[U-Boot] [PATCH] trats: usb: Add usb_cable_connected() function
Changes: - define function usb_cable_connected() in trats board file which returns 1 if cable is connected and 0 otherwise - trats.h: add CONFIG_USB_CHECK_CABLE
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/trats/trats.c | 10 ++++++++++ include/configs/trats.h | 1 + 2 files changed, 11 insertions(+)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 7f61d17..9ed70d3 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -500,6 +500,16 @@ void board_usb_init(void) debug("USB_udc_probe\n"); s3c_udc_probe(&s5pc210_otg_data); } + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + struct pmic *muic = pmic_get("MAX8997_MUIC"); + int cable_connected = muic->chrg->chrg_type(muic); + + return !!cable_connected; +} +#endif #endif
static void pmic_reset(void) diff --git a/include/configs/trats.h b/include/configs/trats.h index 24ea06b..7f8009e 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -300,6 +300,7 @@ #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK
/* LCD */ #define CONFIG_EXYNOS_FB
Hello Minkyu,
On 11/13/2013 11:54 AM, Przemyslaw Marczak wrote:
Changes:
Could you review this patch, please? Thanks
Dear Przemyslaw Marczak,
On 13/11/13 19:54, Przemyslaw Marczak wrote:
Changes:
- struct pmic *muic = pmic_get("MAX8997_MUIC");
Please check that muic is available.
- int cable_connected = muic->chrg->chrg_type(muic);
- return !!cable_connected;
I think, cable_connected is unnecessary.
return !!muic->chrg->chrg_type(muic);
+} +#endif #endif
Thanks, Minkyu Kang.
Changes v2: - add muic avaibility check
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/trats/trats.c | 11 +++++++++++ include/configs/trats.h | 1 + 2 files changed, 12 insertions(+)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 7012c13..6bd106e 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -501,6 +501,17 @@ int board_usb_init(int index, enum usb_init_type init) debug("USB_udc_probe\n"); return s3c_udc_probe(&s5pc210_otg_data); } + +#ifdef CONFIG_USB_CABLE_CHECK +int usb_cable_connected(void) +{ + struct pmic *muic = pmic_get("MAX8997_MUIC"); + if (!muic) + return 0; + + return !!muic->chrg->chrg_type(muic); +} +#endif #endif
static void pmic_reset(void) diff --git a/include/configs/trats.h b/include/configs/trats.h index 3d080c4..8ff9800 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -308,6 +308,7 @@ #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_USB_CABLE_CHECK
On 02/12/13 21:54, Przemyslaw Marczak wrote:
Changes:
Changes v2:
Change log should be under --- line. This is not a commit message.
Anyway... applied to u-boot-samsung.
Hello,
Changes:
Changes v2:
Sorry for this issue and thank you for patch apply. Could you also check my patch to s5p gpio?
Regards
Minkyu Kang
Przemyslaw Marczak
