Hi Tom,
https://source.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/21789 https://dev.azure.com/simon0972/u-boot/_build/results?buildId=66&view=re...
The following changes since commit 9366640449ac3ef702b624e2f6f7604754a9082b:
Merge tag 'dm-pull-26jul24' of https://gitlab.denx.de/u-boot/custodians/u-boot-dm (2024-07-26 10:35:44 -0600)
git://git.denx.de/u-boot-dm.git tags/dm-pull-29jul24
for you to fetch changes up to 20e5399a311eb3aca5cebfd3e494047ed1ceacb8:
Makefile: Pass OF_SPL_REMOVE_PROPS to binman (2024-07-29 08:42:18 -0600)
---------------------------------------------------------------- qconfig minor improvement binman support for alternate entries
---------------------------------------------------------------- Simon Glass (23): qconfig: Allow searching for CONFIG values qconfig: Sort the boards by name when finding qconfig: Support a 'list' format fixdep: Support VPL binman: Correct an error in the FIT-template example binman: Tidy up bintool docs binman: Tidy up comment for Bintoolfdt_add_pubkey.run() binman: Move problem-checking code into a function binman: elf: Add more debugging to LookupAndWriteSymbols() binman: Write the compressed output to a file binman: Correct comment in blob_dtb GetFdtEtype() binman: Mention expanded entries in u-boot-vpl binman: Fix a comment typo in _DoReadFileDtb() binman: Correct indentation in testSplPubkeyDtb binman: Add a bintool for fdtgrep binman: Remove dependency on pylibfdt for entry-docs binman: Allow entry types to override FDT contents binman: Add support for alternative FDTs binman: fit: Allow providing FDT filenames in a directory binman: fit: Write the compatible string to configuration binman: fit: Allow running fdtgrep on devicetree blobs Makefile: Provide VPL devicetree and padding to binman Makefile: Pass OF_SPL_REMOVE_PROPS to binman
Makefile | 3 + doc/develop/qconfig.rst | 14 ++++ doc/develop/spl.rst | 2 + scripts/basic/fixdep.c | 2 + tools/binman/binman.rst | 4 +- tools/binman/bintools.rst | 69 ++++++++++------ tools/binman/btool/fdt_add_pubkey.py | 4 + tools/binman/btool/fdtgrep.py | 137 +++++++++++++++++++++++++++++++ tools/binman/control.py | 77 +++++++++++------- tools/binman/elf.py | 2 +- tools/binman/entries.rst | 94 ++++++++++++++++++++-- tools/binman/entry.py | 17 ++++ tools/binman/etype/alternates_fdt.py | 132 ++++++++++++++++++++++++++++++ tools/binman/etype/blob_dtb.py | 8 +- tools/binman/etype/fit.py | 93 ++++++++++++++++++++- tools/binman/etype/u_boot_spl_nodtb.py | 2 - tools/binman/etype/u_boot_tpl_nodtb.py | 2 - tools/binman/etype/u_boot_vpl.py | 3 + tools/binman/etype/u_boot_vpl_nodtb.py | 4 +- tools/binman/ftest.py | 255 ++++++++++++++++++++++++++++++++++++++++++++++++++++------ tools/binman/image.py | 24 ++++++ tools/binman/main.py | 2 + tools/binman/test/328_alternates_fdt.dts | 28 +++++++ tools/binman/test/329_alternates_fdtgrep.dts | 29 +++++++ tools/binman/test/330_alternates_vpl.dts | 29 +++++++ tools/binman/test/331_alternates_spl.dts | 29 +++++++ tools/binman/test/332_alternates_inval.dts | 29 +++++++ tools/binman/test/333_fit_fdt_dir.dts | 58 +++++++++++++ tools/binman/test/334_fit_fdt_compat.dts | 60 ++++++++++++++ tools/binman/test/335_fit_fdt_phase.dts | 61 ++++++++++++++ tools/binman/test/alt_dts/model1.dts | 24 ++++++ tools/binman/test/alt_dts/model2.dts | 24 ++++++ tools/qconfig.py | 29 +++++-- 33 files changed, 1243 insertions(+), 107 deletions(-) create mode 100644 tools/binman/btool/fdtgrep.py create mode 100644 tools/binman/etype/alternates_fdt.py create mode 100644 tools/binman/test/328_alternates_fdt.dts create mode 100644 tools/binman/test/329_alternates_fdtgrep.dts create mode 100644 tools/binman/test/330_alternates_vpl.dts create mode 100644 tools/binman/test/331_alternates_spl.dts create mode 100644 tools/binman/test/332_alternates_inval.dts create mode 100644 tools/binman/test/333_fit_fdt_dir.dts create mode 100644 tools/binman/test/334_fit_fdt_compat.dts create mode 100644 tools/binman/test/335_fit_fdt_phase.dts create mode 100644 tools/binman/test/alt_dts/model1.dts
On Mon, Jul 29, 2024 at 10:19:00AM -0600, Simon Glass wrote:
Hi Tom,
