD(0x010c, PIN_INPUT, 4) /* (V11) PRG1_PRU1_GPO1.RGMII2_RD1 */ @@ -324,6 +335,7 @@ };
main_usb0_pins_default: main-usb0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (E19) USB0_DRVVBUS */ >; @@ -366,6 +378,7 @@ };
ddr_vtt_pins_default: ddr-vtt-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0030, PIN_OUTPUT_PULLUP, 7) /* (L18) OSPI0_CSN1.GPIO0_12 */ >; @@ -373,6 +386,7 @@ };
&main_uart0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; @@ -387,11 +401,21 @@ };
&main_i2c0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>;
+ gpio@38 { + /* TCA9554 */ + compatible = "nxp,pca9554"; + reg = <0x38>; + gpio-controller; + #gpio-cells = <2>; + gpio-line-names = "HSE_DETECT"; + }; + eeprom@50 { /* AT24CM01 */ compatible = "atmel,24c1024"; @@ -400,12 +424,14 @@ };
&main_i2c1 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>;
exp1: gpio@22 { + bootph-all; compatible = "ti,tca6424"; reg = <0x22>; gpio-controller; @@ -438,6 +464,10 @@ }; };
+&main_gpio0 { + bootph-all; +}; + /* mcu_gpio0 is reserved for mcu firmware usage */ &mcu_gpio0 { status = "reserved"; @@ -467,6 +497,7 @@
&sdhci1 { /* SD/MMC */ + bootph-all; vmmc-supply = <&vdd_mmc1>; pinctrl-names = "default"; bus-width = <4>; @@ -476,11 +507,13 @@ };
&usbss0 { + bootph-all; ti,vbus-divider; ti,usb2-only; };
&usb0 { + bootph-all; dr_mode = "otg"; maximum-speed = "high-speed"; pinctrl-names = "default"; @@ -488,11 +521,13 @@ };
&cpsw3g { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&rgmii1_pins_default>, <&rgmii2_pins_default>; };
&cpsw_port1 { + bootph-all; phy-mode = "rgmii-rxid"; phy-handle = <&cpsw3g_phy0>; }; @@ -503,11 +538,13 @@ };
&cpsw3g_mdio { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mdio1_pins_default>;
cpsw3g_phy0: ethernet-phy@0 { + bootph-all; reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index 64b3c3af630..19fc1766b57 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -40,10 +40,6 @@ }; };
-&vtt_supply { - bootph-pre-ram; -}; - &cbass_main { sysctrler: sysctrler { compatible = "ti,am654-system-controller"; @@ -53,18 +49,6 @@ }; };
-&main_esm { - bootph-pre-ram; -}; - -&cbass_mcu { - bootph-pre-ram; -}; - -&mcu_esm { - bootph-pre-ram; -}; - &dmsc { mboxes= <&secure_proxy_main 0>, <&secure_proxy_main 1>, @@ -74,10 +58,6 @@ ti,secure-host; };
-&vtt_supply { - bootph-pre-ram; -}; - &memorycontroller { vtt-supply = <&vtt_supply>; }; @@ -92,10 +72,6 @@ clock-names = "clk_xin"; };
-&main_gpio0 { - bootph-pre-ram; -}; - /* UART is initialized before SYSFW is started * so we can't do any power-domain/clock operations. * Delete clock/power-domain properties to avoid diff --git a/arch/arm/dts/k3-am642-r5-sk.dts b/arch/arm/dts/k3-am642-r5-sk.dts index daa483a7811..6032a6f8fef 100644 --- a/arch/arm/dts/k3-am642-r5-sk.dts +++ b/arch/arm/dts/k3-am642-r5-sk.dts @@ -49,18 +49,6 @@ }; };
-&main_esm { - bootph-pre-ram; -}; - -&cbass_mcu { - bootph-pre-ram; -}; - -&mcu_esm { - bootph-pre-ram; -}; - &dmsc { mboxes= <&secure_proxy_main 0>, <&secure_proxy_main 1>, diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index 2eb227c1d00..818867df8d9 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -9,87 +9,21 @@ chosen { tick-timer = &main_timer0; }; - - memory@80000000 { - bootph-all; - }; -}; - -&cbass_main{ - bootph-all; };
-&main_conf { - bootph-all; - chipid@14 { - bootph-all; - }; -}; - -&main_pmx0 { - bootph-all; -}; - -&main_i2c0_pins_default { - bootph-all; -}; - -&main_i2c0 { - bootph-all; -}; - -&main_uart0_pins_default { - bootph-all; -}; - -&main_uart0 { - bootph-all; -}; - -&dmss { - bootph-all; -}; - -&secure_proxy_main { - bootph-all; -}; - &dmsc { - bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; bootph-all; }; };
-&k3_pds { - bootph-all; -}; - -&k3_clks { - bootph-all; -}; - -&k3_reset { - bootph-all; -}; - &sdhci0 { status = "disabled"; - bootph-all; -}; - -&sdhci1 { - bootph-all; -}; - -&main_mmc1_pins_default { - bootph-all; };
&inta_main_dmss { @@ -179,35 +113,3 @@ &cpsw3g_phy1 { bootph-all; }; - -&main_usb0_pins_default { - bootph-all; -}; - -&serdes_ln_ctrl { - u-boot,mux-autoprobe; -}; - -&usbss0 { - bootph-all; -}; - -&usb0 { - bootph-all; -}; - -&serdes_wiz0 { - bootph-all; -}; - -&serdes0_usb_link { - bootph-all; -}; - -&serdes0 { - bootph-all; -}; - -&serdes_refclk { - bootph-all; -}; diff --git a/arch/arm/dts/k3-am642-sk.dts b/arch/arm/dts/k3-am642-sk.dts index 722fd285a34..f29c8a9b59b 100644 --- a/arch/arm/dts/k3-am642-sk.dts +++ b/arch/arm/dts/k3-am642-sk.dts @@ -34,6 +34,7 @@ };
memory@80000000 { + bootph-pre-ram; device_type = "memory"; /* 2G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>; @@ -107,6 +108,7 @@
vusb_main: regulator-0 { /* USB MAIN INPUT 5V DC */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vusb_main5v0"; regulator-min-microvolt = <5000000>; @@ -117,6 +119,7 @@
vcc_3v3_sys: regulator-1 { /* output of LP8733xx */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vcc_3v3_sys"; regulator-min-microvolt = <3300000>; @@ -128,6 +131,7 @@
vdd_mmc1: regulator-2 { /* TPS2051BD */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vdd_mmc1"; regulator-min-microvolt = <3300000>; @@ -234,6 +238,7 @@
&main_pmx0 { main_mmc1_pins_default: main-mmc1-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x029c, PIN_INPUT_PULLUP, 0) /* (C20) MMC1_SDWP */ AM64X_IOPAD(0x0298, PIN_INPUT_PULLUP, 0) /* (D19) MMC1_SDCD */ @@ -248,6 +253,7 @@ };
main_uart0_pins_default: main-uart0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0238, PIN_INPUT, 0) /* (B16) UART0_CTSn */ AM64X_IOPAD(0x023c, PIN_OUTPUT, 0) /* (A16) UART0_RTSn */ @@ -257,6 +263,7 @@ };
main_uart1_pins_default: main-uart1-default-pins { + bootph-pre-ram; pinctrl-single,pins = < AM64X_IOPAD(0x0248, PIN_INPUT, 0) /* (D16) UART1_CTSn */ AM64X_IOPAD(0x024c, PIN_OUTPUT, 0) /* (E16) UART1_RTSn */ @@ -266,12 +273,14 @@ };
main_usb0_pins_default: main-usb0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (E19) USB0_DRVVBUS */ >; };
main_i2c0_pins_default: main-i2c0-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0260, PIN_INPUT_PULLUP, 0) /* (A18) I2C0_SCL */ AM64X_IOPAD(0x0264, PIN_INPUT_PULLUP, 0) /* (B18) I2C0_SDA */ @@ -279,6 +288,7 @@ };
main_i2c1_pins_default: main-i2c1-default-pins { + bootph-all; pinctrl-single,pins = < AM64X_IOPAD(0x0268, PIN_INPUT_PULLUP, 0) /* (C18) I2C1_SCL */ AM64X_IOPAD(0x026c, PIN_INPUT_PULLUP, 0) /* (B19) I2C1_SDA */ @@ -367,6 +377,7 @@ };
&main_uart0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; @@ -375,12 +386,14 @@
&main_uart1 { /* main_uart1 is reserved for firmware usage */ + bootph-pre-ram; status = "reserved"; pinctrl-names = "default"; pinctrl-0 = <&main_uart1_pins_default>; };
&main_i2c0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; @@ -393,12 +406,14 @@ };
exp1: gpio@70 { + bootph-all; compatible = "nxp,pca9538"; reg = <0x70>; gpio-controller; @@ -445,6 +460,7 @@
&sdhci1 { /* SD/MMC */ + bootph-all; vmmc-supply = <&vdd_mmc1>; pinctrl-names = "default"; bus-width = <4>; @@ -454,11 +470,22 @@ };
&serdes_ln_ctrl { + bootph-all; idle-states = <AM64_SERDES0_LANE0_USB>; };
+&serdes_refclk { + bootph-all; +}; + +&serdes_wiz0 { + bootph-all; +}; + &serdes0 { + bootph-all; serdes0_usb_link: phy@0 { + bootph-all; reg = <0>; cdns,num-lanes = <1>; #phy-cells = <0>; @@ -468,10 +495,12 @@ };
&usbss0 { + bootph-all; ti,vbus-divider; };
&usb0 { + bootph-all; dr_mode = "host"; maximum-speed = "super-speed"; pinctrl-names = "default";
Sync with kernel v6.8-rc1 and sync up the u-boot dts files accordingly.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am64-main.dtsi | 22 +++++++++++++++++----- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 21 +-------------------- arch/arm/dts/k3-am642-evm.dts | 12 +++++++++--- arch/arm/dts/k3-am642-sk-u-boot.dtsi | 20 -------------------- arch/arm/dts/k3-am642-sk.dts | 10 ++++++++-- 5 files changed, 35 insertions(+), 50 deletions(-)
diff --git a/arch/arm/dts/k3-am64-main.dtsi b/arch/arm/dts/k3-am64-main.dtsi index 0be642bc1b8..e348114f42e 100644 --- a/arch/arm/dts/k3-am64-main.dtsi +++ b/arch/arm/dts/k3-am64-main.dtsi @@ -63,7 +63,7 @@ #phy-cells = <1>; };
- epwm_tbclk: clock-controller@4140 { + epwm_tbclk: clock-controller@4130 { compatible = "ti,am64-epwm-tbclk"; reg = <0x4130 0x4>; #clock-cells = <1>; @@ -138,8 +138,13 @@ <0x00 0x4c000000 0x00 0x20000>, <0x00 0x4a820000 0x00 0x20000>, <0x00 0x4aa40000 0x00 0x20000>, - <0x00 0x4bc00000 0x00 0x100000>; - reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt"; + <0x00 0x4bc00000 0x00 0x100000>, + <0x00 0x48600000 0x00 0x8000>, + <0x00 0x484a4000 0x00 0x2000>, + <0x00 0x484c2000 0x00 0x2000>, + <0x00 0x48420000 0x00 0x2000>; + reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt", + "ring", "tchan", "rchan", "bchan"; msi-parent = <&inta_main_dmss>; #dma-cells = <3>;
@@ -155,8 +160,13 @@ reg = <0x00 0x485c0000 0x00 0x100>, <0x00 0x4a800000 0x00 0x20000>, <0x00 0x4aa00000 0x00 0x40000>, - <0x00 0x4b800000 0x00 0x400000>; - reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt"; + <0x00 0x4b800000 0x00 0x400000>, + <0x00 0x485e0000 0x00 0x20000>, + <0x00 0x484a0000 0x00 0x4000>, + <0x00 0x484c0000 0x00 0x2000>, + <0x00 0x48430000 0x00 0x4000>; + reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt", + "ring", "tchan", "rchan", "rflow"; msi-parent = <&inta_main_dmss>; #dma-cells = <2>;
@@ -623,6 +633,7 @@ ti,otap-del-sel-mmc-hs = <0x0>; ti,otap-del-sel-ddr52 = <0x6>; ti,otap-del-sel-hs200 = <0x7>; + status = "disabled"; };
sdhci1: mmc@fa00000 { @@ -641,6 +652,7 @@ ti,otap-del-sel-sdr104 = <0x6>; ti,otap-del-sel-ddr50 = <0x9>; ti,clkbuf-sel = <0x7>; + status = "disabled"; };
cpsw3g: ethernet@8000000 { diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index a052941e235..c98adc65e89 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -43,29 +43,10 @@ };
&main_bcdma { - reg = <0x00 0x485c0100 0x00 0x100>, - <0x00 0x4c000000 0x00 0x20000>, - <0x00 0x4a820000 0x00 0x20000>, - <0x00 0x4aa40000 0x00 0x20000>, - <0x00 0x4bc00000 0x00 0x100000>, - <0x00 0x48600000 0x00 0x8000>, - <0x00 0x484a4000 0x00 0x2000>, - <0x00 0x484c2000 0x00 0x2000>; - reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt", - "cfg", "tchan", "rchan"; + bootph-all; };
&main_pktdma { - reg = <0x00 0x485c0000 0x00 0x100>, - <0x00 0x4a800000 0x00 0x20000>, - <0x00 0x4aa00000 0x00 0x40000>, - <0x00 0x4b800000 0x00 0x400000>, - <0x00 0x485e0000 0x00 0x20000>, - <0x00 0x484a0000 0x00 0x4000>, - <0x00 0x484c0000 0x00 0x2000>, - <0x00 0x48430000 0x00 0x4000>; - reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt", "cfg", - "tchan", "rchan", "rflow"; bootph-all; };
diff --git a/arch/arm/dts/k3-am642-evm.dts b/arch/arm/dts/k3-am642-evm.dts index 4dba1894101..8c5651d2cf5 100644 --- a/arch/arm/dts/k3-am642-evm.dts +++ b/arch/arm/dts/k3-am642-evm.dts @@ -468,11 +468,15 @@ bootph-all; };
-/* mcu_gpio0 is reserved for mcu firmware usage */ +/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */ &mcu_gpio0 { status = "reserved"; };
+&mcu_gpio_intr { + status = "reserved"; +}; + &main_spi0 { status = "okay"; pinctrl-names = "default"; @@ -487,17 +491,19 @@ }; };
+/* eMMC */ &sdhci0 { - /* emmc */ + status = "okay"; bus-width = <8>; non-removable; ti,driver-strength-ohm = <50>; disable-wp; };
+/* SD/MMC */ &sdhci1 { - /* SD/MMC */ bootph-all; + status = "okay"; vmmc-supply = <&vdd_mmc1>; pinctrl-names = "default"; bus-width = <4>; diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index 818867df8d9..b71f2fb067c 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -71,30 +71,10 @@ };
&main_bcdma { - reg = <0x00 0x485c0100 0x00 0x100>, - <0x00 0x4c000000 0x00 0x20000>, - <0x00 0x4a820000 0x00 0x20000>, - <0x00 0x4aa40000 0x00 0x20000>, - <0x00 0x4bc00000 0x00 0x100000>, - <0x00 0x48600000 0x00 0x8000>, - <0x00 0x484a4000 0x00 0x2000>, - <0x00 0x484c2000 0x00 0x2000>; - reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt", - "cfg", "tchan", "rchan"; bootph-all; };
diff --git a/arch/arm/dts/k3-am642-sk.dts b/arch/arm/dts/k3-am642-sk.dts index f29c8a9b59b..1dddd6fc1a0 100644 --- a/arch/arm/dts/k3-am642-sk.dts +++ b/arch/arm/dts/k3-am642-sk.dts @@ -433,12 +433,17 @@ }; };
+&mcu_gpio_intr { + status = "reserved"; +}; + &sdhci0 { + status = "okay"; vmmc-supply = <&wlan_en>; bus-width = <4>; non-removable; @@ -458,9 +463,10 @@ }; };
Reviewed-by: Nishanth Menon nm@ti.com
I'm deferring this series in favor of having these platforms moved to OF_UPSTREAM in -next, thanks.
Andrew Davis
Nishanth Menon
